Info
PID: 16573 (nemo)
UID: 1000 (franck)
GID: 1000 (franck)
Signal: 11 (SEGV)
Timestamp: Fri 2024-11-22 18:48:13 CET (1h 4min ago)
Command Line: /usr/bin/nemo /run/user/1000/gvfs/mtp:host=SAMSUNG_SAMSUNG_Android_RZCW20WA7WJ
Executable: /usr/bin/nemo
Control Group: /user.slice/user-1000.slice/session-c2.scope
Unit: session-c2.scope
Slice: user-1000.slice
Session: c2
Owner UID: 1000 (franck)
Boot ID: 0bd0d2a51eaa44989abb16e6b1f11323
Machine ID: ed5206852f2e4895a19544e149307aef
Hostname: franck-GB-BMCE-5105
Storage: /var/lib/systemd/coredump/core.nemo.1000.0bd0d2a51eaa44989abb16e6b1f11323.16573.1732297693000000.zst (present)
Size on Disk: 4.5M
Message: Process 16573 (nemo) of user 1000 dumped core.
Module libzstd.so.1 from deb libzstd-1.5.5+dfsg2-2build1.1.amd64
Module libgcc_s.so.1 from deb gcc-14-14.2.0-4ubuntu2~24.04.amd64
Module libstdc++.so.6 from deb gcc-14-14.2.0-4ubuntu2~24.04.amd64
Module libsystemd.so.0 from deb systemd-255.4-1ubuntu8.4.amd64
Stack trace of thread 16573:
#0 0x00005e78b88351e8 viewed_file_changed_callback (nemo + 0xae1e8)
#1 0x0000739ee72e02fa g_closure_invoke (libgobject-2.0.so.0 + 0x152fa)
#2 0x0000739ee730f90c n/a (libgobject-2.0.so.0 + 0x4490c)
#3 0x0000739ee7300591 n/a (libgobject-2.0.so.0 + 0x35591)
#4 0x0000739ee73007c1 g_signal_emit_valist (libgobject-2.0.so.0 + 0x357c1)
#5 0x0000739ee7300883 g_signal_emit (libgobject-2.0.so.0 + 0x35883)
#6 0x00005e78b887ad64 nemo_file_emit_changed (nemo + 0xf3d64)
#7 0x00005e78b885ad78 nemo_directory_emit_change_signals (nemo + 0xd3d78)
#8 0x0000739ee71cca1b g_hash_table_foreach (libglib-2.0.so.0 + 0x4aa1b)
#9 0x00005e78b88bbc2d nemo_directory_notify_files_removed (nemo + 0x134c2d)
#10 0x00005e78b888e8cd call_consume_changes_idle_cb (nemo + 0x1078cd)
#11 0x0000739ee71df48e n/a (libglib-2.0.so.0 + 0x5d48e)
#12 0x0000739ee723e717 n/a (libglib-2.0.so.0 + 0xbc717)
#13 0x0000739ee71dea53 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca53)
#14 0x0000739ee741588d g_application_run (libgio-2.0.so.0 + 0xe788d)
#15 0x00005e78b87c4e6c main (nemo + 0x3de6c)
#16 0x0000739ee6a2a1ca __libc_start_call_main (libc.so.6 + 0x2a1ca)
#17 0x0000739ee6a2a28b __libc_start_main_impl (libc.so.6 + 0x2a28b)
#18 0x00005e78b87c4ef5 _start (nemo + 0x3def5)
Stack trace of thread 16575:
#0 0x0000739ee6b2725d syscall (libc.so.6 + 0x12725d)
#1 0x0000739ee723840d g_cond_wait (libglib-2.0.so.0 + 0xb640d)
#2 0x0000739ee71a952b n/a (libglib-2.0.so.0 + 0x2752b)
#3 0x0000739ee7211043 n/a (libglib-2.0.so.0 + 0x8f043)
#4 0x0000739ee720dc82 n/a (libglib-2.0.so.0 + 0x8bc82)
#5 0x0000739ee6a9ca94 start_thread (libc.so.6 + 0x9ca94)
#6 0x0000739ee6b29c3c __clone3 (libc.so.6 + 0x129c3c)
Stack trace of thread 16576:
#0 0x0000739ee6b1b4cd __GI___poll (libc.so.6 + 0x11b4cd)
#1 0x0000739ee723e66e n/a (libglib-2.0.so.0 + 0xbc66e)
#2 0x0000739ee71dea53 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca53)
#3 0x0000739ee71deaa9 n/a (libglib-2.0.so.0 + 0x5caa9)
Stack trace of thread 16580:
#3 0x0000739ee584c595 n/a (libdconfsettings.so + 0x7595)
Stack trace of thread 16592:
#3 0x0000739ee71a958c g_async_queue_pop (libglib-2.0.so.0 + 0x2758c)
#4 0x0000739ee68b00fb n/a (libpangoft2-1.0.so.0 + 0xc0fb)
#5 0x0000739ee720dc82 n/a (libglib-2.0.so.0 + 0x8bc82)
