En cours adaptateur interne bluetooth non reconnu par mint 18.1
vulcanoo
Message par vulcanoo »
L'adaptateur bluetooth interne sur mon autre pc HP 6720S compaq n'est pas reconnu
Il tourne sous linux mint mate 18.1 Linux 4.4.0-189 generic.
Y a t'il un probléme matos?
[    1.519142] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 6
[    1.519151] uhci_hcd 0000:00:1d.2: detected 2 ports
[    1.519175] uhci_hcd 0000:00:1d.2: irq 18, io base 0x000040a0
[    1.519245] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    1.519249] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.519253] usb usb6: Product: UHCI Host Controller
[    1.519256] usb usb6: Manufacturer: Linux 4.4.0-189-generic uhci_hcd
[    1.519260] usb usb6: SerialNumber: 0000:00:1d.2
[    1.519447] hub 6-0:1.0: USB hub found
[    1.519457] hub 6-0:1.0: 2 ports detected
[    1.519737] i8042: PNP: PS/2 Controller [PNP0303:C298,PNP0f13:C299] at 0x60,0x64 irq 1,12
[    1.521486] i8042: Detected active multiplexing controller, rev 1.1
[    1.522159] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.522167] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[    1.522232] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[    1.522291] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[    1.522351] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[    1.522578] mousedev: PS/2 mouse device common for all mice
[    1.522894] rtc_cmos 00:01: RTC can wake from S4
[    1.523088] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[    1.523122] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    1.523138] i2c /dev entries driver
[    1.523235] device-mapper: uevent: version 1.0.3
[    1.523343] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    1.523392] platform eisa.0: Probing EISA bus 0
[    1.523397] platform eisa.0: EISA: Cannot allocate resource for mainboard
[    1.523400] platform eisa.0: Cannot allocate resource for EISA slot 1
[    1.523404] platform eisa.0: Cannot allocate resource for EISA slot 2
[    1.523408] platform eisa.0: Cannot allocate resource for EISA slot 3
[    1.523411] platform eisa.0: Cannot allocate resource for EISA slot 4
[    1.523415] platform eisa.0: Cannot allocate resource for EISA slot 5
[    1.523418] platform eisa.0: Cannot allocate resource for EISA slot 6
[    1.523422] platform eisa.0: Cannot allocate resource for EISA slot 7
[    1.523425] platform eisa.0: Cannot allocate resource for EISA slot 8
[    1.523428] platform eisa.0: EISA: Detected 0 cards
[    1.523455] cpufreq-nforce2: No nForce2 chipset.
[    1.523466] ledtrig-cpu: registered to indicate activity on CPUs
[    1.523962] NET: Registered protocol family 10
[    1.524350] NET: Registered protocol family 17
[    1.524369] Key type dns_resolver registered
[    1.524705] microcode: CPU0 sig=0x6fd, pf=0x80, revision=0xa1
[    1.524715] microcode: CPU1 sig=0x6fd, pf=0x80, revision=0xa1
[    1.524777] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.524794] Using IPI No-Shortcut mode
[    1.525022] registered taskstats version 1
[    1.525045] Loading compiled-in X.509 certificates
[    1.529793] Loaded X.509 cert 'Build time autogenerated kernel key: c69baeff894c85a308ce8b2877dad48f6403336c'
[    1.529818] zswap: loaded using pool lzo/zbud
[    1.533205] Key type trusted registered
[    1.539127] Key type encrypted registered
[    1.539136] AppArmor: AppArmor sha1 policy hashing enabled
[    1.539142] ima: No TPM chip found, activating TPM-bypass!
[    1.539153] ima: Allocated hash algorithm: sha1
[    1.539181] evm: HMAC attrs: 0x1
[    1.539666]   Magic number: 4:650:733
[    1.539697] hwmon hwmon0: hash matches
[    1.539793] rtc_cmos 00:01: setting system clock to 2020-09-09 12:43:25 UTC (1599655405)
[    1.540496] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    1.540499] EDD information not available.
[    1.540614] PM: Hibernation image not present or could not be loaded.
