Résolu le 29-12-20 smartphone android non détécté
rb39
Message par rb39 »
bonjour,
j'ai une amie à qui j'ai installé Mint sur une machine nouvellement acquise en reconditionnement :
System:    Kernel: 5.4.0-58-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Cinnamon 4.6.7
           wm: muffin dm: LightDM Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Machine:   Type: Desktop System: HP product: HP ProDesk 400 G3 SFF v: N/A serial: <filter>
           Chassis: type: 4 serial: <filter>
           Mobo: HP model: 8062 v: KBC Version 05.22 serial: <filter> UEFI [Legacy]: HP
           v: N03 Ver. 02.07 date: 05/31/2016
CPU:       Topology: Dual Core model: Intel Core i3-6100 bits: 64 type: MT MCP arch: Skylake-S
           rev: 3 L2 cache: 3072 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 29598
           Speed: 900 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900
Graphics:  Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:1912
           Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa
           resolution: 1680x1050~60Hz
           OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 20.0.8
           direct render: Yes
Audio:     Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Hewlett-Packard
           driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
           Sound Server: ALSA v: k5.4.0-58-generic
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
           vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 01:00.0
           chip ID: 10ec:8168
           IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 465.76 GiB used: 40.56 GiB (8.7%)
           ID-1: /dev/sda vendor: Seagate model: ST500DM002-1BD142 size: 465.76 GiB
           speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 450.08 GiB used: 40.56 GiB (9.0%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 7.48 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 39.5 C mobo: N/A
           Fan Speeds (RPM): N/A
Repos:     No active apt repos in: /etc/apt/sources.list
           1: deb http: //packages.linuxmint.com ulyana main upstream import backport
           2: deb http: //archive.ubuntu.com/ubuntu focal main restricted universe multiverse
           3: deb http: //archive.ubuntu.com/ubuntu focal-updates main restricted universe multiverse
           4: deb http: //archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse
           5: deb http: //security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
           6: deb http: //archive.canonical.com/ubuntu/ focal partner
           Active apt repos in: /etc/apt/sources.list.d/teamviewer.list
           1: deb https: //linux.teamviewer.com/deb stable main
Info:      Processes: 193 Uptime: 4m Memory: 7.67 GiB used: 737.5 MiB (9.4%) Init: systemd v: 245
           runlevel: 5 Compilers: gcc: 9.3.0 alt: 9 Client: Unknown python3.8 client inxi: 3.0.38
j'ai voulu montrer comment transférer des fichiers/dossiers entre son smartphone "xiaomi note5" et son pc. mais le smartphone n'est pas reconnu donc pas de montage.
après recherche et questionnement sur un autre site, il m'a été indiqué que cela pouvait venir de l'absence de MTP. j'ai installé, à partir de Synaptic, les logiciels si rapportant mais toujours rien , j'ai voulu installé mtp-tools qui apparement n'avait pas été installé :
xxxx :~$ sudo apt-get install mtp-tools
mtp-tools est déjà la version la plus récente (1.1.17-3).
Après cette opération, 0 o d'espace disque supplémentaires seront utilisés.
Souhaitez-vous continuer ? [O/n]
Paramétrage de android-androresolvd (1.3-1build1) ...
Job for android-androresolvd.service failed because the control process exited with error code.
See "systemctl status android-androresolvd.service" and "journalctl -xe" for details.
invoke-rc.d: initscript android-androresolvd, action "start" failed.
● android-androresolvd.service - LSB: Updates /etc/resolv.conf from Android system props
Loaded: loaded (/etc/init.d/android-androresolvd; generated)
Active: failed (Result: exit-code) since Sat 2020-12-26 18:08:16 CET; 4ms ago
Docs: man:systemd-sysv-generator(8)
Process: 3562 ExecStart=/etc/init.d/android-androresolvd start (code=exited, status=255/EXCEPTION)
déc. 26 18:08:16 xxxxxx-HP-ProDesk-400-G3-SFF systemd[1]: Starting LSB: Updates /etc/resolv.conf from Android system props...
déc. 26 18:08:16 xxxxxx-HP-ProDesk-400-G3-SFF android-androresolvd[3581]: Cannot access system properties via ANDROID_PROPERTY_WORKSPACE environment setting.
déc. 26 18:08:16 xxxxxxx-HP-ProDesk-400-G3-SFF systemd[1]: android-androresolvd.service: Control process exited, code=exited, status=255/EXCEPTION
déc. 26 18:08:16 xxxxxx-HP-ProDesk-400-G3-SFF systemd[1]: android-androresolvd.service: Failed with result 'exit-code'.
déc. 26 18:08:16 xxxxxx-HP-ProDesk-400-G3-SFF systemd[1]: Failed to start LSB: Updates /etc/resolv.conf from Android system props.
dpkg: erreur de traitement du paquet android-androresolvd (--configure) :
installed android-androresolvd package post-installation script subprocess returned error exit status 1
Des erreurs ont été rencontrées pendant l'exécution :
j'ai désinstallé "android-androresolvd" mais rien de neuf.
pouvez vous me dire que faire ?
Modifié en dernier par arghlub le lun. 28 déc. 2020 10:32, modifié 1 fois.
Raison : remplacement des balises [quote] par des [code]
Re: smartphone android non détécté
Merci de ne pas confondre les balises "quote" (réservées aux citations) et les balises "code" (pour les commandes en terminal).
J'ai donc modifié ton message pour mettre les retours du terminal entre balises “code”.
Il faut utiliser ces balises (sélectionner le code et cliquer sur Image) pour tout ce qui concerne le terminal (commandes, retours de commandes, etc…), cela améliore grandement la lisibilité.
Voir tuto Barre d'outils des messages.
toryx
Message par toryx »
salut
vérifie à tout hasard si ton xiaomi ne se met pas directement en mode "chargeur" quand tu le branche sur ton usb
rb39
Message par rb39 »
bonjour,
désolé pour le balisage, je vais essayer de mieux faire.
pour le smartphone, en fait après vérification , c'est le câble qui n'était pas bon. Soit il est mort soit il ne permet que le chargement batterie.
J'ai découvert ça en testant avec mon smartphone qui a été reconnu/monté spontanément. je n'avais pas pût le faire précédemment parce que ce je n'avait pas mon câble usb avec connecteur différent.
j'ai donc refait avec le "xiaomi note5" mais avec un autre câble et le problème était réglé, reconnaissance et montage illico.
merci pour les retours
Richard
