J'ai encore un soucis sur mon installe, à chaque fois que je ferme l'ordinateur, au redémarrage, j'ai un fichier nommé "hs_err_pid2389.log" qui se créé à la racine de mon /home :
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x000070f6fda4798b, pid=2389, tid=2441
# JRE version: OpenJDK Runtime Environment (21.0.2+13) (build 21.0.2+13-58)
# Java VM: OpenJDK 64-Bit Server VM (21.0.2+13-58, mixed mode, tiered, compressed oops, compressed class ptrs, g1 gc, linux-amd64)
# Problematic frame:
# C [libc.so.6+0x4798b]
# Core dump will be written. Default location: Core dumps may be processed with "/usr/lib/systemd/systemd-coredump %P %u %g %s %t 9223372036854775808 %h" (or dumping to /home/toto/core.2389)
# If you would like to submit a bug report, please visit:
# https://bugreport.java.com/bugreport/crash.jsp
--------------- S U M M A R Y ------------
Command Line: -Djpackage.app-version=2.4.2 -Dolvid.sqlcipher=true -Dolvid.dev=false -Dolvid.packaged=true -Dolvid.multiuser=false -Dolvid.debug=false -Dolvid.version=2.4.2 -Djava.net.useSystemProxies=true -Djpackage.app-path=/opt/olvid/bin/olvid io.olvid.windows.messenger.start_up.Launcher
Host: 13th Gen Intel(R) Core(TM) i5-1335U, 12 cores, 15G, Linux Mint 22.1 Xia
Time: Wed Apr 30 14:46:56 2025 CEST elapsed time: 37203.782519 seconds (0d 10h 20m 3s)
--------------- T H R E A D ---------------
Current thread (0x000070f6f8153220): VMThread "VM Thread" [id=2441, stack(0x000070f6e0e49000,0x000070f6e0f49000) (1024K)]
Stack: [0x000070f6e0e49000,0x000070f6e0f49000], sp=0x000070f6e0f47880, free space=1018k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [libc.so.6+0x47bbe]
V [libjvm.so+0xcce379]
V [libjvm.so+0x8e0d1a]
V [libjvm.so+0xf31007] VM_Operation::evaluate()+0x107
V [libjvm.so+0xf3356b] VMThread::evaluate_operation(VM_Operation*)+0xbb
V [libjvm.so+0xf341b7] VMThread::inner_execute(VM_Operation*)+0x357
V [libjvm.so+0xf344b7] VMThread::run()+0xb7
V [libjvm.so+0xe9e998] Thread::call_run()+0xa8
V [libjvm.so+0xcc444a] thread_native_entry(Thread*)+0xda
C [libc.so.6+0x9caa4]
siginfo: si_signo: 11 (SIGSEGV), si_code: 128 (SI_KERNEL), si_addr: 0x0000000000000000
Registers:
RAX=0x000e8fc1580abb30, RBX=0x000070f6fdc04fa8, RCX=0x000070f6fda98f0b, RDX=0x0000000000000002
RSP=0x000070f6e0f47880, RBP=0x000070f6e0f478d0, RSI=0x0000000000000080, RDI=0x000070f6fdc04fa8
R8 =0x000070f657f7ae88, R9 =0x0000000000000007, R10=0x0000000000000000, R11=0x0000000000000246
R12=0x0000000000000a69, R13=0x0000000000000000, R14=0x000000000000008f, R15=0x000070f6580aa950
RIP=0x000070f6fda4798b, EFLAGS=0x0000000000010206, CSGSFS=0x002b000000000033, ERR=0x0000000000000000
TRAPNO=0x000000000000000d
Register to memory mapping:
RAX=0x000e8fc1580abb30 is an unknown value
RBX=0x000070f6fdc04fa8: <offset 0x0000000000204fa8> in /lib/x86_64-linux-gnu/libc.so.6 at 0x000070f6fda00000
RCX=0x000070f6fda98f0b: __lll_lock_wait_private+0x000000000000002b in /lib/x86_64-linux-gnu/libc.so.6 at 0x000070f6fda00000
RDX=0x0000000000000002 is an unknown value
RSP=0x000070f6e0f47880 points into unknown readable memory: 0x00000001f8153220 | 20 32 15 f8 01 00 00 00
RBP=0x000070f6e0f478d0 points into unknown readable memory: 0x000070f6e0f478e0 | e0 78 f4 e0 f6 70 00 00
RSI=0x0000000000000080 is an unknown value
RDI=0x000070f6fdc04fa8: <offset 0x0000000000204fa8> in /lib/x86_64-linux-gnu/libc.so.6 at 0x000070f6fda00000
R8 =0x000070f657f7ae88: <offset 0x0000000007b7ae88> in /lib/x86_64-linux-gnu/libLLVM.so.19.1 at 0x000070f650400000
R9 =0x0000000000000007 is an unknown value
R10=0x0 is null
R11=0x0000000000000246 is an unknown value
R12=0x0000000000000a69 is an unknown value
R13=0x0 is null
R14=0x000000000000008f is an unknown value
R15=0x000070f6580aa950 points into unknown readable memory: 0x000070f6580ab2c0 | c0 b2 0a 58 f6 70 00 00
Top of Stack: (sp=0x000070f6e0f47880)
0x000070f6e0f47880: 00000001f8153220 000070f6e0f478a8
0x000070f6e0f47890: 000070f6e0f47910 000070f6fdc03680
0x000070f6e0f478a0: 000070f6e0f47900 000070f6fd86a660
0x000070f6e0f478b0: 000000000000008f 000070f6f81e0110
0x000070f6e0f478c0: 000070f6f81d1650 000070f550d7c6e0
0x000070f6e0f478d0: 000070f6e0f478e0 000070f6fda47bbe
0x000070f6e0f478e0: 000070f6e0f478f0 000070f6fd0ce379
0x000070f6e0f478f0: 000070f6e0f47910 000070f6fcce0d1a
0x000070f6e0f47900: 000070f6f81d1650 000070f6f81d1650
0x000070f6e0f47910: 000070f6e0f47a20 000070f6fd331007
0x000070f6e0f47920: 000070f6e0f479e0 00000000000003d8
0x000070f6e0f47930: 000070f6f81d1650 000070f6f81d1660
0x000070f6e0f47940: 000070f6f81d1a38 000070f6f81d1660
0x000070f6e0f47950: 00000000ffffffff 000070f6b800bd00
0x000070f6e0f47960: 000070f600000005 0000000000000000
0x000070f6e0f47970: 000070f6e0f40100 0000000000000000
0x000070f6e0f47980: 0000000000000000 0000000000000000
0x000070f6e0f47990: 000070f6f8153220 000070f6fd829780
0x000070f6e0f479a0: 000000000000005c 00000000000000e6
0x000070f6e0f479b0: 000070f6e0f479c0 000070f6e0f47a70
0x000070f6e0f479c0: 000070f550d7c6e0 00000000000003d8
0x000070f6e0f479d0: 000070f6e0f479e0 000070f6fdaec96d
0x000070f6e0f479e0: 000070f6e0f47a00 f45c97dadd830a00
0x000070f6e0f479f0: 000000000000918c 000070f6f81e0110
0x000070f6e0f47a00: 000070f550d7c6e0 00000000000003d8
0x000070f6e0f47a10: 000070f6f81d1650 000070f6e0f47a70
0x000070f6e0f47a20: 000070f6e0f47b00 000070f6fd33356b
0x000070f6e0f47a30: 0000000000000c15 0000000000000000
0x000070f6e0f47a40: 0000000000000000 0000000000000000
0x000070f6e0f47a50: 000070f6f81d1650 000070f6f81d1660
0x000070f6e0f47a60: 000070f6f81d1a38 000070f6f81d1660
0x000070f6e0f47a70: 0000000000000000 000021d61af11c20
Instructions: (pc=0x000070f6fda4798b)
0x000070f6fda4788b: 00 00 75 02 c9 c3 e8 fa 05 0f 00 66 2e 0f 1f 84
0x000070f6fda4789b: 00 00 00 00 00 f3 0f 1e fa 55 48 89 e5 41 54 49
0x000070f6fda478ab: 89 fc 53 48 89 d3 e8 1a ff ff ff 85 c0 78 4b 41
0x000070f6fda478bb: 0f b7 4c 24 02 41 0f b7 44 24 04 89 ca c1 e0 04
0x000070f6fda478cb: 66 c1 ea 0c c1 e1 14 0f b7 d2 09 d0 41 0f b7 14
0x000070f6fda478db: 24 0d 00 00 f0 3f c1 e2 04 48 c1 e0 20 09 ca 48
0x000070f6fda478eb: 09 d0 66 48 0f 6e c0 f2 0f 5c 05 ce e4 18 00 31
0x000070f6fda478fb: c0 f2 0f 11 03 5b 41 5c 5d c3 b8 ff ff ff ff eb
0x000070f6fda4790b: f4 0f 1f 40 00 f3 0f 1e fa 55 48 89 e5 41 57 41
0x000070f6fda4791b: 56 41 89 fe 41 55 41 54 53 48 83 ec 28 48 89 75
0x000070f6fda4792b: c8 89 55 b4 84 c9 0f 85 2e 02 00 00 48 8d 1d 6a
0x000070f6fda4793b: d6 1b 00 31 c0 ba 01 00 00 00 f0 0f b1 13 0f 85
0x000070f6fda4794b: 37 02 00 00 48 8b 45 c8 4c 8b 38 4d 85 ff 0f 84
0x000070f6fda4795b: b1 00 00 00 45 31 ed 66 0f 1f 44 00 00 49 8b 47
0x000070f6fda4796b: 08 48 85 c0 0f 84 63 01 00 00 48 83 e8 01 4c 8b
0x000070f6fda4797b: 25 20 d6 1b 00 49 89 47 08 48 c1 e0 05 4c 01 f8
0x000070f6fda4798b: 48 8b 48 10 48 83 f9 03 0f 84 ff 00 00 00 48 83
0x000070f6fda4799b: f9 04 0f 84 9d 00 00 00 48 83 f9 02 75 bf 48 8b
0x000070f6fda479ab: 48 18 48 8b 70 20 48 89 c8 44 89 e9 48 c1 c8 11
0x000070f6fda479bb: 64 48 33 04 25 30 00 00 00 87 0b 83 f9 01 0f 8f
0x000070f6fda479cb: 59 01 00 00 44 89 f7 ff d0 b9 01 00 00 00 44 89
0x000070f6fda479db: e8 f0 0f b1 0b 0f 85 a2 00 00 00 48 8b 05 b3 d5
0x000070f6fda479eb: 1b 00 4c 39 e0 0f 84 72 ff ff ff 48 8b 45 c8 4c
0x000070f6fda479fb: 8b 38 4d 85 ff 0f 85 62 ff ff ff 66 2e 0f 1f 84
0x000070f6fda47a0b: 00 00 00 00 00 31 c0 c6 05 cf d9 1b 00 01 87 03
0x000070f6fda47a1b: 83 f8 01 0f 8f 55 01 00 00 80 7d b4 00 0f 85 41
0x000070f6fda47a2b: 01 00 00 44 89 f7 e8 ca 67 0a 00 66 2e 0f 1f 84
0x000070f6fda47a3b: 00 00 00 00 00 48 8b 48 18 4c 8b 40 20 48 c7 40
0x000070f6fda47a4b: 10 00 00 00 00 48 89 c8 44 89 e9 48 c1 c8 11 64
0x000070f6fda47a5b: 48 33 04 25 30 00 00 00 87 0b 83 f9 01 0f 8f da
0x000070f6fda47a6b: 00 00 00 44 89 f6 4c 89 c7 ff d0 b9 01 00 00 00
0x000070f6fda47a7b: 44 89 e8 f0 0f b1 0b 0f 84 5e ff ff ff 48 89 df
Stack slot to memory mapping:
stack at sp + 0 slots: 0x00000001f8153220 is an unknown value
stack at sp + 1 slots: 0x000070f6e0f478a8 points into unknown readable memory: 0x000070f6fd86a660 | 60 a6 86 fd f6 70 00 00
stack at sp + 2 slots: 0x000070f6e0f47910 points into unknown readable memory: 0x000070f6e0f47a20 | 20 7a f4 e0 f6 70 00 00
stack at sp + 3 slots: 0x000070f6fdc03680: <offset 0x0000000000203680> in /lib/x86_64-linux-gnu/libc.so.6 at 0x000070f6fda00000
stack at sp + 4 slots: 0x000070f6e0f47900 points into unknown readable memory: 0x000070f6f81d1650 | 50 16 1d f8 f6 70 00 00
stack at sp + 5 slots: 0x000070f6fd86a660: <offset 0x000000000146a660> in /opt/olvid/lib/runtime/lib/server/libjvm.so at 0x000070f6fc400000
stack at sp + 6 slots: 0x000000000000008f is an unknown value
stack at sp + 7 slots: 0x000070f6f81e0110 points into unknown readable memory: 0x0000000000000002 | 02 00 00 00 00 00 00 00
VM_Operation (0x000070f550d7c6e0): Exit, mode: safepoint, requested by thread 0x000070f6b40094b0
--------------- P R O C E S S ---------------
Threads class SMR info:
_java_thread_list=0x000070f6b400a510, length=92, elements={
0x000070f6f8028d10, 0x000070f6f8224100, 0x000070f6f8225150, 0x000070f6f82282a0,
0x000070f6f8239850, 0x000070f6f823b2e0, 0x000070f6f823c950, 0x000070f6f82c1450,
0x000070f6f82c6750, 0x000070f6f8a51b60, 0x000070f6f8a527f0, 0x000070f6f8a57360,
0x000070f67c2cd7f0, 0x000070f67c1db920, 0x000070f6280a1420, 0x000070f6280f4ce0,
0x000070f6280f62a0, 0x000070f6280ff150, 0x000070f628217510, 0x000070f629237e70,
0x000070f60052eca0, 0x000070f6006bac00, 0x000070f6008e6330, 0x000070f60097fcb0,
0x000070f6009824e0, 0x000070f6009861b0, 0x000070f60098a630, 0x000070f60098c870,
0x000070f60098eab0, 0x000070f6009911e0, 0x000070f600993610, 0x000070f600995b40,
0x000070f6009995f0, 0x000070f60099b830, 0x000070f60099da70, 0x000070f60099fcb0,
0x000070f6009a2410, 0x000070f6009a4950, 0x000070f6009a85b0, 0x000070f6009aa7f0,
0x000070f6009aca30, 0x000070f6009aec70, 0x000070f6009b0ed0, 0x000070f6009b3680,
0x000070f6009b7570, 0x000070f6009b9a80, 0x000070f6009bc0b0, 0x000070f6009bfe70,
0x000070f6009c20b0, 0x000070f6009c4720, 0x000070f6009c8770, 0x000070f6009ca9b0,
0x000070f6009cd030, 0x000070f6009cf810, 0x000070f6009fe0a0, 0x000070f600a14400,
0x000070f600a16ae0, 0x000070f600988dd0, 0x000070f6009e9120, 0x000070f600a18520,
0x000070f60094ba20, 0x000070f60094cbd0, 0x000070f6700776a0, 0x000070f6292b6170,
0x000070f54c0a49e0, 0x000070f54c0a7670, 0x000070f5841ae560, 0x000070f58c03c830,
0x000070f55c0018c0, 0x000070f62957b0c0, 0x000070f6294a0120, 0x000070f62949e6b0,
0x000070f629694050, 0x000070f629694ca0, 0x000070f5e4004d10, 0x000070f5740041d0,
0x000070f5740048e0, 0x000070f57400e0d0, 0x000070f57400ea70, 0x000070f57400f990,
0x000070f574010d10, 0x000070f574012260, 0x000070f5740137b0, 0x000070f574015100,
0x000070f574016a50, 0x000070f5740180e0, 0x000070f574019a40, 0x000070f57401b3b0,
