DVD illisible avec VLC
sam_49
Message par sam_49 »
Bonjour comme l'indique le titre il m'est impossible de lire des DVD avec vlc meme en mode console.
Je l'ai reinstallé mais avec le même probleme. J'utilise un autre logiciel pour depanner (celluloid) mais je le trouve pas excellent.
Voici l’état du problème :
samuel@samuel-H110M-S2PV:~$ vlc
VLC media player 3.0.9.2 Vetinari (revision 3.0.9.2-0-gd4c1aefe4d)
[000055d22f4735b0] main libvlc: Lancement de vlc avec l'interface par défaut. Utiliser « cvlc » pour démarrer VLC sans interface.
qt5ct: using qt5ct plugin
qt5ct: D-Bus global menu: no
qt5ct: D-Bus system tray: yes
[000055d22f50d610] main playlist: playlist is empty
libdvdnav: Using dvdnav version 6.0.1
libdvdnav: DVD Title: RUE_DES_ORMES
libdvdnav: DVD Serial Number: 3D04A933APPLEDSP
libdvdnav: DVD Title (Alternative): RUE_DES_ORMES
libdvdnav: DVD disk reports itself with Region mask 0x00fd0000. Regions: 2
libdvdread: Attempting to retrieve all CSS keys
libdvdread: This can take a _long_ time, please be patient
libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x00000160
libdvdread: Elapsed time 0
libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x000001e0
libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x0000c3e3
libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x002cec70
libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x002cecbd
libdvdread: Get key for /VIDEO_TS/VTS_03_0.VOB at 0x002cfb51
libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x002cfb9e
libdvdread: Get key for /VIDEO_TS/VTS_04_0.VOB at 0x002d7a5a
libdvdread: Get key for /VIDEO_TS/VTS_04_1.VOB at 0x002d7aa7
libdvdread: Get key for /VIDEO_TS/VTS_05_0.VOB at 0x002e1946
libdvdread: Get key for /VIDEO_TS/VTS_05_1.VOB at 0x002e1993
libdvdread: Get key for /VIDEO_TS/VTS_06_0.VOB at 0x002e81cd
libdvdread: Get key for /VIDEO_TS/VTS_06_1.VOB at 0x002e821a
libdvdread: Get key for /VIDEO_TS/VTS_07_0.VOB at 0x002f1968
libdvdread: Get key for /VIDEO_TS/VTS_07_1.VOB at 0x002f19b5
libdvdread: Get key for /VIDEO_TS/VTS_08_0.VOB at 0x00307442
libdvdread: Get key for /VIDEO_TS/VTS_08_1.VOB at 0x0030748f
libdvdread: Get key for /VIDEO_TS/VTS_09_0.VOB at 0x0031ab34
libdvdread: Get key for /VIDEO_TS/VTS_09_1.VOB at 0x0031ab81
libdvdread: Get key for /VIDEO_TS/VTS_10_0.VOB at 0x0032f5d7
libdvdread: Get key for /VIDEO_TS/VTS_10_1.VOB at 0x0032f624
libdvdread: Found 10 VTS's
libdvdnav: Language 'en' not found, using 'fr' instead
libdvdnav: Menu Languages available: fr
[000055d22f52efe0] main audio output error: too low audio sample frequency (0)
[00007f1f181add30] main decoder error: failed to create audio output
[000055d22f52efe0] vlcpulse audio output error: digital pass-through stream connection failure: Non pris en charge
[000055d22f52efe0] main audio output error: module not functional
libva info: VA-API version 1.7.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/r600_drv_video.so
libva info: Found init function __vaDriverInit_1_7
libva info: va_openDriver() returns 0
[00007f1f1000b4b0] glconv_vaapi_x11 gl error: vaDeriveImage: operation failed
[000055d22f5814e0] main video output error: video output creation failed
[00007f1f180693e0] main decoder error: failed to create video output
[00007f1f180693e0] avcodec decoder: Using G3DVL VDPAU Driver Shared Library version 1.0 for hardware decoding
[00007f1f14000c80] main input error: ES_OUT_SET_(GROUP_)PCR  is called too late (pts_delay increased to 300 ms)
si vous avez une solution pour faire fonctionner VLC ou alors si vous avez des suggestions de logiciel pour remplacer et qui me permette de lire DVD et Blu-ray je suis preneur
Host: samuel-H110M-S2PV Kernel: 5.4.0-73-generic x86_64 bits: 64 Desktop: Cinnamon 4.8.6 Distro: Linux Mint 20.1 Ulyssa
Mobo: Gigabyte model: H110M-S2PV-CF -Topology: Dual Core model: Intel Pentium G4400 - ID-1: /dev/sda vendor: PNY model: CS900 480GB SSD size: 447.13 GiB ID-2: /dev/sdb vendor: Samsung model: HD103UJ size: 931.51 GiB ID-3: /dev/sdc vendor: Seagate model: ST380013AS size: 74.53 GiB ID-4: /dev/sdd vendor: Western Digital model: WD10EADS-65M2B0 size: 931.51 GiB
Re: DVD illisible avec VLC
Hello
Essaie d'installer ces codecs
sudo apt install ubuntu-restricted-extras
sam_49
Merci, j'essaye et je te redis ce qu'il en est
sam_49
sam_49 a écrit :
sam. 19 juin 2021 18:45
Aucun changement
[000056499839d5b0] main libvlc: Lancement de vlc avec l'interface par défaut. Utiliser « cvlc » pour démarrer VLC sans interface.
[0000564998437610] main playlist: playlist is empty
[0000564998458fe0] main audio output error: too low audio sample frequency (0)
[00007f29281da890] main decoder error: failed to create audio output
[0000564998458fe0] vlcpulse audio output error: digital pass-through stream connection failure: Non pris en charge
[0000564998458fe0] main audio output error: module not functional
[00007f2920009b40] glconv_vaapi_x11 gl error: vaDeriveImage: operation failed
[00005649984c82d0] main video output error: video output creation failed
[00007f29280694f0] main decoder error: failed to create video output
[00007f29280694f0] avcodec decoder: Using G3DVL VDPAU Driver Shared Library version 1.0 for hardware decoding
as tu testé avec smplayer (mon lecteur favori, une inteface graphique de mplayer légère et ultra-configurable), pour l'installer :
sudo apt install smplayer smplayer-l10n smplayer-themes
sam_49
En effet smplayer est pas mal par contre pas encore trouvé l'actuce pour acceder au menu principal ( ca me lance direct le film)
D'après la FAQ de smplayer : https://www.smplayer.info/faq.php
Allez dans « Préférences -> Lecteurs » et activez l'option « Activer les menus DVD (expérimental) ».
Je n'utilise plus de DVD depuis des années donc je ne peux pas tester à ta place.
sam_49
arghlub a écrit :
sam. 19 juin 2021 21:07
c'est déjà bien d'avoir trouvé ça :D
