System:
Kernel: 5.15.0-56-generic x86_64 bits: 64 compiler: gcc v: 11.3.0 Desktop: Cinnamon 5.4.12
tk: GTK 3.24.33 wm: Mutter dm: LightDM Distro: Linux Mint 21 Vanessa base: Ubuntu 22.04 jammy
Machine:
Type: Desktop Mobo: Micro-Star model: MPG Z390 GAMING PRO CARBON (MS-7B17) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.60 date: 08/08/2019
CPU:
Info: 8-core model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake rev: D cache:
L1: 512 KiB L2: 2 MiB L3: 16 MiB
Speed (MHz): avg: 4724 high: 4800 min/max: 800/5000 cores: 1: 4780 2: 4767 3: 4702 4: 4699
5: 4700 6: 4700 7: 4700 8: 4700 9: 4700 10: 4700 11: 4800 12: 4796 13: 4738 14: 4702 15: 4700
16: 4700 bogomips: 115200
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: Micro-Star MSI driver: nvidia
v: 515.86.01 pcie: speed: 2.5 GT/s lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2216
Device-2: Logitech Webcam C170 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3.2:9
chip-ID: 046d:082b
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 90
Monitor-1: HDMI-0 res: 1920x1080 dpi: 90 diag: 623mm (24.5")
OpenGL: renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2 v: 4.6.0 NVIDIA 515.86.01
direct render: Yes
Audio:
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a348
Device-2: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:1aef
Device-3: Logitech Webcam C170 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-3.2:9
chip-ID: 046d:082b
Sound Server-1: ALSA v: k5.15.0-56-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15bc
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: speed: 5 GT/s lanes: 1
bus-ID: 6f:00.0 chip-ID: 8086:2723
IF: wlp111s0 state: up mac: <filter>
Drives:
Local Storage: total: 12.74 TiB used: 2.99 TiB (23.5%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 4TB size: 3.64 TiB speed: 6.0 Gb/s
serial: <filter>
ID-2: /dev/sdb vendor: Seagate model: ST4000DM004-2CV104 size: 3.64 TiB speed: 6.0 Gb/s
serial: <filter>
ID-3: /dev/sdc vendor: Samsung model: SSD 870 EVO 4TB size: 3.64 TiB speed: 6.0 Gb/s
serial: <filter>
ID-4: /dev/sdd vendor: Crucial model: CT2000MX500SSD1 size: 1.82 TiB speed: 6.0 Gb/s
serial: <filter>
Partition:
ID-1: / size: 3.58 TiB used: 945.87 GiB (25.8%) fs: ext4 dev: /dev/sdc2
ID-2: /boot/efi size: 96 MiB used: 34 MiB (35.4%) fs: vfat dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Sensors:
System Temperatures: cpu: 27.8 C pch: 42.0 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Repos:
Packages: apt: 2649
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/microsoft-edge.list
1: deb [arch=amd64] https: //packages.microsoft.com/repos/edge/ stable main
1: deb http: //packages.linuxmint.com vanessa main upstream import backport
2: deb http: //archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
3: deb http: //archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
4: deb http: //archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
Active apt repos in: /etc/apt/sources.list.d/winehq-jammy.sources
1: deb [arch=amd64 i386] https: //dl.winehq.org/wine-builds/ubuntu jammy main
Info:
Processes: 394 Uptime: 26m Memory: 62.74 GiB used: 5.93 GiB (9.5%) Init: systemd v: 249
runlevel: 5 Compilers: gcc: 11.3.0 alt: 11 Client: Cinnamon v: 5.4.12 inxi: 3.3.13Le nvidia-driver-525-open pas de son
Le nvidia-driver-525 Out Of Mémory
Il n'y as que le nvidia-driver-515 qui fonctionne a peu prêt (malgré parfois des grésillements dans le son).
Je précise que sur Ubuntu 22.10 il me la installé sans problème (la nvidia-driver-525 )
