Résolu le 14-10-19 Logiciels de téléchargement de video avec Firefox
Linuxing
Message par Linuxing »
Je dispose de Video DownloadHelper et de Video Downloader Pro, mais aucun des deux ne reconnaît la vidéo suivante :
[suppression de lien par la modération]
Et j'ai essayé avec youtube-dl dans le Terminal, mais ça ne marche pas non plus :
linuxing@linuxing-Satellite-Pro-S300:~$ youtube-dl https://www.******************************.html
[generic] 45916-the-eye: Requesting header
WARNING: Falling back on generic information extractor.
[generic] 45916-the-eye: Downloading webpage
[generic] 45916-the-eye: Extracting information
[download] Downloading playlist: The Eye
[generic] playlist The Eye: Collected 1 video ids (downloading 1 of them)
[download] Downloading video 1 of 1
Traceback (most recent call last):
  File "/usr/bin/youtube-dl", line 6, in <module>
    youtube_dl.main()
  File "/usr/lib/python3/dist-packages/youtube_dl/__init__.py", line 476, in main
    _real_main(argv)
  File "/usr/lib/python3/dist-packages/youtube_dl/__init__.py", line 466, in _real_main
    retcode = ydl.download(all_urls)
  File "/usr/lib/python3/dist-packages/youtube_dl/YoutubeDL.py", line 1989, in download
    url, force_generic_extractor=self.params.get('force_generic_extractor', False))
  File "/usr/lib/python3/dist-packages/youtube_dl/YoutubeDL.py", line 796, in extract_info
    return self.process_ie_result(ie_result, download, extra_info)
  File "/usr/lib/python3/dist-packages/youtube_dl/YoutubeDL.py", line 995, in process_ie_result
    extra_info=extra)
  File "/usr/lib/python3/dist-packages/youtube_dl/YoutubeDL.py", line 850, in process_ie_result
    return self.process_video_result(ie_result, download=download)
  File "/usr/lib/python3/dist-packages/youtube_dl/YoutubeDL.py", line 1623, in process_video_result
    self.process_info(new_info)
  File "/usr/lib/python3/dist-packages/youtube_dl/YoutubeDL.py", line 1896, in process_info
    success = dl(filename, info_dict)
  File "/usr/lib/python3/dist-packages/youtube_dl/YoutubeDL.py", line 1835, in dl
    return fd.download(name, info)
  File "/usr/lib/python3/dist-packages/youtube_dl/downloader/common.py", line 364, in download
    return self.real_download(filename, info_dict)
  File "/usr/lib/python3/dist-packages/youtube_dl/downloader/http.py", line 340, in real_download
    establish_connection()
  File "/usr/lib/python3/dist-packages/youtube_dl/downloader/http.py", line 109, in establish_connection
    ctx.data = self.ydl.urlopen(request)
  File "/usr/lib/python3/dist-packages/youtube_dl/YoutubeDL.py", line 2199, in urlopen
    return self._opener.open(req, timeout=self._socket_timeout)
  File "/usr/lib/python3.6/urllib/request.py", line 526, in open
    response = self._open(req, data)
  File "/usr/lib/python3.6/urllib/request.py", line 544, in _open
    '_open', req)
  File "/usr/lib/python3.6/urllib/request.py", line 504, in _call_chain
    result = func(*args)
  File "/usr/lib/python3/dist-packages/youtube_dl/utils.py", line 1101, in https_open
    req, **kwargs)
  File "/usr/lib/python3.6/urllib/request.py", line 1318, in do_open
    encode_chunked=req.has_header('Transfer-encoding'))
  File "/usr/lib/python3.6/http/client.py", line 1254, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1300, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1249, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1036, in _send_output
    self.send(msg)
  File "/usr/lib/python3.6/http/client.py", line 974, in send
    self.connect()
  File "/usr/lib/python3.6/http/client.py", line 1415, in connect
    server_hostname=server_hostname)
  File "/usr/lib/python3.6/ssl.py", line 407, in wrap_socket
    _context=self, _session=session)
  File "/usr/lib/python3.6/ssl.py", line 817, in __init__
    self.do_handshake()
  File "/usr/lib/python3.6/ssl.py", line 1077, in do_handshake
    self._sslobj.do_handshake()
  File "/usr/lib/python3.6/ssl.py", line 694, in do_handshake
    match_hostname(self.getpeercert(), self.server_hostname)
  File "/usr/lib/python3.6/ssl.py", line 327, in match_hostname
    % (hostname, ', '.join(map(repr, dnsnames))))
ssl.CertificateError: hostname 's3.vid.web.acsta.net' doesn't match either of '*.jeuxvideo.com', 'jeuxvideo.com'
Si quelqu'un a un tuyau, merci ;)
Modifié en dernier par arghlub le mer. 9 oct. 2019 21:04, modifié 1 fois.
