Résolu le 26-09-24 Wifi qui ne fonctionne pas linux Mint
hubbubhum
Message par hubbubhum »
Le bouton d'activation du wifi ne fonctionne pas : il est en grisé et ne peut être activé.
mes infos :
Linux ******-Inspiron-3721 6.8.0-45-generic #45-Ubuntu SMP PREEMPT_DYNAMIC Fri Aug 30 12:02:04 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
et pour la carte wifi :
00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.1 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation HM76 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 05)
02:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
la réponse à
inxi -Fxxxz && rfkill list && mokutil --sb-state
est :
System:
  Kernel: 6.8.0-45-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
    clocksource: tsc
  Desktop: Cinnamon v: 6.2.9 tk: GTK v: 3.24.41 wm: Muffin v: 6.2.0 vt: 7
    dm: LightDM v: 1.30.0 Distro: Linux Mint 22 Wilma base: Ubuntu 24.04 noble
Machine:
  Type: Portable System: Dell product: Inspiron 3721 v: A14
    serial: <superuser required> Chassis: type: 8 v: A14
  Mobo: Dell model: 07PX56 v: A00 serial: <superuser required>
    part-nu: Inspiron 3721 uuid: <superuser required> UEFI: Dell v: A14
    date: 07/31/2015
Battery:
  ID-1: BAT1 charge: 12.9 Wh (100.0%) condition: 12.9/41.4 Wh (31.2%)
    volts: 16.9 min: 14.8 model: SDI DELL XRDW235N type: Unknown
    serial: <filter> status: full
CPU:
  Info: dual core model: Intel Core i3-3227U bits: 64 type: MT MCP
    smt: enabled arch: Ivy Bridge rev: 9 cache: L1: 128 KiB L2: 512 KiB
    L3: 3 MiB
  Speed (MHz): avg: 799 high: 800 min/max: 800/1900 cores: 1: 800 2: 800
    3: 798 4: 800 bogomips: 15164
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
    v: kernel arch: Gen-7 ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  Device-2: Realtek Integrated Webcam HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 bus-ID: 1-1.4:4 chip-ID: 0bda:58c2 class-ID: 0e02
    serial: <filter>
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
    loaded: modesetting unloaded: fbdev,vesa dri: crocus gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
    s-diag: 485mm (19.11")
  Monitor-1: LVDS-1 model: Seiko Epson 0x544b res: 1600x900 hz: 60 dpi: 106
    size: 382x215mm (15.04x8.46") diag: 438mm (17.3") modes: 1600x900
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
    inactive: gbm,wayland
  API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 24.0.9-0ubuntu0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB
    GT2) device-ID: 8086:0166
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell 7
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  API: ALSA v: k6.8.0-45-generic status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
Network:
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
    driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: 2000
    bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
  IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
    vendor: Dell driver: ath9k v: kernel pcie: speed: 2.5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
  IF: wlp2s0 state: down mac: <filter>
Drives:
  Local Storage: total: 698.64 GiB used: 12.47 GiB (1.8%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABD075 size: 698.64 GiB
    speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter> fw-rev: 2D scheme: GPT
Partition:
  ID-1: / size: 686.11 GiB used: 12.47 GiB (1.8%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
Sensors:
  System Temperatures: cpu: 51.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2600
Info:
  Memory: total: 6 GiB available: 5.67 GiB used: 2.14 GiB (37.8%)
  Processes: 232 Power: uptime: 35m states: freeze,mem,disk suspend: deep
    wakeups: 0 hibernate: platform Init: systemd v: 255 target: graphical (5)
    default: graphical
  Packages: pm: dpkg pkgs: 1955 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21
    running-in: gnome-terminal inxi: 3.3.34
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: yes
SecureBoot disabled
Merci pour votre aide !
hubbubhum
Re: Wifi qui ne fonctionne pas linux Mint
et en réponse à
sudo desmg
j'ai ça :
[    0.000000] Linux version 6.8.0-45-generic (buildd@lcy02-amd64-115) (x86_64-linux-gnu-gcc-13 (Ubuntu 13.2.0-23ubuntu4) 13.2.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #45-Ubuntu SMP PREEMPT_DYNAMIC Fri Aug 30 12:02:04 UTC 2024 (Ubuntu 6.8.0-45.45-generic 6.8.12)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.8.0-45-generic root=UUID=12db4868-764a-4e8e-8cd9-75ec38e04532 ro quiet splash
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Hygon HygonGenuine
[    0.000000]   Centaur CentaurHauls
[    0.000000]   zhaoxin   Shanghai
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000087fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000088000-0x00000000000bffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000040005000-0x00000000a0baffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000a0bb0000-0x00000000a13affff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000a13b0000-0x00000000a9dbefff] usable
[    0.000000] BIOS-e820: [mem 0x00000000a9dbf000-0x00000000aaebefff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000aaebf000-0x00000000aafbefff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000aafbf000-0x00000000aaffefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000aafff000-0x00000000aaffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000ab000000-0x00000000af9fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000feb00000-0x00000000feb03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ffb80000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000001cf5fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] e820: update [mem 0x9e86f018-0x9e87f057] usable ==> usable
[    0.000000] e820: update [mem 0x9e863018-0x9e86e057] usable ==> usable
[    0.000000] extended physical RAM map:
[    0.000000] reserve setup_data: [mem 0x0000000000000000-0x0000000000087fff] usable
[    0.000000] reserve setup_data: [mem 0x0000000000088000-0x00000000000bffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000000100000-0x000000001fffffff] usable
[    0.000000] reserve setup_data: [mem 0x0000000020000000-0x00000000201fffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000020200000-0x0000000040003fff] usable
[    0.000000] reserve setup_data: [mem 0x0000000040004000-0x0000000040004fff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000040005000-0x000000009e863017] usable
[    0.000000] reserve setup_data: [mem 0x000000009e863018-0x000000009e86e057] usable
[    0.000000] reserve setup_data: [mem 0x000000009e86e058-0x000000009e86f017] usable
[    0.000000] reserve setup_data: [mem 0x000000009e86f018-0x000000009e87f057] usable
[    0.000000] reserve setup_data: [mem 0x000000009e87f058-0x00000000a0baffff] usable
[    0.000000] reserve setup_data: [mem 0x00000000a0bb0000-0x00000000a13affff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000a13b0000-0x00000000a9dbefff] usable
[    0.000000] reserve setup_data: [mem 0x00000000a9dbf000-0x00000000aaebefff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000aaebf000-0x00000000aafbefff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x00000000aafbf000-0x00000000aaffefff] ACPI data
[    0.000000] reserve setup_data: [mem 0x00000000aafff000-0x00000000aaffffff] usable
[    0.000000] reserve setup_data: [mem 0x00000000ab000000-0x00000000af9fffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000feb00000-0x00000000feb03fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000ffb80000-0x00000000ffffffff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000100000000-0x00000001cf5fffff] usable
[    0.000000] efi: EFI v2.3.1 by INSYDE Corp.
[    0.000000] efi: ACPI=0xaaffe000 ACPI 2.0=0xaaffe014 SMBIOS=0xaaebef98 MOKvar=0xaa2b0000 INITRD=0xa13be898
[    0.000000] efi: Remove mem60: MMIO range=[0xe0000000-0xefffffff] (256MB) from e820 map
[    0.000000] e820: remove [mem 0xe0000000-0xefffffff] reserved
[    0.000000] efi: Not removing mem61: MMIO range=[0xfeb00000-0xfeb03fff] (16KB) from e820 map
[    0.000000] efi: Not removing mem62: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem63: MMIO range=[0xfed10000-0xfed19fff] (40KB) from e820 map
[    0.000000] efi: Not removing mem64: MMIO range=[0xfed1c000-0xfed1ffff] (16KB) from e820 map
[    0.000000] efi: Not removing mem65: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[    0.000000] efi: Remove mem66: MMIO range=[0xffb80000-0xffbfffff] (0MB) from e820 map
[    0.000000] e820: remove [mem 0xffb80000-0xffbfffff] reserved
[    0.000000] efi: Remove mem67: MMIO range=[0xffc00000-0xffefffff] (3MB) from e820 map
[    0.000000] e820: remove [mem 0xffc00000-0xffefffff] reserved
[    0.000000] efi: Remove mem68: MMIO range=[0xfff00000-0xfff3ffff] (0MB) from e820 map
[    0.000000] e820: remove [mem 0xfff00000-0xfff3ffff] reserved
[    0.000000] efi: Remove mem69: MMIO range=[0xfff40000-0xffffffff] (0MB) from e820 map
[    0.000000] e820: remove [mem 0xfff40000-0xffffffff] reserved
[    0.000000] secureboot: Secure boot disabled
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: Dell Inc. Inspiron 3721/07PX56, BIOS A14 07/31/2015
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 1895.625 MHz processor
[    0.000408] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000414] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000431] last_pfn = 0x1cf600 max_arch_pfn = 0x400000000
[    0.000442] MTRR map: 10 entries (5 fixed + 5 variable; max 25), built from 10 variable MTRRs
[    0.000446] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000876] last_pfn = 0xab000 max_arch_pfn = 0x400000000
[    0.038345] secureboot: Secure boot disabled
[    0.038347] RAMDISK: [mem 0x96f79000-0x9b518fff]
[    0.039150] ACPI: Early table checksum verification disabled
[    0.039155] ACPI: RSDP 0x00000000AAFFE014 000024 (v02 DELL  )
[    0.039162] ACPI: XSDT 0x00000000AAFFE210 0000A4 (v01 DELL   CL09     00000001      01000013)
[    0.039173] ACPI: FACP 0x00000000AAFFA000 00010C (v05 DELL   CL09     00000001 ASL  00040000)
[    0.039184] ACPI: DSDT 0x00000000AAFED000 009332 (v01 DELL   CL09     00000000 ASL  00040000)
[    0.039191] ACPI: FACS 0x00000000AAFB9000 000040
[    0.039196] ACPI: SLIC 0x00000000AAFFD000 000176 (v01 DELL   CL09     00000001 ASL  00040000)
[    0.039202] ACPI: UEFI 0x00000000AAFFC000 000236 (v01 DELL   CL09     00000001 ASL  00040000)
[    0.039208] ACPI: ASF! 0x00000000AAFFB000 0000A5 (v32 DELL   CL09     00000001 ASL  00040000)
[    0.039215] ACPI: HPET 0x00000000AAFF9000 000038 (v01 DELL   CL09     00000001 ASL  00040000)
[    0.039221] ACPI: APIC 0x00000000AAFF8000 00008C (v03 DELL   CL09     00000001 ASL  00040000)
[    0.039226] ACPI: MCFG 0x00000000AAFF7000 00003C (v01 DELL   CL09     00000001 ASL  00040000)
[    0.039232] ACPI: SLIC 0x00000000AAFEC000 000176 (v01 DELL   CL09     00000001 ASL  00040000)
[    0.039239] ACPI: SSDT 0x00000000AAFEB000 0006FE (v01 COMPAL CRV ORB  00001000 ACPI 00040000)
[    0.039245] ACPI: BOOT 0x00000000AAFE9000 000028 (v01 DELL   CL09     00000001 ASL  00040000)
[    0.039251] ACPI: ASPT 0x00000000AAFE7000 000034 (v07 DELL   CL09     00000001 ASL  00040000)
[    0.039257] ACPI: DBGP 0x00000000AAFE6000 000034 (v01 DELL   CL09     00000001 ASL  00040000)