[    1.547917] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[    1.652388] ata1.00: ATAPI: Optiarc DVD RW AD-7561A, GH09, max MWDMA2
[    1.668265] ata1.00: configured for MWDMA2
[    1.788544] isapnp: No Plug & Play device found
[    1.789718] scsi 0:0:0:0: CD-ROM            Optiarc  DVD RW AD-7561A  GH09 PQ: 0 ANSI: 5
[    1.807390] sr 0:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[    1.807394] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.807630] sr 0:0:0:0: Attached scsi CD-ROM sr0
[    1.807740] sr 0:0:0:0: Attached scsi generic sg0 type 5
[    1.808309] Freeing unused kernel memory: 940K
[    1.820214] Write protecting the kernel text: 8148k
[    1.820302] Write protecting the kernel read-only data: 3220k
[    1.820304] NX-protecting the kernel data: 6188k
[    1.840599] random: systemd-udevd: uninitialized urandom read (16 bytes read, 4 bits of entropy available)
[    1.840752] random: systemd-udevd: uninitialized urandom read (16 bytes read, 4 bits of entropy available)
[    1.840797] random: systemd-udevd: uninitialized urandom read (16 bytes read, 4 bits of entropy available)
[    1.841548] random: udevadm: uninitialized urandom read (16 bytes read, 4 bits of entropy available)
[    1.864445] random: udevadm: uninitialized urandom read (16 bytes read, 4 bits of entropy available)
[    1.864547] random: udevadm: uninitialized urandom read (16 bytes read, 4 bits of entropy available)
[    1.864859] random: udevadm: uninitialized urandom read (16 bytes read, 4 bits of entropy available)
[    1.864998] random: udevadm: uninitialized urandom read (16 bytes read, 4 bits of entropy available)
[    1.865134] random: udevadm: uninitialized urandom read (16 bytes read, 4 bits of entropy available)
[    1.865256] random: udevadm: uninitialized urandom read (16 bytes read, 4 bits of entropy available)
[    1.960034] usb 4-2: new low-speed USB device number 2 using uhci_hcd
[    1.963174] FUJITSU Extended Socket Network Device Driver - version 1.0 - Copyright (c) 2015 FUJITSU LIMITED
[    1.970684] [drm] Initialized drm 1.1.0 20060810
[    1.971392] pps_core: LinuxPPS API ver. 1 registered
[    1.971395] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.991353] wmi: Mapper loaded
[    1.996554] PTP clock support registered
[    2.084312] [drm] Memory usable by graphics device = 512M
[    2.084318] checking generic (d0000000 300000) vs hw (d0000000 10000000)
[    2.084321] fb: switching to inteldrmfb from VESA VGA
[    2.084363] Console: switching to colour dummy device 80x25
[    2.084692] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.084696] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.087130] [drm] Replacing VGA console driver
[    2.093460] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.093464] [drm] Driver supports precise vblank timestamp query.
