Résolu le 24-10-20 Temps de boot extrêmement long
AngeDesOmbres
Message par AngeDesOmbres »
Bonjour à vous,
Alors tout est dans le titre du poste :lol:
voici le retour de la commande:
angel@Dreamy-PC:~$ systemd-analyze blame
37.350s apt-daily.service
14.503s networkd-dispatcher.service
13.450s man-db.service
12.785s fwupd-refresh.service
12.082s udisks2.service
10.447s accounts-daemon.service
 8.353s fwupd.service
 8.224s ubuntu-system-adjustments.service
 7.856s dev-sda2.device
 7.514s avahi-daemon.service
 7.499s bluetooth.service
 7.293s NetworkManager.service
 6.800s polkit.service
 6.414s thermald.service
 6.376s wpa_supplicant.service
 6.373s systemd-logind.service
 5.192s systemd-resolved.service
 4.664s ModemManager.service
 4.641s gpu-manager.service
 4.545s hddtemp.service
 3.907s logrotate.service
 3.610s grub-common.service
 3.593s rsyslog.service
 2.554s grub-initrd-fallback.service
 2.349s networking.service
 2.235s lightdm.service
 2.175s plymouth-quit-wait.service
 2.061s systemd-journal-flush.service
 2.058s e2scrub_reap.service
 1.787s apt-daily-upgrade.service
 1.760s systemd-fsck@dev-disk-by\x2duuid-4F4E\x2d9690.service
 1.707s alsa-restore.service
 1.574s systemd-fsck@dev-disk-by\x2duuid-96d322e5\x2d28e4\x2d410a\x2d9c3d\x2d36
 1.565s lm-sensors.service
 1.531s systemd-rfkill.service
 1.431s apparmor.service
 1.260s systemd-tmpfiles-setup-dev.service
 1.180s systemd-fsck@dev-disk-by\x2duuid-d8ba056e\x2d853e\x2d4e24\x2dacd3\x2d66
 1.139s systemd-modules-load.service
 1.037s systemd-sysctl.service
  922ms dns-clean.service
  902ms upower.service
  873ms keyboard-setup.service
  794ms systemd-sysusers.service
  767ms systemd-random-seed.service
  751ms systemd-tmpfiles-setup.service
  686ms systemd-udev-trigger.service
  608ms qemu-kvm.service
  552ms systemd-timesyncd.service
  502ms pppd-dns.service
  480ms kerneloops.service
  473ms systemd-udevd.service
  459ms fstrim.service
  432ms lvm2-monitor.service
  420ms user@1000.service
  401ms systemd-journald.service
  382ms systemd-backlight@backlight:intel_backlight.service
  356ms ufw.service
  338ms home.mount
  298ms ifupdown-pre.service
  283ms packagekit.service
  275ms dev-hugepages.mount
  271ms dev-mqueue.mount
  268ms sys-kernel-debug.mount
  260ms sys-kernel-tracing.mount
  249ms setvtrgb.service
  249ms blk-availability.service
  242ms kmod-static-nodes.service
  224ms systemd-remount-fs.service
  185ms boot-efi.mount
  161ms plymouth-read-write.service
  157ms data.mount
  148ms colord.service
  140ms console-setup.service
  102ms dev-disk-by\x2duuid-f1f2f521\x2ddd0a\x2d4d5e\x2d872d\x2d8a3d0003bd1b.sw
   91ms flatpak-system-helper.service
   81ms user-runtime-dir@1000.service
   80ms systemd-update-utmp.service
   57ms rtkit-daemon.service
   45ms systemd-user-sessions.service
   41ms systemd-update-utmp-runlevel.service
   40ms finalrd.service
   24ms motd-news.service
   24ms plymouth-start.service
   18ms sys-kernel-config.mount
   17ms openvpn.service
   13ms sys-fs-fuse-connections.mount
lines 65-87/87 (END)
caractéristique de la machine en question :
Laptop HP 80C5 v 64 bits
OS : LM 20 | cinnamon 4.6.7
Kernel : 5.4.0-51-generic
Proc : Intel celeron CPU N3050 @ 1.60Ghz x2
CG : Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics
Je trouve le chargement de apt-daily.service extrêmement long partiquement 40 secondes c'est énorme :-o :-o :-o :-o
Des solutions pour réduire drastiquement le temps de boot ?
Merci d'avance pour vos future réponse.
Bye
@Ange
Modifié en dernier par AngeDesOmbres le sam. 24 oct. 2020 11:59, modifié 1 fois.
Pingouin dans les champs, hiver très méchant !!!
Qui pisse loin ménage ses chaussures !!! :D
Re: Temps de boot extrêmement long
En fait ce service ne devrait pas être lancé au boot mais plus tard... (bogue Debian n ° 844453)
Le mieux est de retarder son execution afin de le décaler par rapport à la séance de boot
sudo systemctl edit apt-daily.timer
# Ajouter les informations suivantes :
[Timer]
OnBootSec=15min
OnUnitActiveSec=1d
AccuracySec=1h
RandomizedDelaySec=30min
Ou le virer (si pas besoin)...