[    0.039262] ACPI: FPDT 0x00000000AAFE4000 000044 (v01 DELL   CL09     00000001 ASL  00040000)
[    0.039268] ACPI: SSDT 0x00000000AAFE3000 000926 (v01 COMPAL CRV ORB  00003000 ACPI 00040000)
[    0.039274] ACPI: SSDT 0x00000000AAFE2000 000A92 (v01 COMPAL CRV ORB  00003000 ACPI 00040000)
[    0.039281] ACPI: BGRT 0x00000000AAFE1000 000038 (v01 DELL   CL09     00000001 ASL  00040000)
[    0.039285] ACPI: Reserving FACP table memory at [mem 0xaaffa000-0xaaffa10b]
[    0.039288] ACPI: Reserving DSDT table memory at [mem 0xaafed000-0xaaff6331]
[    0.039290] ACPI: Reserving FACS table memory at [mem 0xaafb9000-0xaafb903f]
[    0.039292] ACPI: Reserving SLIC table memory at [mem 0xaaffd000-0xaaffd175]
[    0.039293] ACPI: Reserving UEFI table memory at [mem 0xaaffc000-0xaaffc235]
[    0.039295] ACPI: Reserving ASF! table memory at [mem 0xaaffb000-0xaaffb0a4]
[    0.039297] ACPI: Reserving HPET table memory at [mem 0xaaff9000-0xaaff9037]
[    0.039298] ACPI: Reserving APIC table memory at [mem 0xaaff8000-0xaaff808b]
[    0.039300] ACPI: Reserving MCFG table memory at [mem 0xaaff7000-0xaaff703b]
[    0.039302] ACPI: Reserving SLIC table memory at [mem 0xaafec000-0xaafec175]
[    0.039303] ACPI: Reserving SSDT table memory at [mem 0xaafeb000-0xaafeb6fd]
[    0.039305] ACPI: Reserving BOOT table memory at [mem 0xaafe9000-0xaafe9027]
[    0.039307] ACPI: Reserving ASPT table memory at [mem 0xaafe7000-0xaafe7033]
[    0.039309] ACPI: Reserving DBGP table memory at [mem 0xaafe6000-0xaafe6033]
[    0.039310] ACPI: Reserving FPDT table memory at [mem 0xaafe4000-0xaafe4043]
[    0.039312] ACPI: Reserving SSDT table memory at [mem 0xaafe3000-0xaafe3925]
[    0.039314] ACPI: Reserving SSDT table memory at [mem 0xaafe2000-0xaafe2a91]
[    0.039315] ACPI: Reserving BGRT table memory at [mem 0xaafe1000-0xaafe1037]
[    0.039498] No NUMA configuration found
[    0.039500] Faking a node at [mem 0x0000000000000000-0x00000001cf5fffff]
[    0.039516] NODE_DATA(0) allocated [mem 0x1cf5d4000-0x1cf5fefff]
[    0.039854] Zone ranges:
[    0.039856]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.039860]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.039863]   Normal   [mem 0x0000000100000000-0x00000001cf5fffff]
[    0.039866]   Device   empty
[    0.039868] Movable zone start for each node
[    0.039872] Early memory node ranges
[    0.039873]   node   0: [mem 0x0000000000001000-0x0000000000087fff]
[    0.039876]   node   0: [mem 0x0000000000100000-0x000000001fffffff]
[    0.039878]   node   0: [mem 0x0000000020200000-0x0000000040003fff]
[    0.039880]   node   0: [mem 0x0000000040005000-0x00000000a0baffff]
[    0.039882]   node   0: [mem 0x00000000a13b0000-0x00000000a9dbefff]
[    0.039884]   node   0: [mem 0x00000000aafff000-0x00000000aaffffff]
[    0.039885]   node   0: [mem 0x0000000100000000-0x00000001cf5fffff]
[    0.039888] Initmem setup node 0 [mem 0x0000000000001000-0x00000001cf5fffff]
[    0.039897] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.039930] On node 0, zone DMA: 120 pages in unavailable ranges
[    0.042051] On node 0, zone DMA32: 512 pages in unavailable ranges
[    0.045328] On node 0, zone DMA32: 1 pages in unavailable ranges
[    0.045659] On node 0, zone DMA32: 2048 pages in unavailable ranges
[    0.045738] On node 0, zone DMA32: 4672 pages in unavailable ranges
[    0.053065] On node 0, zone Normal: 20480 pages in unavailable ranges
[    0.053118] On node 0, zone Normal: 2560 pages in unavailable ranges
[    0.053129] Reserving Intel graphics memory at [mem 0xaba00000-0xaf9fffff]
[    0.053304] ACPI: PM-Timer IO Port: 0x408
[    0.053331] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
[    0.053337] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.053341] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.053349] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.053351] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.053366] e820: update [mem 0xa75be000-0xa75fafff] usable ==> reserved
[    0.053388] TSC deadline timer available
[    0.053390] smpboot: Allowing 8 CPUs, 4 hotplug CPUs
[    0.053422] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.053426] PM: hibernation: Registered nosave memory: [mem 0x00088000-0x000bffff]
[    0.053428] PM: hibernation: Registered nosave memory: [mem 0x000c0000-0x000fffff]
[    0.053431] PM: hibernation: Registered nosave memory: [mem 0x20000000-0x201fffff]
[    0.053434] PM: hibernation: Registered nosave memory: [mem 0x40004000-0x40004fff]
[    0.053437] PM: hibernation: Registered nosave memory: [mem 0x9e863000-0x9e863fff]
[    0.053440] PM: hibernation: Registered nosave memory: [mem 0x9e86e000-0x9e86efff]
[    0.053442] PM: hibernation: Registered nosave memory: [mem 0x9e86f000-0x9e86ffff]
[    0.053445] PM: hibernation: Registered nosave memory: [mem 0x9e87f000-0x9e87ffff]
[    0.053448] PM: hibernation: Registered nosave memory: [mem 0xa0bb0000-0xa13affff]
[    0.053451] PM: hibernation: Registered nosave memory: [mem 0xa75be000-0xa75fafff]
[    0.053454] PM: hibernation: Registered nosave memory: [mem 0xa9dbf000-0xaaebefff]
[    0.053456] PM: hibernation: Registered nosave memory: [mem 0xaaebf000-0xaafbefff]
[    0.053457] PM: hibernation: Registered nosave memory: [mem 0xaafbf000-0xaaffefff]
[    0.053461] PM: hibernation: Registered nosave memory: [mem 0xab000000-0xaf9fffff]
[    0.053462] PM: hibernation: Registered nosave memory: [mem 0xafa00000-0xfeafffff]
[    0.053464] PM: hibernation: Registered nosave memory: [mem 0xfeb00000-0xfeb03fff]
[    0.053465] PM: hibernation: Registered nosave memory: [mem 0xfeb04000-0xfebfffff]
[    0.053467] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.053468] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed0ffff]
[    0.053470] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[    0.053471] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed1bfff]
[    0.053473] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.053474] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.053476] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.053477] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
[    0.053480] [mem 0xafa00000-0xfeafffff] available for PCI devices
[    0.053483] Booting paravirtualized kernel on bare hardware
[    0.053486] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.053499] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[    0.054375] percpu: Embedded 86 pages/cpu s229376 r8192 d114688 u524288
[    0.054392] pcpu-alloc: s229376 r8192 d114688 u524288 alloc=1*2097152
[    0.054396] pcpu-alloc: [0] 0 1 2 3 [0] 4 5 6 7
[    0.054441] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.8.0-45-generic root=UUID=12db4868-764a-4e8e-8cd9-75ec38e04532 ro quiet splash
[    0.054572] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.8.0-45-generic", will be passed to user space.
[    0.055657] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.056212] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.056453] Fallback order for Node 0: 0
[    0.056460] Built 1 zonelists, mobility grouping on.  Total pages: 1518232
[    0.056463] Policy zone: Normal
[    0.056474] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.056481] software IO TLB: area num 8.
[    0.096070] Memory: 5800376K/6169880K available (22528K kernel code, 4442K rwdata, 14312K rodata, 4976K init, 4732K bss, 369244K reserved, 0K cma-reserved)
[    0.152144] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.152317] Kernel/User page tables isolation: enabled
[    0.152440] ftrace: allocating 57892 entries in 227 pages
[    0.168307] ftrace: allocated 227 pages with 5 groups
[    0.169740] Dynamic Preempt: voluntary
[    0.170082] rcu: Preemptible hierarchical RCU implementation.
[    0.170084] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=8.
[    0.170087] 	Trampoline variant of Tasks RCU enabled.
[    0.170088] 	Rude variant of Tasks RCU enabled.
[    0.170088] 	Tracing variant of Tasks RCU enabled.
[    0.170090] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.170091] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.175938] NR_IRQS: 524544, nr_irqs: 488, preallocated irqs: 16
[    0.176216] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.176409] Console: colour dummy device 80x25
[    0.176414] printk: legacy console [tty0] enabled
[    0.176795] ACPI: Core revision 20230628
[    0.177235] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.177262] APIC: Switch to symmetric I/O mode setup
[    0.177336] x2apic: IRQ remapping doesn't support X2APIC mode
[    0.177805] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.182257] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x36a60d99ee0, max_idle_ns: 881590472816 ns
[    0.182268] Calibrating delay loop (skipped), value calculated using timer frequency.. 3791.25 BogoMIPS (lpj=1895625)
[    0.182304] CPU0: Thermal monitoring enabled (TM1)
[    0.182343] process: using mwait in idle threads
[    0.182349] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[    0.182351] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[    0.182357] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.182360] Spectre V2 : Mitigation: Retpolines
[    0.182362] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.182364] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[    0.182365] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.182368] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.182370] Spectre V2 : User space: Mitigation: STIBP via prctl
[    0.182373] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.182376] MDS: Mitigation: Clear CPU buffers
[    0.182377] MMIO Stale Data: Unknown: No mitigations
[    0.182385] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.182388] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.182390] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.182392] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.182395] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.223553] Freeing SMP alternatives memory: 48K
[    0.223565] pid_max: default: 32768 minimum: 301
[    0.229267] LSM: initializing lsm=lockdown,capability,landlock,yama,apparmor,integrity
[    0.229614] landlock: Up and running.
[    0.229616] Yama: becoming mindful.
[    0.229739] AppArmor: AppArmor initialized
[    0.230150] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.230168] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.231400] smpboot: CPU0: Intel(R) Core(TM) i3-3227U CPU @ 1.90GHz (family: 0x6, model: 0x3a, stepping: 0x9)
[    0.231758] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.231800] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.231833] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.231870] Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.231901] ... version:                3
[    0.231903] ... bit width:              48
[    0.231904] ... generic registers:      4
[    0.231906] ... value mask:             0000ffffffffffff
[    0.231908] ... max period:             00007fffffffffff
[    0.231909] ... fixed-purpose events:   3
[    0.231911] ... event mask:             000000070000000f
[    0.232184] signal: max sigframe size: 1776
[    0.232216] Estimated ratio of average max frequency by base frequency (times 1024): 1024
[    0.234353] rcu: Hierarchical SRCU implementation.