Raison : suppession des url de streaming
DEADMAN57
Re: Logiciels de téléchargement de video avec Firefox
Message par DEADMAN57 »
si c'est pour telecharger des videos de youtube tu peut utiliser clipgrab ou jdownloader. il y a aussi des scriptes mais je ne crois pas que tu sois pret a les utiliser
Linux Mint 20 Mate 64-bit : 3.6.6
Noyau Linux : 4.13.14-041314-gen Pentium CPU G3420 3.20GHz x 2
Disques durs : SURPRISE Go
Mémoire vive : 15.6 Go
Carte graphique : NVIDIA Corporation GP107 [GeForce GTX 1050 Ti]
Linuxing
DEADMAN57 a écrit :
jeu. 10 oct. 2019 08:50
Salut ;)
Je viens d'installer jdownloader, mais en cliquant sur l'icône dans le navigateur, les seules choses visibles sont celles-ci :
Pas de menu pour déclencher le téléchargement :|
Merci pour tout éclaircissement :)
As-tu essayé une extension comme https://addons.mozilla.org/fr/firefox/a ... and-flash/ ?
DEADMAN57
tu pourrai mettre une capture d écran moi je l utilise depuis des annee (d abord sur windobs apres sur linux) je n'est jamais eu ce message
et le l installe sur tous les pc qui tombe entre mes mains que se soit windobs ou linux (ubuntu, debian, linux mint, fedora, opensuse kali linux etc ...)
Linuxing a écrit :
jeu. 10 oct. 2019 17:42
Salut ;)
DEADMAN57
tu a installer l extension de jdownloader??? si tu parle de cela je ne lai jamais utiliser et veut pas l utiliser. moi j utilise seulement le programme. voici le lien ici ===> http://jdownloader.org/ disponible en windob linux mac java (portable et sans installation)
Linuxing
arghlub a écrit :
jeu. 10 oct. 2019 18:05
Je viens de l'installer, mais il ne repère pas le film en question :
J'ai fait un autre essai avec une vidéo sur Youtube ; ici il repère, mais lorsque je clique sur Dowload, j'ai ce charabia :
Bref, je ne suis pas sorti de l'auberge :lol:
Linuxing
DEADMAN57 a écrit :tu pourrai mettre une capture d écran moi je l utilise depuis des annee (d abord sur windobs apres sur linux) je n'est jamais eu ce message....
Je ne vois pas trop de quelle capture d'écran tu parles, mais les petits screenshots que j'ai mis plus haut apparaissent lorsque je mets le curseur sur l'iĉone de jdownloader qui se trouve dans le navigateur. Si je clique dessus, il me met «enabled» et si je clique une deuxième fois, il me met «disabled» et l'icône est alors grisé. ;)
DEADMAN57
cela veut juste dire que tu a installer l'extension et pas le logiciel. le lien pour le logiciel, je l'ai déjà mis. je n'utilise pas l'extension comme déjà dit plus tôt
Linuxing
DEADMAN57 a écrit :
jeu. 10 oct. 2019 20:25
J'ai téléchargé ceci :
J'ai double-cliqué dessus et un script s'est ouvert avec une barre de défilement qui semblait durer une éternité, j'ai cliqué sur Annuler :roll:
