Pas de son après installation linux mint
Oirimi
Message par Oirimi »
je suis débutant et vient d'installer linux mint 21.2 sur un Acer Aspire Nitro; Cela marche bien à part que je n'ai pas de son. Qui peut m'aider ? Merci
System:
  Kernel: 5.15.0-82-generic x86_64 bits: 64 compiler: gcc v: 11.4.0 Desktop: Cinnamon 5.8.4
    tk: GTK 3.24.33 wm: muffin dm: LightDM Distro: Linux Mint 21.2 Victoria base: Ubuntu 22.04 jammy
Machine:
  Type: Laptop System: Acer product: Aspire VN7-572G v: V1.05 serial: <superuser required>
  Mobo: Acer model: Aspire VN7-572G v: V1.05 serial: <superuser required> UEFI-[Legacy]: Insyde
    v: 1.05 date: 09/25/2015
Battery:
  ID-1: BAT0 charge: 36.0 Wh (80.0%) condition: 45.0/52.5 Wh (85.7%) volts: 12.7 min: 11.4
    model: LGC AC14A8L serial: <filter> status: Charging
CPU:
  Info: dual core model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake rev: 3 cache:
    L1: 128 KiB L2: 512 KiB L3: 3 MiB
  Speed (MHz): avg: 2299 high: 2300 min/max: 400/2800 cores: 1: 2300 2: 2300 3: 2300 4: 2298
    bogomips: 19200
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Acer Incorporated ALI driver: i915
    v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
  Device-2: NVIDIA GM107M [GeForce GTX 950M] vendor: Acer Incorporated ALI driver: nouveau
    v: kernel pcie: speed: 2.5 GT/s lanes: 4 bus-ID: 01:00.0 chip-ID: 10de:139a
  Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:11 chip-ID: 04f2:b526
  Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: modesetting unloaded: fbdev,vesa
    gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96
  Monitor-1: eDP-1 model: LG res: 1920x1080 dpi: 141 diag: 396mm (15.6")
  OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 23.0.4-0ubuntu1~22.04.1
    direct render: Yes
Audio:
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI driver: snd_soc_skl
    v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d70
  Sound Server-1: ALSA v: k5.15.0-82-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI
    driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
    chip-ID: 10ec:8168
  IF: enp2s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Lite-On
    driver: ath10k_pci v: kernel pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:003e
  IF: wlp3s0 state: down mac: <filter>
  Device-3: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153] type: USB
    driver: r8152 bus-ID: 1-1.4:4 chip-ID: 2357:0601
  IF: enx503eaa81c67c state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
  Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-5:5 chip-ID: 04ca:3016
  Report: hciconfig ID: hci0 rfk-id: 5 state: up address: <filter> bt-v: 2.1 lmp-v: 4.2
    sub-v: 25a
Drives:
  Local Storage: total: 931.51 GiB used: 35.55 GiB (3.8%)
  ID-1: /dev/sda vendor: Western Digital model: WD10JPVX-22JC3T0 size: 931.51 GiB
    speed: 6.0 Gb/s serial: <filter>
Partition:
  ID-1: / size: 915.32 GiB used: 35.55 GiB (3.9%) fs: ext4 dev: /dev/sda3
  ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda2
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 940 KiB (0.0%) priority: -2 file: /swapfile
Sensors:
  System Temperatures: cpu: 49.0 C pch: 45.5 C mobo: 42.0 C gpu: nouveau temp: 43.0 C
  Fan Speeds (RPM): N/A
Repos:
  Packages: apt: 2287
  No active apt repos in: /etc/apt/sources.list
    1: deb http: //packages.linuxmint.com victoria main upstream import backport
    2: deb http: //archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
    3: deb http: //archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
    4: deb http: //archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
    5: deb http: //security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
Info:
  Processes: 242 Uptime: 23h 13m Memory: 7.67 GiB used: 4.07 GiB (53.0%) Init: systemd v: 249
  runlevel: 5 Compilers: gcc: 11.4.0 alt: 11/12 Client: Cinnamon v: 5.8.4 inxi: 3.3.13
rmik
Re: Pas de son après installation linux mint
Message par rmik »
Peut-être paramètres systeme puis matériel, son, périphériques et choisir Line out
Linux Mint 20.3| Cinnamon | 5.4.0-135-generic x86_64 |Dual Core Intel Core i3-4160 | 16 GO|
Intel HD Graphics 4400 | CM: Gigabyte model: B85M-HD3 |
Hello,
mis en balises code [</>] :)
Penses-y la prochaine fois ;)
Pis, une tite signure serait sympa pour les aidants :)
regarde là => signature utile ;)
Oirimi
Merci de la réponse mais je ne comprends rien ?
michLapprenti
Message par michLapprenti »
Oirimi a écrit : dim. 3 sept. 2023 11:02 je n'ai pas de son.
Audio:
Les outils qui génèrent le son semblent installés
-------------------------------------------------------------(si je me trompe, que les connaisseurs me corrigent)
Aussi je te suggère de lire ce post :arrow: viewtopic.php?p=224196#p224196
Distrib : Linux Mint 22.3 Desktop : X-Cinnamon Lenovo T480S - SSD 500go
Kernel : 6.17.0-35-generic CPU : Intel(R) Core(TM) i5-8350U CPU @ 1.70GHz
RAM : 15Gi CG : Intel Corporation UHD Graphics 620 (rev 07)
