lenteurs pc et internet
Bosco
Message par Bosco »
Depuis quelques temps j'ai des lenteurs de mon mint.
Certaines fois pour ouvrir des programmes ou des fichiers, ou comme aujourd'hui sur le réseau alors que j'ai la fibre.
Voilà ma config :
System:    Kernel: 5.4.0-66-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Cinnamon 4.8.6
           wm: muffin dm: LightDM Distro: Linux Mint 20.1 Ulyssa base: Ubuntu 20.04 focal
Machine:   Type: Desktop System: LENOVO product: 90G9007KFR v: ideacentre 310S-08ASR
           serial: <filter> Chassis: type: 3 serial: <filter>
           Mobo: LENOVO model: 36F7 v: SDK0J40700 WIN 3258136604115 serial: <filter> UEFI: LENOVO
           v: O2HKT60A date: 03/27/2019
CPU:       Topology: Dual Core model: AMD A9-9425 RADEON R5 5 COMPUTE CORES 2C+3G bits: 64
           type: MCP arch: Excavator L2 cache: 1024 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 12376
           Speed: 2915 MHz min/max: 1400/3100 MHz Core speeds (MHz): 1: 2819 2: 2841
Graphics:  Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Lenovo driver: amdgpu
           v: kernel bus ID: 00:01.0 chip ID: 1002:98e4
           Display: x11 server: X.Org 1.20.9 driver: amdgpu,ati unloaded: fbdev,modesetting,vesa
           resolution: 1920x1080~60Hz
           OpenGL: renderer: AMD STONEY (DRM 3.35.0 5.4.0-66-generic LLVM 11.0.0)
           v: 4.5 Mesa 20.2.6 direct render: Yes
Audio:     Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:01.1
           chip ID: 1002:15b3
           Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 00:09.2 chip ID: 1022:157a
           Sound Server: ALSA v: k5.4.0-66-generic
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
           driver: r8169 v: kernel port: e000 bus ID: 01:00.0 chip ID: 10ec:8168
           IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 1.82 TiB used: 555.98 GiB (29.8%)
           ID-1: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB speed: 6.0 Gb/s
           serial: <filter>
Partition: ID-1: / size: 1.79 TiB used: 555.97 GiB (30.3%) fs: ext4 dev: /dev/sda2
Sensors:   System Temperatures: cpu: 53.5 C mobo: N/A gpu: amdgpu temp: 53 C
           Fan Speeds (RPM): N/A
Repos:     No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/gezakovacs-ppa-focal.list
           1: deb http: //ppa.launchpad.net/gezakovacs/ppa/ubuntu focal main
           1: deb http: //mirror6.layerjet.com/linuxmint/packages ulyssa main upstream import backport
           2: deb http: //mirrors.ircam.fr/pub/ubuntu/archive focal main restricted universe multiverse
           3: deb http: //mirrors.ircam.fr/pub/ubuntu/archive focal-updates main restricted universe multiverse
           4: deb http: //mirrors.ircam.fr/pub/ubuntu/archive focal-backports main restricted universe multiverse
           5: deb http: //security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
           6: deb http: //archive.canonical.com/ubuntu/ focal partner
           Active apt repos in: /etc/apt/sources.list.d/signal-xenial.list
           1: deb [arch=amd64] https: //updates.signal.org/desktop/apt xenial main
           Active apt repos in: /etc/apt/sources.list.d/vivaldi-snapshot.list
           1: deb http: //repo.vivaldi.com/snapshot/deb/ stable main
Info:      Processes: 212 Uptime: 2h 29m Memory: 7.23 GiB used: 2.19 GiB (30.3%) Init: systemd
           v: 245 runlevel: 5 Compilers: gcc: 9.3.0 alt: 7/9 Client: Unknown python3.8 client
           inxi: 3.0.38
Comment faire pour trouver d'où çà vient ?
Merci d'avance,
Bosco
Modifié en dernier par arghlub le ven. 5 mars 2021 18:03, modifié 1 fois.
Raison : ajout de balises [code] au retour de la commande terminal
Linux Mint 19.3
PC Lenovo ideacenter
AMD A9-9425 radeon R5, 5 compute cores 2C+3G × 2
Re: lenteurs pc et internet
Salut Bosco,
J'ai modifié ton dernier message pour mettre les retours du terminal entre balises “Code”.
Il faut utiliser ces balises (sélectionner le code et cliquer sur Image) pour tout ce qui concerne le terminal (commandes, retours de commandes, etc…), cela améliore grandement la lisibilité.
Voir tuto Barre d'outils des messages.
falke
Message par falke »
Possiblement ton module driver Ethernet 8169
Si tu parles de la connection Ethernet.
Tu peux pinger ta box pour vérifier (reboot la avant)
ping -c3 sur l'IP de ta box.
Retourne la résultat
Sujet en cours ici :
viewtopic.php?f=33&t=17622
En résumé ça s'arrange avec Version supérieure de Lm ou bien blacklistage de ce module driver et utilisation d'un autre (solution en fin de sujet)
System:
Machine:
Sujet avec 2 mois ou plus sans réponse ➜ sujet classé et verrouillé.
Si besoin de le rouvrir, envoyer un MP à un membre de l'équipe.