[    0.234358] rcu: 	Max phase no-delay instances is 400.
[    0.235513] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.235712] smp: Bringing up secondary CPUs ...
[    0.235964] smpboot: x86: Booting SMP configuration:
[    0.235967] .... node  #0, CPUs:      #2 #1 #3
[    0.240478] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.241336] smp: Brought up 1 node, 4 CPUs
[    0.241336] smpboot: Max logical packages: 2
[    0.241336] smpboot: Total of 4 processors activated (15165.00 BogoMIPS)
[    0.242720] devtmpfs: initialized
[    0.242720] x86/mm: Memory block size: 128MB
[    0.244549] ACPI: PM: Registering ACPI NVS region [mem 0xaaebf000-0xaafbefff] (1048576 bytes)
[    0.244549] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.244549] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.245520] pinctrl core: initialized pinctrl subsystem
[    0.245683] PM: RTC time: 14:17:06, date: 2024-09-25
[    0.246939] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.247249] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.247374] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.247477] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.247501] audit: initializing netlink subsys (disabled)
[    0.247514] audit: type=2000 audit(1727273826.070:1): state=initialized audit_enabled=0 res=1
[    0.247521] thermal_sys: Registered thermal governor 'fair_share'
[    0.247525] thermal_sys: Registered thermal governor 'bang_bang'
[    0.247527] thermal_sys: Registered thermal governor 'step_wise'
[    0.247528] thermal_sys: Registered thermal governor 'user_space'
[    0.247530] thermal_sys: Registered thermal governor 'power_allocator'
[    0.247544] EISA bus registered
[    0.247561] cpuidle: using governor ladder
[    0.247569] cpuidle: using governor menu
[    0.247645] Simple Boot Flag at 0x44 set to 0x1
[    0.247667] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.247669] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.248422] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[    0.248433] PCI: not using ECAM ([mem 0xe0000000-0xefffffff] not reserved)
[    0.248436] PCI: Using configuration type 1 for base access
[    0.248529] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[    0.248720] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.248734] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.248734] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.250353] ipmi:dmi: Base address is zero, assuming no IPMI interface
[    0.250388] ACPI: Added _OSI(Module Device)
[    0.250391] ACPI: Added _OSI(Processor Device)
[    0.250393] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.250395] ACPI: Added _OSI(Processor Aggregator Device)
[    0.261119] ACPI: 4 ACPI AML tables successfully acquired and loaded
[    0.263879] ACPI: Dynamic OEM Table Load:
[    0.263894] ACPI: SSDT 0xFFFF9B44815F5000 00083B (v01 PmRef  Cpu0Cst  00003001 INTL 20130117)
[    0.265275] ACPI: Dynamic OEM Table Load:
[    0.265289] ACPI: SSDT 0xFFFF9B4480349000 000303 (v01 PmRef  ApIst    00003000 INTL 20130117)
[    0.266219] ACPI: Dynamic OEM Table Load:
[    0.266228] ACPI: SSDT 0xFFFF9B44802E1800 000119 (v01 PmRef  ApCst    00003000 INTL 20130117)
[    0.268160] ACPI: _OSC evaluated successfully for all CPUs
[    0.268535] ACPI: EC: EC started
[    0.268538] ACPI: EC: interrupt blocked
[    0.269528] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.269533] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    0.269536] ACPI: Interpreter enabled
[    0.269571] ACPI: PM: (supports S0 S3 S4 S5)
[    0.269573] ACPI: Using IOAPIC for interrupt routing
[    0.270563] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[    0.271737] PCI: ECAM [mem 0xe0000000-0xefffffff] reserved as ACPI motherboard resource
[    0.271759] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.271761] PCI: Using E820 reservations for host bridge windows
[    0.272349] ACPI: Enabled 9 GPEs in block 00 to 3F
[    0.349069] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.349083] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.349333] acpi PNP0A08:00: _OSC: OS requested [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[    0.349338] acpi PNP0A08:00: _OSC: platform willing to grant [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[    0.349341] acpi PNP0A08:00: _OSC: platform retains control of PCIe features (AE_ERROR)
[    0.350058] PCI host bridge to bus 0000:00
[    0.350063] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.350067] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.350071] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000fffff window]
[    0.350074] pci_bus 0000:00: root bus resource [mem 0xafa00000-0xfeafffff window]
[    0.350077] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.350106] pci 0000:00:00.0: [8086:0154] type 00 class 0x060000 conventional PCI endpoint
[    0.350218] pci 0000:00:02.0: [8086:0166] type 00 class 0x030000 conventional PCI endpoint
[    0.350234] pci 0000:00:02.0: BAR 0 [mem 0xc0000000-0xc03fffff 64bit]
[    0.350244] pci 0000:00:02.0: BAR 2 [mem 0xb0000000-0xbfffffff 64bit pref]
[    0.350251] pci 0000:00:02.0: BAR 4 [io  0x3000-0x303f]
[    0.350273] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.350615] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330 conventional PCI endpoint
[    0.350642] pci 0000:00:14.0: BAR 0 [mem 0xc0600000-0xc060ffff 64bit]
[    0.350728] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.350873] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000 conventional PCI endpoint
[    0.350900] pci 0000:00:16.0: BAR 0 [mem 0xc0614000-0xc061400f 64bit]
[    0.350988] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.351092] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320 conventional PCI endpoint
[    0.351112] pci 0000:00:1a.0: BAR 0 [mem 0xc0619000-0xc06193ff]
[    0.351212] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.351363] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300 PCIe Root Complex Integrated Endpoint
[    0.351386] pci 0000:00:1b.0: BAR 0 [mem 0xc0610000-0xc0613fff 64bit]
[    0.351485] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.351648] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400 PCIe Root Port
[    0.351686] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.351695] pci 0000:00:1c.0:   bridge window [io  0x2000-0x2fff]
[    0.351712] pci 0000:00:1c.0:   bridge window [mem 0xc0400000-0xc04fffff 64bit pref]
[    0.351788] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.351963] pci 0000:00:1c.1: [8086:1e12] type 01 class 0x060400 PCIe Root Port
[    0.352000] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.352009] pci 0000:00:1c.1:   bridge window [mem 0xc0500000-0xc05fffff]
[    0.352095] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    0.352283] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320 conventional PCI endpoint
[    0.352307] pci 0000:00:1d.0: BAR 0 [mem 0xc0618000-0xc06183ff]
[    0.352408] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.352557] pci 0000:00:1f.0: [8086:1e59] type 00 class 0x060100 conventional PCI endpoint
[    0.352815] pci 0000:00:1f.2: [8086:1e03] type 00 class 0x010601 conventional PCI endpoint
[    0.352833] pci 0000:00:1f.2: BAR 0 [io  0x3088-0x308f]
[    0.352844] pci 0000:00:1f.2: BAR 1 [io  0x3094-0x3097]
[    0.352854] pci 0000:00:1f.2: BAR 2 [io  0x3080-0x3087]
[    0.352864] pci 0000:00:1f.2: BAR 3 [io  0x3090-0x3093]
[    0.352873] pci 0000:00:1f.2: BAR 4 [io  0x3060-0x307f]
[    0.352883] pci 0000:00:1f.2: BAR 5 [mem 0xc0617000-0xc06177ff]
[    0.352935] pci 0000:00:1f.2: PME# supported from D3hot
[    0.353057] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500 conventional PCI endpoint
[    0.353082] pci 0000:00:1f.3: BAR 0 [mem 0xc0615000-0xc06150ff 64bit]
[    0.353106] pci 0000:00:1f.3: BAR 4 [io  0x3040-0x305f]
[    0.353407] pci 0000:01:00.0: [10ec:8136] type 00 class 0x020000 PCIe Endpoint
[    0.353502] pci 0000:01:00.0: BAR 0 [io  0x2000-0x20ff]
[    0.353628] pci 0000:01:00.0: BAR 2 [mem 0xc0404000-0xc0404fff 64bit pref]
[    0.353707] pci 0000:01:00.0: BAR 4 [mem 0xc0400000-0xc0403fff 64bit pref]
[    0.354133] pci 0000:01:00.0: supports D1 D2
[    0.354136] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.354679] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.354809] pci 0000:02:00.0: [168c:0036] type 00 class 0x028000 PCIe Endpoint
[    0.354877] pci 0000:02:00.0: BAR 0 [mem 0xc0500000-0xc057ffff 64bit]
[    0.354991] pci 0000:02:00.0: ROM [mem 0xffff0000-0xffffffff pref]
[    0.355163] pci 0000:02:00.0: supports D1 D2
[    0.355166] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.355469] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.421730] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.421734] ACPI: PCI: Interrupt link LNKA disabled
[    0.421835] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[    0.421838] ACPI: PCI: Interrupt link LNKB disabled
[    0.421935] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.421938] ACPI: PCI: Interrupt link LNKC disabled
[    0.422035] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.422038] ACPI: PCI: Interrupt link LNKD disabled
[    0.422134] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.422137] ACPI: PCI: Interrupt link LNKE disabled
[    0.422238] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.422240] ACPI: PCI: Interrupt link LNKF disabled
[    0.422341] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.422344] ACPI: PCI: Interrupt link LNKG disabled
[    0.422441] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.422444] ACPI: PCI: Interrupt link LNKH disabled
[    0.422774] ACPI: EC: interrupt unblocked
[    0.422777] ACPI: EC: event unblocked
[    0.422781] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.422783] ACPI: EC: GPE=0x17
[    0.422786] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
[    0.422789] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[    0.422911] iommu: Default domain type: Translated
[    0.422911] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.423313] SCSI subsystem initialized
[    0.423332] libata version 3.00 loaded.