[    2.094300] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    2.136059] usb 4-2: New USB device found, idVendor=046d, idProduct=c077
[    2.136066] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.136070] usb 4-2: Product: USB Optical Mouse
[    2.136073] usb 4-2: Manufacturer: Logitech
[    2.151418] hidraw: raw HID events driver (C) Jiri Kosina
[    2.171609] usbcore: registered new interface driver usbhid
[    2.171614] usbhid: USB HID core driver
[    2.178109] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb4/4-2/4-2:1.0/0003:046D:C077.0001/input/input12
[    2.178348] hid-generic 0003:046D:C077.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.0-2/input0
[    2.185413] [drm] initialized overlay support
[    2.222283] ACPI Exception: AE_AML_PACKAGE_LIMIT, Index (0x000000004) is beyond end of object (length 0x4) (20150930/exoparg2-424)
[    2.222305] ACPI Error: Method parse/execution failed [\_SB.C003.C099._DOD] (Node f248e5a0), AE_AML_PACKAGE_LIMIT (20150930/psparse-542)
[    2.222324] ACPI Exception: AE_AML_PACKAGE_LIMIT, Evaluating _DOD (20150930/video-1219)
[    2.222642] ACPI: Video Device [C099] (multi-head: yes  rom: no  post: no)
[    2.223662] acpi device:01: registered as cooling_device7
[    2.223874] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13
[    2.225269] [drm] Initialized i915 1.6.0 20151010 for 0000:00:02.0 on minor 0
[    2.225660] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    2.225662] fbcon: inteldrmfb (fb0) is primary device
[    2.225770] Console: switching to colour frame buffer device 160x50
[    2.225812] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    2.384381] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:1f:29:8f:4a:86
[    2.384388] e1000e 0000:00:19.0 eth0: Intel(R) PRO/10/100 Network Connection
[    2.384422] e1000e 0000:00:19.0 eth0: MAC: 6, PHY: 7, PBA No: FFFFFF-0FF
[    2.384466] ahci 0000:00:1f.2: version 3.0
[    2.384725] ahci 0000:00:1f.2: quirky BIOS, skipping spindown on poweroff
[    2.384802] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[    2.384832] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 3 ports 3 Gbps 0x1 impl SATA mode
[    2.384837] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio slum part ccc
[    2.385813] scsi host2: ahci
[    2.386032] scsi host3: ahci
[    2.386706] e1000e 0000:00:19.0 enp0s25: renamed from eth0
[    2.387128] scsi host4: ahci
[    2.387235] ata3: SATA max UDMA/133 abar m2048@0xe4629000 port 0xe4629100 irq 29
[    2.387238] ata4: DUMMY
[    2.387241] ata5: DUMMY
[    2.412066] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x19e1a45f534, max_idle_ns: 440795274709 ns
[    2.704086] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    2.706048] ata3.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[    2.706053] ata3.00: ACPI cmd b1/c1:00:00:00:00:a0 (DEVICE CONFIGURATION OVERLAY) filtered out
[    2.706157] ata3.00: ACPI cmd c6/00:10:00:00:00:a0 (SET MULTIPLE MODE) succeeded
[    2.706163] ata3.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[    2.706668] ata3.00: ATA-8: WDC WD1600BEVT-60ZCT0, 11.01A11, max UDMA/100
[    2.706672] ata3.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    2.708657] ata3.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[    2.708662] ata3.00: ACPI cmd b1/c1:00:00:00:00:a0 (DEVICE CONFIGURATION OVERLAY) filtered out
[    2.708760] ata3.00: ACPI cmd c6/00:10:00:00:00:a0 (SET MULTIPLE MODE) succeeded
[    2.708765] ata3.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[    2.709291] ata3.00: configured for UDMA/100
[    2.709559] scsi 2:0:0:0: Direct-Access     ATA      WDC WD1600BEVT-6 1A11 PQ: 0 ANSI: 5
[    2.709981] sd 2:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[    2.710061] sd 2:0:0:0: [sda] Write Protect is off
[    2.710066] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.710099] sd 2:0:0:0: Attached scsi generic sg1 type 0
[    2.710125] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.780432]  sda: sda1 sda2 < sda5 >
[    2.781035] sd 2:0:0:0: [sda] Attached SCSI disk
[    2.794028] psmouse serio4: synaptics: Touchpad model: 1, fw: 6.2, id: 0x1a0b1, caps: 0xa04711/0x200000/0x0/0x0, board id: 0, fw id: 496511
[    2.834990] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input11
[    3.516053] raid6: mmxx1    gen()  2608 MB/s
[    3.584035] raid6: mmxx2    gen()  2986 MB/s
[    3.652035] raid6: sse1x1   gen()  1655 MB/s
[    3.720061] raid6: sse1x2   gen()  2274 MB/s
[    3.788035] raid6: sse2x1   gen()  3037 MB/s
[    3.856040] raid6: sse2x1   xor()  3487 MB/s
[    3.924050] raid6: sse2x2   gen()  3426 MB/s
[    3.992032] raid6: sse2x2   xor()  4175 MB/s
[    3.992035] raid6: using algorithm sse2x2 gen() 3426 MB/s
[    3.992037] raid6: .... xor() 4175 MB/s, rmw enabled
[    3.992040] raid6: using ssse3x1 recovery algorithm
[    3.997420] xor: measuring software checksum speed
[    4.036032]    pIII_sse  :  6739.000 MB/sec
[    4.076029]    prefetch64-sse:  7651.000 MB/sec
[    4.076034] xor: using function: prefetch64-sse (7651.000 MB/sec)
[    4.121796] Btrfs loaded
[    4.332985] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    4.933379] random: nonblocking pool is initialized
[    5.970942] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    5.971147] systemd[1]: Detected architecture x86.