#6 0x0000739ee6a9ca94 start_thread (libc.so.6 + 0x9ca94)
#7 0x0000739ee6b29c3c __clone3 (libc.so.6 + 0x129c3c)
Stack trace of thread 16596:
#1 0x0000739ee7238d00 g_cond_wait_until (libglib-2.0.so.0 + 0xb6d00)
#2 0x0000739ee71a94f3 n/a (libglib-2.0.so.0 + 0x274f3)
#3 0x0000739ee71a9646 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x27646)
#4 0x0000739ee72133df n/a (libglib-2.0.so.0 + 0x913df)
Stack trace of thread 16577:
#2 0x0000739ee71dff77 g_main_loop_run (libglib-2.0.so.0 + 0x5df77)
#3 0x0000739ee7448422 n/a (libgio-2.0.so.0 + 0x11a422)
ELF object binary architecture: AMD x86-64
GDB Log
warning: Can't open file /SYSV00000000 (deleted) during file-backed mapping note processing
warning: Can't open file /home/franck/.local/share/gvfs-metadata/home-4310f544.log during file-backed mapping note processing
[New LWP 16573]
[New LWP 16575]
[New LWP 16576]
[New LWP 16580]
[New LWP 16592]
[New LWP 16596]
[New LWP 16577]
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgdk-3.so.0
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgobject-2.0.so.0
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libglib-2.0.so.0
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgmodule-2.0.so.0
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libxapp.so.1
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgnomekbdui.so.8
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libcap.so.2
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libbrotlidec.so.1
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgnomekbd.so.8
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libbrotlicommon.so.1
warning: could not find '.gnu_debugaltlink' file for /usr/lib/x86_64-linux-gnu/gtk-3.0/modules/libxapp-gtk3-module.so
warning: could not find '.gnu_debugaltlink' file for /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
warning: could not find '.gnu_debugaltlink' file for /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so
warning: could not find '.gnu_debugaltlink' file for /usr/lib/x86_64-linux-gnu/gio/modules/libgioremote-volume-monitor.so
warning: could not find '.gnu_debugaltlink' file for /usr/lib/x86_64-linux-gnu/gtk-3.0/3.0.0/immodules/im-cedilla.so
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/bin/nemo /run/user/1000/gvfs/mtp:host=SAMSUNG_SAMSUNG_Android_RZCW20WA7WJ'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00005e78b88351e8 in viewed_file_changed_callback (file=0x5e78ba5f9450, slot=0x5e78ba59cff0) at ../src/nemo-window-manage-views.c:289
warning: 289 ../src/nemo-window-manage-views.c: No such file or directory
[Current thread is 1 (Thread 0x739ee5969a80 (LWP 16573))]
GDB Backtrace
[New LWP 16573]
[New LWP 16575]
[New LWP 16576]
[New LWP 16580]
[New LWP 16592]
[New LWP 16596]
[New LWP 16577]
#1 0x0000739ee72e02fa in g_closure_invoke () at /lib/x86_64-linux-gnu/libgobject-2.0.so.0
#2 0x0000739ee730f90c in ??? () at /lib/x86_64-linux-gnu/libgobject-2.0.so.0
#3 0x0000739ee7300591 in ??? () at /lib/x86_64-linux-gnu/libgobject-2.0.so.0
#4 0x0000739ee73007c1 in g_signal_emit_valist () at /lib/x86_64-linux-gnu/libgobject-2.0.so.0
#5 0x0000739ee7300883 in g_signal_emit () at /lib/x86_64-linux-gnu/libgobject-2.0.so.0