[    0.423332] ACPI: bus type USB registered
[    0.423346] usbcore: registered new interface driver usbfs
[    0.423356] usbcore: registered new interface driver hub
[    0.423369] usbcore: registered new device driver usb
[    0.423409] pps_core: LinuxPPS API ver. 1 registered
[    0.423411] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.423416] PTP clock support registered
[    0.423444] EDAC MC: Ver: 3.0.0
[    0.423444] efivars: Registered efivars operations
[    0.424392] NetLabel: Initializing
[    0.424395] NetLabel:  domain hash size = 128
[    0.424397] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.424430] NetLabel:  unlabeled traffic allowed by default
[    0.424461] mctp: management component transport protocol core
[    0.424461] NET: Registered PF_MCTP protocol family
[    0.424461] PCI: Using ACPI for IRQ routing
[    0.432018] PCI: pci_cache_line_size set to 64 bytes
[    0.432082] e820: reserve RAM buffer [mem 0x00088000-0x0008ffff]
[    0.432086] e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
[    0.432088] e820: reserve RAM buffer [mem 0x9e863018-0x9fffffff]
[    0.432090] e820: reserve RAM buffer [mem 0x9e86f018-0x9fffffff]
[    0.432092] e820: reserve RAM buffer [mem 0xa0bb0000-0xa3ffffff]
[    0.432094] e820: reserve RAM buffer [mem 0xa75be000-0xa7ffffff]
[    0.432096] e820: reserve RAM buffer [mem 0xa9dbf000-0xabffffff]
[    0.432098] e820: reserve RAM buffer [mem 0xab000000-0xabffffff]
[    0.432100] e820: reserve RAM buffer [mem 0x1cf600000-0x1cfffffff]
[    0.432187] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.432187] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.432187] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.432187] vgaarb: loaded
[    0.432333] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.432346] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.434305] clocksource: Switched to clocksource tsc-early
[    0.435880] VFS: Disk quotas dquot_6.6.0
[    0.435933] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.436209] AppArmor: AppArmor Filesystem Enabled
[    0.436276] pnp: PnP ACPI init
[    0.436469] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.436475] system 00:00: [io  0x1000-0x100f] has been reserved
[    0.436479] system 00:00: [io  0xffff] has been reserved
[    0.436482] system 00:00: [io  0xffff] has been reserved
[    0.436484] system 00:00: [io  0x0400-0x0453] has been reserved
[    0.436487] system 00:00: [io  0x0458-0x047f] has been reserved
[    0.436490] system 00:00: [io  0x0500-0x057f] has been reserved
[    0.436492] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.436495] system 00:00: [io  0xfd60-0xfd63] has been reserved
[    0.436642] system 00:02: [io  0x0454-0x0457] has been reserved
[    0.502543] system 00:05: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.502549] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.502552] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.502554] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.502557] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[    0.502560] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.502562] system 00:05: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.502570] system 00:05: [mem 0xff000000-0xff000fff] has been reserved
[    0.502573] system 00:05: [mem 0xff010000-0xffffffff] has been reserved
[    0.502576] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.502579] system 00:05: [mem 0xafa00000-0xafa00fff] has been reserved
[    0.503059] system 00:06: [mem 0x20000000-0x201fffff] has been reserved
[    0.503064] system 00:06: [mem 0x40004000-0x40004fff] has been reserved
[    0.503099] pnp: PnP ACPI: found 7 devices
[    0.510390] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.510678] NET: Registered PF_INET protocol family
[    0.510815] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.538514] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.538556] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.538615] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.538886] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.539319] TCP: Hash tables configured (established 65536 bind 65536)
[    0.539583] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[    0.539664] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.539700] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.539856] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.539868] NET: Registered PF_XDP protocol family
[    0.539876] pci 0000:02:00.0: ROM [mem 0xffff0000-0xffffffff pref]: can't claim; no compatible bridge window
[    0.539896] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.539901] pci 0000:00:1c.0:   bridge window [io  0x2000-0x2fff]
[    0.539913] pci 0000:00:1c.0:   bridge window [mem 0xc0400000-0xc04fffff 64bit pref]
[    0.539926] pci 0000:02:00.0: ROM [mem 0xc0580000-0xc058ffff pref]: assigned
[    0.539930] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.539936] pci 0000:00:1c.1:   bridge window [mem 0xc0500000-0xc05fffff]
[    0.539948] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.539951] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.539954] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000fffff window]
[    0.539957] pci_bus 0000:00: resource 7 [mem 0xafa00000-0xfeafffff window]
[    0.539960] pci_bus 0000:01: resource 0 [io  0x2000-0x2fff]
[    0.539962] pci_bus 0000:01: resource 2 [mem 0xc0400000-0xc04fffff 64bit pref]
[    0.539965] pci_bus 0000:02: resource 1 [mem 0xc0500000-0xc05fffff]
[    0.553411] pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x190 took 11503 usecs
[    0.565408] pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x190 took 11688 usecs
[    0.565443] PCI: CLS 64 bytes, default 64
[    0.565464] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.565465] software IO TLB: mapped [mem 0x00000000a287a000-0x00000000a687a000] (64MB)
[    0.565547] Trying to unpack rootfs image as initramfs...
[    0.569232] Initialise system trusted keyrings
[    0.569254] Key type blacklist registered
[    0.569377] workingset: timestamp_bits=36 max_order=21 bucket_order=0
[    0.569413] zbud: loaded
[    0.571804] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.572879] fuse: init (API version 7.39)
[    0.573251] integrity: Platform Keyring initialized
[    0.573272] integrity: Machine keyring initialized
[    0.595159] Key type asymmetric registered
[    0.595167] Asymmetric key parser 'x509' registered
[    0.595211] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.595352] io scheduler mq-deadline registered
[    0.598910] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.599814] ACPI: AC: AC Adapter [ACAD] (on-line)
[    0.599914] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0C:00/input/input0
[    0.599948] ACPI: button: Power Button [PWRB]
[    0.600020] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[    0.600093] ACPI: button: Lid Switch [LID0]
[    0.600149] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    0.600215] ACPI: button: Power Button [PWRF]
[    0.601236] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.605675] Linux agpgart interface v0.103
[    0.610074] loop: module loaded
[    0.610580] ACPI: bus type drm_connector registered
[    0.611219] tun: Universal TUN/TAP device driver, 1.6
[    0.611342] PPP generic driver version 2.4.2
[    0.611654] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    0.611753] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    0.611767] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    0.611795] ehci-pci 0000:00:1a.0: debug port 2
[    0.615786] ehci-pci 0000:00:1a.0: irq 16, io mem 0xc0619000
[    0.627716] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.627732] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.627940] mousedev: PS/2 mouse device common for all mice
[    0.628192] rtc_cmos 00:01: RTC can wake from S4
[    0.628584] rtc_cmos 00:01: registered as rtc0
[    0.628621] rtc_cmos 00:01: setting system clock to 2024-09-25T14:17:06 UTC (1727273826)
[    0.628693] rtc_cmos 00:01: alarms up to one month, 242 bytes nvram
[    0.628716] i2c_dev: i2c /dev entries driver
[    0.630279] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    0.630445] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[    0.630452] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.630455] usb usb1: Product: EHCI Host Controller
[    0.630457] usb usb1: Manufacturer: Linux 6.8.0-45-generic ehci_hcd
[    0.630459] usb usb1: SerialNumber: 0000:00:1a.0
[    0.630697] hub 1-0:1.0: USB hub found
[    0.630729] hub 1-0:1.0: 2 ports detected
[    0.631096] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    0.631107] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    0.631124] ehci-pci 0000:00:1d.0: debug port 2
[    0.631389] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[    0.631447] device-mapper: uevent: version 1.0.3
[    0.631613] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[    0.631672] platform eisa.0: Probing EISA bus 0
[    0.631685] platform eisa.0: EISA: Cannot allocate resource for mainboard
[    0.631690] platform eisa.0: Cannot allocate resource for EISA slot 1
[    0.631693] platform eisa.0: Cannot allocate resource for EISA slot 2
[    0.631698] platform eisa.0: Cannot allocate resource for EISA slot 3
[    0.631701] platform eisa.0: Cannot allocate resource for EISA slot 4
[    0.631704] platform eisa.0: Cannot allocate resource for EISA slot 5
[    0.631707] platform eisa.0: Cannot allocate resource for EISA slot 6
[    0.631710] platform eisa.0: Cannot allocate resource for EISA slot 7
[    0.631713] platform eisa.0: Cannot allocate resource for EISA slot 8
[    0.631718] platform eisa.0: EISA: Detected 0 cards
[    0.631773] intel_pstate: Intel P-state driver initializing
[    0.635094] ehci-pci 0000:00:1d.0: irq 23, io mem 0xc0618000
[    0.635185] ledtrig-cpu: registered to indicate activity on CPUs
[    0.635808] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[    0.637041] fbcon: Deferring console take-over
[    0.637050] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    0.637246] drop_monitor: Initializing network drop monitor service
[    0.637982] NET: Registered PF_INET6 protocol family
[    0.641290] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    0.641393] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[    0.641398] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.641401] usb usb2: Product: EHCI Host Controller
[    0.641404] usb usb2: Manufacturer: Linux 6.8.0-45-generic ehci_hcd
[    0.641406] usb usb2: SerialNumber: 0000:00:1d.0
[    0.641688] hub 2-0:1.0: USB hub found
[    0.641704] hub 2-0:1.0: 2 ports detected
[    0.645851] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[    0.784402] Freeing initrd memory: 71296K
[    0.795966] Segment Routing with IPv6
[    0.796015] In-situ OAM (IOAM) with IPv6
[    0.796078] NET: Registered PF_PACKET protocol family
[    0.796205] Key type dns_resolver registered
[    0.797019] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.797107] microcode: Current revision: 0x00000021
[    0.797137] microcode: Updated early from: 0x00000017
[    0.797331] IPI shorthand broadcast: enabled
[    0.800613] sched_clock: Marking stable (799250910, 1014034)->(833148756, -32883812)
[    0.800930] registered taskstats version 1
[    0.801383] Loading compiled-in X.509 certificates
[    0.802588] Loaded X.509 cert 'Build time autogenerated kernel key: 7e025e0cbc510606ab90d1bfb5b71bc9263fcc8e'
[    0.803581] Loaded X.509 cert 'Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969'
[    0.804541] Loaded X.509 cert 'Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19'
[    0.804545] blacklist: Loading compiled-in revocation X.509 certificates
[    0.804577] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing: 61482aa2830d0ab2ad5af10b7250da9033ddcef0'
[    0.804603] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2017): 242ade75ac4a15e50d50c84b0d45ff3eae707a03'
[    0.804628] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (ESM 2018): 365188c1d374d6b07c3c8f240f8ef722433d6a8b'
[    0.804661] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2019): c0746fd6c5da3ae827864651ad66ae47fe24b3e8'
[    0.804691] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v1): a8d54bbb3825cfb94fa13c9f8a594a195c107b8d'
[    0.804727] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v2): 4cf046892d6fd3c9a5b03f98d845f90851dc6a8c'
[    0.804752] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v3): 100437bb6de6e469b581e61cd66bce3ef4ed53af'
[    0.804777] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (Ubuntu Core 2019): c1d57b8f6b743f23ee41f4f7ee292f06eecadfb9'
[    0.811690] Key type .fscrypt registered
[    0.811696] Key type fscrypt-provisioning registered
[    0.821842] cryptd: max_cpu_qlen set to 1000
[    0.832546] ACPI: battery: Slot [BAT1] (battery present)
[    0.868245] Key type encrypted registered
[    0.868255] AppArmor: AppArmor sha256 policy hashing enabled
[    0.869283] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    0.869865] integrity: Loading X.509 certificate: UEFI:db
[    0.869929] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    0.869932] integrity: Loading X.509 certificate: UEFI:db
[    0.869964] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    0.884588] ima: No TPM chip found, activating TPM-bypass!