[    5.989941] systemd[1]: Set hostname to <chantal-HP-Compaq-6720s>.
[    8.206881] systemd[1]: Listening on udev Control Socket.
[    8.207108] systemd[1]: Created slice User and Session Slice.
[    8.207338] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.207407] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    8.207461] systemd[1]: Listening on udev Kernel Socket.
[    8.207521] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    8.207603] systemd[1]: Listening on Journal Socket.
[    8.207641] systemd[1]: Reached target Encrypted Volumes.
[    8.207716] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    8.207839] systemd[1]: Listening on Journal Audit Socket.
[    8.207896] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.208044] systemd[1]: Created slice System Slice.
[    8.220170] systemd[1]: Mounting POSIX Message Queue File System...
[    8.221099] systemd[1]: Starting Uncomplicated firewall...
[    8.222122] systemd[1]: Started Braille Device Support.
[    8.223374] systemd[1]: Started Read required files in advance.
[    8.224534] systemd[1]: Mounting Debug File System...
[    8.408342] systemd[1]: Starting Load Kernel Modules...
[    8.409282] systemd[1]: Starting Set console keymap...
[    8.409320] systemd[1]: Reached target Slices.
[    8.410200] systemd[1]: Mounting Huge Pages File System...
[    8.410299] systemd[1]: Listening on Syslog Socket.
[    8.411293] systemd[1]: Starting Journal Service...
[    8.412269] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    8.412327] systemd[1]: Reached target Remote File Systems (Pre).
[    8.412425] systemd[1]: Listening on fsck to fsckd communication Socket.
[    8.413518] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.746424] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[    8.747780] systemd[1]: Listening on LVM2 metadata daemon socket.
[    8.764347] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    8.764408] systemd[1]: Reached target Remote File Systems.
[    8.764450] systemd[1]: Reached target User and Group Name Lookups.
[    8.764556] systemd[1]: Started Trigger resolvconf update for networkd DNS.
[    8.764631] systemd[1]: Listening on LVM2 poll daemon socket.
[    8.767233] systemd[1]: Mounted POSIX Message Queue File System.
[    8.767371] systemd[1]: Mounted Debug File System.
[    8.767464] systemd[1]: Mounted Huge Pages File System.
[    8.768281] systemd[1]: Started Remount Root and Kernel File Systems.
[    8.802205] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    8.860452] systemd[1]: Starting Create Static Device Nodes in /dev...
[    9.016288] systemd[1]: Starting udev Coldplug all Devices...
[    9.017233] systemd[1]: Starting Load/Save Random Seed...
[    9.018249] systemd[1]: Started Uncomplicated firewall.
[    9.327708] systemd[1]: Started udev Coldplug all Devices.
[    9.419025] systemd[1]: Started Load/Save Random Seed.
[    9.646480] systemd[1]: Started Journal Service.