0x000070f57401cd20, 0x000070f629485560, 0x000070f6b40094b0, 0x000070f6b400a860
Java Threads: ( => current thread )
0x000070f6f8028d10 JavaThread "main" [_thread_blocked, id=2434, stack(0x000070f6fc300000,0x000070f6fc400000) (1024K)]
0x000070f6f8224100 JavaThread "Reference Handler" daemon [_thread_blocked, id=2442, stack(0x000070f6e0500000,0x000070f6e0600000) (1024K)]
0x000070f6f8225150 JavaThread "Finalizer" daemon [_thread_blocked, id=2443, stack(0x000070f6e0400000,0x000070f6e0500000) (1024K)]
0x000070f6f82282a0 JavaThread "Service Thread" daemon [_thread_blocked, id=2445, stack(0x000070f6e0200000,0x000070f6e0300000) (1024K)]
0x000070f6f8239850 JavaThread "Monitor Deflation Thread" daemon [_thread_blocked, id=2446, stack(0x000070f6e0100000,0x000070f6e0200000) (1024K)]
0x000070f6f823b2e0 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=2447, stack(0x000070f6e0000000,0x000070f6e0100000) (1024K)]
0x000070f6f823c950 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=2448, stack(0x000070f6d1f00000,0x000070f6d2000000) (1024K)]
0x000070f6f82c1450 JavaThread "Notification Thread" daemon [_thread_blocked, id=2449, stack(0x000070f6d1e00000,0x000070f6d1f00000) (1024K)]
0x000070f6f82c6750 JavaThread "Common-Cleaner" daemon [_thread_blocked, id=2450, stack(0x000070f6d1d00000,0x000070f6d1e00000) (1024K)]
0x000070f6f8a51b60 JavaThread "App-TcpServerThread" [_thread_in_native, id=2464, stack(0x000070f6d1c00000,0x000070f6d1d00000) (1024K)]
0x000070f6f8a527f0 JavaThread "App-TcpServerMessageNotifier" [_thread_blocked, id=2465, stack(0x000070f6d1b00000,0x000070f6d1c00000) (1024K)]
0x000070f6f8a57360 JavaThread "JavaFX-Launcher" [_thread_blocked, id=2480, stack(0x000070f6d109e000,0x000070f6d119e000) (1024K)]
0x000070f67c2cd7f0 JavaThread "InvokeLaterDispatcher" daemon [_thread_blocked, id=2519, stack(0x000070f64c07c000,0x000070f64c17c000) (1024K)]
0x000070f67c1db920 JavaThread "JavaFX Application Thread" [_thread_in_native, id=2520, stack(0x000070f6476ff000,0x000070f6477ff000) (1024K)]
0x000070f6280a1420 JavaThread "App-LiveDataCallBackExecutor" [_thread_blocked, id=2526, stack(0x000070f6d0f9e000,0x000070f6d109e000) (1024K)]
0x000070f6280f4ce0 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=2527, stack(0x000070f644b22000,0x000070f644c22000) (1024K)]
0x000070f6280f62a0 JavaThread "AWT-XAWT" daemon [_thread_blocked, id=2528, stack(0x000070f644700000,0x000070f644800000) (1024K)]
0x000070f6280ff150 JavaThread "Cleaner-0" daemon [_thread_blocked, id=2529, stack(0x000070f644600000,0x000070f644700000) (1024K)]
0x000070f628217510 JavaThread "App-AsyncTaskExecutor-2" [_thread_blocked, id=2537, stack(0x000070f644400000,0x000070f644500000) (1024K)]
0x000070f629237e70 JavaThread "Cleaner-1" daemon [_thread_blocked, id=2542, stack(0x000070f5ffe00000,0x000070f5fff00000) (1024K)]
0x000070f60052eca0 JavaThread "Engine-DeviceDiscoveryTimer" [_thread_blocked, id=2569, stack(0x000070f644500000,0x000070f644600000) (1024K)]
0x000070f6006bac00 JavaThread "Engine-WellKnownDownloadTimer" [_thread_blocked, id=2580, stack(0x000070f5ff300000,0x000070f5ff400000) (1024K)]
0x000070f6008e6330 JavaThread "Engine-EngineNotificationPosting" [_thread_blocked, id=2606, stack(0x000070f5ff100000,0x000070f5ff200000) (1024K)]
0x000070f60097fcb0 JavaThread "Engine-CreateServerSessionCoordinator-0" [_thread_blocked, id=2612, stack(0x000070f5ff000000,0x000070f5ff100000) (1024K)]
0x000070f6009824e0 JavaThread "Engine-CreateServerSessionCoordinator-QueryApiKeyStatus-0" [_thread_blocked, id=2613, stack(0x000070f5fef00000,0x000070f5ff000000) (1024K)]
0x000070f6009861b0 JavaThread "Engine-DeleteMessageAndAttachmentsCoordinator-0" [_thread_blocked, id=2614, stack(0x000070f5fee00000,0x000070f5fef00000) (1024K)]
0x000070f60098a630 JavaThread "Engine-DownloadAttachmentCoordinator-weight-0" [_thread_blocked, id=2615, stack(0x000070f5fed00000,0x000070f5fee00000) (1024K)]
0x000070f60098c870 JavaThread "Engine-DownloadAttachmentCoordinator-weight-1" [_thread_blocked, id=2616, stack(0x000070f5fec00000,0x000070f5fed00000) (1024K)]
0x000070f60098eab0 JavaThread "Engine-DownloadAttachmentCoordinator-weight-2" [_thread_blocked, id=2617, stack(0x000070f5feb00000,0x000070f5fec00000) (1024K)]
0x000070f6009911e0 JavaThread "Engine-DownloadAttachmentCoordinator-weight-3" [_thread_blocked, id=2618, stack(0x000070f5fea00000,0x000070f5feb00000) (1024K)]
0x000070f600993610 JavaThread "Engine-DownloadAttachmentCoordinator-timestamp-0" [_thread_blocked, id=2619, stack(0x000070f5fe900000,0x000070f5fea00000) (1024K)]
0x000070f600995b40 JavaThread "Engine-DownloadAttachmentCoordinator-timestamp-1" [_thread_blocked, id=2620, stack(0x000070f5fe800000,0x000070f5fe900000) (1024K)]
0x000070f6009995f0 JavaThread "Engine-DownloadAttachmentCoordinator-timestamp-2" [_thread_blocked, id=2621, stack(0x000070f5fe700000,0x000070f5fe800000) (1024K)]
0x000070f60099b830 JavaThread "Engine-DownloadAttachmentCoordinator-timestamp-3" [_thread_blocked, id=2622, stack(0x000070f5fe600000,0x000070f5fe700000) (1024K)]
0x000070f60099da70 JavaThread "Engine-DownloadMessagesExtendedPayloadCoordinator-0" [_thread_blocked, id=2623, stack(0x000070f5fe500000,0x000070f5fe600000) (1024K)]
0x000070f60099fcb0 JavaThread "Engine-DownloadMessagesAndListAttachmentsCoordinator-0" [_thread_blocked, id=2624, stack(0x000070f5fe400000,0x000070f5fe500000) (1024K)]
0x000070f6009a2410 JavaThread "Engine-FreeTrialCoordinator-0" [_thread_blocked, id=2625, stack(0x000070f5fe300000,0x000070f5fe400000) (1024K)]
0x000070f6009a4950 JavaThread "Engine-GetTurnCredentialsCoordinator-0" [_thread_blocked, id=2626, stack(0x000070f5fe200000,0x000070f5fe300000) (1024K)]
0x000070f6009a85b0 JavaThread "Engine-RefreshInboxAttachmentSignedUrlCoordinator-0" [_thread_blocked, id=2627, stack(0x000070f5fe100000,0x000070f5fe200000) (1024K)]
0x000070f6009aa7f0 JavaThread "Engine-RegisterServerPushNotificationsCoordinator-0" [_thread_blocked, id=2628, stack(0x000070f5fe000000,0x000070f5fe100000) (1024K)]
0x000070f6009aca30 JavaThread "Engine-ServerQueryCoordinator-0" [_thread_blocked, id=2629, stack(0x000070f5fdf00000,0x000070f5fe000000) (1024K)]
0x000070f6009aec70 JavaThread "Engine-ServerUserDataCoordinator-delete-0" [_thread_blocked, id=2630, stack(0x000070f5fde00000,0x000070f5fdf00000) (1024K)]
0x000070f6009b0ed0 JavaThread "Engine-ServerUserDataCoordinator-refresh-0" [_thread_blocked, id=2631, stack(0x000070f5fdd00000,0x000070f5fde00000) (1024K)]
0x000070f6009b3680 JavaThread "Engine-VerifyReceiptCoordinator-0" [_thread_blocked, id=2632, stack(0x000070f5fdc00000,0x000070f5fdd00000) (1024K)]
0x000070f6009b7570 JavaThread "Engine-WebsocketCoordinator-create-0" [_thread_blocked, id=2633, stack(0x000070f5fdb00000,0x000070f5fdc00000) (1024K)]
0x000070f6009b9a80 JavaThread "Engine-WebsocketCoordinator-register-0" [_thread_blocked, id=2634, stack(0x000070f5fda00000,0x000070f5fdb00000) (1024K)]
0x000070f6009bc0b0 JavaThread "Engine-WellKnownDownloadCoordinator-0" [_thread_blocked, id=2635, stack(0x000070f5fd900000,0x000070f5fda00000) (1024K)]
0x000070f6009bfe70 JavaThread "Engine-CancelAttachmentUploadCoordinator-0" [_thread_blocked, id=2636, stack(0x000070f5fd800000,0x000070f5fd900000) (1024K)]
0x000070f6009c20b0 JavaThread "Engine-RefreshOutboxAttachmentSignedUrlCoordinator-0" [_thread_blocked, id=2637, stack(0x000070f5fd700000,0x000070f5fd800000) (1024K)]
0x000070f6009c4720 JavaThread "Engine-SendAttachmentCoordinator-0" [_thread_blocked, id=2638, stack(0x000070f5fd600000,0x000070f5fd700000) (1024K)]
0x000070f6009c8770 JavaThread "Engine-SendAttachmentCoordinator-1" [_thread_blocked, id=2639, stack(0x000070f5fd500000,0x000070f5fd600000) (1024K)]
0x000070f6009ca9b0 JavaThread "Engine-SendAttachmentCoordinator-2" [_thread_blocked, id=2640, stack(0x000070f5fd400000,0x000070f5fd500000) (1024K)]
0x000070f6009cd030 JavaThread "Engine-SendAttachmentCoordinator-3" [_thread_blocked, id=2641, stack(0x000070f5fd300000,0x000070f5fd400000) (1024K)]
0x000070f6009cf810 JavaThread "Engine-SendMessageCoordinator-WithAttachment-0" [_thread_blocked, id=2642, stack(0x000070f5fd200000,0x000070f5fd300000) (1024K)]
0x000070f6009fe0a0 JavaThread "Engine-SendMessageCoordinator-WithUserContent-0" [_thread_blocked, id=2643, stack(0x000070f5fd100000,0x000070f5fd200000) (1024K)]
0x000070f600a14400 JavaThread "Engine-SendMessageCoordinator-Protocol-0" [_thread_blocked, id=2644, stack(0x000070f5fd000000,0x000070f5fd100000) (1024K)]
0x000070f600a16ae0 JavaThread "Engine-SendReturnReceiptCoordinator-0" [_thread_blocked, id=2645, stack(0x000070f5fcf00000,0x000070f5fd000000) (1024K)]
0x000070f600988dd0 JavaThread "Engine-ProtocolStepCoordinator-0" [_thread_blocked, id=2646, stack(0x000070f5fce00000,0x000070f5fcf00000) (1024K)]
0x000070f6009e9120 JavaThread "App-AsyncTaskExecutor-3" [_thread_blocked, id=2655, stack(0x000070f5fcd00000,0x000070f5fce00000) (1024K)]
0x000070f600a18520 JavaThread "KeycloakManagerRetryTimer" [_thread_blocked, id=2656, stack(0x000070f5fcc00000,0x000070f5fcd00000) (1024K)]
0x000070f60094ba20 JavaThread "App-AsyncTaskExecutor-4" [_thread_blocked, id=2663, stack(0x000070f552fff000,0x000070f5530ff000) (1024K)]
0x000070f60094cbd0 JavaThread "pool-1-thread-1" [_thread_blocked, id=2664, stack(0x000070f552eff000,0x000070f552fff000) (1024K)]
0x000070f6700776a0 JavaThread "App-LiveDataStatementExecutor" [_thread_blocked, id=2666, stack(0x000070f552cff000,0x000070f552dff000) (1024K)]
0x000070f6292b6170 JavaThread "Prism Font Disposer" daemon [_thread_blocked, id=2671, stack(0x000070f5fc0a1000,0x000070f5fc1a1000) (1024K)]
0x000070f54c0a49e0 JavaThread "OkHttp TaskRunner" daemon [_thread_blocked, id=2681, stack(0x000070f552bff000,0x000070f552cff000) (1024K)]
0x000070f54c0a7670 JavaThread "Okio Watchdog" daemon [_thread_blocked, id=2684, stack(0x000070f5529ff000,0x000070f552aff000) (1024K)]
0x000070f5841ae560 JavaThread "pool-14-thread-1" [_thread_blocked, id=2686, stack(0x000070f5528ff000,0x000070f5529ff000) (1024K)]
0x000070f58c03c830 JavaThread "OkHttp https://ws-server.olvid.io/..." [_thread_in_native, id=2687, stack(0x000070f5527ff000,0x000070f5528ff000) (1024K)]
0x000070f55c0018c0 JavaThread "OkHttp TaskRunner" daemon [_thread_blocked, id=2689, stack(0x000070f5ff200000,0x000070f5ff300000) (1024K)]
0x000070f62957b0c0 JavaThread "pool-24-thread-1" [_thread_blocked, id=2696, stack(0x000070f5526ff000,0x000070f5527ff000) (1024K)]
0x000070f6294a0120 JavaThread "pool-23-thread-1" [_thread_blocked, id=2697, stack(0x000070f551dfe000,0x000070f551efe000) (1024K)]
0x000070f62949e6b0 JavaThread "App-AsyncTaskExecutor-5" [_thread_blocked, id=2729, stack(0x000070f551cfe000,0x000070f551dfe000) (1024K)]
0x000070f629694050 JavaThread "App-UtilityNotifier" [_thread_blocked, id=2730, stack(0x000070f551bfe000,0x000070f551cfe000) (1024K)]