[    0.884603] Loading compiled-in module X.509 certificates
[    0.885595] Loaded X.509 cert 'Build time autogenerated kernel key: 7e025e0cbc510606ab90d1bfb5b71bc9263fcc8e'
[    0.885600] ima: Allocated hash algorithm: sha256
[    0.885619] ima: No architecture policies found
[    0.885637] evm: Initialising EVM extended attributes:
[    0.885639] evm: security.selinux
[    0.885640] evm: security.SMACK64
[    0.885642] evm: security.SMACK64EXEC
[    0.885643] evm: security.SMACK64TRANSMUTE
[    0.885644] evm: security.SMACK64MMAP
[    0.885645] evm: security.apparmor
[    0.885647] evm: security.ima
[    0.885648] evm: security.capability
[    0.885649] evm: HMAC attrs: 0x1
[    0.886167] PM:   Magic number: 8:103:284
[    0.886281] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    0.892864] RAS: Correctable Errors collector initialized.
[    0.892991] clk: Disabling unused clocks
[    0.895536] Freeing unused decrypted memory: 2028K
[    0.896549] Freeing unused kernel image (initmem) memory: 4976K
[    0.896651] Write protecting the kernel read-only data: 36864k
[    0.896947] Freeing unused kernel image (rodata/data gap) memory: 24K
[    0.971630] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.971634] x86/mm: Checking user space page tables
[    1.037638] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[    1.037646] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.037782] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[    1.037788] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.038057] hub 1-1:1.0: USB hub found
[    1.038230] hub 1-1:1.0: 6 ports detected
[    1.038327] hub 2-1:1.0: USB hub found
[    1.038828] hub 2-1:1.0: 6 ports detected
[    1.044108] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.044117] Run /init as init process
[    1.044119]   with arguments:
[    1.044121]     /init
[    1.044123]     splash
[    1.044124]   with environment:
[    1.044126]     HOME=/
[    1.044127]     TERM=linux
[    1.044128]     BOOT_IMAGE=/boot/vmlinuz-6.8.0-45-generic
[    1.268229] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[    1.307074] usb 1-1.3: new high-speed USB device number 3 using ehci-pci
[    1.318197] ahci 0000:00:1f.2: version 3.0
[    1.321682] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.321699] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    1.322824] xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x000000000000b930
[    1.323126] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.323134] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[    1.323142] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    1.323228] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[    1.323235] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.323239] usb usb3: Product: xHCI Host Controller
[    1.323243] usb usb3: Manufacturer: Linux 6.8.0-45-generic xhci-hcd
[    1.323247] usb usb3: SerialNumber: 0000:00:14.0
[    1.323548] hub 3-0:1.0: USB hub found
[    1.323578] hub 3-0:1.0: 4 ports detected
[    1.325416] r8169 0000:01:00.0: can't disable ASPM; OS doesn't have ASPM control
[    1.326595] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08
[    1.326607] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.326613] usb usb4: Product: xHCI Host Controller
[    1.326618] usb usb4: Manufacturer: Linux 6.8.0-45-generic xhci-hcd
[    1.326622] usb usb4: SerialNumber: 0000:00:14.0
[    1.330110] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x5 impl SATA mode
[    1.330125] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[    1.330931] hub 4-0:1.0: USB hub found
[    1.330961] hub 4-0:1.0: 4 ports detected
[    1.341654] scsi host0: ahci
[    1.342715] r8169 0000:01:00.0 eth0: RTL8105e, b8:ca:3a:c4:c5:c3, XID 40c, IRQ 26
[    1.343444] scsi host1: ahci
[    1.344327] scsi host2: ahci
[    1.344953] scsi host3: ahci
[    1.345628] scsi host4: ahci
[    1.346323] scsi host5: ahci
[    1.346455] ata1: SATA max UDMA/133 abar m2048@0xc0617000 port 0xc0617100 irq 24 lpm-pol 3
[    1.346463] ata2: DUMMY
[    1.346468] ata3: SATA max UDMA/133 abar m2048@0xc0617000 port 0xc0617200 irq 24 lpm-pol 3
[    1.346472] ata4: DUMMY
[    1.346474] ata5: DUMMY
[    1.346476] ata6: DUMMY
[    1.357164] r8169 0000:01:00.0 enp1s0: renamed from eth0
[    1.386195] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
[    1.386205] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.386208] usb 1-1.3: Product: USB2.0-CRW
[    1.386210] usb 1-1.3: Manufacturer: Generic
[    1.386212] usb 1-1.3: SerialNumber: 20100201396000000
[    1.394572] usbcore: registered new interface driver rtsx_usb
[    1.451103] usb 1-1.4: new high-speed USB device number 4 using ehci-pci
[    1.586824] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=58c2, bcdDevice=28.28
[    1.586843] usb 1-1.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    1.586850] usb 1-1.4: Product: Laptop_Integrated_Webcam_HD
[    1.586855] usb 1-1.4: Manufacturer: CNFCH41j256040055882
[    1.586860] usb 1-1.4: SerialNumber: 0x0001
[    1.618080] tsc: Refined TSC clocksource calibration: 1895.693 MHz
[    1.618111] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x36a68ea8fe5, max_idle_ns: 881590678518 ns
[    1.618578] clocksource: Switched to clocksource tsc
[    1.655998] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.657338] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.657923] ata3.00: ATAPI: MATSHITA DVD+/-RW UJ8C2, 1.02, max UDMA/133
[    1.660457] ata3.00: configured for UDMA/133
[    1.684543] ata1.00: ATA-8: TOSHIBA MQ01ABD075, AX002D, max UDMA/100
[    1.684942] ata1.00: 1465149168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.686954] ata1.00: configured for UDMA/100
[    1.687830] scsi 0:0:0:0: Direct-Access     ATA      TOSHIBA MQ01ABD0 2D   PQ: 0 ANSI: 5
[    1.689125] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    1.689363] sd 0:0:0:0: [sda] 1465149168 512-byte logical blocks: (750 GB/699 GiB)
[    1.689385] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    1.689445] sd 0:0:0:0: [sda] Write Protect is off
[    1.689461] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.689529] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.689578] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[    1.690679] scsi 2:0:0:0: CD-ROM            MATSHITA DVD+-RW UJ8C2    1.02 PQ: 0 ANSI: 5
[    1.727201] sr 2:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[    1.727216] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.740367] sr 2:0:0:0: Attached scsi CD-ROM sr0
[    1.740636] sr 2:0:0:0: Attached scsi generic sg1 type 5
[    1.811154]  sda: sda1 sda2
[    1.811722] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.078360] psmouse serio1: synaptics: queried max coordinates: x [..5674], y [..4754]
[    2.140942] psmouse serio1: synaptics: queried min coordinates: x [1268..], y [1098..]
[    2.140955] psmouse serio1: synaptics: Your touchpad (PNP: DLL059c PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[    2.263462] psmouse serio1: synaptics: Touchpad model: 1, fw: 8.1, id: 0x1e2b1, caps: 0xd00123/0x840300/0x26c00/0x0, board id: 2382, fw id: 1238635
[    2.336620] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input5
[    2.490023] raid6: sse2x4   gen()  8248 MB/s
[    2.507018] raid6: sse2x2   gen()  9433 MB/s
[    2.524019] raid6: sse2x1   gen()  8129 MB/s
[    2.524023] raid6: using algorithm sse2x2 gen() 9433 MB/s
[    2.541018] raid6: .... xor() 5093 MB/s, rmw enabled
[    2.541022] raid6: using ssse3x2 recovery algorithm
[    2.542749] xor: automatically using best checksumming function   avx
[    2.544377] async_tx: api initialized (async)
[    3.002132] Btrfs loaded, zoned=yes, fsverity=yes
[    3.656045] random: crng init done
[    3.681415] EXT4-fs (sda2): mounted filesystem 12db4868-764a-4e8e-8cd9-75ec38e04532 ro with ordered data mode. Quota mode: none.
[    6.117183] systemd[1]: Inserted module 'autofs4'
[    6.366113] systemd[1]: systemd 255.4-1ubuntu8.4 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    6.366174] systemd[1]: Detected architecture x86-64.
[    6.427122] systemd[1]: Hostname set to <debout-Inspiron-3721>.
[   11.810480] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[   12.930285] systemd[1]: Queued start job for default target graphical.target.
[   13.047575] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[   13.049237] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[   13.050278] systemd[1]: Created slice user.slice - User and Session Slice.
[   13.050570] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[   13.051336] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[   13.051439] systemd[1]: Expecting device dev-disk-by\x2duuid-8DB1\x2dDAB2.device - /dev/disk/by-uuid/8DB1-DAB2...
[   13.051540] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[   13.051661] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[   13.051717] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[   13.051772] systemd[1]: Reached target slices.target - Slice Units.
[   13.051890] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[   13.052367] systemd[1]: Listening on dm-event.socket - Device-mapper event daemon FIFOs.
[   13.109136] systemd[1]: Listening on lvm2-lvmpolld.socket - LVM2 poll daemon socket.
[   13.109698] systemd[1]: Listening on syslog.socket - Syslog Socket.
[   13.131430] systemd[1]: Listening on systemd-coredump.socket - Process Core Dump Socket.
[   13.131876] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[   13.132193] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[   13.132727] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[   13.133298] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[   13.133474] systemd[1]: systemd-pcrextend.socket - TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   13.156301] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[   13.156806] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[   13.198247] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[   13.200388] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[   13.203241] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[   13.205558] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[   13.211124] systemd[1]: Starting systemd-journald.service - Journal Service...
[   13.211480] systemd[1]: Finished blk-availability.service - Availability of block devices.
[   13.219915] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[   13.222081] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[   13.226425] systemd[1]: Starting lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   13.232370] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[   13.234832] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[   13.240415] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[   13.243372] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   13.249740] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[   13.257420] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[   13.257692] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[   13.300085] pstore: Using crash dump compression: deflate
[   13.321241] pstore: Registered efi_pstore as persistent store backend
[   13.458350] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[   13.458396] systemd[1]: systemd-pcrmachine.service - TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   13.460588] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[   13.460694] systemd[1]: systemd-tpm2-setup-early.service - TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   13.462105] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[   13.466946] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[   13.467247] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[   13.467518] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[   13.467772] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[   13.468300] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[   13.468969] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   13.469309] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[   13.469992] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[   13.470347] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[   13.471035] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   13.471372] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[   13.472081] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   13.472444] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   13.473316] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   13.473530] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[   13.473968] systemd[1]: modprobe@loop.service: Deactivated successfully.
[   13.474238] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[   13.475983] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[   13.481233] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[   13.481379] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[   13.485586] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[   13.492505] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[   13.492794] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[   13.597092] EXT4-fs (sda2): re-mounted 12db4868-764a-4e8e-8cd9-75ec38e04532 r/w. Quota mode: none.
[   13.599428] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[   13.609211] systemd[1]: Activating swap swapfile.swap - /swapfile...
[   13.916340] lp: driver loaded but no devices found
[   13.926383] ppdev: user-space parallel port driver
[   14.270817] systemd-journald[301]: Collecting audit messages is disabled.
[   14.343663] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[   14.343866] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[   14.357383] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
[   14.357469] systemd[1]: systemd-tpm2-setup.service - TPM2 SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   14.358505] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[   14.359274] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[   14.361970] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[   14.406794] systemd[1]: Started systemd-journald.service - Journal Service.
[   14.425302] Adding 2097148k swap on /swapfile.  Priority:-2 extents:6 across:2260988k
[   14.487224] systemd-journald[301]: Received client request to flush runtime journal.
