Lorsque j'allume mon ordinateur, mon IP local est 192.168.1.46 et mon Broadcast (DNS) est 192.168.1.255 automatiquement!
Je PING mon routeur 192.168.1.1 et cela fonctionne parfaitement!
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=3.87 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=3.79 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=7.32 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=3.85 ms
64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=3.86 ms
--- 192.168.1.1 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4007ms
rtt min/avg/max/mdev = 3.785/4.535/7.318/1.391 ms
J'utilise donc,
ifconfig enp1s0 192.168.1.83 netmask 255.255.255.0 broadcast 192.168.1.255
enp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.83 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 2a02:8429:3e6:ca01:bf4f:35b5:65b8:b3f4 prefixlen 64 scopeid 0x0<global>
inet6 fe80::36:a0c7:4278:4219 prefixlen 64 scopeid 0x20<link>
inet6 2a02:8429:3e6:ca01:9428:a543:6b6:2359 prefixlen 64 scopeid 0x0<global>
ether 48:5b:39:d8:02:29 txqueuelen 1000 (Ethernet)
RX packets 20537 bytes 27931034 (27.9 MB)
RX errors 0 dropped 946 overruns 0 frame 0
TX packets 9870 bytes 1209141 (1.2 MB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Boucle locale)
RX packets 421 bytes 51161 (51.1 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 421 bytes 51161 (51.1 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0Je PING mon routeur 192.168.1.1 et cela ne fonctionne plus!
ping: connect: Le réseau n'est pas accessibleAi-je loupé quelques choses?
J'aimerai créer un petit Script Q/R pour changer mon IP et DNS facilement...
Pouvez vous m'aider à changer mon IP local?
Merci,