0x000070f629694ca0 JavaThread "App-UINotificationExecutor" [_thread_blocked, id=2731, stack(0x000070f551afe000,0x000070f551bfe000) (1024K)]
0x000070f5e4004d10 JavaThread "App-AsyncTaskExecutor-6" [_thread_blocked, id=2806, stack(0x000070f5fcb00000,0x000070f5fcc00000) (1024K)]
0x000070f5740041d0 JavaThread "pool-5-thread-1" [_thread_blocked, id=11282, stack(0x000070f552dff000,0x000070f552eff000) (1024K)]
0x000070f5740048e0 JavaThread "pool-10-thread-1" [_thread_blocked, id=11283, stack(0x000070f552aff000,0x000070f552bff000) (1024K)]
0x000070f57400e0d0 JavaThread "pool-7-thread-1" [_thread_blocked, id=11284, stack(0x000070f5530ff000,0x000070f5531ff000) (1024K)]
0x000070f57400ea70 JavaThread "pool-8-thread-1" [_thread_blocked, id=11285, stack(0x000070f644300000,0x000070f644400000) (1024K)]
0x000070f57400f990 JavaThread "pool-9-thread-1" [_thread_blocked, id=11286, stack(0x000070f55197e000,0x000070f551a7e000) (1024K)]
0x000070f574010d10 JavaThread "pool-6-thread-1" [_thread_blocked, id=11287, stack(0x000070f55187e000,0x000070f55197e000) (1024K)]
0x000070f574012260 JavaThread "pool-11-thread-1" [_thread_blocked, id=11288, stack(0x000070f55177e000,0x000070f55187e000) (1024K)]
0x000070f5740137b0 JavaThread "pool-13-thread-1" [_thread_blocked, id=11289, stack(0x000070f55167e000,0x000070f55177e000) (1024K)]
0x000070f574015100 JavaThread "pool-19-thread-1" [_thread_blocked, id=11290, stack(0x000070f55157e000,0x000070f55167e000) (1024K)]
0x000070f574016a50 JavaThread "pool-17-thread-1" [_thread_blocked, id=11291, stack(0x000070f55147e000,0x000070f55157e000) (1024K)]
0x000070f5740180e0 JavaThread "pool-18-thread-1" [_thread_blocked, id=11292, stack(0x000070f55137e000,0x000070f55147e000) (1024K)]
0x000070f574019a40 JavaThread "pool-15-thread-1" [_thread_blocked, id=11293, stack(0x000070f55127e000,0x000070f55137e000) (1024K)]
0x000070f57401b3b0 JavaThread "pool-16-thread-1" [_thread_blocked, id=11294, stack(0x000070f55117e000,0x000070f55127e000) (1024K)]
0x000070f57401cd20 JavaThread "pool-20-thread-1" [_thread_blocked, id=11295, stack(0x000070f55107e000,0x000070f55117e000) (1024K)]
0x000070f629485560 JavaThread "pool-25-thread-1" [_thread_blocked, id=36323, stack(0x000070f550d7e000,0x000070f550e7e000) (1024K)]
0x000070f6b40094b0 JavaThread "SIGTERM handler" daemon [_thread_blocked, id=49564, stack(0x000070f550c7e000,0x000070f550d7e000) (1024K)]
0x000070f6b400a860 JavaThread "SIGHUP handler" daemon [_thread_blocked, id=49565, stack(0x000070f550e7e000,0x000070f550f7e000) (1024K)]
Total: 92
Other Threads:
=>0x000070f6f8153220 VMThread "VM Thread" [id=2441, stack(0x000070f6e0e49000,0x000070f6e0f49000) (1024K)]
0x000070f6f8090fc0 WorkerThread "GC Thread#0" [id=2435, stack(0x000070f6e1f35000,0x000070f6e2035000) (1024K)]
0x000070f6b8008290 WorkerThread "GC Thread#1" [id=2454, stack(0x000070f6d15a3000,0x000070f6d16a3000) (1024K)]
0x000070f6b8008d10 WorkerThread "GC Thread#2" [id=2455, stack(0x000070f6d14a2000,0x000070f6d15a2000) (1024K)]
0x000070f6b8009800 WorkerThread "GC Thread#3" [id=2456, stack(0x000070f6d13a1000,0x000070f6d14a1000) (1024K)]
0x000070f6b800a2f0 WorkerThread "GC Thread#4" [id=2457, stack(0x000070f6d12a0000,0x000070f6d13a0000) (1024K)]
0x000070f6b8012d20 WorkerThread "GC Thread#5" [id=2458, stack(0x000070f6d119f000,0x000070f6d129f000) (1024K)]
0x000070f6b8012740 WorkerThread "GC Thread#6" [id=2489, stack(0x000070f6d0e9e000,0x000070f6d0f9e000) (1024K)]
0x000070f6b800bd70 WorkerThread "GC Thread#7" [id=2490, stack(0x000070f6d0d9d000,0x000070f6d0e9d000) (1024K)]
0x000070f6b800d1e0 WorkerThread "GC Thread#8" [id=2491, stack(0x000070f6d0c9c000,0x000070f6d0d9c000) (1024K)]
0x000070f6b8011140 WorkerThread "GC Thread#9" [id=2539, stack(0x000070f644200000,0x000070f644300000) (1024K)]
0x000070f6f80a1b70 ConcurrentGCThread "G1 Main Marker" terminated
0x000070f6f80a2b10 WorkerThread "G1 Conc#0" [id=2437, stack(0x000070f6e1d33000,0x000070f6e1e33000) (1024K)]
0x000070f6d4000d90 WorkerThread "G1 Conc#1" [id=2492, stack(0x000070f6d0b9b000,0x000070f6d0c9b000) (1024K)]
0x000070f6d40018c0 WorkerThread "G1 Conc#2" [id=2493, stack(0x000070f6d0a9a000,0x000070f6d0b9a000) (1024K)]
0x000070f6f81354a0 ConcurrentGCThread "G1 Refine#0" terminated
0x000070f6f8136450 ConcurrentGCThread "G1 Service" terminated
Total: 17
Threads with active compile tasks:
Total: 0
VM state: at safepoint (shutting down)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x000070f6fd840860] Threads_lock - owner thread: 0x000070f6f8153220
[0x000070f6fd840760] Heap_lock - owner thread: 0x000070f6b40094b0
Heap address: 0x000000070a600000, size: 3930 MB, Compressed Oops mode: Zero based, Oop shift amount: 3
CDS archive(s) not mapped
Compressed class space mapped at: 0x0000000800000000-0x0000000840000000, reserved size: 1073741824
Narrow klass base: 0x0000000800000000, Narrow klass shift: 0, Narrow klass range: 0x40000000
GC Precious Log:
CardTable entry size: 512
Card Set container configuration: InlinePtr #cards 4 size 8 Array Of Cards #cards 16 size 48 Howl #buckets 8 coarsen threshold 3686 Howl Bitmap #cards 512 size 80 coarsen threshold 460 Card regions per heap region 1 cards per card region 4096
CPUs: 12 total, 12 available
Memory: 15715M
Large Page Support: Disabled
NUMA Support: Disabled
Compressed Oops: Enabled (Zero based)
Heap Region Size: 2M
Heap Min Capacity: 8M
Heap Initial Capacity: 246M
Heap Max Capacity: 3930M
Pre-touch: Disabled
Parallel Workers: 10
Concurrent Workers: 3
Concurrent Refinement Workers: 10
Periodic GC: Disabled
Heap:
garbage-first heap total 139264K, used 70448K [0x000000070a600000, 0x0000000800000000)
region size 2048K, 7 young (14336K), 1 survivors (2048K)
Metaspace used 71314K, committed 72384K, reserved 1114112K
class space used 9339K, committed 9792K, reserved 1048576K
Heap Regions: E=young(eden), S=young(survivor), O=old, HS=humongous(starts), HC=humongous(continues), CS=collection set, F=free, TAMS=top-at-mark-start, PB=parsable bottom
| 0|0x000000070a600000, 0x000000070a800000, 0x000000070a800000|100%|HS| |TAMS 0x000000070a600000| PB 0x000000070a600000| Complete
| 1|0x000000070a800000, 0x000000070aa00000, 0x000000070aa00000|100%| O| |TAMS 0x000000070a800000| PB 0x000000070a800000| Untracked
| 2|0x000000070aa00000, 0x000000070ac00000, 0x000000070ac00000|100%| O| |TAMS 0x000000070aa00000| PB 0x000000070aa00000| Untracked
| 3|0x000000070ac00000, 0x000000070ae00000, 0x000000070ae00000|100%|HS| |TAMS 0x000000070ac00000| PB 0x000000070ac00000| Complete
| 4|0x000000070ae00000, 0x000000070b000000, 0x000000070b000000|100%| O| |TAMS 0x000000070ae00000| PB 0x000000070ae00000| Untracked
| 5|0x000000070b000000, 0x000000070b200000, 0x000000070b200000|100%| O| |TAMS 0x000000070b000000| PB 0x000000070b000000| Untracked
| 6|0x000000070b200000, 0x000000070b400000, 0x000000070b400000|100%| O| |TAMS 0x000000070b200000| PB 0x000000070b200000| Untracked
| 7|0x000000070b400000, 0x000000070b400000, 0x000000070b600000| 0%| F| |TAMS 0x000000070b400000| PB 0x000000070b400000| Untracked
| 8|0x000000070b600000, 0x000000070b6b75e0, 0x000000070b800000| 35%| O| |TAMS 0x000000070b600000| PB 0x000000070b600000| Untracked
| 9|0x000000070b800000, 0x000000070ba00000, 0x000000070ba00000|100%| O|Cm|TAMS 0x000000070b800000| PB 0x000000070b800000| Complete
| 10|0x000000070ba00000, 0x000000070bc00000, 0x000000070bc00000|100%| O| |TAMS 0x000000070ba00000| PB 0x000000070ba00000| Untracked
| 11|0x000000070bc00000, 0x000000070be00000, 0x000000070be00000|100%| O| |TAMS 0x000000070bc00000| PB 0x000000070bc00000| Untracked
| 12|0x000000070be00000, 0x000000070c000000, 0x000000070c000000|100%| O| |TAMS 0x000000070be00000| PB 0x000000070be00000| Untracked
| 13|0x000000070c000000, 0x000000070c200000, 0x000000070c200000|100%| O| |TAMS 0x000000070c000000| PB 0x000000070c000000| Untracked
| 14|0x000000070c200000, 0x000000070c400000, 0x000000070c400000|100%| O| |TAMS 0x000000070c200000| PB 0x000000070c200000| Untracked
| 15|0x000000070c400000, 0x000000070c600000, 0x000000070c600000|100%| O| |TAMS 0x000000070c400000| PB 0x000000070c400000| Untracked
| 16|0x000000070c600000, 0x000000070c800000, 0x000000070c800000|100%| O| |TAMS 0x000000070c600000| PB 0x000000070c600000| Untracked
| 17|0x000000070c800000, 0x000000070ca00000, 0x000000070ca00000|100%|HS| |TAMS 0x000000070c800000| PB 0x000000070c800000| Complete
| 18|0x000000070ca00000, 0x000000070cc00000, 0x000000070cc00000|100%|HC| |TAMS 0x000000070ca00000| PB 0x000000070ca00000| Complete
| 19|0x000000070cc00000, 0x000000070cc00000, 0x000000070ce00000| 0%| F| |TAMS 0x000000070cc00000| PB 0x000000070cc00000| Untracked
| 20|0x000000070ce00000, 0x000000070ce00000, 0x000000070d000000| 0%| F| |TAMS 0x000000070ce00000| PB 0x000000070ce00000| Untracked
| 21|0x000000070d000000, 0x000000070d200000, 0x000000070d200000|100%|HS| |TAMS 0x000000070d000000| PB 0x000000070d000000| Complete
| 22|0x000000070d200000, 0x000000070d400000, 0x000000070d400000|100%|HC| |TAMS 0x000000070d200000| PB 0x000000070d200000| Complete
| 23|0x000000070d400000, 0x000000070d400000, 0x000000070d600000| 0%| F| |TAMS 0x000000070d400000| PB 0x000000070d400000| Untracked
| 24|0x000000070d600000, 0x000000070d600000, 0x000000070d800000| 0%| F| |TAMS 0x000000070d600000| PB 0x000000070d600000| Untracked
| 25|0x000000070d800000, 0x000000070d814b00, 0x000000070da00000| 4%| S|CS|TAMS 0x000000070d800000| PB 0x000000070d800000| Complete
| 26|0x000000070da00000, 0x000000070da00000, 0x000000070dc00000| 0%| F| |TAMS 0x000000070da00000| PB 0x000000070da00000| Untracked
| 27|0x000000070dc00000, 0x000000070de00000, 0x000000070de00000|100%| O| |TAMS 0x000000070dc00000| PB 0x000000070dc00000| Untracked
| 28|0x000000070de00000, 0x000000070e000000, 0x000000070e000000|100%| O| |TAMS 0x000000070de00000| PB 0x000000070de00000| Untracked
| 29|0x000000070e000000, 0x000000070e200000, 0x000000070e200000|100%| O| |TAMS 0x000000070e000000| PB 0x000000070e000000| Untracked
| 30|0x000000070e200000, 0x000000070e200000, 0x000000070e400000| 0%| F| |TAMS 0x000000070e200000| PB 0x000000070e200000| Untracked
| 31|0x000000070e400000, 0x000000070e600000, 0x000000070e600000|100%| O| |TAMS 0x000000070e400000| PB 0x000000070e400000| Untracked
| 32|0x000000070e600000, 0x000000070e800000, 0x000000070e800000|100%| O| |TAMS 0x000000070e600000| PB 0x000000070e600000| Untracked
| 33|0x000000070e800000, 0x000000070ea00000, 0x000000070ea00000|100%| O| |TAMS 0x000000070e800000| PB 0x000000070e800000| Untracked
| 34|0x000000070ea00000, 0x000000070ec00000, 0x000000070ec00000|100%| O| |TAMS 0x000000070ea00000| PB 0x000000070ea00000| Untracked
| 35|0x000000070ec00000, 0x000000070ec00000, 0x000000070ee00000| 0%| F| |TAMS 0x000000070ec00000| PB 0x000000070ec00000| Untracked