[   15.296416] systemd-journald[301]: /var/log/journal/51fe11ea3d5a4fdd89a47a6bde27c137/system.journal: Journal file uses a different sequence number ID, rotating.
[   15.296442] systemd-journald[301]: Rotating system journal.
[   17.276483] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
[   17.288226] input: Dell WMI hotkeys as /devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input6
[   17.379010] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20230628/utaddress-204)
[   17.379052] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[   17.379061] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[   17.379075] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[   17.379080] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[   17.379095] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[   17.379099] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[   17.379114] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[   17.379117] lpc_ich: Resource conflict(s) found affecting gpio_ich
[   17.412109] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
[   17.412122] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[   17.412127] RAPL PMU: hw unit of domain package 2^-16 Joules
[   17.412130] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
[   17.787986] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[   17.858482] i2c i2c-0: 2/2 memory slots populated (from DMI)
[   17.858847] i2c i2c-0: Successfully instantiated SPD at 0x50
[   18.069650] at24 0-0050: supply vcc not found, using dummy regulator
[   18.072562] at24 0-0050: 256 byte spd EEPROM, read-only
[   18.294821] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   18.295319] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   18.295709] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   18.712651] intel_rapl_common: Found RAPL domain package
[   18.712662] intel_rapl_common: Found RAPL domain core
[   18.712666] intel_rapl_common: Found RAPL domain uncore
[   18.712715] intel_rapl_common: package-0:package:long_term locked by BIOS
[   18.712724] intel_rapl_common: package-0:package:short_term locked by BIOS
[   19.861374] mc: Linux media interface: v0.10
[   19.878469] i915 0000:00:02.0: vgaarb: deactivate vga console
[   19.919179] [drm] Initialized i915 1.6.0 20230929 for 0000:00:02.0 on minor 1
[   19.920854] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   19.921230] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input7
[   19.921876] i915 display info: display version: 7
[   19.921882] i915 display info: cursor_needs_physical: no
[   19.921886] i915 display info: has_cdclk_crawl: no
[   19.921889] i915 display info: has_cdclk_squash: no
[   19.921891] i915 display info: has_ddi: no
[   19.921894] i915 display info: has_dp_mst: no
[   19.921896] i915 display info: has_dsb: no
[   19.921899] i915 display info: has_fpga_dbg: no
[   19.921901] i915 display info: has_gmch: no
[   19.921904] i915 display info: has_hotplug: yes
[   19.921906] i915 display info: has_hti: no
[   19.921909] i915 display info: has_ipc: no
[   19.921911] i915 display info: has_overlay: no
[   19.921913] i915 display info: has_psr: no
[   19.921915] i915 display info: has_psr_hw_tracking: no
[   19.921918] i915 display info: overlay_needs_physical: no
[   19.921920] i915 display info: supports_tv: no
[   19.921923] i915 display info: has_hdcp: no
[   19.921925] i915 display info: has_dmc: no
[   19.921928] i915 display info: has_dsc: no
[   19.921790] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   20.015551] fbcon: i915drmfb (fb0) is primary device
[   20.015562] fbcon: Deferring console take-over
[   20.015572] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[   20.106135] videodev: Linux video capture interface: v2.00
[   20.267563] ath: phy0: WB335 1-ANT card detected
[   20.267580] ath: phy0: Set BT/WLAN RX diversity capability
[   20.277247] ath: phy0: Enable LNA combining
[   20.278528] ath: phy0: ASPM enabled: 0x43
[   20.278536] ath: EEPROM regdomain: 0x60
[   20.278539] ath: EEPROM indicates we should expect a direct regpair map
[   20.278544] ath: Country alpha2 being used: 00
[   20.278547] ath: Regpair used: 0x60
[   20.280409] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   20.282028] ieee80211 phy0: Atheros AR9565 Rev:1 mem=0x000000005e30985b, irq=17
[   20.289959] ath9k 0000:02:00.0 wlp2s0: renamed from wlan0
[   20.489723] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3221: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   20.489755] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   20.489769] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[   20.489783] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   20.489792] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   20.489802] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
[   20.489812] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[   20.536849] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[   20.537079] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[   20.537277] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[   20.669381] usb 1-1.4: Found UVC 1.00 device Laptop_Integrated_Webcam_HD (0bda:58c2)
[   20.682311] usbcore: registered new interface driver uvcvideo
[   22.699572] spl: loading out-of-tree module taints kernel.
[   22.925220] zfs: module license 'CDDL' taints kernel.
[   22.925228] Disabling lock debugging due to kernel taint
[   22.925266] zfs: module license taints kernel.
[   26.489374] ZFS: Loaded module v2.2.2-0ubuntu9, ZFS pool version 5000, ZFS filesystem version 5
[   27.877935] audit: type=1400 audit(1727273853.747:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=604 comm="apparmor_parser"
[   27.877947] audit: type=1400 audit(1727273853.747:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=603 comm="apparmor_parser"
[   27.877953] audit: type=1400 audit(1727273853.747:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=605 comm="apparmor_parser"
[   27.877958] audit: type=1400 audit(1727273853.747:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=606 comm="apparmor_parser"
[   27.925270] audit: type=1400 audit(1727273853.795:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=614 comm="apparmor_parser"
[   27.947671] audit: type=1400 audit(1727273853.817:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=616 comm="apparmor_parser"
[   27.975315] audit: type=1400 audit(1727273853.845:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-checkns" pid=619 comm="apparmor_parser"
[   27.978236] audit: type=1400 audit(1727273853.848:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-run" pid=621 comm="apparmor_parser"
[   28.010889] audit: type=1400 audit(1727273853.880:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=618 comm="apparmor_parser"
[   28.010969] audit: type=1400 audit(1727273853.880:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=615 comm="apparmor_parser"
[   38.018364] NET: Registered PF_QIPCRTR protocol family
[   45.776729] RTL8208 Fast Ethernet r8169-0-100:00: attached PHY driver (mii_bus:phy_addr=r8169-0-100:00, irq=MAC)
[   46.040393] r8169 0000:01:00.0 enp1s0: Link is Down
[   47.400945] kauditd_printk_skb: 114 callbacks suppressed
[   47.400963] audit: type=1400 audit(1727273873.270:126): apparmor="DENIED" operation="capable" class="cap" profile="/usr/sbin/cupsd" pid=1043 comm="cupsd" capability=12  capname="net_admin"
[   47.656985] r8169 0000:01:00.0 enp1s0: Link is Up - 100Mbps/Full - flow control off
[   47.919665] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=40259 PROTO=UDP SPT=43266 DPT=10001 LEN=285
[   49.410274] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=394628 PROTO=UDP SPT=47617 DPT=10001 LEN=170
[   57.925458] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=733102 PROTO=UDP SPT=48183 DPT=10001 LEN=285
[   58.271200] [UFW BLOCK] IN=enp1s0 OUT= MAC= SRC=192.168.14.137 DST=239.255.255.250 LEN=635 TOS=0x00 PREC=0x00 TTL=1 ID=37610 DF PROTO=UDP SPT=55539 DPT=3702 LEN=615
[   58.271358] [UFW BLOCK] IN=enp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:9ba4:a043:4f27:95b7 DST=ff02:0000:0000:0000:0000:0000:0000:000c LEN=655 TC=0 HOPLIMIT=1 FLOWLBL=735054 PROTO=UDP SPT=43811 DPT=3702 LEN=615
[   58.272283] [UFW BLOCK] IN=enp1s0 OUT= MAC=b8:ca:3a:c4:c5:c3:90:09:d0:35:a4:02:08:00 SRC=192.168.14.9 DST=192.168.14.137 LEN=1365 TOS=0x00 PREC=0x00 TTL=64 ID=5981 DF PROTO=UDP SPT=3702 DPT=55539 LEN=1345
[   58.272384] [UFW BLOCK] IN=enp1s0 OUT= MAC=b8:ca:3a:c4:c5:c3:90:09:d0:35:a4:02:08:00 SRC=192.168.14.9 DST=192.168.14.137 LEN=1365 TOS=0x00 PREC=0x00 TTL=64 ID=5982 DF PROTO=UDP SPT=3702 DPT=55539 LEN=1345
[   58.372670] [UFW BLOCK] IN=enp1s0 OUT= MAC= SRC=192.168.14.137 DST=239.255.255.250 LEN=635 TOS=0x00 PREC=0x00 TTL=1 ID=37638 DF PROTO=UDP SPT=55539 DPT=3702 LEN=615
[   58.374340] [UFW BLOCK] IN=enp1s0 OUT= MAC=b8:ca:3a:c4:c5:c3:90:09:d0:35:a4:02:08:00 SRC=192.168.14.9 DST=192.168.14.137 LEN=1365 TOS=0x00 PREC=0x00 TTL=64 ID=5983 DF PROTO=UDP SPT=3702 DPT=55539 LEN=1345
[   58.374537] [UFW BLOCK] IN=enp1s0 OUT= MAC=b8:ca:3a:c4:c5:c3:90:09:d0:35:a4:02:08:00 SRC=192.168.14.9 DST=192.168.14.137 LEN=1365 TOS=0x00 PREC=0x00 TTL=64 ID=5984 DF PROTO=UDP SPT=3702 DPT=55539 LEN=1345
[   58.374747] [UFW BLOCK] IN=enp1s0 OUT= MAC=b8:ca:3a:c4:c5:c3:90:09:d0:35:a4:02:08:00 SRC=192.168.14.9 DST=192.168.14.137 LEN=1365 TOS=0x00 PREC=0x00 TTL=64 ID=5985 DF PROTO=UDP SPT=3702 DPT=55539 LEN=1345
[   58.374964] [UFW BLOCK] IN=enp1s0 OUT= MAC=b8:ca:3a:c4:c5:c3:90:09:d0:35:a4:02:08:00 SRC=192.168.14.9 DST=192.168.14.137 LEN=1365 TOS=0x00 PREC=0x00 TTL=64 ID=5986 DF PROTO=UDP SPT=3702 DPT=55539 LEN=1345
[   58.506678] [UFW BLOCK] IN=enp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:9ba4:a043:4f27:95b7 DST=ff02:0000:0000:0000:0000:0000:0000:000c LEN=655 TC=0 HOPLIMIT=1 FLOWLBL=735054 PROTO=UDP SPT=43811 DPT=3702 LEN=615
[   58.596417] [UFW BLOCK] IN=enp1s0 OUT= MAC= SRC=192.168.14.137 DST=239.255.255.250 LEN=635 TOS=0x00 PREC=0x00 TTL=1 ID=37692 DF PROTO=UDP SPT=55539 DPT=3702 LEN=615
[   58.597823] [UFW BLOCK] IN=enp1s0 OUT= MAC=b8:ca:3a:c4:c5:c3:90:09:d0:35:a4:02:08:00 SRC=192.168.14.9 DST=192.168.14.137 LEN=1365 TOS=0x00 PREC=0x00 TTL=64 ID=6025 DF PROTO=UDP SPT=3702 DPT=55539 LEN=1345
[   58.704028] [UFW BLOCK] IN=enp1s0 OUT= MAC= SRC=fe80:0000:0000:0000:9ba4:a043:4f27:95b7 DST=ff02:0000:0000:0000:0000:0000:0000:000c LEN=655 TC=0 HOPLIMIT=1 FLOWLBL=735054 PROTO=UDP SPT=43811 DPT=3702 LEN=615
[   59.199167] systemd-journald[301]: /var/log/journal/51fe11ea3d5a4fdd89a47a6bde27c137/user-1000.journal: Journal file uses a different sequence number ID, rotating.