#6 0x00005e78b887ad64 in nemo_file_emit_changed (file=0x5e78ba5f9450) at ../libnemo-private/nemo-file.c:7953
#7 0x00005e78b885ad78 in nemo_directory_emit_change_signals (changed_files=<optimized out>, directory=<optimized out>) at ../libnemo-private/nemo-directory.c:776
#8 call_files_changed_common (file_list=<optimized out>, directory=<optimized out>) at ../libnemo-private/nemo-directory.c:870
#9 call_files_changed_unref_free_list (key=0x5e78ba5f87c0, value=0x5e78ba8ec6f0, user_data=<optimized out>) at ../libnemo-private/nemo-directory.c:889
#10 0x0000739ee71cca1b in g_hash_table_foreach () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#11 0x00005e78b88bbc2d in nemo_directory_notify_files_removed (files=<optimized out>) at ../libnemo-private/nemo-directory.c:1158
#12 nemo_file_changes_consume_changes.constprop.0 (consume_all=1) at ../libnemo-private/nemo-file-changes-queue.c:314
#13 0x00005e78b888e8cd in call_consume_changes_idle_cb (not_used=<optimized out>) at ../libnemo-private/nemo-monitor.c:69
#14 0x0000739ee71df48e in ??? () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#15 0x0000739ee723e717 in ??? () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#16 0x0000739ee71dea53 in g_main_context_iteration () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#17 0x0000739ee741588d in g_application_run () at /lib/x86_64-linux-gnu/libgio-2.0.so.0
#18 0x00005e78b87c4e6c in main (argc=2, argv=0x7fff03c179c8) at ../src/nemo-main.c:104
GDB Backtrace (all threads)
[New LWP 16573]
[New LWP 16575]
[New LWP 16576]
[New LWP 16580]
[New LWP 16592]
[New LWP 16596]
[New LWP 16577]
Thread 7 (Thread 0x739ee1a006c0 (LWP 16577)):
#0 0x0000739ee6b1b4cd in __GI___poll (fds=0x5e78ba619420, nfds=6, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
sc_ret = 2
sc_cancel_oldtype = 0
sc_ret = <optimized out>
#1 0x0000739ee723e66e in ??? () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2 0x0000739ee71dff77 in g_main_loop_run () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x0000739ee7448422 in ??? () at /lib/x86_64-linux-gnu/libgio-2.0.so.0
#4 0x0000739ee720dc82 in ??? () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#5 0x0000739ee6a9ca94 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:447
pd = <optimized out>
out = <optimized out>
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {127126227388096, -7096406159351827538, 127126227388096, -128, 11, 140733256392912, -7096406159406353490, -7096390577405906002}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
not_first_call = <optimized out>
#6 0x0000739ee6b29c3c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:78
Thread 6 (Thread 0x739ecfe006c0 (LWP 16596)):
#0 syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
#1 0x0000739ee7238d00 in g_cond_wait_until () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2 0x0000739ee71a94f3 in ??? () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x0000739ee71a9646 in g_async_queue_timeout_pop () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#4 0x0000739ee72133df in ??? () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#5 0x0000739ee720dc82 in ??? () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#6 0x0000739ee6a9ca94 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:447