| 36|0x000000070ee00000, 0x000000070ee00000, 0x000000070f000000| 0%| F| |TAMS 0x000000070ee00000| PB 0x000000070ee00000| Untracked
| 37|0x000000070f000000, 0x000000070f000000, 0x000000070f200000| 0%| F| |TAMS 0x000000070f000000| PB 0x000000070f000000| Untracked
| 38|0x000000070f200000, 0x000000070f200000, 0x000000070f400000| 0%| F| |TAMS 0x000000070f200000| PB 0x000000070f200000| Untracked
| 39|0x000000070f400000, 0x000000070f400000, 0x000000070f600000| 0%| F| |TAMS 0x000000070f400000| PB 0x000000070f400000| Untracked
| 40|0x000000070f600000, 0x000000070f600000, 0x000000070f800000| 0%| F| |TAMS 0x000000070f600000| PB 0x000000070f600000| Untracked
| 41|0x000000070f800000, 0x000000070f800000, 0x000000070fa00000| 0%| F| |TAMS 0x000000070f800000| PB 0x000000070f800000| Untracked
| 42|0x000000070fa00000, 0x000000070fa00000, 0x000000070fc00000| 0%| F| |TAMS 0x000000070fa00000| PB 0x000000070fa00000| Untracked
| 43|0x000000070fc00000, 0x000000070fc00000, 0x000000070fe00000| 0%| F| |TAMS 0x000000070fc00000| PB 0x000000070fc00000| Untracked
| 44|0x000000070fe00000, 0x000000070fe00000, 0x0000000710000000| 0%| F| |TAMS 0x000000070fe00000| PB 0x000000070fe00000| Untracked
| 45|0x0000000710000000, 0x0000000710000000, 0x0000000710200000| 0%| F| |TAMS 0x0000000710000000| PB 0x0000000710000000| Untracked
| 46|0x0000000710200000, 0x0000000710200000, 0x0000000710400000| 0%| F| |TAMS 0x0000000710200000| PB 0x0000000710200000| Untracked
| 47|0x0000000710400000, 0x0000000710400000, 0x0000000710600000| 0%| F| |TAMS 0x0000000710400000| PB 0x0000000710400000| Untracked
| 48|0x0000000710600000, 0x0000000710600000, 0x0000000710800000| 0%| F| |TAMS 0x0000000710600000| PB 0x0000000710600000| Untracked
| 49|0x0000000710800000, 0x0000000710800000, 0x0000000710a00000| 0%| F| |TAMS 0x0000000710800000| PB 0x0000000710800000| Untracked
| 50|0x0000000710a00000, 0x0000000710a00000, 0x0000000710c00000| 0%| F| |TAMS 0x0000000710a00000| PB 0x0000000710a00000| Untracked
| 51|0x0000000710c00000, 0x0000000710c00000, 0x0000000710e00000| 0%| F| |TAMS 0x0000000710c00000| PB 0x0000000710c00000| Untracked
| 52|0x0000000710e00000, 0x0000000710e00000, 0x0000000711000000| 0%| F| |TAMS 0x0000000710e00000| PB 0x0000000710e00000| Untracked
| 53|0x0000000711000000, 0x0000000711000000, 0x0000000711200000| 0%| F| |TAMS 0x0000000711000000| PB 0x0000000711000000| Untracked
| 54|0x0000000711200000, 0x0000000711200000, 0x0000000711400000| 0%| F| |TAMS 0x0000000711200000| PB 0x0000000711200000| Untracked
| 55|0x0000000711400000, 0x0000000711400000, 0x0000000711600000| 0%| F| |TAMS 0x0000000711400000| PB 0x0000000711400000| Untracked
| 56|0x0000000711600000, 0x0000000711600000, 0x0000000711800000| 0%| F| |TAMS 0x0000000711600000| PB 0x0000000711600000| Untracked
| 57|0x0000000711800000, 0x0000000711800000, 0x0000000711a00000| 0%| F| |TAMS 0x0000000711800000| PB 0x0000000711800000| Untracked
| 58|0x0000000711a00000, 0x0000000711a00000, 0x0000000711c00000| 0%| F| |TAMS 0x0000000711a00000| PB 0x0000000711a00000| Untracked
| 59|0x0000000711c00000, 0x0000000711c77538, 0x0000000711e00000| 23%| E| |TAMS 0x0000000711c00000| PB 0x0000000711c00000| Complete
| 60|0x0000000711e00000, 0x0000000712000000, 0x0000000712000000|100%| E|CS|TAMS 0x0000000711e00000| PB 0x0000000711e00000| Complete
| 61|0x0000000712000000, 0x0000000712200000, 0x0000000712200000|100%| E|CS|TAMS 0x0000000712000000| PB 0x0000000712000000| Complete
| 62|0x0000000712200000, 0x0000000712400000, 0x0000000712400000|100%| E|CS|TAMS 0x0000000712200000| PB 0x0000000712200000| Complete
| 63|0x0000000712400000, 0x0000000712600000, 0x0000000712600000|100%| E|CS|TAMS 0x0000000712400000| PB 0x0000000712400000| Complete
| 122|0x0000000719a00000, 0x0000000719c00000, 0x0000000719c00000|100%| E|CS|TAMS 0x0000000719a00000| PB 0x0000000719a00000| Complete
|1962|0x00000007ffa00000, 0x00000007ffc00000, 0x00000007ffc00000|100%| O| |TAMS 0x00000007ffa00000| PB 0x00000007ffa00000| Untracked
|1963|0x00000007ffc00000, 0x00000007ffe00000, 0x00000007ffe00000|100%| O| |TAMS 0x00000007ffc00000| PB 0x00000007ffc00000| Untracked
|1964|0x00000007ffe00000, 0x0000000800000000, 0x0000000800000000|100%| O| |TAMS 0x00000007ffe00000| PB 0x00000007ffe00000| Untracked
Card table byte_map: [0x000070f6e5d9d000,0x000070f6e654a000] _byte_map_base: 0x000070f6e254a000
Marking Bits: (CMBitMap*) 0x000070f6f8091ae0
Bits: [0x000070f6e2035000, 0x000070f6e5d9d000)
Polling page: 0x000070f6fdc78000
Metaspace:
Usage:
Non-class: 60,52 MB used.
Class: 9,12 MB used.
Both: 69,64 MB used.
Virtual space:
Non-class space: 64,00 MB reserved, 61,12 MB ( 96%) committed, 1 nodes.
Class space: 1,00 GB reserved, 9,56 MB ( <1%) committed, 1 nodes.
Both: 1,06 GB reserved, 70,69 MB ( 6%) committed.
Chunk freelists:
Non-Class: 2,36 MB
Class: 6,61 MB
Both: 8,97 MB
MaxMetaspaceSize: unlimited
CompressedClassSpaceSize: 1,00 GB
Initial GC threshold: 21,00 MB
Current GC threshold: 117,75 MB
CDS: off
- commit_granule_bytes: 65536.
- commit_granule_words: 8192.
- virtual_space_node_default_size: 8388608.
- enlarge_chunks_in_place: 1.
- use_allocation_guard: 0.
Internal statistics:
num_allocs_failed_limit: 14.
num_arena_births: 1070.
num_arena_deaths: 366.
num_vsnodes_births: 2.
num_vsnodes_deaths: 0.
num_space_committed: 1130.
num_space_uncommitted: 0.
num_chunks_returned_to_freelist: 464.
num_chunks_taken_from_freelist: 3319.
num_chunk_merges: 122.
num_chunk_splits: 2179.
num_chunks_enlarged: 1528.
num_inconsistent_stats: 0.
CodeHeap 'non-profiled nmethods': size=120028Kb used=6021Kb max_used=7665Kb free=114007Kb
bounds [0x000070f6ef0c9000, 0x000070f6ef849000, 0x000070f6f6600000]
CodeHeap 'profiled nmethods': size=120028Kb used=15874Kb max_used=21721Kb free=104153Kb
bounds [0x000070f6e7600000, 0x000070f6e8b40000, 0x000070f6eeb37000]
CodeHeap 'non-nmethods': size=5704Kb used=2252Kb max_used=2309Kb free=3451Kb
bounds [0x000070f6eeb37000, 0x000070f6eeda7000, 0x000070f6ef0c9000]
total_blobs=9429 nmethods=8230 adapters=1103
compilation: enabled
stopped_count=0, restarted_count=0
full_count=0
Compilation events (20 events):
Event: 36323,690 Thread 0x000070f6f823c950 10676 3 sun.security.ssl.SSLTrafficKeyDerivation$KeySchedule::getKeyLength (40 bytes)
Event: 36323,690 Thread 0x000070f6f823c950 nmethod 10676 0x000070f6e76a2810 code [0x000070f6e76a29c0, 0x000070f6e76a2bd8]
Event: 36323,874 Thread 0x000070f6f823c950 10677 3 org.sqlite.core.CoreStatement::<init> (37 bytes)
Event: 36323,875 Thread 0x000070f6f823c950 nmethod 10677 0x000070f6e772ec90 code [0x000070f6e772ee60, 0x000070f6e772f268]
Event: 36323,999 Thread 0x000070f6f823c950 10678 3 com.fasterxml.jackson.databind.util.internal.PrivateMaxEntriesMap::afterRead (18 bytes)
Event: 36324,000 Thread 0x000070f6f823c950 nmethod 10678 0x000070f6e76e7990 code [0x000070f6e76e7b60, 0x000070f6e76e7e70]
Event: 36324,000 Thread 0x000070f6f823c950 10679 3 com.fasterxml.jackson.databind.util.internal.PrivateMaxEntriesMap::readBufferIndex (12 bytes)
Event: 36324,000 Thread 0x000070f6f823c950 nmethod 10679 0x000070f6e765df10 code [0x000070f6e765e0a0, 0x000070f6e765e2a0]
Event: 36324,126 Thread 0x000070f6f823c950 10680 3 net.iharder.Base64::getDecodabet (30 bytes)
Event: 36324,126 Thread 0x000070f6f823c950 nmethod 10680 0x000070f6e76cdd90 code [0x000070f6e76cdf40, 0x000070f6e76ce108]
Event: 36324,126 Thread 0x000070f6f823c950 10681 3 net.iharder.Base64::decode4to3 (344 bytes)
Event: 36324,131 Thread 0x000070f6f823c950 nmethod 10681 0x000070f6e7626d90 code [0x000070f6e7627240, 0x000070f6e7629c18]
Event: 36905,421 Thread 0x000070f6f823b2e0 10682 4 org.apache.logging.log4j.core.time.MutableInstant::getEpochMillisecond (22 bytes)
Event: 36905,422 Thread 0x000070f6f823b2e0 nmethod 10682 0x000070f6ef0f3090 code [0x000070f6ef0f3200, 0x000070f6ef0f32b0]
Event: 37203,397 Thread 0x000070f6f823c950 10685 3 javax.management.ObjectName::getDomainLength (9 bytes)
Event: 37203,397 Thread 0x000070f6f823c950 nmethod 10685 0x000070f6e76d1410 code [0x000070f6e76d15a0, 0x000070f6e76d16a8]
Event: 37203,398 Thread 0x000070f6f823c950 10684 1 javax.management.ObjectName$Property::setKeyIndex (6 bytes)
Event: 37203,398 Thread 0x000070f6f823c950 nmethod 10684 0x000070f6ef0f3710 code [0x000070f6ef0f38a0, 0x000070f6ef0f3960]
Event: 37203,400 Thread 0x000070f6f823b2e0 10683 4 javafx.event.Event::copyFor (45 bytes)
Event: 37203,427 Thread 0x000070f6f823b2e0 nmethod 10683 0x000070f6ef18ca10 code [0x000070f6ef18cbc0, 0x000070f6ef18cfd8]
GC Heap History (20 events):
Event: 27014,685 GC heap before
{Heap before GC invocations=37 (full 0):
garbage-first heap total 139264K, used 121186K [0x000000070a600000, 0x0000000800000000)
region size 2048K, 29 young (59392K), 4 survivors (8192K)
Metaspace used 71557K, committed 72320K, reserved 1114112K
class space used 9425K, committed 9792K, reserved 1048576K
Event: 27014,728 GC heap after
{Heap after GC invocations=38 (full 0):
garbage-first heap total 139264K, used 70792K [0x000000070a600000, 0x0000000800000000)
region size 2048K, 1 young (2048K), 1 survivors (2048K)
Event: 27983,161 GC heap before
{Heap before GC invocations=39 (full 0):
garbage-first heap total 139264K, used 117896K [0x000000070a600000, 0x0000000800000000)
region size 2048K, 28 young (57344K), 1 survivors (2048K)
Metaspace used 71372K, committed 72320K, reserved 1114112K
class space used 9375K, committed 9792K, reserved 1048576K
Event: 27983,164 GC heap after
{Heap after GC invocations=40 (full 0):
garbage-first heap total 139264K, used 62221K [0x000000070a600000, 0x0000000800000000)
Event: 29106,383 GC heap before
{Heap before GC invocations=40 (full 0):
garbage-first heap total 139264K, used 125709K [0x000000070a600000, 0x0000000800000000)
region size 2048K, 32 young (65536K), 1 survivors (2048K)
Metaspace used 71380K, committed 72384K, reserved 1114112K
Event: 29106,393 GC heap after
{Heap after GC invocations=41 (full 0):
garbage-first heap total 139264K, used 61643K [0x000000070a600000, 0x0000000800000000)
Event: 30228,714 GC heap before
{Heap before GC invocations=41 (full 0):
garbage-first heap total 139264K, used 125131K [0x000000070a600000, 0x0000000800000000)
Metaspace used 71393K, committed 72384K, reserved 1114112K
Event: 30228,718 GC heap after
{Heap after GC invocations=42 (full 0):
garbage-first heap total 139264K, used 61604K [0x000000070a600000, 0x0000000800000000)
Event: 31346,984 GC heap before
{Heap before GC invocations=43 (full 0):
garbage-first heap total 139264K, used 125092K [0x000000070a600000, 0x0000000800000000)
Metaspace used 71254K, committed 72384K, reserved 1114112K
class space used 9334K, committed 9792K, reserved 1048576K
Event: 31346,989 GC heap after
{Heap after GC invocations=44 (full 0):
garbage-first heap total 139264K, used 61603K [0x000000070a600000, 0x0000000800000000)
Event: 32461,238 GC heap before