[    9.805549] systemd-journald[317]: Received request to flush runtime journal from PID 1
[   10.178872] lp: driver loaded but no devices found
[   10.186657] ppdev: user-space parallel port driver
[   16.141436] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   16.566924] ACPI Warning: SystemIO range 0x0000000000001028-0x000000000000102F conflicts with OpRegion 0x0000000000001000-0x0000000000001042 (\_SB_.C003.C004.C0D3) (20150930/utaddress-254)
[   16.566935] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   16.566942] ACPI Warning: SystemIO range 0x0000000000001130-0x000000000000113F conflicts with OpRegion 0x0000000000001100-0x000000000000113B (\_SB_.C003.C004.C0E5) (20150930/utaddress-254)
[   16.566949] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   16.566952] ACPI Warning: SystemIO range 0x0000000000001100-0x000000000000112F conflicts with OpRegion 0x0000000000001100-0x000000000000113B (\_SB_.C003.C004.C0E5) (20150930/utaddress-254)
[   16.566959] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[   16.566961] lpc_ich: Resource conflict(s) found affecting gpio_ich
[   17.246052] intel_powerclamp: No package C-state available
[   17.278016] intel_powerclamp: No package C-state available
[   17.590630] input: HP WMI hotkeys as /devices/virtual/input/input14
[   18.189405] iwl3945: Intel(R) PRO/Wireless 3945ABG/BG Network Connection driver for Linux, in-tree:s
[   18.189411] iwl3945: Copyright(c) 2003-2011 Intel Corporation
[   18.189483] iwl3945 0000:10:00.0: can't disable ASPM; OS doesn't have ASPM control
[   18.244955] iwl3945 0000:10:00.0: Tunable channels: 13 802.11bg, 23 802.11a channels
[   18.244962] iwl3945 0000:10:00.0: Detected Intel Wireless WiFi Link 3945ABG
[   18.606126] ieee80211 phy0: Selected rate control algorithm 'iwl-3945-rs'
[   18.609351] iwl3945 0000:10:00.0 wlp16s0: renamed from wlan0
[   18.673876] cfg80211: World regulatory domain updated:
[   18.673881] cfg80211:  DFS Master region: unset
[   18.673884] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   18.673888] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   18.673892] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   18.673895] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   18.673898] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   18.673902] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   18.673906] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   18.673909] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   18.673912] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   19.655722] snd_hda_codec_analog hdaudioC0D0: autoconfig for AD1981: line_outs=1 (0x5/0x0/0x0/0x0/0x0) type:speaker
[   19.655729] snd_hda_codec_analog hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   19.655733] snd_hda_codec_analog hdaudioC0D0:    hp_outs=1 (0x6/0x0/0x0/0x0/0x0)
[   19.655736] snd_hda_codec_analog hdaudioC0D0:    mono: mono_out=0x0
[   19.655739] snd_hda_codec_analog hdaudioC0D0:    inputs:
[   19.655743] snd_hda_codec_analog hdaudioC0D0:      Mic=0x8
[   19.655747] snd_hda_codec_analog hdaudioC0D0:      Internal Mic=0x18
[   19.655750] snd_hda_codec_analog hdaudioC0D0:      Line=0x9
[   19.684177] Adding 2086908k swap on /dev/sda5.  Priority:-1 extents:1 across:2086908k FS
[   24.427462] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[   24.427595] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[   24.427715] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[   26.314011] cgroup: new mount options do not match the existing superblock, will be ignored
[   29.878647] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready
[   30.076461] IPv6: ADDRCONF(NETDEV_UP): enp0s25: link is not ready
[   30.191873] IPv6: ADDRCONF(NETDEV_UP): wlp16s0: link is not ready
[   31.500846] e1000e: enp0s25 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[   31.500855] e1000e 0000:00:19.0 enp0s25: 10/100 speed: disabling TSO
[   31.500896] IPv6: ADDRCONF(NETDEV_CHANGE): enp0s25: link becomes ready
[   40.934986] iwl3945 0000:10:00.0: loaded firmware version 15.32.2.9
[   41.005548] IPv6: ADDRCONF(NETDEV_UP): wlp16s0: link is not ready
[   41.120428] IPv6: ADDRCONF(NETDEV_UP): wlp16s0: link is not ready
[   51.533634] wlp16s0: authenticate with e4:9e:12:bb:6e:30
[   51.538365] wlp16s0: send auth to e4:9e:12:bb:6e:30 (try 1/3)
[   51.542871] wlp16s0: authenticated
[   51.548032] wlp16s0: associate with e4:9e:12:bb:6e:30 (try 1/3)
[   51.553833] wlp16s0: RX AssocResp from e4:9e:12:bb:6e:30 (capab=0x411 status=0 aid=1)
[   51.558625] wlp16s0: associated
[   51.558711] IPv6: ADDRCONF(NETDEV_CHANGE): wlp16s0: link becomes ready
[  448.616886] perf interrupt took too long (2520 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
[ 1549.476916] iwl3945 0000:10:00.0: Card state received: HW:Kill SW:On
[ 1549.477730] wlp16s0: deauthenticating from e4:9e:12:bb:6e:30 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1549.479611] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1549.479625] iwl3945 0000:10:00.0: Error sending C_REM_STA: enqueue_hcmd failed: -5
[ 1549.479636] iwl3945 0000:10:00.0: Error removing station e4:9e:12:bb:6e:30
[ 1549.479754] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1549.479763] iwl3945 0000:10:00.0: Error sending C_QOS_PARAM: enqueue_hcmd failed: -5
[ 1549.479774] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1549.479782] iwl3945 0000:10:00.0: Error sending C_RXON: enqueue_hcmd failed: -5
[ 1549.479791] iwl3945 0000:10:00.0: Error setting new configuration (-5).
