J'ai un lecteur de DVD externe et certains DVD font planter VLC (et Totem) quand j'essaie de les lire.
Par exemple ici avec... La Soupe aux Choux (un classique !
totem
(totem:221692): GLib-GObject-CRITICAL **: 14:02:22.817: g_param_values_cmp: assertion 'G_IS_VALUE (value1)' failed
(totem:221692): Tracker-WARNING **: 14:02:22.818: Error getting remote connection 'dbus:org.freedesktop.Tracker3.Miner.Files:/org/freedesktop/Tracker3/Endpoint': GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Tracker3.Miner.Files was not provided by any .service files
(totem:221692): Grilo-WARNING **: 14:02:22.821: [tracker-source-request] ../src/tracker3/grl-tracker-source-api.c:339: error in parsing query id=7 : In service 'dbus:org.freedesktop.Tracker3.Miner.Files': GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Tracker3.Miner.Files was not provided by any .service files
libdvdread: Attempting to use device /dev/sr0 mounted on /media/fish/_LA SOUPE AUX CHOUX_ for CSS authentication
libdvdread: Zero check failed in src/ifo_read.c:570 for vmgi_mat->zero_6 : 0x0000000f00000000000000000000000000000000000000000000000000000000
libdvdnav: Can't read name block. Probably not a DVD-ROM device.
libdvdnav: vm: dvd_read_name failed
libdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions: 01 02 03 04 05 06 07 08
libdvdread: Attempting to retrieve all CSS keys
libdvdread: This can take a _long_ time, please be patient
libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x00000174
libdvdread: Elapsed time 0
libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x00001722
libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x00001742
libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x0000175e
libdvdread: Get key for /VIDEO_TS/VTS_04_1.VOB at 0x0000177a
libdvdread: Get key for /VIDEO_TS/VTS_05_1.VOB at 0x00001796
libdvdread: Found 5 VTS's
libdvdread: CHECK_VALUE failed in src/ifo_read.c:839 for cell_playback[i].first_sector <= cell_playback[i].last_vobu_start_sector
totem: src/vm/play.c :210 : play_Cell: l'assertion « (vm->state).pgc->cell_playback[(vm->state).cellN - 1].block_type == 0 » a échoué.
Abandon (core dumped)
vlc
VLC media player 3.0.16 Vetinari (revision 3.0.13-8-g41878ff4f2)
[00005649284e0580] main libvlc: Lancement de vlc avec l'interface par défaut. Utiliser « cvlc » pour démarrer VLC sans interface.
[0000564928588e00] main playlist: playlist is empty
[00007f1b8c001130] dvdread demux error: Zero check failed in src/ifo_read.c:570 for vmgi_mat->zero_6 : 0x0000000f00000000000000000000000000000000000000000000000000000000
[00007f1b8c001130] dvdread demux error: DvdReadSetArea(0,0,1) failed (can't decrypt DVD?)
[00007f1b8c000b40] dvdread demux error: Zero check failed in src/ifo_read.c:570 for vmgi_mat->zero_6 : 0x0000000f00000000000000000000000000000000000000000000000000000000
[00007f1b8c000b40] dvdread demux error: DvdReadSetArea(0,0,1) failed (can't decrypt DVD?)
[00007f1b8c0009a0] dvdread demux error: Zero check failed in src/ifo_read.c:570 for vmgi_mat->zero_6 : 0x0000000f00000000000000000000000000000000000000000000000000000000
[00007f1b8c0009a0] dvdread demux error: DvdReadSetArea(0,0,1) failed (can't decrypt DVD?)
[00007f1b8c03bc10] dvdread demux error: Zero check failed in src/ifo_read.c:570 for vmgi_mat->zero_6 : 0x0000000f00000000000000000000000000000000000000000000000000000000
[00007f1b8c03bc10] dvdread demux error: DvdReadSetArea(0,0,1) failed (can't decrypt DVD?)
[00007f1b8c03ba50] dvdread demux error: Zero check failed in src/ifo_read.c:570 for vmgi_mat->zero_6 : 0x0000000f00000000000000000000000000000000000000000000000000000000
[00007f1b8c03ba50] dvdread demux error: DvdReadSetArea(0,0,1) failed (can't decrypt DVD?)
QObject::~QObject: Timers cannot be stopped from another threadMerci par avance !