{Heap before GC invocations=44 (full 0):
garbage-first heap total 139264K, used 125091K [0x000000070a600000, 0x0000000800000000)
Event: 32461,248 GC heap after
{Heap after GC invocations=45 (full 0):
garbage-first heap total 139264K, used 60958K [0x000000070a600000, 0x0000000800000000)
Event: 33613,458 GC heap before
{Heap before GC invocations=45 (full 0):
garbage-first heap total 139264K, used 126494K [0x000000070a600000, 0x0000000800000000)
region size 2048K, 33 young (67584K), 1 survivors (2048K)
Metaspace used 71259K, committed 72384K, reserved 1114112K
class space used 9335K, committed 9792K, reserved 1048576K
Event: 33613,461 GC heap after
{Heap after GC invocations=46 (full 0):
garbage-first heap total 139264K, used 60935K [0x000000070a600000, 0x0000000800000000)
Event: 34767,698 GC heap before
{Heap before GC invocations=47 (full 0):
garbage-first heap total 139264K, used 126471K [0x000000070a600000, 0x0000000800000000)
Event: 34767,702 GC heap after
{Heap after GC invocations=48 (full 0):
garbage-first heap total 139264K, used 60934K [0x000000070a600000, 0x0000000800000000)
Event: 35904,936 GC heap before
{Heap before GC invocations=48 (full 0):
garbage-first heap total 139264K, used 126470K [0x000000070a600000, 0x0000000800000000)
Metaspace used 71275K, committed 72384K, reserved 1114112K
Event: 35904,948 GC heap after
{Heap after GC invocations=49 (full 0):
garbage-first heap total 139264K, used 60194K [0x000000070a600000, 0x0000000800000000)
Event: 37047,166 GC heap before
{Heap before GC invocations=49 (full 0):
garbage-first heap total 139264K, used 125730K [0x000000070a600000, 0x0000000800000000)
Metaspace used 71300K, committed 72384K, reserved 1114112K
Event: 37047,171 GC heap after
{Heap after GC invocations=50 (full 0):
garbage-first heap total 139264K, used 60208K [0x000000070a600000, 0x0000000800000000)
Dll operation events (18 events):
Event: 0,025 Loaded shared library /opt/olvid/lib/runtime/lib/libjava.so
Event: 0,045 Loaded shared library /opt/olvid/lib/runtime/lib/libzip.so
Event: 0,165 Loaded shared library /opt/olvid/lib/runtime/lib/libnio.so
Event: 0,193 Loaded shared library /opt/olvid/lib/runtime/lib/libzip.so
Event: 0,340 Loaded shared library /opt/olvid/lib/runtime/lib/libnet.so
Event: 0,390 Loaded shared library /opt/olvid/lib/runtime/lib/libjimage.so
Event: 0,760 Loaded shared library /opt/olvid/lib/runtime/lib/libmanagement.so
Event: 1,684 Loaded shared library /home/moi/.openjfx/cache/21+31/amd64/libprism_es2.so
Event: 1,778 Loaded shared library /home/moi/.openjfx/cache/21+31/amd64/libglass.so
Event: 1,807 Loaded shared library /home/moi/.openjfx/cache/21+31/amd64/libglassgtk3.so
Event: 2,050 Loaded shared library /opt/olvid/lib/runtime/lib/libawt.so
Event: 2,055 Loaded shared library /opt/olvid/lib/runtime/lib/libawt_xawt.so
Event: 2,092 Loaded shared library /opt/olvid/lib/runtime/lib/libfontmanager.so
Event: 2,272 Loaded shared library /home/moi/.openjfx/cache/21+31/amd64/libjavafx_font.so
Event: 2,447 Loaded shared library /home/moi/.openjfx/cache/21+31/amd64/libjavafx_font_freetype.so
Event: 2,781 Loaded shared library /home/moi/.openjfx/cache/21+31/amd64/libjavafx_font_pango.so
Event: 2,882 Loaded shared library /opt/olvid/lib/runtime/lib/sqlcipher-jdbc.so
Event: 25916,407 Loaded shared library /home/moi/.openjfx/cache/21+31/amd64/libjavafx_iio.so
Deoptimization events (20 events):
Event: 25984,437 Thread 0x000070f67c1db920 Uncommon trap: trap_request=0xffffffc6 fr.pc=0x000070f6ef785594 relative=0x0000000000000294
Event: 25984,437 Thread 0x000070f67c1db920 Uncommon trap: reason=bimorphic_or_optimized_type_check action=maybe_recompile pc=0x000070f6ef785594 method=com.sun.glass.ui.InvokeLaterDispatcher$Future.run()V @ 4 c2
Event: 25984,437 Thread 0x000070f67c1db920 DEOPT PACKING pc=0x000070f6ef785594 sp=0x000070f6477fd1b0
Event: 25984,437 Thread 0x000070f67c1db920 DEOPT UNPACKING pc=0x000070f6eeb8af99 sp=0x000070f6477fd160 mode 2
Event: 37203,392 Thread 0x000070f67c075a40 Uncommon trap: trap_request=0xffffff45 fr.pc=0x000070f6ef470db8 relative=0x0000000000000558
Event: 37203,392 Thread 0x000070f67c075a40 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000070f6ef470db8 method=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionNode.isReleasable()Z @ 14 c2
Event: 37203,392 Thread 0x000070f67c075a40 DEOPT PACKING pc=0x000070f6ef470db8 sp=0x000070f6d0a976e0
Event: 37203,393 Thread 0x000070f67c075a40 DEOPT UNPACKING pc=0x000070f6eeb8af99 sp=0x000070f6d0a97508 mode 2
Event: 37203,393 Thread 0x000070f67c075a40 Uncommon trap: trap_request=0xffffff45 fr.pc=0x000070f6ef489658 relative=0x0000000000000058
Event: 37203,393 Thread 0x000070f67c075a40 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000070f6ef489658 method=java.lang.Thread.getAndClearInterrupt()Z @ 6 c2
Event: 37203,393 Thread 0x000070f67c075a40 DEOPT PACKING pc=0x000070f6ef489658 sp=0x000070f6d0a97670
Event: 37203,393 Thread 0x000070f67c075a40 DEOPT UNPACKING pc=0x000070f6eeb8af99 sp=0x000070f6d0a975c8 mode 2
Event: 37203,396 Thread 0x000070f54c1f64e0 Uncommon trap: trap_request=0xfffffff4 fr.pc=0x000070f6ef316504 relative=0x0000000000000164
Event: 37203,396 Thread 0x000070f54c1f64e0 Uncommon trap: reason=null_check action=make_not_entrant pc=0x000070f6ef316504 method=java.lang.Class.reflectionData()Ljava/lang/Class$ReflectionData; @ 18 c2
Event: 37203,396 Thread 0x000070f54c1f64e0 DEOPT PACKING pc=0x000070f6ef316504 sp=0x000070f5509d8650
Event: 37203,396 Thread 0x000070f54c1f64e0 DEOPT UNPACKING pc=0x000070f6eeb8af99 sp=0x000070f5509d8600 mode 2
Event: 37203,397 Thread 0x000070f54c1f64e0 Uncommon trap: trap_request=0xffffff45 fr.pc=0x000070f6ef493c44 relative=0x0000000000000044
Event: 37203,397 Thread 0x000070f54c1f64e0 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000070f6ef493c44 method=java.util.concurrent.ThreadPoolExecutor.runStateAtLeast(II)Z @ 2 c2
Event: 37203,397 Thread 0x000070f54c1f64e0 DEOPT PACKING pc=0x000070f6ef493c44 sp=0x000070f5509d8400
Event: 37203,397 Thread 0x000070f54c1f64e0 DEOPT UNPACKING pc=0x000070f6eeb8af99 sp=0x000070f5509d83b8 mode 2
Classes loaded (20 events):
Event: 25982,469 Loading class java/util/Spliterators$IntArraySpliterator
Event: 25982,476 Loading class java/util/Spliterators$IntArraySpliterator done
Event: 25982,477 Loading class java/util/stream/ReduceOps$9
Event: 25982,478 Loading class java/util/stream/ReduceOps$9 done
Event: 25982,478 Loading class java/util/stream/ReduceOps$CountingSink$OfInt
Event: 25982,479 Loading class java/util/stream/ReduceOps$CountingSink
Event: 25982,479 Loading class java/util/stream/ReduceOps$CountingSink done
Event: 25982,479 Loading class java/util/stream/ReduceOps$CountingSink$OfInt done
Event: 25982,480 Loading class java/util/stream/Nodes$IntSpinedNodeBuilder
Event: 25982,480 Loading class java/util/stream/Node$Builder$OfInt
Event: 25982,481 Loading class java/util/stream/Node$Builder$OfInt done
Event: 25982,481 Loading class java/util/stream/SpinedBuffer$OfInt
Event: 25982,482 Loading class java/util/stream/SpinedBuffer$OfPrimitive
Event: 25982,482 Loading class java/util/stream/SpinedBuffer$OfPrimitive done
Event: 25982,482 Loading class java/util/stream/SpinedBuffer$OfInt done
Event: 25982,482 Loading class java/util/stream/Nodes$IntSpinedNodeBuilder done
Event: 37203,372 Loading class jdk/internal/misc/Signal$1
Event: 37203,373 Loading class jdk/internal/misc/Signal$1 done
Event: 37203,396 Loading class java/io/FileOutputStream$1
Event: 37203,397 Loading class java/io/FileOutputStream$1 done
Classes unloaded (20 events):
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x000000080009a400 'java/lang/invoke/LambdaForm$MH+0x000000080009a400'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800098c00 'java/lang/invoke/LambdaForm$MH+0x0000000800098c00'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800088c00 'java/lang/invoke/LambdaForm$MH+0x0000000800088c00'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800088400 'java/lang/invoke/LambdaForm$MH+0x0000000800088400'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800088000 'java/lang/invoke/LambdaForm$MH+0x0000000800088000'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800085c00 'java/lang/invoke/LambdaForm$MH+0x0000000800085c00'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800085000 'java/lang/invoke/LambdaForm$MH+0x0000000800085000'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800084c00 'java/lang/invoke/LambdaForm$MH+0x0000000800084c00'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800084400 'java/lang/invoke/LambdaForm$MH+0x0000000800084400'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800083c00 'java/lang/invoke/LambdaForm$MH+0x0000000800083c00'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800083400 'java/lang/invoke/LambdaForm$MH+0x0000000800083400'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800083000 'java/lang/invoke/LambdaForm$MH+0x0000000800083000'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800082c00 'java/lang/invoke/LambdaForm$MH+0x0000000800082c00'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800081c00 'java/lang/invoke/LambdaForm$MH+0x0000000800081c00'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800081800 'java/lang/invoke/LambdaForm$MH+0x0000000800081800'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800080400 'java/lang/invoke/LambdaForm$MH+0x0000000800080400'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800003c00 'java/lang/invoke/LambdaForm$MH+0x0000000800003c00'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800003400 'java/lang/invoke/LambdaForm$MH+0x0000000800003400'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800002800 'java/lang/invoke/LambdaForm$MH+0x0000000800002800'
Event: 30228,768 Thread 0x000070f6f8153220 Unloading class 0x0000000800002000 'java/lang/invoke/LambdaForm$MH+0x0000000800002000'
Classes redefined (0 events):
No events
Internal exceptions (20 events):
Event: 25914,869 Thread 0x000070f67c1db920 Implicit null exception at 0x000070f6ef14949d to 0x000070f6ef149894
Event: 25914,876 Thread 0x000070f67c1db920 Implicit null exception at 0x000070f6ef2fbaf6 to 0x000070f6ef2fbbf0
Event: 25914,881 Thread 0x000070f67c1db920 Exception <a 'java/lang/NoSuchMethodError'{0x000000070d606cd0}: 'int java.lang.invoke.Invokers$Holder.linkToTargetMethod(java.lang.Object, int, java.lang.Object)'> (0x000000070d606cd0)
thrown [open/src/hotspot/share/interpreter/linkResolver.cpp, line 772]
Event: 25915,360 Thread 0x000070f67c1db920 Exception <a 'java/lang/NoSuchMethodError'{0x0000000711ac4540}: 'java.lang.Object java.lang.invoke.DirectMethodHandle$Holder.invokeInterface(java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object)'> (0x0000000711ac4540)
