Alternative le 5-03-21 Problème Ethernet [LMDE 4]
ITX
Message par ITX »
J'ai un souci avec la liason ethernet de mon PC portable.
J'ai découvert linux et installé LMDE en Dualboot en septembre. Tout allait bien. Mais aujourd'hui sans explications, la connexion ethernet à des ratés.
Voici ma config :
System:
  Host: nicolas-portable-linux Kernel: 4.19.0-14-amd64 x86_64 bits: 64
  compiler: gcc v: 8.3.0 Desktop: Cinnamon 4.8.6 Distro: LMDE 4 Debbie
  base: Debian 10.2 buster
Machine:
  Type: Laptop System: ASUSTeK product: N53SN v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: N53SN v: 1.0 serial: <filter>
  BIOS: American Megatrends v: N53SN.206 date: 04/07/2011
Battery:
  ID-1: BAT0 charge: 41.4 Wh condition: 41.4/48.4 Wh (86%)
  model: ASUSTek M50--24 status: Full
CPU:
  Topology: Dual Core model: Intel Core i5-2410M bits: 64 type: MT MCP
  arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18358
  Speed: 798 MHz min/max: 800/2900 MHz Core speeds (MHz): 1: 975 2: 935
  3: 1154 4: 1142
Graphics:
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
  Device-2: NVIDIA GF108M [GeForce GT 550M] vendor: ASUSTeK driver: N/A
  bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
  resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 18.3.6
  direct render: Yes
Audio:
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio
  vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
  v: kernel bus ID: 01:00.1
  Sound Server: ALSA v: k4.19.0-14-amd64
Network:
  Device-1: Intel Centrino Wireless-N 1000 [Condor Peak] driver: iwlwifi
  v: kernel port: d000 bus ID: 03:00.0
  IF: wlp3s0 state: up mac: <filter>
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  vendor: ASUSTeK U6V/U31J laptop driver: r8169 v: kernel port: 9000
  bus ID: 05:00.0
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
Drives:
  Local Storage: total: 698.64 GiB used: 161.31 GiB (23.1%)
  ID-1: /dev/sda vendor: Seagate model: ST9750420AS size: 698.64 GiB
Partition:
  ID-1: / size: 57.42 GiB used: 12.29 GiB (21.4%) fs: ext4 dev: /dev/sda6
  ID-2: /home size: 192.59 GiB used: 148.80 GiB (77.3%) fs: ext4
  dev: /dev/sda7
  ID-3: swap-1 size: 3.91 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors:
  System Temperatures: cpu: 54.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2700
Info:
  Processes: 202 Uptime: 36m Memory: 15.58 GiB used: 1.47 GiB (9.5%)
  Init: systemd runlevel: 5 Compilers: gcc: 8.3.0 Shell: bash v: 5.0.3
  inxi: 3.0.32
Le Wifi marche bien, et l'ethernet fonctionnne très bien sur W7. LMDE me détecte bien le cable, mais le flux sortant est très faible (ne dépasse pas les 300 o/s).
Le problème décrit dans ce sujet https://forums.linuxmint.com/viewtopic.php?t=204951 ressemble au mien, à la différence près que seul le wifi fonctionne.
Avez-vous des pistes de soultions ?
D'avance merci pour votre aide ;)
ITX
PC Portable : ASUS N53SN
Système d'exploitation : [Dualboot] W7 32 bits / LMDE 4 Debbie 64 bits, Cinnamon 4.8.6
Processeur : Intel Core i5-2410M CPU @ 2.30GHz × 2
Carte graphique : NVIDIA Corporation GF108M [GeForce GT 550M]
Carte ethernet : Realtek PCIe GBE Family Controller
ledudulela
Re: Problème Ethernet [LMDE 4]
Message par ledudulela »
bonjour,
en démarrant sur une clé USB bootable LMDE4, as tu des problèmes en ethernet ?
La box internet a-t-elle subit une mise à jour ?
ethernet en IP V4 ou en IP V6 ?
leDuduLéLà - Linux Mint Debian Edition 1 Mate , 2 Mate , 3 Cinnamon , 4 Cinnamon , 5 Cinnamon / 64 bits 6 Cinnamon / 64 bits
ITX
Message par ITX »
Merci pour ta réponse, j'ai vérifié via le W7, l'ethernet est en IPv4, même si il supporte le IPv6 (j'ai deux adresses).
Sinon je suis en résidence étudiante donc pas moyen de savoir si la box à été mise à jour :? , ce qui me sert de wifi, c'est mon téléphone en partage de connexion.
J'ai lancé un session live avec la clé usb qui m'avait servi à installer LMDE (une version plus ancienne donc) et visiblement ça marche.
Ca viendrait donc des pilotes ?
ITX
falke
Message par falke »
salut,
à tout hasard as tu lancé la commande qui a résolu le problème dans le post
que tu as cité :
sudo dpkg --configure -a
ça ne mange pas de pain..
System:
Machine:
ITX
Message par ITX »
EDIT de la modération : merci de ne pas citer le message précédent, si c'est dans son intégralité. Cela n'amène aucune clarté au suivi du sujet :roll:
J'ai réessayé, mais malheureusement ça ne retourne rien du tout 😕
Modifié en dernier par débitant le mer. 3 mars 2021 20:57, modifié 1 fois.
Raison : suppression du quote reprenant le précedent message dans sa totalité
ledudulela
que donne la commande ifconfig ?
ITX
Message par ITX »
La commande ifconfig donne :
docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
        ether 02:42:a5:8e:f3:53  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
enp5s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.106  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::6325:59f6:d19e:7707  prefixlen 64  scopeid 0x20<link>
        ether f4:6d:04:39:11:bc  txqueuelen 1000  (Ethernet)
        RX packets 11884  bytes 4022603 (3.8 MiB)
        TX packets 370  bytes 38330 (37.4 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Boucle locale)
        RX packets 448  bytes 35196 (34.3 KiB)
        TX packets 448  bytes 35196 (34.3 KiB)
ledudulela
et la commande ping -c3 192.168.0.1
ITX
Message par ITX »
Voilà le résultat pour le ping :
portable-linux:~$ ping -c3 192.168.0.1
PING 192.168.0.1 (192.168.0.1) 56(84) bytes of data.
64 bytes from 192.168.0.1: icmp_seq=1 ttl=64 time=0.837 ms
--- 192.168.0.1 ping statistics ---
3 packets transmitted, 1 received, 66.6667% packet loss, time 22ms
rtt min/avg/max/mdev = 0.837/0.837/0.837/0.000 ms
ledudulela
Dans le menu au démarrage de linux, tu as les options avancées,
as tu essayé de démarrer sur un noyau antérieur ?
l'interface réseau docker0, ça te parle ?
https://stackoverflow.com/questions/400 ... ce-docker0