[   59.415343] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=40445 PROTO=UDP SPT=36335 DPT=10001 LEN=170
[   67.933492] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=618431 PROTO=UDP SPT=38379 DPT=10001 LEN=285
[   69.419660] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=189176 PROTO=UDP SPT=43598 DPT=10001 LEN=170
[   77.934920] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=305353 PROTO=UDP SPT=37874 DPT=10001 LEN=285
[   79.424863] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=748303 PROTO=UDP SPT=46261 DPT=10001 LEN=170
[   87.939774] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=148630 PROTO=UDP SPT=42565 DPT=10001 LEN=285
[  108.082307] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=157376 PROTO=UDP SPT=44161 DPT=10001 LEN=285
[  128.103530] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=227148 PROTO=UDP SPT=39461 DPT=10001 LEN=285
[  135.353476] [UFW BLOCK] IN=enp1s0 OUT= MAC=b8:ca:3a:c4:c5:c3:dc:4a:3e:99:c5:6e:08:00 SRC=192.168.14.120 DST=192.168.14.137 LEN=90 TOS=0x00 PREC=0x00 TTL=128 ID=19505 PROTO=UDP SPT=137 DPT=46723 LEN=70
[  135.403374] [UFW BLOCK] IN=enp1s0 OUT= MAC=b8:ca:3a:c4:c5:c3:14:50:51:d7:7e:8b:08:00 SRC=192.168.14.242 DST=192.168.14.137 LEN=90 TOS=0x00 PREC=0x00 TTL=64 ID=64695 DF PROTO=UDP SPT=137 DPT=46723 LEN=70
[  135.546482] [UFW BLOCK] IN=enp1s0 OUT= MAC=b8:ca:3a:c4:c5:c3:dc:4a:3e:99:c5:6e:08:00 SRC=192.168.14.120 DST=192.168.14.137 LEN=90 TOS=0x00 PREC=0x00 TTL=128 ID=19506 PROTO=UDP SPT=137 DPT=46723 LEN=70
[  148.122107] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=678233 PROTO=UDP SPT=60872 DPT=10001 LEN=285
[  168.132524] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=302751 PROTO=UDP SPT=34534 DPT=10001 LEN=285
[  188.144060] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=452870 PROTO=UDP SPT=49111 DPT=10001 LEN=285
[  208.157525] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=515509 PROTO=UDP SPT=58210 DPT=10001 LEN=285
[  228.175084] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=650156 PROTO=UDP SPT=48095 DPT=10001 LEN=285
[  248.185496] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=901824 PROTO=UDP SPT=49505 DPT=10001 LEN=285
[  268.192141] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=482459 PROTO=UDP SPT=47205 DPT=10001 LEN=285
[  288.211685] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=486507 PROTO=UDP SPT=46262 DPT=10001 LEN=285
[  289.151043] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=48618 PROTO=2
[  309.533466] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=720013 PROTO=UDP SPT=48686 DPT=10001 LEN=170
[  329.546114] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=1012080 PROTO=UDP SPT=39181 DPT=10001 LEN=170
[  349.560208] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=761255 PROTO=UDP SPT=51921 DPT=10001 LEN=170
[  369.571942] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=773677 PROTO=UDP SPT=48351 DPT=10001 LEN=170
[  389.581296] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=64611 PROTO=UDP SPT=48866 DPT=10001 LEN=170
[  409.592891] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=100394 PROTO=UDP SPT=48460 DPT=10001 LEN=170
[  429.604988] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=332750 PROTO=UDP SPT=41063 DPT=10001 LEN=170
[  449.618628] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=432665 PROTO=UDP SPT=36843 DPT=10001 LEN=170
[  469.629980] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=216510 PROTO=UDP SPT=58909 DPT=10001 LEN=170
[  489.642542] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=430464 PROTO=UDP SPT=41374 DPT=10001 LEN=170
[  509.653748] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=867128 PROTO=UDP SPT=49118 DPT=10001 LEN=170
[  529.661601] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=103630 PROTO=UDP SPT=50640 DPT=10001 LEN=170
[  549.674048] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=711158 PROTO=UDP SPT=39995 DPT=10001 LEN=170
[  569.686378] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=908950 PROTO=UDP SPT=36274 DPT=10001 LEN=170
[  589.696532] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=210716 PROTO=UDP SPT=58345 DPT=10001 LEN=170
[  599.025392] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=42171 PROTO=2
[  609.709361] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=879183 PROTO=UDP SPT=35478 DPT=10001 LEN=170
[  629.722916] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=102768 PROTO=UDP SPT=48035 DPT=10001 LEN=170
[  649.734422] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=739000 PROTO=UDP SPT=50196 DPT=10001 LEN=170
[  669.743876] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=770850 PROTO=UDP SPT=39196 DPT=10001 LEN=170
[  689.755339] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=197382 PROTO=UDP SPT=52483 DPT=10001 LEN=170
[  702.471621] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56676 PROTO=2
[  709.766402] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=910338 PROTO=UDP SPT=49113 DPT=10001 LEN=170
[  729.779788] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=510158 PROTO=UDP SPT=50362 DPT=10001 LEN=170
[  749.787303] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=129713 PROTO=UDP SPT=33581 DPT=10001 LEN=170
[  769.796777] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=700110 PROTO=UDP SPT=46830 DPT=10001 LEN=170
[  789.808551] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=802181 PROTO=UDP SPT=33214 DPT=10001 LEN=170
[  809.820090] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=51558 PROTO=UDP SPT=43750 DPT=10001 LEN=170
[  815.100929] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=51550 PROTO=2
[  829.834647] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=668186 PROTO=UDP SPT=38613 DPT=10001 LEN=170
[  845.979916] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56803 PROTO=2
[  849.846569] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=344681 PROTO=UDP SPT=56505 DPT=10001 LEN=170
[  867.923042] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:8c:ec:4b:ac:13:ab:86:dd SRC=fe80:0000:0000:0000:2d56:8c1b:23fc:2a0a DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=156 TC=0 HOPLIMIT=1 FLOWLBL=162425 PROTO=UDP SPT=49812 DPT=61117 LEN=116
[  888.295420] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:8c:ec:4b:ac:13:ab:86:dd SRC=fe80:0000:0000:0000:2d56:8c1b:23fc:2a0a DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=156 TC=0 HOPLIMIT=1 FLOWLBL=851397 PROTO=UDP SPT=49825 DPT=61117 LEN=116
[  909.885645] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=531258 PROTO=UDP SPT=56979 DPT=10001 LEN=170
[  929.898245] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=354885 PROTO=UDP SPT=54352 DPT=10001 LEN=170
[  949.912117] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=673560 PROTO=UDP SPT=56216 DPT=10001 LEN=170
[  969.924812] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=764254 PROTO=UDP SPT=54508 DPT=10001 LEN=170
[  989.936257] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=416128 PROTO=UDP SPT=56194 DPT=10001 LEN=170
[ 1009.947125] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=209850 PROTO=UDP SPT=47640 DPT=10001 LEN=170
[ 1029.961663] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=497629 PROTO=UDP SPT=41849 DPT=10001 LEN=170
[ 1049.976432] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=624620 PROTO=UDP SPT=58929 DPT=10001 LEN=170
[ 1069.988730] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=959849 PROTO=UDP SPT=55437 DPT=10001 LEN=170
[ 1089.999616] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=909797 PROTO=UDP SPT=36511 DPT=10001 LEN=170
[ 1110.011501] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=949389 PROTO=UDP SPT=45034 DPT=10001 LEN=170
[ 1130.026929] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=87201 PROTO=UDP SPT=36612 DPT=10001 LEN=170
[ 1131.810707] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=60848 PROTO=2
[ 1150.038744] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=131476 PROTO=UDP SPT=45264 DPT=10001 LEN=170
[ 1170.050420] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=313126 PROTO=UDP SPT=57483 DPT=10001 LEN=170
[ 1190.059831] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=224378 PROTO=UDP SPT=34633 DPT=10001 LEN=170
[ 1210.069427] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=315657 PROTO=UDP SPT=60016 DPT=10001 LEN=170
[ 1230.081728] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=55720 PROTO=UDP SPT=60706 DPT=10001 LEN=170
[ 1233.785907] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=17987 PROTO=2
[ 1250.094559] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=504554 PROTO=UDP SPT=35523 DPT=10001 LEN=170
[ 1270.107774] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=268708 PROTO=UDP SPT=37623 DPT=10001 LEN=170
[ 1290.120660] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=807550 PROTO=UDP SPT=50525 DPT=10001 LEN=170
[ 1310.133859] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=805601 PROTO=UDP SPT=49692 DPT=10001 LEN=170
[ 1330.146190] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=732294 PROTO=UDP SPT=36687 DPT=10001 LEN=170
[ 1350.155595] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=1013774 PROTO=UDP SPT=52642 DPT=10001 LEN=170
[ 1370.168699] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=506773 PROTO=UDP SPT=60730 DPT=10001 LEN=170
[ 1390.182479] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=422033 PROTO=UDP SPT=50781 DPT=10001 LEN=170
[ 1408.955342] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:dc:4a:3e:99:c5:6e:86:dd SRC=fe80:0000:0000:0000:fbdf:f3ed:984d:4360 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=156 TC=0 HOPLIMIT=1 FLOWLBL=509093 PROTO=UDP SPT=56925 DPT=61117 LEN=116
[ 1429.700935] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:dc:4a:3e:99:c5:6e:86:dd SRC=fe80:0000:0000:0000:fbdf:f3ed:984d:4360 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=156 TC=0 HOPLIMIT=1 FLOWLBL=748740 PROTO=UDP SPT=54453 DPT=61117 LEN=116
[ 1450.218638] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=198643 PROTO=UDP SPT=36365 DPT=10001 LEN=170
[ 1470.228525] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=153243 PROTO=UDP SPT=54671 DPT=10001 LEN=170
[ 1490.241767] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=824994 PROTO=UDP SPT=39641 DPT=10001 LEN=170
[ 1507.818509] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:dc:4a:3e:99:c5:6e:86:dd SRC=fe80:0000:0000:0000:fbdf:f3ed:984d:4360 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=156 TC=0 HOPLIMIT=1 FLOWLBL=712776 PROTO=UDP SPT=50938 DPT=61117 LEN=116
[ 1528.422416] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:dc:4a:3e:99:c5:6e:86:dd SRC=fe80:0000:0000:0000:fbdf:f3ed:984d:4360 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=156 TC=0 HOPLIMIT=1 FLOWLBL=79855 PROTO=UDP SPT=53111 DPT=61117 LEN=116
[ 1550.278364] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=834861 PROTO=UDP SPT=52949 DPT=10001 LEN=170
[ 1570.290026] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=189442 PROTO=UDP SPT=58347 DPT=10001 LEN=170
[ 1590.299295] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=837091 PROTO=UDP SPT=50401 DPT=10001 LEN=170