Event: 25915,691 Thread 0x000070f67c1db920 Exception <a 'java/lang/NoSuchMethodError'{0x0000000711343060}: 'java.lang.Object java.lang.invoke.DirectMethodHandle$Holder.invokeStatic(java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object)'> (0x0000000711343060)
Event: 25915,883 Thread 0x000070f67c1db920 Exception <a 'java/lang/NoSuchMethodError'{0x0000000710ccdac8}: 'java.lang.Object java.lang.invoke.DirectMethodHandle$Holder.invokeSpecial(java.lang.Object, java.lang.Object, int, int, java.lang.Object)'> (0x0000000710ccdac8)
Event: 25915,884 Thread 0x000070f67c1db920 Exception <a 'java/lang/NoSuchMethodError'{0x0000000710cd3a70}: 'java.lang.Object java.lang.invoke.DirectMethodHandle$Holder.newInvokeSpecial(java.lang.Object, java.lang.Object, int, int)'> (0x0000000710cd3a70)
Event: 25915,885 Thread 0x000070f67c1db920 Exception <a 'java/lang/NoSuchMethodError'{0x0000000710cd7b08}: 'java.lang.Object java.lang.invoke.DirectMethodHandle$Holder.invokeSpecial(java.lang.Object, java.lang.Object, java.lang.Object, int, int)'> (0x0000000710cd7b08)
Event: 25915,885 Thread 0x000070f67c1db920 Exception <a 'java/lang/NoSuchMethodError'{0x0000000710cdb600}: 'java.lang.Object java.lang.invoke.Invokers$Holder.linkToTargetMethod(java.lang.Object, int, int, java.lang.Object)'> (0x0000000710cdb600)
Event: 25915,978 Thread 0x000070f67c1db920 Exception <a 'java/lang/NoSuchMethodError'{0x0000000710a969d8}: 'java.lang.Object java.lang.invoke.DirectMethodHandle$Holder.invokeSpecialIFC(java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object, java.lang.Object)'> (0x0000000710a969d8)
Event: 25916,024 Thread 0x000070f67c075a40 Exception <a 'java/lang/NoSuchMethodError'{0x000000071080c618}: 'java.lang.Object java.lang.invoke.DirectMethodHandle$Holder.invokeStaticInit(java.lang.Object, int)'> (0x000000071080c618)
Event: 25916,052 Thread 0x000070f6009e9120 Exception <a 'java/lang/NoSuchMethodError'{0x00000007109003a8}: 'long java.lang.invoke.Invokers$Holder.invokeExact_MT(java.lang.Object, java.lang.Object, java.lang.Object)'> (0x00000007109003a8)
Event: 25916,297 Thread 0x000070f600a16ae0 Implicit null exception at 0x000070f6e83a0673 to 0x000070f6e83a124c
Event: 25916,298 Thread 0x000070f600a16ae0 Exception <a 'java/lang/NullPointerException'{0x00000007102445c8}> (0x00000007102445c8)
thrown [open/src/hotspot/share/runtime/sharedRuntime.cpp, line 625]
Event: 25922,015 Thread 0x000070f6280a1420 Implicit null exception at 0x000070f6ef4a4a98 to 0x000070f6ef4a4f5c
Event: 28200,101 Thread 0x000070f54c0a49e0 Exception <a 'java/io/IOException'{0x0000000711a02b70}> (0x0000000711a02b70)
thrown [open/src/hotspot/share/prims/jni.cpp, line 520]
Event: 28200,102 Thread 0x000070f54c0a49e0 Exception <a 'java/io/IOException'{0x0000000711a045b0}> (0x0000000711a045b0)
Event: 35421,338 Thread 0x000070f54c0a49e0 Exception <a 'java/io/IOException'{0x0000000710218178}> (0x0000000710218178)
Event: 35421,338 Thread 0x000070f54c0a49e0 Exception <a 'java/io/IOException'{0x000000071021b028}> (0x000000071021b028)
Event: 37203,396 Thread 0x000070f54c1f64e0 Implicit null exception at 0x000070f6ef3163f5 to 0x000070f6ef3164ed
ZGC Phase Switch (0 events):
No events
VM Operations (20 events):
Event: 36927,800 Executing VM operation: RendezvousGCThreads done
Event: 37047,166 Executing VM operation: G1CollectForAllocation (G1 Evacuation Pause)
Event: 37047,171 Executing VM operation: G1CollectForAllocation (G1 Evacuation Pause) done
Event: 37047,223 Executing VM operation: G1PauseRemark
Event: 37047,229 Executing VM operation: G1PauseRemark done
Event: 37047,252 Executing VM operation: G1PauseCleanup
Event: 37047,253 Executing VM operation: G1PauseCleanup done
Event: 37047,868 Executing VM operation: HandshakeAllThreads (HandshakeForDeflation)
Event: 37047,868 Executing VM operation: HandshakeAllThreads (HandshakeForDeflation) done
Event: 37047,868 Executing VM operation: RendezvousGCThreads
Event: 37047,868 Executing VM operation: RendezvousGCThreads done
Event: 37107,900 Executing VM operation: HandshakeAllThreads (HandshakeForDeflation)
Event: 37107,900 Executing VM operation: HandshakeAllThreads (HandshakeForDeflation) done
Event: 37107,900 Executing VM operation: RendezvousGCThreads
Event: 37107,900 Executing VM operation: RendezvousGCThreads done
Event: 37167,933 Executing VM operation: HandshakeAllThreads (HandshakeForDeflation)
Event: 37167,934 Executing VM operation: HandshakeAllThreads (HandshakeForDeflation) done
Event: 37167,934 Executing VM operation: RendezvousGCThreads
Event: 37167,934 Executing VM operation: RendezvousGCThreads done
Event: 37203,459 Executing VM operation: Exit
Events (20 events):
Event: 37203,377 Protecting memory [0x000070f550c7e000,0x000070f550c82000] with protection modes 0
Event: 37203,378 Thread 0x000070f6b400a860 Thread added: 0x000070f6b400a860
Event: 37203,378 Protecting memory [0x000070f550e7e000,0x000070f550e82000] with protection modes 0
Event: 37203,384 Thread 0x000070f54c0eece0 Thread added: 0x000070f54c0eece0
Event: 37203,385 Protecting memory [0x000070f550f7e000,0x000070f550f82000] with protection modes 0
Event: 37203,390 Thread 0x000070f54c1f64e0 Thread added: 0x000070f54c1f64e0
Event: 37203,391 Thread 0x000070f54c0eece0 Thread exited: 0x000070f54c0eece0
Event: 37203,391 Protecting memory [0x000070f5508da000,0x000070f5508de000] with protection modes 0
Event: 37203,391 Thread 0x000070f54c0eece0 Thread added: 0x000070f54c0eece0
Event: 37203,391 Protecting memory [0x000070f550f7e000,0x000070f550f82000] with protection modes 0
Event: 37203,396 Thread 0x000070f54c1f6bf0 Thread added: 0x000070f54c1f6bf0
Event: 37203,396 Protecting memory [0x000070f5507da000,0x000070f5507de000] with protection modes 0
Event: 37203,400 Thread 0x000070f54c1f7b30 Thread added: 0x000070f54c1f7b30
Event: 37203,400 Thread 0x000070f67c075a40 Thread exited: 0x000070f67c075a40
Event: 37203,402 Thread 0x000070f54c1f64e0 Thread exited: 0x000070f54c1f64e0
Event: 37203,403 Thread 0x000070f54c0eece0 Thread exited: 0x000070f54c0eece0
Event: 37203,408 Thread 0x000070f54c1f6bf0 Thread exited: 0x000070f54c1f6bf0
Event: 37203,410 Protecting memory [0x000070f5504da000,0x000070f5504de000] with protection modes 0
Event: 37203,411 Thread 0x000070f54c1f7b30 Thread exited: 0x000070f54c1f7b30
Event: 37203,449 Thread 0x000070f6f8226d30 Thread exited: 0x000070f6f8226d30
Dynamic libraries:
70a600000-712600000 rw-p 00000000 00:00 0
712600000-719a00000 ---p 00000000 00:00 0
719a00000-719c00000 rw-p 00000000 00:00 0
719c00000-7ffa00000 ---p 00000000 00:00 0
7ffa00000-800030000 rw-p 00000000 00:00 0
800030000-8000b0000 rw-p 00000000 00:00 0
8000b0000-800130000 rw-p 00000000 00:00 0
800130000-800170000 rw-p 00000000 00:00 0
800170000-8001b0000 rw-p 00000000 00:00 0
8001b0000-800270000 rw-p 00000000 00:00 0
800270000-800370000 rw-p 00000000 00:00 0
800370000-8004f0000 rw-p 00000000 00:00 0
8004f0000-800530000 rw-p 00000000 00:00 0
800530000-800570000 rw-p 00000000 00:00 0
800570000-8005f0000 rw-p 00000000 00:00 0
8005f0000-8006d0000 rw-p 00000000 00:00 0
8006d0000-8006f0000 rw-p 00000000 00:00 0
8006f0000-8008f0000 rw-p 00000000 00:00 0
8008f0000-800900000 ---p 00000000 00:00 0
800900000-8009a0000 rw-p 00000000 00:00 0
8009a0000-840000000 ---p 00000000 00:00 0
614856a7a000-614856a7d000 r-xp 00000000 fc:00 10878982 /opt/olvid/bin/olvid
614856a7d000-614856a7e000 r--p 00002000 fc:00 10878982 /opt/olvid/bin/olvid
614856a7e000-614856a7f000 rw-p 00003000 fc:00 10878982 /opt/olvid/bin/olvid
614896506000-614896e5b000 rw-p 00000000 00:00 0 [heap]
70f540000000-70f54004d000 rw-p 00000000 00:00 0
70f54004d000-70f544000000 ---p 00000000 00:00 0
70f548000000-70f548043000 rw-p 00000000 00:00 0
70f548043000-70f54c000000 ---p 00000000 00:00 0
70f54c000000-70f54c00f000 rw-p 00000000 00:00 0
70f54c00f000-70f54c010000 rw-p 00000000 00:00 0
70f54c010000-70f54c026000 rw-p 00000000 00:00 0
70f54c026000-70f54c027000 rw-p 00000000 00:00 0
70f54c027000-70f54c028000 rw-p 00000000 00:00 0
70f54c028000-70f54d384000 rw-p 00000000 00:00 0
70f54d384000-70f550000000 ---p 00000000 00:00 0
70f5505da000-70f5507da000 rw-s 10241b000 00:0f 2083 anon_inode:i915.gem
70f5509da000-70f550bda000 rw-s 105d8e000 00:0f 2083 anon_inode:i915.gem
70f550bda000-70f550bfc000 r-xp 00000000 fc:00 13640610 /home/moi/.openjfx/cache/21+31/amd64/libjavafx_iio.so
70f550bfc000-70f550bfd000 r--p 00021000 fc:00 13640610 /home/moi/.openjfx/cache/21+31/amd64/libjavafx_iio.so
70f550bfd000-70f550bfe000 rw-p 00022000 fc:00 13640610 /home/moi/.openjfx/cache/21+31/amd64/libjavafx_iio.so
70f550c7e000-70f550c82000 ---p 00000000 00:00 0
70f550c82000-70f550d7e000 rw-p 00000000 00:00 0
70f550d7e000-70f550d82000 ---p 00000000 00:00 0
70f550d82000-70f550e7e000 rw-p 00000000 00:00 0
70f550e7e000-70f550e82000 ---p 00000000 00:00 0
70f550e82000-70f550f7e000 rw-p 00000000 00:00 0
70f55107e000-70f551082000 ---p 00000000 00:00 0
70f551082000-70f55117e000 rw-p 00000000 00:00 0
70f55117e000-70f551182000 ---p 00000000 00:00 0
70f551182000-70f55127e000 rw-p 00000000 00:00 0
70f55127e000-70f551282000 ---p 00000000 00:00 0
70f551282000-70f55137e000 rw-p 00000000 00:00 0
70f55137e000-70f551382000 ---p 00000000 00:00 0
70f551382000-70f55147e000 rw-p 00000000 00:00 0
70f55147e000-70f551482000 ---p 00000000 00:00 0
70f551482000-70f55157e000 rw-p 00000000 00:00 0
70f55157e000-70f551582000 ---p 00000000 00:00 0
70f551582000-70f55167e000 rw-p 00000000 00:00 0
70f55167e000-70f551682000 ---p 00000000 00:00 0
70f551682000-70f55177e000 rw-p 00000000 00:00 0
70f55177e000-70f551782000 ---p 00000000 00:00 0
70f551782000-70f55187e000 rw-p 00000000 00:00 0
70f55187e000-70f551882000 ---p 00000000 00:00 0
70f551882000-70f55197e000 rw-p 00000000 00:00 0
70f55197e000-70f551982000 ---p 00000000 00:00 0
70f551982000-70f551a7e000 rw-p 00000000 00:00 0
70f551afe000-70f551b02000 ---p 00000000 00:00 0
70f551b02000-70f551bfe000 rw-p 00000000 00:00 0
70f551bfe000-70f551c02000 ---p 00000000 00:00 0
70f551c02000-70f551cfe000 rw-p 00000000 00:00 0
70f551cfe000-70f551d02000 ---p 00000000 00:00 0
70f551d02000-70f551dfe000 rw-p 00000000 00:00 0
70f551dfe000-70f551e02000 ---p 00000000 00:00 0
70f551e02000-70f551efe000 rw-p 00000000 00:00 0
70f551efe000-70f551eff000 ---p 00000000 00:00 0
70f551eff000-70f5526ff000 rw-p 00000000 00:00 0
70f5526ff000-70f552703000 ---p 00000000 00:00 0
70f552703000-70f5527ff000 rw-p 00000000 00:00 0
70f5527ff000-70f552803000 ---p 00000000 00:00 0
70f552803000-70f5528ff000 rw-p 00000000 00:00 0
70f5528ff000-70f552903000 ---p 00000000 00:00 0
70f552903000-70f5529ff000 rw-p 00000000 00:00 0
70f5529ff000-70f552a03000 ---p 00000000 00:00 0
70f552a03000-70f552aff000 rw-p 00000000 00:00 0
70f552aff000-70f552b03000 ---p 00000000 00:00 0
