Pour configurer Conky, créez le fichier .conkyrc dans votre dossier personnel
Pour faire court : Tu créés un fichier dans ton /home/megamatman , tu le nomme :
.conkyrc oublies pas le point devant , et tu copie colle ce qui se trouve ci dessous dedans , tu enregistres .
background no
font Sans:size=8
#xftfont Sans:size=10
use_xft yes
xftalpha 0.9
update_interval 3.0
total_run_times 0
own_window yes
own_window_type normal
own_window_transparent yes
own_window_hints undecorated,under,sticky,skip_taskbar,skip_pager
double_buffer yes
minimum_size 220 5
maximum_width 220
draw_shades yes
draw_outline no
draw_borders no
draw_graph_borders yes
default_color white
default_shade_color black
default_outline_color green
alignment middle_right
gap_x 12
gap_y 35
no_buffers yes
uppercase no
cpu_avg_samples 2
override_utf8_locale no
uppercase no # set to yes if you want all text to be in uppercase
TEXT
${color white}SYSTEM ${hr 1}${color}
Hostname: $alignr$nodename
Kernel: $alignr$kernel
Temp: ${alignr}${hwmon 0 temp 1}C
CPU: ${alignr}${freq} MHz
Processes: ${alignr}$processes ($running_processes running)
Load: ${alignr}$loadavg
CPU1 ${alignr}${cpu cpu1}%
${cpubar cpu1 4}
CPU2 ${alignr}${cpu cpu2}%
${cpubar cpu2 4}
Ram ${alignr}$mem / $memmax ($memperc%)
${membar 4}
Swap ${alignr}$swap / $swapmax ($swapperc%)
${swapbar 4}
Highest CPU $alignr CPU% MEM%
${top name 1}$alignr${top cpu 1}${top mem 1}
${top name 2}$alignr${top cpu 2}${top mem 2}
Highest MEM $alignr CPU% MEM%
${top_mem name 1}$alignr${top_mem cpu 1}${top_mem mem 1}
${top_mem name 2}$alignr${top_mem cpu 2}${top_mem mem 2}
${color white}FILE SYSTEM ${hr 1}${color}
Root: ${alignr}${fs_free /} / ${fs_size /}
${fs_bar 4 /}
Windows: ${alignr}${fs_free /home} / ${fs_size /home}
${fs_bar 4 /home}
${color white}NETWORK ${hr 1}${color}
Down ${downspeed eth0} k/s ${alignr}Down ${downspeed eth1} k/s
Up ${upspeed eth0} k/s ${alignr}Up ${upspeed eth1} k/s
Ensuite pour le lancer : alt + f2 puis entre conky puis valide
Pour un démarrage automatique , je te renvois sur la page "tuto" chap 3.3 :
https://doc.ubuntu-fr.org/conky
