bonjour, depuis 4/5jours j'ai ce message au démarrage tout fonctionne parfaitement pourtant...pouvez vous m'expliquer de quoi il retourne (et éventuellement comment y remédier...sachant que je ne suis pas trop informaticien....merci.
GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Distrib : Linux Mint 21.3 Desktop : X-Cinnamon
Kernel : 5.15.0-107-generic CPU : AMD A10-6790K APU with Radeon(tm) HD Graphics RAM : 15Gi
CG : NVIDIA Corporation GM107 [GeForce GTX 750 Ti] (rev a2)
Re: org.freedesktop.DBus.Error.NoReply
bonjour, merci pour la réponse:
[ 3.089677] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 6.276231] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro. Quota mode: none.Distrib : Linux Mint 21.3 Desktop : X-Cinnamon
message du journal:10:54:05 kernel: [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
07:48:55 pulseaudio: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
07:48:34 hp-systray: hp-systray(qt5)[1762]: error: Unable to find hp-upgrade --notify on PATH.
07:48:30 colord-sane: io/hpmud/musb.c 2101: Invalid usb_open: Permission denied
07:48:30 kernel: [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
07:48:28 systemd: Failed to start casper-md5check Verify Live ISO checksums.
07:47:55 kernel: usb 6-1: Failed to query (GET_INFO) UVC control 2 on unit 1: -32 (exp. 1).
07:47:55 kernel:
Modifié en dernier par cyrille le mer. 3 juil. 2024 16:32, modifié 1 fois.
Raison : Ajout balises code
bonjour, merci pour l'accompagnement . j'ai essayé la 1er solution...le problème revient donc ne fonctionne pas ...pour la seconde :cp /usr/share/gdm/default.pa ~/.config/pulse/
cp: impossible d'évaluer '/usr/share/gdm/default.pa': Aucun fichier ou dossier de ce nom ...
pour l'ajout : ### unload driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
unload-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
unload-module module-bluetooth-discover
.endif
.ifexists : commande introuvable
unload-module : commande introuvable
.endif : commande introuvable
.endif
.endif
j'ai refais la commande pour voir ça donne : sudo apt-get remove --auto-remove pulseaudio-module-bluetooth
[sudo] Mot de passe de ange :
Le paquet « pulseaudio-module-bluetooth » n'est pas installé, et ne peut donc être supprimé
par contre si je rallume l'ordi ça me refait le même message que la première fois. donc ça n'a pas changer le problème....une idée ?
ok trouvé....on sauvegarde comment ( il n'y a pas (edited) dans le compte rendu... normal ? 60 .nofail
61 load-module module-jackdbus-detect channels=2
62 .fail
63 .endif
64
65 ### Automatically load driver modules for Bluetooth hardware
66 .ifexists module-bluetooth-policy.so
67 load-module module-bluetooth-policy
68 .endif
69
70 .ifexists module-bluetooth-discover.so
71 load-module module-bluetooth-discover
72 .endif
73
74 ### Load several protocols
75 .ifexists module-esound-protocol-unix.so
76 load-module module-esound-protocol-unix
77 .endif
78 load-module module-native-protocol-unix
79
80 ### Network access (may be configured with paprefs, so leave this commented
81 ### here if you plan to use paprefs)
82 #load-module module-esound-protocol-tcp
83 #load-module module-native-protocol-tcp
84 #load-module module-zeroconf-publish
Modifié en dernier par alain le jeu. 4 juil. 2024 14:29, modifié 1 fois.
Raison : mise en place de la balise code