[ 1610.310268] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=35663 PROTO=UDP SPT=55523 DPT=10001 LEN=170
[ 1628.402521] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=81490 PROTO=UDP SPT=60835 DPT=10001 LEN=285
[ 1648.408629] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=779094 PROTO=UDP SPT=55296 DPT=10001 LEN=285
[ 1668.426233] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=57813 PROTO=UDP SPT=59387 DPT=10001 LEN=285
[ 1671.028401] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=65245 PROTO=2
[ 1688.431816] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=977106 PROTO=UDP SPT=38800 DPT=10001 LEN=285
[ 1708.461382] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=11029 PROTO=UDP SPT=37014 DPT=10001 LEN=285
[ 1728.473129] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=158615 PROTO=UDP SPT=60920 DPT=10001 LEN=285
[ 1748.478339] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=995922 PROTO=UDP SPT=34743 DPT=10001 LEN=285
[ 1768.479203] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=811904 PROTO=UDP SPT=45154 DPT=10001 LEN=285
[ 1788.491370] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=790702 PROTO=UDP SPT=45078 DPT=10001 LEN=285
[ 1808.501903] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=228720 PROTO=UDP SPT=39362 DPT=10001 LEN=285
[ 1828.518706] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=378686 PROTO=UDP SPT=51558 DPT=10001 LEN=285
[ 1844.149910] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=34302 PROTO=2
[ 1848.530447] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=1033084 PROTO=UDP SPT=53356 DPT=10001 LEN=285
[ 1868.547382] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=903458 PROTO=UDP SPT=50380 DPT=10001 LEN=285
[ 1888.567001] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=766833 PROTO=UDP SPT=38471 DPT=10001 LEN=285
[ 1908.580768] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=327680 PROTO=UDP SPT=53292 DPT=10001 LEN=285
[ 1928.587916] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=947770 PROTO=UDP SPT=53821 DPT=10001 LEN=285
[ 1933.891280] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=27130 PROTO=2
[ 1948.604584] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=373802 PROTO=UDP SPT=41893 DPT=10001 LEN=285
[ 1964.232199] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=33910 PROTO=2
[ 1968.603026] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=669481 PROTO=UDP SPT=36079 DPT=10001 LEN=285
[ 1979.741656] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=17790 PROTO=2
[ 1988.035341] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:d0:37:45:e8:0a:66:86:dd SRC=fe80:0000:0000:0000:8fb6:5307:0e6e:6133 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=156 TC=0 HOPLIMIT=1 FLOWLBL=337489 PROTO=UDP SPT=64996 DPT=61117 LEN=116
[ 2008.607851] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=932064 PROTO=UDP SPT=33332 DPT=10001 LEN=285
[ 2028.621791] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=259577 PROTO=UDP SPT=45362 DPT=10001 LEN=285
[ 2048.626912] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=685815 PROTO=UDP SPT=41070 DPT=10001 LEN=285
[ 2068.646485] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=38485 PROTO=UDP SPT=53010 DPT=10001 LEN=285
[ 2088.072027] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:d0:37:45:e8:0a:66:86:dd SRC=fe80:0000:0000:0000:8fb6:5307:0e6e:6133 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=156 TC=0 HOPLIMIT=1 FLOWLBL=493268 PROTO=UDP SPT=65052 DPT=61117 LEN=116
[ 2108.661323] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=794385 PROTO=UDP SPT=52887 DPT=10001 LEN=285
[ 2128.666962] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=414454 PROTO=UDP SPT=40237 DPT=10001 LEN=285
[ 2148.674746] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=72687 PROTO=UDP SPT=56616 DPT=10001 LEN=285
[ 2168.686324] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=748225 PROTO=UDP SPT=39470 DPT=10001 LEN=285
[ 2188.702190] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=874795 PROTO=UDP SPT=49363 DPT=10001 LEN=285
[ 2208.716965] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=685043 PROTO=UDP SPT=42344 DPT=10001 LEN=285
[ 2228.726843] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=599829 PROTO=UDP SPT=54184 DPT=10001 LEN=285
[ 2248.722958] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=920251 PROTO=UDP SPT=51761 DPT=10001 LEN=285
[ 2268.741773] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=970149 PROTO=UDP SPT=45550 DPT=10001 LEN=285
[ 2288.749478] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=277205 PROTO=UDP SPT=37808 DPT=10001 LEN=285
[ 2308.766888] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=34993 PROTO=UDP SPT=56977 DPT=10001 LEN=285
[ 2328.776424] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=781958 PROTO=UDP SPT=41713 DPT=10001 LEN=285
[ 2348.791603] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=587010 PROTO=UDP SPT=40875 DPT=10001 LEN=285
[ 2368.894546] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=491090 PROTO=UDP SPT=37178 DPT=10001 LEN=285
[ 2388.902800] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=220765 PROTO=UDP SPT=39868 DPT=10001 LEN=285
[ 2408.907430] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=526674 PROTO=UDP SPT=52178 DPT=10001 LEN=285
[ 2428.922731] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=988681 PROTO=UDP SPT=52682 DPT=10001 LEN=285
[ 2448.921550] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=465756 PROTO=UDP SPT=35543 DPT=10001 LEN=285
[ 2470.885642] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=158820 PROTO=UDP SPT=42032 DPT=10001 LEN=170
[ 2490.898075] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=60200 PROTO=UDP SPT=34995 DPT=10001 LEN=170
[ 2510.909561] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=477588 PROTO=UDP SPT=59418 DPT=10001 LEN=170
[ 2530.921562] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=709041 PROTO=UDP SPT=36410 DPT=10001 LEN=170
[ 2550.933673] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=36569 PROTO=UDP SPT=37586 DPT=10001 LEN=170
[ 2570.944784] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=132865 PROTO=UDP SPT=48383 DPT=10001 LEN=170
[ 2590.955831] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=155381 PROTO=UDP SPT=46843 DPT=10001 LEN=170
[ 2598.892180] [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:76:7a:63:a6:d7:1f:08:00 SRC=192.168.14.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=34569 PROTO=2
[ 2610.967007] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=837732 PROTO=UDP SPT=54441 DPT=10001 LEN=170
[ 2630.975974] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=620574 PROTO=UDP SPT=33564 DPT=10001 LEN=170
[ 2650.988071] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=136058 PROTO=UDP SPT=50144 DPT=10001 LEN=170
[ 2671.000325] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=838782 PROTO=UDP SPT=56897 DPT=10001 LEN=170
[ 2691.013766] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=149148 PROTO=UDP SPT=33033 DPT=10001 LEN=170
[ 2711.024196] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=347787 PROTO=UDP SPT=52692 DPT=10001 LEN=170
[ 2731.035893] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=451438 PROTO=UDP SPT=45594 DPT=10001 LEN=170
[ 2751.048286] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=856092 PROTO=UDP SPT=60798 DPT=10001 LEN=170
[ 2771.061521] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=837648 PROTO=UDP SPT=49347 DPT=10001 LEN=170
[ 2791.073569] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=950329 PROTO=UDP SPT=43364 DPT=10001 LEN=170
[ 2811.084702] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=660275 PROTO=UDP SPT=59581 DPT=10001 LEN=170
[ 2831.096115] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=669469 PROTO=UDP SPT=37946 DPT=10001 LEN=170
[ 2851.107063] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=762437 PROTO=UDP SPT=52866 DPT=10001 LEN=170
[ 2871.119858] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=603141 PROTO=UDP SPT=32812 DPT=10001 LEN=170
[ 2891.131303] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=635130 PROTO=UDP SPT=39766 DPT=10001 LEN=170
[ 2911.141848] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=364245 PROTO=UDP SPT=48587 DPT=10001 LEN=170
[ 2931.153362] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=471292 PROTO=UDP SPT=39563 DPT=10001 LEN=170
[ 2951.167550] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=1042578 PROTO=UDP SPT=42636 DPT=10001 LEN=170
[ 2971.178626] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:78:8a:20:92:f1:64:86:dd SRC=fe80:0000:0000:0000:7a8a:20ff:fe92:f164 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=210 TC=0 HOPLIMIT=1 FLOWLBL=881875 PROTO=UDP SPT=34326 DPT=10001 LEN=170
[ 2987.562918] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=779102 PROTO=UDP SPT=42983 DPT=10001 LEN=285
[ 3010.709918] [UFW BLOCK] IN=enp1s0 OUT= MAC=33:33:00:00:00:01:f0:9f:c2:29:ff:83:86:dd SRC=fe80:0000:0000:0000:f29f:c2ff:fe29:ff83 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=325 TC=0 HOPLIMIT=1 FLOWLBL=583323 PROTO=UDP SPT=50795 DPT=10001 LEN=285
Armaggion
Re: Wifi qui ne fonctionne pas linux Mint
Message par Armaggion »
Pour autant est-ce qu'il fonctionne ? Je veux dire : est-ce que c'est un problème de notification qui reste bloquée dans un statut, ou un dysfonctionnement de fond ?
Pourrais-tu être un peu plus spécifique sur le dmesg ?
sudo dmesg | egrep 'fail|warn|error'
hubbubhum
Message par hubbubhum »
le wifi ne fonctionne pas
et la commande que tu m'as suggérée ne renvoie aucun message en réponse.
Armaggion
Très bien qu'il n'y ait aucun retour à la commande précédente, c'est qu'il n'y a rien à signaler a priori.
Après vérification, ton matériel est théoriquement bien géré depuis le noyau 3.17 mais on dirait qu'il y a une régression car tous les derniers rapports le notent en "failed".
https://linux-hardware.org/?id=pci:168c-0036-1028-020e
Pourrais-tu vérifier ce que retourne la commande suivante, exécutée dans un terminal, pour écarter le fait d'un blocage matériel ou par le BIOS potentiellement ?
rfkill list all
Pas de signature de ta part (les admins vont te rattraper, fais vite ;)) mais j'imagine que tu es sur une Linux Mint 22, avec un noyau disposant de paramétrages spécifiques, correct ?
Modifié en dernier par Armaggion le jeu. 26 sept. 2024 10:40, modifié 1 fois.
hubbubhum
j'ai cette réponse :
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: yes
Armaggion
Hard blocked yes signifie que c'est un blocage matériel qui empêche ton wifi de fonctionner.
Y a-t-il un interrupteur quelque part sur ton boitier ? ou une clé de touche pour le lancer ? Sinon, une activation du chipset dans le BIOS ?
hubbubhum
oulalalalalah.... j'ai vraiment honte !
c'est le bouton sur le clavier que je n'avais pas vu et qui n'était pas activé !...
Merci beaucoup pour l'oeil affûté et désolé de vous avoir pris ce temps !
merci !
Armaggion
Tu as bien fait, sinon tu aurais peut-être tourné encore longtemps ;)
Qui plus est, tu avais fourni la réponse dès le premier post, mais elle m'avait échappé.
Problème résolu, bonne journée !