70f552b03000-70f552bff000 rw-p 00000000 00:00 0
70f552bff000-70f552c03000 ---p 00000000 00:00 0
70f552c03000-70f552cff000 rw-p 00000000 00:00 0
70f552cff000-70f552d03000 ---p 00000000 00:00 0
70f552d03000-70f552dff000 rw-p 00000000 00:00 0
70f552dff000-70f552e03000 ---p 00000000 00:00 0
70f552e03000-70f552eff000 rw-p 00000000 00:00 0
70f552eff000-70f552f03000 ---p 00000000 00:00 0
70f552f03000-70f552fff000 rw-p 00000000 00:00 0
70f552fff000-70f553003000 ---p 00000000 00:00 0
70f553003000-70f5530ff000 rw-p 00000000 00:00 0
70f5530ff000-70f553103000 ---p 00000000 00:00 0
70f553103000-70f5531ff000 rw-p 00000000 00:00 0
70f553a00000-70f553ab3000 r--p 00000000 fc:00 5899275 /usr/lib/x86_64-linux-gnu/libcrypto.so.3
70f553ab3000-70f553de6000 r-xp 000b3000 fc:00 5899275 /usr/lib/x86_64-linux-gnu/libcrypto.so.3
70f553de6000-70f553eb1000 r--p 003e6000 fc:00 5899275 /usr/lib/x86_64-linux-gnu/libcrypto.so.3
70f553eb1000-70f553f0d000 r--p 004b0000 fc:00 5899275 /usr/lib/x86_64-linux-gnu/libcrypto.so.3
70f553f0d000-70f553f10000 rw-p 0050c000 fc:00 5899275 /usr/lib/x86_64-linux-gnu/libcrypto.so.3
70f553f10000-70f553f13000 rw-p 00000000 00:00 0
70f553f37000-70f553f57000 r--p 00000000 fc:00 5903931 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
70f553f57000-70f553fb8000 r-xp 00020000 fc:00 5903931 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
70f553fb8000-70f553ff1000 r--p 00081000 fc:00 5903931 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
70f553ff1000-70f553ffe000 r--p 000ba000 fc:00 5903931 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
70f553ffe000-70f554000000 rw-p 000c7000 fc:00 5903931 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
70f554000000-70f55404a000 rw-p 00000000 00:00 0
70f55404a000-70f558000000 ---p 00000000 00:00 0
70f558000000-70f558033000 rw-p 00000000 00:00 0
70f558033000-70f55c000000 ---p 00000000 00:00 0
70f55c000000-70f55c021000 rw-p 00000000 00:00 0
70f55c021000-70f560000000 ---p 00000000 00:00 0
70f560000000-70f56000f000 rw-p 00000000 00:00 0
70f56000f000-70f560010000 rw-p 00000000 00:00 0
70f560010000-70f560026000 rw-p 00000000 00:00 0
70f560026000-70f560027000 rw-p 00000000 00:00 0
70f560027000-70f560028000 rw-p 00000000 00:00 0
70f560028000-70f560078000 rw-p 00000000 00:00 0
70f560078000-70f560079000 rw-p 00000000 00:00 0
70f560079000-70f56007a000 rw-p 00000000 00:00 0
70f56007a000-70f56008f000 rw-p 00000000 00:00 0
70f56008f000-70f560090000 rw-p 00000000 00:00 0
70f560090000-70f5600a1000 rw-p 00000000 00:00 0
70f5600a1000-70f564000000 ---p 00000000 00:00 0
70f564000000-70f564021000 rw-p 00000000 00:00 0
70f564021000-70f568000000 ---p 00000000 00:00 0
70f568000000-70f568021000 rw-p 00000000 00:00 0
70f568021000-70f56c000000 ---p 00000000 00:00 0
70f56c000000-70f56c021000 rw-p 00000000 00:00 0
70f56c021000-70f570000000 ---p 00000000 00:00 0
70f570000000-70f570021000 rw-p 00000000 00:00 0
70f570021000-70f574000000 ---p 00000000 00:00 0
70f574000000-70f57403b000 rw-p 00000000 00:00 0
70f57403b000-70f578000000 ---p 00000000 00:00 0
70f578000000-70f578021000 rw-p 00000000 00:00 0
70f578021000-70f57c000000 ---p 00000000 00:00 0
70f57c000000-70f57c021000 rw-p 00000000 00:00 0
70f57c021000-70f580000000 ---p 00000000 00:00 0
70f580000000-70f580021000 rw-p 00000000 00:00 0
70f580021000-70f584000000 ---p 00000000 00:00 0
70f584000000-70f58400f000 rw-p 00000000 00:00 0
70f58400f000-70f584010000 rw-p 00000000 00:00 0
70f584010000-70f584026000 rw-p 00000000 00:00 0
70f584026000-70f584027000 rw-p 00000000 00:00 0
70f584027000-70f584028000 rw-p 00000000 00:00 0
70f584028000-70f5841b4000 rw-p 00000000 00:00 0
70f5841b4000-70f588000000 ---p 00000000 00:00 0
70f588000000-70f588021000 rw-p 00000000 00:00 0
70f588021000-70f58c000000 ---p 00000000 00:00 0
70f58c000000-70f58c06e000 rw-p 00000000 00:00 0
70f58c06e000-70f590000000 ---p 00000000 00:00 0
70f590000000-70f590068000 rw-p 00000000 00:00 0
70f590068000-70f594000000 ---p 00000000 00:00 0
70f594000000-70f5941fd000 rw-p 00000000 00:00 0
70f5941fd000-70f598000000 ---p 00000000 00:00 0
70f598000000-70f598021000 rw-p 00000000 00:00 0
70f598021000-70f59c000000 ---p 00000000 00:00 0
70f59c000000-70f59c021000 rw-p 00000000 00:00 0
70f59c021000-70f5a0000000 ---p 00000000 00:00 0
70f5a0000000-70f5a04a3000 rw-p 00000000 00:00 0
70f5a04a3000-70f5a4000000 ---p 00000000 00:00 0
70f5a4000000-70f5a4021000 rw-p 00000000 00:00 0
70f5a4021000-70f5a8000000 ---p 00000000 00:00 0
70f5a8000000-70f5a8021000 rw-p 00000000 00:00 0
70f5a8021000-70f5ac000000 ---p 00000000 00:00 0
70f5ac000000-70f5ac021000 rw-p 00000000 00:00 0
70f5ac021000-70f5b0000000 ---p 00000000 00:00 0
70f5b0000000-70f5b0021000 rw-p 00000000 00:00 0
70f5b0021000-70f5b4000000 ---p 00000000 00:00 0
70f5b4000000-70f5b4021000 rw-p 00000000 00:00 0
70f5b4021000-70f5b8000000 ---p 00000000 00:00 0
70f5b8000000-70f5b8021000 rw-p 00000000 00:00 0
70f5b8021000-70f5bc000000 ---p 00000000 00:00 0
70f5bc000000-70f5bc021000 rw-p 00000000 00:00 0
70f5bc021000-70f5c0000000 ---p 00000000 00:00 0
70f5c0000000-70f5c0021000 rw-p 00000000 00:00 0
70f5c0021000-70f5c4000000 ---p 00000000 00:00 0
70f5c4000000-70f5c4021000 rw-p 00000000 00:00 0
70f5c4021000-70f5c8000000 ---p 00000000 00:00 0
70f5c8000000-70f5c8021000 rw-p 00000000 00:00 0
70f5c8021000-70f5cc000000 ---p 00000000 00:00 0
70f5cc000000-70f5cc021000 rw-p 00000000 00:00 0
70f5cc021000-70f5d0000000 ---p 00000000 00:00 0
70f5d0000000-70f5d0021000 rw-p 00000000 00:00 0
70f5d0021000-70f5d4000000 ---p 00000000 00:00 0
70f5d4000000-70f5d4021000 rw-p 00000000 00:00 0
70f5d4021000-70f5d8000000 ---p 00000000 00:00 0
70f5d8000000-70f5d8021000 rw-p 00000000 00:00 0
70f5d8021000-70f5dc000000 ---p 00000000 00:00 0
70f5dc000000-70f5dc021000 rw-p 00000000 00:00 0
70f5dc021000-70f5e0000000 ---p 00000000 00:00 0
70f5e0000000-70f5e0021000 rw-p 00000000 00:00 0
70f5e0021000-70f5e4000000 ---p 00000000 00:00 0
70f5e4000000-70f5e4021000 rw-p 00000000 00:00 0
70f5e4021000-70f5e8000000 ---p 00000000 00:00 0
70f5e8000000-70f5e8021000 rw-p 00000000 00:00 0
70f5e8021000-70f5ec000000 ---p 00000000 00:00 0
70f5ec000000-70f5ec021000 rw-p 00000000 00:00 0
70f5ec021000-70f5f0000000 ---p 00000000 00:00 0
70f5f0000000-70f5f0861000 rw-p 00000000 00:00 0
70f5f0861000-70f5f4000000 ---p 00000000 00:00 0
70f5f4000000-70f5f4021000 rw-p 00000000 00:00 0
70f5f4021000-70f5f8000000 ---p 00000000 00:00 0
70f5f8000000-70f5f8021000 rw-p 00000000 00:00 0
70f5f8021000-70f5fc000000 ---p 00000000 00:00 0
70f5fc00a000-70f5fc088000 r--p 00000000 fc:00 6054247 /usr/share/fonts/truetype/noto/NotoSans-Regular.ttf
70f5fc088000-70f5fc089000 r--p 00000000 fc:00 5931886 /usr/lib/x86_64-linux-gnu/libnss_mdns4_minimal.so.2
70f5fc089000-70f5fc08b000 r-xp 00001000 fc:00 5931886 /usr/lib/x86_64-linux-gnu/libnss_mdns4_minimal.so.2
70f5fc08b000-70f5fc08c000 r--p 00003000 fc:00 5931886 /usr/lib/x86_64-linux-gnu/libnss_mdns4_minimal.so.2
70f5fc08c000-70f5fc08d000 r--p 00003000 fc:00 5931886 /usr/lib/x86_64-linux-gnu/libnss_mdns4_minimal.so.2
70f5fc08d000-70f5fc08e000 rw-p 00004000 fc:00 5931886 /usr/lib/x86_64-linux-gnu/libnss_mdns4_minimal.so.2
70f5fc08e000-70f5fc091000 r--p 00000000 fc:00 5901717 /usr/lib/x86_64-linux-gnu/libresolv.so.2
70f5fc091000-70f5fc09b000 r-xp 00003000 fc:00 5901717 /usr/lib/x86_64-linux-gnu/libresolv.so.2
70f5fc09b000-70f5fc09d000 r--p 0000d000 fc:00 5901717 /usr/lib/x86_64-linux-gnu/libresolv.so.2
70f5fc09d000-70f5fc09e000 r--p 0000f000 fc:00 5901717 /usr/lib/x86_64-linux-gnu/libresolv.so.2
70f5fc09e000-70f5fc09f000 rw-p 00010000 fc:00 5901717 /usr/lib/x86_64-linux-gnu/libresolv.so.2
70f5fc09f000-70f5fc0a1000 rw-p 00000000 00:00 0
70f5fc0a1000-70f5fc0a5000 ---p 00000000 00:00 0
70f5fc0a5000-70f5fc1a1000 rw-p 00000000 00:00 0
70f5fc1a1000-70f5fc1ab000 r--p 00000000 fc:00 5903793 /usr/lib/x86_64-linux-gnu/libgmp.so.10.5.0
70f5fc1ab000-70f5fc20e000 r-xp 0000a000 fc:00 5903793 /usr/lib/x86_64-linux-gnu/libgmp.so.10.5.0
70f5fc20e000-70f5fc223000 r--p 0006d000 fc:00 5903793 /usr/lib/x86_64-linux-gnu/libgmp.so.10.5.0
70f5fc223000-70f5fc224000 r--p 00081000 fc:00 5903793 /usr/lib/x86_64-linux-gnu/libgmp.so.10.5.0
70f5fc224000-70f5fc225000 rw-p 00082000 fc:00 5903793 /usr/lib/x86_64-linux-gnu/libgmp.so.10.5.0
70f5fc225000-70f5fc25d000 r--p 00000000 fc:00 5931928 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.1
70f5fc25d000-70f5fc32f000 r-xp 00038000 fc:00 5931928 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.1
70f5fc32f000-70f5fc3ae000 r--p 0010a000 fc:00 5931928 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.1
70f5fc3ae000-70f5fc3bb000 r--p 00188000 fc:00 5931928 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.1
70f5fc3bb000-70f5fc3c8000 rw-p 00195000 fc:00 5931928 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.1
70f5fc3c8000-70f5fc3c9000 rw-p 00000000 00:00 0
70f5fc3cd000-70f5fc3cf000 r--p 00000000 fc:00 5931670 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.10
70f5fc3cf000-70f5fc3d1000 r-xp 00002000 fc:00 5931670 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.10
70f5fc3d1000-70f5fc3d2000 r--p 00004000 fc:00 5931670 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.10
70f5fc3d2000-70f5fc3d3000 r--p 00004000 fc:00 5931670 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.10
70f5fc3d3000-70f5fc3d4000 rw-p 00005000 fc:00 5931670 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.10
70f5fc3d4000-70f5fc3d7000 r--p 00000000 fc:00 5932141 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
70f5fc3d7000-70f5fc3e7000 r-xp 00003000 fc:00 5932141 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
70f5fc3e7000-70f5fc3ec000 r--p 00013000 fc:00 5932141 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
70f5fc3ec000-70f5fc3ed000 r--p 00017000 fc:00 5932141 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
70f5fc3ed000-70f5fc3ee000 rw-p 00018000 fc:00 5932141 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
70f5fc3ee000-70f5fc3f1000 r--p 00000000 fc:00 5903929 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
70f5fc3f1000-70f5fc3f7000 r-xp 00003000 fc:00 5903929 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
70f5fc3f7000-70f5fc3f9000 r--p 00009000 fc:00 5903929 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
70f5fc3f9000-70f5fc3fa000 r--p 0000a000 fc:00 5903929 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
70f5fc3fa000-70f5fc3fb000 rw-p 0000b000 fc:00 5903929 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
70f5fc3fb000-70f5fc3fd000 r--p 00000000 fc:00 5931070 /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
70f5fc3fd000-70f5fc3fe000 r-xp 00002000 fc:00 5931070 /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
70f5fc3fe000-70f5fc3ff000 r--p 00003000 fc:00 5931070 /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