[ 1549.479799] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1549.479807] iwl3945 0000:10:00.0: Error sending C_RXON_ASSOC: enqueue_hcmd failed: -5
[ 1549.479821] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1549.479829] iwl3945 0000:10:00.0: Error sending C_RXON_ASSOC: enqueue_hcmd failed: -5
[ 1549.479843] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1549.479851] iwl3945 0000:10:00.0: Error sending C_RXON: enqueue_hcmd failed: -5
[ 1549.479859] iwl3945 0000:10:00.0: Error setting new configuration (-5).
[ 1549.479870] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1549.479878] iwl3945 0000:10:00.0: Error sending C_LEDS: enqueue_hcmd failed: -5
[ 1549.479896] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1549.479904] iwl3945 0000:10:00.0: Error sending C_RXON: enqueue_hcmd failed: -5
[ 1549.479911] iwl3945 0000:10:00.0: Error setting new configuration (-5).
[ 1549.487264] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1549.487279] iwl3945 0000:10:00.0: Error sending C_RXON: enqueue_hcmd failed: -5
[ 1549.487290] iwl3945 0000:10:00.0: Error setting new configuration (-5).
[ 1549.488042] iwl3945 0000:10:00.0: Master Disable Timed Out, 100 usec
[ 1549.517845] cfg80211: World regulatory domain updated:
[ 1549.517852] cfg80211:  DFS Master region: unset
[ 1549.517855] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1549.517859] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1549.517864] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1549.517868] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1549.517872] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1549.517876] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1549.517879] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1549.517883] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1549.517886] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1554.074953] IPv6: ADDRCONF(NETDEV_UP): wlp16s0: link is not ready
[ 1554.119608] IPv6: ADDRCONF(NETDEV_UP): wlp16s0: link is not ready
[ 1558.411843] Bluetooth: Core ver 2.21
[ 1558.411879] NET: Registered protocol family 31
[ 1558.411881] Bluetooth: HCI device and connection manager initialized
[ 1558.411888] Bluetooth: HCI socket layer initialized
[ 1558.411892] Bluetooth: L2CAP socket layer initialized
[ 1558.411903] Bluetooth: SCO socket layer initialized
[ 1563.617463] wlp16s0: authenticate with e4:9e:12:bb:6e:30
[ 1563.620926] wlp16s0: send auth to e4:9e:12:bb:6e:30 (try 1/3)
[ 1563.631402] wlp16s0: authenticated
[ 1563.636039] wlp16s0: associate with e4:9e:12:bb:6e:30 (try 1/3)
[ 1563.639509] wlp16s0: RX AssocResp from e4:9e:12:bb:6e:30 (capab=0x411 status=0 aid=1)
[ 1563.642403] wlp16s0: associated
[ 1563.642471] IPv6: ADDRCONF(NETDEV_CHANGE): wlp16s0: link becomes ready
[ 1588.036516] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1588.036521] Bluetooth: BNEP filters: protocol multicast
[ 1588.036529] Bluetooth: BNEP socket layer initialized
[ 1839.602920] iwl3945 0000:10:00.0: Card state received: HW:Kill SW:On
[ 1839.603853] wlp16s0: deauthenticating from e4:9e:12:bb:6e:30 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1839.605409] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1839.605422] iwl3945 0000:10:00.0: Error sending C_REM_STA: enqueue_hcmd failed: -5
[ 1839.605433] iwl3945 0000:10:00.0: Error removing station e4:9e:12:bb:6e:30
[ 1839.605558] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1839.605568] iwl3945 0000:10:00.0: Error sending C_QOS_PARAM: enqueue_hcmd failed: -5
[ 1839.605580] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1839.605588] iwl3945 0000:10:00.0: Error sending C_RXON: enqueue_hcmd failed: -5
[ 1839.605597] iwl3945 0000:10:00.0: Error setting new configuration (-5).
