depuis que je suis passé sur mint 20 ma kobo aura n'est plus reconnue alors qu'auparavant elle fonctionnait tres bien. JE l'ai testé sur un autre pc avec le meme cable et ca fonctionne correctement.
Quelqu'un saurait-il me dire quoi faire ?
samuel@samuel-H110M-S2PV:~$ lsusb
Bus 001 Device 022: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Bus 001 Device 023: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 027: ID 0dc4:00d5 inXtron, Inc. Store & Play 3500
Bus 001 Device 002: ID 152d:2329 JMicron Technology Corp. / JMicron USA Technology Corp. JM20329 SATA Bridge
Bus 001 Device 026: ID 046d:c52b Logitech, Inc. Unifying Receiver
Aug 8 12:33:24 samuel-H110M-S2PV kernel: [78186.965026] usb 1-8.1: new high-speed USB device number 121 using xhci_hcd
Aug 8 12:33:24 samuel-H110M-S2PV kernel: [78187.071140] usb 1-8.1: New USB device found, idVendor=2237, idProduct=4226, bcdDevice= 1.10
Aug 8 12:33:24 samuel-H110M-S2PV kernel: [78187.071146] usb 1-8.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 8 12:33:24 samuel-H110M-S2PV kernel: [78187.071150] usb 1-8.1: Product: eReader-4.22.15190
Aug 8 12:33:24 samuel-H110M-S2PV kernel: [78187.071153] usb 1-8.1: Manufacturer: Kobo
Aug 8 12:33:24 samuel-H110M-S2PV kernel: [78187.071155] usb 1-8.1: SerialNumber: N236770536441
Aug 8 12:33:24 samuel-H110M-S2PV kernel: [78187.076216] usb-storage 1-8.1:1.0: USB Mass Storage device detected
Aug 8 12:33:24 samuel-H110M-S2PV kernel: [78187.077788] scsi host6: usb-storage 1-8.1:1.0
Aug 8 12:33:25 samuel-H110M-S2PV kernel: [78188.086197] scsi 6:0:0:0: Direct-Access Kobo eReader-4.22.151 0110 PQ: 0 ANSI: 2
Aug 8 12:33:25 samuel-H110M-S2PV kernel: [78188.087655] sd 6:0:0:0: Attached scsi generic sg6 type 0
Aug 8 12:33:25 samuel-H110M-S2PV kernel: [78188.090047] sd 6:0:0:0: Power-on or device reset occurred
Aug 8 12:33:25 samuel-H110M-S2PV kernel: [78188.093064] sd 6:0:0:0: [sdf] 6614013 512-byte logical blocks: (3.39 GB/3.15 GiB)
Aug 8 12:33:25 samuel-H110M-S2PV kernel: [78188.198099] sd 6:0:0:0: [sdf] Write Protect is off
Aug 8 12:33:25 samuel-H110M-S2PV kernel: [78188.198106] sd 6:0:0:0: [sdf] Mode Sense: 0f 00 00 00
Aug 8 12:33:25 samuel-H110M-S2PV kernel: [78188.308251] sd 6:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78188.545035] sdf:
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78188.768223] sd 6:0:0:0: [sdf] Attached SCSI removable disk
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78188.945493] usb 1-8.1: reset high-speed USB device number 121 using xhci_hcd
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.048347] sd 6:0:0:0: [sdf] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.048355] sd 6:0:0:0: [sdf] tag#0 CDB: Read(10) 28 00 00 00 00 88 00 00 78 00
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.048361] blk_update_request: I/O error, dev sdf, sector 136 op 0x0:(READ) flags 0x80700 phys_seg 15 prio class 0
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162097] sd 6:0:0:0: Power-on or device reset occurred
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162118] sd 6:0:0:0: [sdf] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162123] sd 6:0:0:0: [sdf] tag#0 Sense Key : Unit Attention [current]
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162128] sd 6:0:0:0: [sdf] tag#0 Add. Sense: Power on, reset, or bus device reset occurred
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162133] sd 6:0:0:0: [sdf] tag#0 CDB: Read(10) 28 00 00 00 01 08 00 00 08 00
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162140] blk_update_request: I/O error, dev sdf, sector 264 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162183] sd 6:0:0:0: [sdf] tag#0 device offline or changed
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162189] blk_update_request: I/O error, dev sdf, sector 136 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 0
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162195] Buffer I/O error on dev sdf, logical block 136, async page read
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162199] Buffer I/O error on dev sdf, logical block 137, async page read
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162202] Buffer I/O error on dev sdf, logical block 138, async page read
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162206] Buffer I/O error on dev sdf, logical block 139, async page read
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162209] Buffer I/O error on dev sdf, logical block 140, async page read
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162212] Buffer I/O error on dev sdf, logical block 141, async page read
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162216] Buffer I/O error on dev sdf, logical block 142, async page read
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162219] Buffer I/O error on dev sdf, logical block 143, async page read
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162543] sd 6:0:0:0: [sdf] tag#0 device offline or changed
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162555] blk_update_request: I/O error, dev sdf, sector 136 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162561] Buffer I/O error on dev sdf, logical block 136, async page read
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162595] sd 6:0:0:0: [sdf] tag#0 device offline or changed
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162601] blk_update_request: I/O error, dev sdf, sector 137 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162605] Buffer I/O error on dev sdf, logical block 137, async page read
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162626] sd 6:0:0:0: [sdf] tag#0 device offline or changed
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162630] blk_update_request: I/O error, dev sdf, sector 138 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162650] sd 6:0:0:0: [sdf] tag#0 device offline or changed
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162654] blk_update_request: I/O error, dev sdf, sector 139 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162673] sd 6:0:0:0: [sdf] tag#0 device offline or changed
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162677] blk_update_request: I/O error, dev sdf, sector 140 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162694] sd 6:0:0:0: [sdf] tag#0 device offline or changed
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162698] blk_update_request: I/O error, dev sdf, sector 141 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162716] sd 6:0:0:0: [sdf] tag#0 device offline or changed
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162720] blk_update_request: I/O error, dev sdf, sector 142 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Aug 8 12:33:26 samuel-H110M-S2PV kernel: [78189.162738] sd 6:0:0:0: [sdf] tag#0 device offline or changed
Aug 8 12:33:27 samuel-H110M-S2PV kernel: [78189.651551] sdf:
Aug 8 12:33:27 samuel-H110M-S2PV kernel: [78189.833131] usb 1-8.1: reset high-speed USB device number 121 using xhci_hcd
Aug 8 12:33:27 samuel-H110M-S2PV kernel: [78189.936073] sd 6:0:0:0: [sdf] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
Aug 8 12:33:27 samuel-H110M-S2PV kernel: [78189.936081] sd 6:0:0:0: [sdf] tag#0 CDB: Read(10) 28 00 00 00 01 10 00 00 f0 00
Aug 8 12:33:27 samuel-H110M-S2PV kernel: [78189.938111] sd 6:0:0:0: Power-on or device reset occurred
Aug 8 12:33:27 samuel-H110M-S2PV kernel: [78190.389131] usb 1-8.1: reset high-speed USB device number 121 using xhci_hcd
Aug 8 12:33:28 samuel-H110M-S2PV kernel: [78190.495923] sd 6:0:0:0: [sdf] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
Aug 8 12:33:28 samuel-H110M-S2PV kernel: [78190.495931] sd 6:0:0:0: [sdf] tag#0 CDB: Read(10) 28 00 00 64 e6 00 00 00 f0 00
Aug 8 12:33:28 samuel-H110M-S2PV kernel: [78190.598806] sd 6:0:0:0: Power-on or device reset occurred
