Nouveau dans l'utilisation de Linux j'ai installé Mate pour en finir avec Windows. Je me débrouille comme je peut dans son installation, mais la je bute sur la fonction scanner .
J' ai installer mon imprimante multifonction Epson XP-255 et l’impression fonctionne correctement.
Pour la fonction scanner, en consultant le forum, j'ai installer Xsane qui semblais prendre en charge mon imprimante
Mais il ne trouve pas le scanner
J'ai donc , toujours en consultant le forrum, lancé
denis@denis-MS-7592:~$ sane-find-scanner
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a kernel SCSI driver for your SCSI adapter.
could not open USB device 0x04b8/0x113d at 001:005: Access denied (insufficient permissions)
could not open USB device 0x046d/0xc077 at 001:004: Access denied (insufficient permissions)
could not open USB device 0x2101/0x8501 at 001:003: Access denied (insufficient permissions)
could not open USB device 0x2101/0x8500 at 001:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 001:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 005:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 004:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 003:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 002:001: Access denied (insufficient permissions)
# No USB scanners found. If you expected something different, make sure that
# you have loaded a kernel driver for your USB host controller and have setup
# the USB system correctly. See man sane-usb for details.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
# You may want to run this program as root to find all devices. Once you
# found the scanner devices, be sure to adjust access permissions as
# necessary.
Là j’ai besoins d'aide je crois !
C'est mon premier post alors j’espère avoir été assez clair et avoir bien utiliser le service