AngeDesOmbres
Donc j'ai tenté de faire se que tu m'as proposé MAIS je bloque a un moment
J'ai edit le fichier puis fait un copier/coller puis un CTRL+x pour enregistrer.
C'est la que je bloque en effet ca me demande le nom du fichier a écrire et la je comprend pas se que je dois faire (cf image jointe)
merci d'avance.
perso je le mettrai dans
 /etc/systemd/system/apt-daily.timer
et le man du pourquoi du comment https://man7.org/linux/man-pages/man5/s ... mer.5.html
AngeDesOmbres
Alors suite a une fausse manip dans mon terminal :lol: j'ai refait une analyse du boot
se que je comprend c'est que la le apt-daily.service n'y figure pas, alors que je n'ai pas encore enregistrer le fichier que tu m'a conseillé.
13.583s networkd-dispatcher.service
10.933s udisks2.service
 9.432s accounts-daemon.service
 8.003s ubuntu-system-adjustments.service
 7.811s dev-sda2.device
 7.310s NetworkManager.service
 6.375s avahi-daemon.service
 6.368s bluetooth.service
 5.833s polkit.service
 5.289s thermald.service
 5.256s systemd-logind.service
 5.254s wpa_supplicant.service
 4.960s ModemManager.service
 4.543s systemd-resolved.service
 4.223s gpu-manager.service
 3.903s hddtemp.service
 2.580s rsyslog.service
 2.574s grub-initrd-fallback.service
 2.480s networking.service
 2.429s grub-common.service
 2.334s systemd-journal-flush.service
 2.160s systemd-fsck@dev-disk-by\x2duuid-d8ba056e\x2d853e\x2d4e24\x2dacd3\x2d66
 2.000s alsa-restore.service
 1.848s systemd-rfkill.service
 1.840s e2scrub_reap.service
 1.803s systemd-fsck@dev-disk-by\x2duuid-96d322e5\x2d28e4\x2d410a\x2d9c3d\x2d36
 1.671s lm-sensors.service
 1.625s lightdm.service
 1.593s plymouth-quit-wait.service
 1.467s systemd-udevd.service
 1.284s apparmor.service
 1.027s systemd-fsck@dev-disk-by\x2duuid-4F4E\x2d9690.service
  896ms keyboard-setup.service
  874ms systemd-modules-load.service
  821ms systemd-tmpfiles-setup-dev.service
  818ms upower.service
  797ms dns-clean.service
  753ms systemd-journald.service
  707ms systemd-tmpfiles-setup.service
  680ms systemd-udev-trigger.service
  633ms systemd-timesyncd.service
  632ms pppd-dns.service
  559ms systemd-sysctl.service
  518ms qemu-kvm.service
  507ms lvm2-monitor.service
  500ms systemd-sysusers.service
  473ms user@1000.service
  416ms kerneloops.service
  398ms systemd-random-seed.service
  395ms systemd-user-sessions.service
  298ms dev-hugepages.mount
  295ms dev-mqueue.mount
  291ms sys-kernel-debug.mount
  284ms sys-kernel-tracing.mount
  283ms home.mount
  274ms blk-availability.service
  266ms ufw.service
  259ms kmod-static-nodes.service
  253ms dev-disk-by\x2duuid-f1f2f521\x2ddd0a\x2d4d5e\x2d872d\x2d8a3d0003bd1b.sw
  240ms systemd-backlight@backlight:intel_backlight.service
  235ms colord.service
  191ms systemd-remount-fs.service
  188ms ifupdown-pre.service
  172ms boot-efi.mount
  159ms setvtrgb.service
  139ms console-setup.service
   98ms data.mount
   96ms systemd-tmpfiles-clean.service
   67ms rtkit-daemon.service
   66ms plymouth-read-write.service
   61ms user-runtime-dir@1000.service
   58ms systemd-update-utmp.service
   46ms systemd-update-utmp-runlevel.service
   35ms finalrd.service
   27ms plymouth-start.service
   15ms openvpn.service
   13ms sys-kernel-config.mount
   12ms sys-fs-fuse-connections.mount
il a disparue je ne sais pas comment je comprend pas. malgrer ca le temps de boot reste extrêmement long.
Startup finished in 3.082s (firmware) + 12.123s (loader) + 8.723s (kernel) + 31.404s (userspace) = 55.334s
graphical.target reached after 31.349s in userspace
55s c'est très long et le graphical.target reached after 31.349s in userspace je comprend se que c'est...
le bluetooth.service ne me sert a rien aussi il est désactivable ?
Merci d'avance.
À tout hasard : viewtopic.php?f=23&t=13951&p=158540
Les services que tu indiques n'y figurent pas mais c'est une piste ;)
PS :
AngeDesOmbres a écrit :
mar. 20 oct. 2020 17:55
pour enregistrer dans nano tu fais Ctrl+o, il te demande le nom du fichier, si tu veux le même nom de fichier tu tapes <Entrée> et tu quittes avec Ctrl+x.
AngeDesOmbres
Merci arglub avec ton lien j'ai pu désactivé certain chose et gagner pas loin de 35s sur le boot