[ 1839.605605] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1839.605613] iwl3945 0000:10:00.0: Error sending C_RXON_ASSOC: enqueue_hcmd failed: -5
[ 1839.605627] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1839.605635] iwl3945 0000:10:00.0: Error sending C_RXON_ASSOC: enqueue_hcmd failed: -5
[ 1839.605649] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1839.605657] iwl3945 0000:10:00.0: Error sending C_RXON: enqueue_hcmd failed: -5
[ 1839.605665] iwl3945 0000:10:00.0: Error setting new configuration (-5).
[ 1839.605677] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1839.605684] iwl3945 0000:10:00.0: Error sending C_LEDS: enqueue_hcmd failed: -5
[ 1839.605702] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1839.605710] iwl3945 0000:10:00.0: Error sending C_RXON: enqueue_hcmd failed: -5
[ 1839.605718] iwl3945 0000:10:00.0: Error setting new configuration (-5).
[ 1839.606773] iwl3945 0000:10:00.0: Not sending command - RF KILL
[ 1839.606786] iwl3945 0000:10:00.0: Error sending C_RXON: enqueue_hcmd failed: -5
[ 1839.606797] iwl3945 0000:10:00.0: Error setting new configuration (-5).
[ 1839.608018] iwl3945 0000:10:00.0: Master Disable Timed Out, 100 usec
[ 1839.629584] cfg80211: World regulatory domain updated:
[ 1839.629590] cfg80211:  DFS Master region: unset
[ 1839.629593] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 1839.629597] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 1839.629602] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1839.629605] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 1839.629609] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 1839.629613] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 1839.629617] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 1839.629620] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 1839.629624] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 1915.240370] perf interrupt took too long (5005 > 5000), lowering kernel.perf_event_max_sample_rate to 25000
chantal@chantal-HP-Compaq-6720s ~ $
HP-Pavilion-Notebook 8097 : | Linux Mint 22.2 ZARA | MATE 1.26.2 | 6.14.0-35-generic x86_64: 64 | dual core model: Intel Core i5-5200U bits: 64 type: MT MCP cache:
L2: 512 KiB
| 7.42 GiB | Device-1: Intel HD Graphics 5500 driver: i915 v: kernel
Device-2: NVIDIA GM108M [GeForce 940M] driver: nvidia v: 535.161.07
vulcanoo
Re: adaptateur interne bluetooth non reconnu par mint 18.1
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
1: hp-wifi: Wireless LAN
	Soft blocked: no
	Hard blocked: no
2: hp-gps: GPS
	Soft blocked: yes
	Hard blocked: yes
L2: 512 KiB
vulcanoo
Oui le wifi fonctionne bien.
Et la commande que tu m'as donné elle sert à quoi?
L2: 512 KiB
vulcanoo
j'ai upgradé vers 18.3 noyau 4.15.0-117
Adaptateur toujours pas reconnu
L2: 512 KiB
sujet de 2 mois ou plus sans réponse
si besoin de rouvrir => mp à un membre de l'équipe ;)
