Résolu le 15-12-21 Connexion Wi-Fi
Anne-Neige
Connexion Wi-Fi
Message par Anne-Neige »
Bonsoir tout le monde,
En plus de mon PC avec Ubuntu, j'ai un petit Asus sur lequel j'ai installé Linux Mint 18.3 Sylvia (ce petit appareil me sert essentiellement pour écrire).
En voici les spécifications :
anneneige@anneneige-1000H ~ $ inxi -F -v 7
System:    		Host: anneneige-1000H Kernel: 4.10.0-38-generic i686 (32 bit gcc: 5.4.0)
           			Desktop: MATE 1.18.0 (Gtk 3.18.9-1ubuntu3.3) info: mate-panel dm: lightdm
           			Distro: Linux Mint 18.3 Sylvia
Machine:   		System: ASUSTeK (portable) product: 1000H v: x.x
          			Mobo: ASUSTeK model: 1000H v: x.xx
           			Bios: American Megatrends v: 1501 date: 02/04/2009
           			Chassis: ASUSTek type: 10 v: x.x
CPU:       		Single core Intel Atom N270 (-HT-) cache: 512 KB
           			flags: (nx pae sse sse2 sse3 ssse3) bmips: 3192
           			clock speeds: min/max: 800/1600 MHz 1: 800 MHz 2: 1333 MHz
Memory:    		No dmidecode memory data: try newer kernel.
Graphics:  		Card: Intel Mobile 945GSE Express Integrated Graphics Controller bus-ID: 00:02.0 chip-ID: 8086:27ae
           			Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa)
           			Resolution: 1024x600@60.00hz
           			GLX Renderer: Mesa DRI Intel 945GME x86/MMX/SSE2
           			GLX Version: 1.4 Mesa 17.0.7 Direct Rendering: Yes
Audio:     		Card Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:27d8
           			Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
Network:   		Card-1: Ralink RT2790 Wireless 802.11n 1T/2R PC Ie driver: rt2800pci v: 2.3.0 bus-ID: 01:00.0 chip-ID: 1814:0781
           			IF: wlp1s0 state: up mac: 00:15:af:d9:dd:b6
           			Card-2: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
driver: ATL1E port: ec00 bus-ID: 03:00.0 chip-ID: 1969:1026
           			IF: enp3s0 state: down mac: 00:24:8c:27:cc:ae
           			WAN IP: 91.164.116.161
           			IF: wlp1s0 ip-v4: 192.168.0.12 ip-v6: fe80::b466:c4f5:dd31:858
           			IF: enp3s0 ip-v4: N/A ip-v6: N/A
Drives:    		HDD Total Size: 160.0GB (4.6% used)
           			ID-1: /dev/sda model: ST9160310AS size: 160.0GB serial: 5SV32R42
           			Optical: No optical drives detected.
Partition: 		ID-1: / size: 146G used: 6.0G (5%) fs: ext4 dev: /dev/sda1
          			label: N/A uuid: e84fa8a2-cafd-4c09-9adf-aa9a3e152bde
           			ID-2: swap-1 size: 1.06GB used: 0.01GB (1%) fs: swap dev: /dev/sda5
           			label: N/A uuid: 58cc735e-db57-419c-bdab-28ce2150e418
RAID:      		System: supported: N/A
          			No RAID devices: /proc/mdstat, md_mod kernel module present
           			Unused Devices: none
Unmounted: 	No unmounted partitions detected
Sensors:   		System Temperatures: cpu: 53.0C mobo: N/A
           			Fan Speeds (in rpm): cpu: 1300
Info:      		Processes: 159 Uptime: 2:56 Memory: 510.3/2004.1MB
           			Init: systemd v: 229 runlevel: 5 default: 2 Gcc sys: 5.4.0
           			Client: Shell (bash 4.3.481 running in mate-terminal) inxi: 2.2.35
Il y a quelques temps, j'arrivais à me connecter en wi-fi mais à présent, je n'y arrive plus et je me connecte donc avec le câble Ethernet.... et voici ce que cela donne : https://i.postimg.cc/9fn7K73w/Connexion ... hernet.png
Est-ce que quelqu'un·e pourrait me décrire la marche à suivre pour me connecter au wi-fi ?
Merci d'avance,
Anne-Neige
Modifié en dernier par Anne-Neige le mer. 13 oct. 2021 12:40, modifié 1 fois.
MATE 1.18.0 Distro: Linux Mint 18.3 Sylvia
4.10.0-38-generic i686 (32 bit)
Processes: 157 Uptime: 31 min Memory: 930.3/2004.8MB
Re: Connexion Wi-Fi
Bonjour Anne-Neige.
Ceci semble bon :
C'est ta carte wifi et son pilote.
Peux tu donner le retour de :
rfkill list
Tux03
Re: Connexion Wi-Fi
Message par Tux03 »
HI, et de :
iwconfig
Anne-Neige
Re: Connexion Wi-Fi
Voici le retour de la commande rfkill list :
anneneige@anneneige-1000H ~ $ rfkill list
0: eeepc-wlan: Wireless LAN
	Soft blocked: yes
	Hard blocked: no
1: eeepc-bluetooth: Bluetooth
	Soft blocked: no
	Hard blocked: no
2: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
Et le retour pour la commande iwconfig :
anneneige@anneneige-1000H ~ $ iwconfig
enp3s0    no wireless extensions.
lo        no wireless extensions.
J'espère que cela pourra vous aider.....
Quoiqu'il en soit merci de pendre en compte ma demande.
Re: Connexion Wi-Fi
vas-y avec ça :
sudo rfkill unblock all
Anne-Neige
Re: Connexion Wi-Fi
Bonjour tout le monde,
Ravie de vous retrouver....
La commande
l ne renvoie rien du tout...
anneneige@anneneige-1000H ~ $ sudo rfkill unblock all
[sudo] Mot de passe de anneneige :
Peut-être faut-il installer sudo ?
Robinwood
Re: Connexion Wi-Fi
Message par Robinwood »
"sudo" est par défaut sur linuxmint ;) .
Après:
que retourne:
rfkill list
Tu devrais faire une signature pour que l'on sache le modèle de ton pc et la version de linux ;) :
viewtopic.php?f=2&t=1514
Certains pc ont une interrupteur physique pour le wifi.
Intel nuc8i3phn Linux mint cinnamon
Firefox Audacious
Anne-Neige
Re: Connexion Wi-Fi
Voici le résultat :
	Soft blocked: no
	Hard blocked: no
	Soft blocked: no
	Hard blocked: no
2: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
3: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
J'ai fait la signature mais je n'ai pas utilisé les couleurs, c'est grave ?
Robinwood
Re: Connexion Wi-Fi
Pas de soucis et merci ;) .
D'après tes résultats de commandes, le wifi devrait pouvoir marcher, testes et dis nous.
Firefox Audacious
Robinwood
Re: Connexion Wi-Fi
Tu as du appuyer par mégarde sur Fn + F2, qui désactive le wifi sur ce pc asus ;) .
Firefox Audacious
