Merci pour les conseils d'installation, je pratique déjà, mais pensais qu'il fallait sans doute localiser quelque part !
Concernant les commandes, comme mon poste n'a pas de communication avec le monde extérieur, je ne peux pas en transmettre les résultats. Je vais faire un peu de copie...
[b]lspci[/b]
00:00.0 Host bridge: Intel Corporation Device 31f0 (rev 03)
00:00.1 Signal processing controller: Intel Corporation Device 318c (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Device 3184 (rev 03)
00:0e.0 Audio device: Intel Corporation Device 3198 (rev 03)
00:0f.0 Communication controller: Intel Corporation Device 319a (rev 03)
00:12.0 SATA controller: Intel Corporation Device 31e3 (rev 03)
00:13.0 PCI bridge: Intel Corporation Device 31d8 (rev f3)
00:13.1 PCI bridge: Intel Corporation Device 31d9 (rev f3)
00:13.2 PCI bridge: Intel Corporation Device 31da (rev f3)
00:14.0 PCI bridge: Intel Corporation Device 31d6 (rev f3)
00:14.1 PCI bridge: Intel Corporation Device 31d7 (rev f3)
00:15.0 USB controller: Intel Corporation Device 31a8 (rev 03)
00:16.0 Signal processing controller: Intel Corporation Device 31ac (rev 03)
00:16.1 Signal processing controller: Intel Corporation Device 31ae (rev 03)
00:16.2 Signal processing controller: Intel Corporation Device 31b0 (rev 03)
00:16.3 Signal processing controller: Intel Corporation Device 31b2 (rev 03)
00:17.0 Signal processing controller: Intel Corporation Device 31b4 (rev 03)
00:17.1 Signal processing controller: Intel Corporation Device 31b6 (rev 03)
00:17.2 Signal processing controller: Intel Corporation Device 31b8 (rev 03)
00:17.3 Signal processing controller: Intel Corporation Device 31ba (rev 03)
00:18.0 Signal processing controller: Intel Corporation Device 31bc (rev 03)
00:18.1 Signal processing controller: Intel Corporation Device 31be (rev 03)
00:18.2 Signal processing controller: Intel Corporation Device 31c0 (rev 03)
00:18.3 Signal processing controller: Intel Corporation Device 31ee (rev 03)
00:19.0 Signal processing controller: Intel Corporation Device 31c2 (rev 03)
00:19.1 Signal processing controller: Intel Corporation Device 31c4 (rev 03)
00:19.2 Signal processing controller: Intel Corporation Device 31c6 (rev 03)
00:1c.0 SD Host controller: Intel Corporation Device 31d4 (rev 03)
00:1f.0 ISA bridge: Intel Corporation Device 31e8 (rev 03)
00:1f.1 SMBus: Intel Corporation Device 31d4 (rev 03)
02:00.0 Network controller: Intel Corporation Device 2723 (rev 1a)
[b]ip a[/b]
inet6 ::1/128 scope host
[b]nmcli[/b]
lo: unmanaged
"lo"
loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
Use...
Consult...
[b]sudo dmesg | grep error[/b]
[ 7.203810] systemd-gpt-auto-generator[403]: Failed to dissect: Input/output error
[ 7.320626] EXT4-fs (mmcblk0p2):re-mounted. Opts: errors=remount-ro
