Résolu le 17-07-19 Probleme avec hplip 3.19.3 erreur key
paolo_3
Message par paolo_3 »
Alors on dirais s'installe .mais fais erreur au moment de téléchargement key.
on dirais pas autorisation de télécharger la clé
c est une hp 1212nfi
voila merci pour votre aide.
Checking for network connection...
Downloading plug-in from:
Downloading plug-in: [\                                   ] 0% Receiving digital keys: /usr/bin/gpg --homedir /home/giova/.hplip/.gnupg --no-permission-warning --keyserver pgp.mit.edu --recv-keys 0x4ABA2F66DBD5A95894910E0673D770CDA59047B9
error: Unable to recieve key from keyserver
Do you still want to install the plug-in? (y=yes, n=no*, q=quit) ? q
Modifié en dernier par paolo_3 le mer. 1 mai 2019 14:40, modifié 3 fois.
System:
Host: toshiba-SATELLITE-P870 Kernel: 4.15.0-45-generic x86_64 bits: 64
Desktop: Cinnamon 4.0.9 Distro: Linux Mint 19.1 Tessa
Quad core Intel Core i7-3630QM ,8 coeurs
Re: Probleme avec hplib 3.19.3 erreur key
Bien le BONJOUR :l
paolo_3
bonjour essayer ..mais veux toujours la clé ....
merci
HP Linux Imaging and Printing System (ver. 3.19.3)
Plugin Download and Install Utility ver. 2.1
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Downloading plug-in from: file:///home/giova/Téléchargements/hplip-3.19.3-plugin.run
1100%Receiving digital keys: /usr/bin/gpg --homedir /home/giova/.hplip/.gnupg --no-permission-warning --keyserver pgp.mit.edu --recv-keys 0x4ABA2F66DBD5A95894910E0673D770CDA59047B9
Creating directory plugin_tmp
Verifying archive integrity... All good.
Uncompressing HPLIP 3.19.3 Plugin Self Extracting Archive..............................................................
Plugin Installer ver. 3.0
Plug-in version: 3.19.3
Installed HPLIP version: 3.19.3
Number of files to install: 64
Plugin installation failed
error: Python gobject/dbus may be not installed
error: Plug-in install failed.
Done.
System:
paolo_3
salut
j'avais essayer la hplip 17 ...est me fessai une erreur ,je sais plus laquelle..
je suis sur linuxmint 19.1...
En fait installe en dirais c'est au moment d un plugin ...qu il 'arrive pas a avoir la clé.
System:
Re: Probleme avec hplip 3.19.3 erreur key
tu as installer hplip 3.19.... depuis un ppa ?
paolo_3
bonjour
allez sur le site....
https://developers.hp.com/hp-linux-imaging-and-printing/gethplip
mais je crois a un bug...
selon le site
https://bugs.launchpad.net/hplip/+bug/1813768
mais pas encore eu le temps d'essayer..
System:
Hplip est dans les depots, il faudrait l'installer depuis le gestionnaire de logiciel ;)
Tu as déjà essayé cette solution ?
paolo_3
salut
alors pas trouver hplip...
donc télécharger le hplip 3.17.11.run
est ca a fonctionner...
voila discussion close
ps: juste préciser aussi erreur non permissions key,mais a télécharger quand même...
System:
Merci pour le retour 8-)
Si le sujet est résolu, merci de mettre un attribut de sujet (résolu), voir tuto ici