70f5fc3ff000-70f5fc400000 r--p 00003000 fc:00 5931070 /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
70f5fc400000-70f5fc401000 rw-p 00004000 fc:00 5931070 /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
70f5fc401000-70f5fc405000 r--p 00000000 fc:00 5903925 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
70f5fc405000-70f5fc420000 r-xp 00004000 fc:00 5903925 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
70f5fc420000-70f5fc42b000 r--p 0001f000 fc:00 5903925 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
70f5fc42b000-70f5fc42c000 r--p 0002a000 fc:00 5903925 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
70f5fc42c000-70f5fc42d000 rw-p 0002b000 fc:00 5903925 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
70f5fc42d000-70f5fc430000 r--p 00000000 fc:00 5903812 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.3
70f5fc430000-70f5fc43e000 r-xp 00003000 fc:00 5903812 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.3
70f5fc43e000-70f5fc441000 r--p 00011000 fc:00 5903812 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.3
70f5fc441000-70f5fc442000 r--p 00014000 fc:00 5903812 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.3
70f5fc442000-70f5fc443000 rw-p 00015000 fc:00 5903812 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.3
70f5fc443000-70f5fc44b000 r--p 00000000 fc:00 5931554 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.8
70f5fc44b000-70f5fc45f000 r-xp 00008000 fc:00 5931554 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.8
70f5fc45f000-70f5fc488000 r--p 0001c000 fc:00 5931554 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.8
70f5fc488000-70f5fc48a000 r--p 00044000 fc:00 5931554 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.8
70f5fc48a000-70f5fc48b000 rw-p 00046000 fc:00 5931554 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.8
70f5fc48b000-70f5fc49c000 r--p 00000000 fc:00 5903807 /usr/lib/x86_64-linux-gnu/libunistring.so.5.0.0
70f5fc49c000-70f5fc4d3000 r-xp 00011000 fc:00 5903807 /usr/lib/x86_64-linux-gnu/libunistring.so.5.0.0
70f5fc4d3000-70f5fc633000 r--p 00048000 fc:00 5903807 /usr/lib/x86_64-linux-gnu/libunistring.so.5.0.0
70f5fc633000-70f5fc637000 r--p 001a8000 fc:00 5903807 /usr/lib/x86_64-linux-gnu/libunistring.so.5.0.0
70f5fc637000-70f5fc638000 rw-p 001ac000 fc:00 5903807 /usr/lib/x86_64-linux-gnu/libunistring.so.5.0.0
70f5fc638000-70f5fc63b000 r--p 00000000 fc:00 5913490 /usr/lib/x86_64-linux-gnu/liblber.so.2.0.200
70f5fc63b000-70f5fc643000 r-xp 00003000 fc:00 5913490 /usr/lib/x86_64-linux-gnu/liblber.so.2.0.200
70f5fc643000-70f5fc646000 r--p 0000b000 fc:00 5913490 /usr/lib/x86_64-linux-gnu/liblber.so.2.0.200
70f5fc646000-70f5fc647000 r--p 0000d000 fc:00 5913490 /usr/lib/x86_64-linux-gnu/liblber.so.2.0.200
70f5fc647000-70f5fc648000 rw-p 0000e000 fc:00 5913490 /usr/lib/x86_64-linux-gnu/liblber.so.2.0.200
70f5fc648000-70f5fc656000 r--p 00000000 fc:00 5913492 /usr/lib/x86_64-linux-gnu/libldap.so.2.0.200
70f5fc656000-70f5fc692000 r-xp 0000e000 fc:00 5913492 /usr/lib/x86_64-linux-gnu/libldap.so.2.0.200
70f5fc692000-70f5fc6a1000 r--p 0004a000 fc:00 5913492 /usr/lib/x86_64-linux-gnu/libldap.so.2.0.200
70f5fc6a1000-70f5fc6a3000 r--p 00058000 fc:00 5913492 /usr/lib/x86_64-linux-gnu/libldap.so.2.0.200
70f5fc6a3000-70f5fc6a4000 rw-p 0005a000 fc:00 5913492 /usr/lib/x86_64-linux-gnu/libldap.so.2.0.200
70f5fc6a4000-70f5fc6a6000 rw-p 00000000 00:00 0
70f5fc6a6000-70f5fc6b2000 r--p 00000000 fc:00 5903927 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
70f5fc6b2000-70f5fc6ec000 r-xp 0000c000 fc:00 5903927 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
70f5fc6ec000-70f5fc6f6000 r--p 00046000 fc:00 5903927 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
70f5fc6f6000-70f5fc6f8000 r--p 0004f000 fc:00 5903927 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
70f5fc6f8000-70f5fc6fa000 rw-p 00051000 fc:00 5903927 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
70f5fc6fa000-70f5fc72d000 r--p 00000000 fc:00 5903816 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.37.1
70f5fc72d000-70f5fc866000 r-xp 00033000 fc:00 5903816 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.37.1
70f5fc866000-70f5fc8df000 r--p 0016c000 fc:00 5903816 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.37.1
70f5fc8df000-70f5fc8ef000 r--p 001e4000 fc:00 5903816 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.37.1
70f5fc8ef000-70f5fc8f1000 rw-p 001f4000 fc:00 5903816 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.37.1
70f5fc8f1000-70f5fc8f4000 rw-p 00000000 00:00 0
70f5fc8f4000-70f5fc900000 r--p 00000000 fc:00 5931844 /usr/lib/x86_64-linux-gnu/libnettle.so.8.8
70f5fc900000-70f5fc92f000 r-xp 0000c000 fc:00 5931844 /usr/lib/x86_64-linux-gnu/libnettle.so.8.8
70f5fc92f000-70f5fc946000 r--p 0003b000 fc:00 5931844 /usr/lib/x86_64-linux-gnu/libnettle.so.8.8
70f5fc946000-70f5fc948000 r--p 00051000 fc:00 5931844 /usr/lib/x86_64-linux-gnu/libnettle.so.8.8
70f5fc948000-70f5fc949000 rw-p 00053000 fc:00 5931844 /usr/lib/x86_64-linux-gnu/libnettle.so.8.8
70f5fc949000-70f5fc957000 r--p 00000000 fc:00 5932232 /usr/lib/x86_64-linux-gnu/libssh.so.4.9.6
70f5fc957000-70f5fc99e000 r-xp 0000e000 fc:00 5932232 /usr/lib/x86_64-linux-gnu/libssh.so.4.9.6
70f5fc99e000-70f5fc9b6000 r--p 00055000 fc:00 5932232 /usr/lib/x86_64-linux-gnu/libssh.so.4.9.6
70f5fc9b6000-70f5fc9b8000 r--p 0006c000 fc:00 5932232 /usr/lib/x86_64-linux-gnu/libssh.so.4.9.6
70f5fc9b8000-70f5fc9ba000 rw-p 0006e000 fc:00 5932232 /usr/lib/x86_64-linux-gnu/libssh.so.4.9.6
70f5fc9ba000-70f5fc9bf000 r--p 00000000 fc:00 5932119 /usr/lib/x86_64-linux-gnu/librtmp.so.1
70f5fc9bf000-70f5fc9d0000 r-xp 00005000 fc:00 5932119 /usr/lib/x86_64-linux-gnu/librtmp.so.1
70f5fc9d0000-70f5fc9d6000 r--p 00016000 fc:00 5932119 /usr/lib/x86_64-linux-gnu/librtmp.so.1
70f5fc9d6000-70f5fc9d7000 r--p 0001c000 fc:00 5932119 /usr/lib/x86_64-linux-gnu/librtmp.so.1
70f5fc9d7000-70f5fc9d8000 rw-p 0001d000 fc:00 5932119 /usr/lib/x86_64-linux-gnu/librtmp.so.1
70f5fc9d8000-70f5fc9da000 r--p 00000000 fc:00 5903809 /usr/lib/x86_64-linux-gnu/libidn2.so.0.4.0
70f5fc9da000-70f5fc9de000 r-xp 00002000 fc:00 5903809 /usr/lib/x86_64-linux-gnu/libidn2.so.0.4.0
70f5fc9de000-70f5fc9f8000 r--p 00006000 fc:00 5903809 /usr/lib/x86_64-linux-gnu/libidn2.so.0.4.0
70f5fc9f8000-70f5fc9f9000 r--p 0001f000 fc:00 5903809 /usr/lib/x86_64-linux-gnu/libidn2.so.0.4.0
70f5fc9f9000-70f5fc9fa000 rw-p 00020000 fc:00 5903809 /usr/lib/x86_64-linux-gnu/libidn2.so.0.4.0
70f5fc9fa000-70f5fca01000 r--p 00000000 fc:00 5931176 /usr/lib/x86_64-linux-gnu/libduktape.so.207
70f5fca01000-70f5fca33000 r-xp 00007000 fc:00 5931176 /usr/lib/x86_64-linux-gnu/libduktape.so.207
70f5fca33000-70f5fca43000 r--p 00039000 fc:00 5931176 /usr/lib/x86_64-linux-gnu/libduktape.so.207
70f5fca43000-70f5fca44000 r--p 00049000 fc:00 5931176 /usr/lib/x86_64-linux-gnu/libduktape.so.207
70f5fca44000-70f5fca45000 rw-p 0004a000 fc:00 5931176 /usr/lib/x86_64-linux-gnu/libduktape.so.207
70f5fca45000-70f5fca55000 r--p 00000000 fc:00 5931092 /usr/lib/x86_64-linux-gnu/libcurl-gnutls.so.4.8.0
70f5fca55000-70f5fcadd000 r-xp 00010000 fc:00 5931092 /usr/lib/x86_64-linux-gnu/libcurl-gnutls.so.4.8.0
70f5fcadd000-70f5fcaf9000 r--p 00098000 fc:00 5931092 /usr/lib/x86_64-linux-gnu/libcurl-gnutls.so.4.8.0
70f5fcaf9000-70f5fcafd000 r--p 000b4000 fc:00 5931092 /usr/lib/x86_64-linux-gnu/libcurl-gnutls.so.4.8.0
70f5fcafd000-70f5fcb00000 rw-p 000b8000 fc:00 5931092 /usr/lib/x86_64-linux-gnu/libcurl-gnutls.so.4.8.0
70f5fcb00000-70f5fcb04000 ---p 00000000 00:00 0
70f5fcb04000-70f5fcc00000 rw-p 00000000 00:00 0
70f5fcc00000-70f5fcc04000 ---p 00000000 00:00 0
70f5fcc04000-70f5fcd00000 rw-p 00000000 00:00 0
70f5fcd00000-70f5fcd04000 ---p 00000000 00:00 0
70f5fcd04000-70f5fce00000 rw-p 00000000 00:00 0
70f5fce00000-70f5fce04000 ---p 00000000 00:00 0
70f5fce04000-70f5fcf00000 rw-p 00000000 00:00 0
70f5fcf00000-70f5fcf04000 ---p 00000000 00:00 0
70f5fcf04000-70f5fd000000 rw-p 00000000 00:00 0
70f5fd000000-70f5fd004000 ---p 00000000 00:00 0
70f5fd004000-70f5fd100000 rw-p 00000000 00:00 0
70f5fd100000-70f5fd104000 ---p 00000000 00:00 0
70f5fd104000-70f5fd200000 rw-p 00000000 00:00 0
70f5fd200000-70f5fd204000 ---p 00000000 00:00 0
70f5fd204000-70f5fd300000 rw-p 00000000 00:00 0
70f5fd300000-70f5fd304000 ---p 00000000 00:00 0
70f5fd304000-70f5fd400000 rw-p 00000000 00:00 0
70f5fd400000-70f5fd404000 ---p 00000000 00:00 0
70f5fd404000-70f5fd500000 rw-p 00000000 00:00 0
70f5fd500000-70f5fd504000 ---p 00000000 00:00 0
70f5fd504000-70f5fd600000 rw-p 00000000 00:00 0
70f5fd600000-70f5fd604000 ---p 00000000 00:00 0
70f5fd604000-70f5fd700000 rw-p 00000000 00:00 0
70f5fd700000-70f5fd704000 ---p 00000000 00:00 0
70f5fd704000-70f5fd800000 rw-p 00000000 00:00 0
70f5fd800000-70f5fd804000 ---p 00000000 00:00 0
70f5fd804000-70f5fd900000 rw-p 00000000 00:00 0
70f5fd900000-70f5fd904000 ---p 00000000 00:00 0
70f5fd904000-70f5fda00000 rw-p 00000000 00:00 0
70f5fda00000-70f5fda04000 ---p 00000000 00:00 0
70f5fda04000-70f5fdb00000 rw-p 00000000 00:00 0
70f5fdb00000-70f5fdb04000 ---p 00000000 00:00 0
70f5fdb04000-70f5fdc00000 rw-p 00000000 00:00 0
70f5fdc00000-70f5fdc04000 ---p 00000000 00:00 0
70f5fdc04000-70f5fdd00000 rw-p 00000000 00:00 0
70f5fdd00000-70f5fdd04000 ---p 00000000 00:00 0
70f5fdd04000-70f5fde00000 rw-p 00000000 00:00 0
70f5fde00000-70f5fde04000 ---p 00000000 00:00 0
70f5fde04000-70f5fdf00000 rw-p 00000000 00:00 0
70f5fdf00000-70f5fdf04000 ---p 00000000 00:00 0
70f5fdf04000-70f5fe000000 rw-p 00000000 00:00 0
70f5fe000000-70f5fe004000 ---p 00000000 00:00 0
70f5fe004000-70f5fe100000 rw-p 00000000 00:00 0
70f5fe100000-70f5fe104000 ---p 00000000 00:00 0
70f5fe104000-70f5fe200000 rw-p 00000000 00:00 0
70f5fe200000-70f5fe204000 ---p 00000000 00:00 0
70f5fe204000-70f5fe300000 rw-p 00000000 00:00 0
70f5fe300000-70f5fe304000 ---p 00000000 00:00 0
70f5fe304000-70f5fe400000 rw-p 00000000 00:00 0
70f5fe400000-70f5fe404000 ---p 00000000 00:00 0
70f5fe404000-70f5fe500000 rw-p 00000000 00:00 0
70f5fe500000-70f5fe504000 ---p 00000000 00:00 0
70f5fe504000-70f5fe600000 rw-p 00000000 00:00 0
70f5fe600000-70f5fe604000 ---p 00000000 00:00 0
70f5fe604000-70f5fe700000 rw-p 00000000 00:00 0
70f5fe700000-70f5fe704000 ---p 00000000 00:00 0
70f5fe704000-70f5fe800000 rw-p 00000000 00:00 0
70f5fe800000-70f5fe804000 ---p 00000000 00:00 0
70f5fe804000-70f5fe900000 rw-p 00000000 00:00 0
70f5fe900000-70f5fe904000 ---p 00000000 00:00 0
70f5fe904000-70f5fea00000 rw-p 00000000 00:00 0
70f5fea00000-70f5fea04000 ---p 00000000 00:00 0
70f5fea04000-70f5feb00000 rw-p 00000000 00:00 0
70f5feb00000-70f5feb04000 ---p 00000000 00:00 0
70f5feb04000-70f5fec00000 rw-p 00000000 00:00 0
70f5fec00000-70f5fec04000 ---p 00000000 00:00 0
70f5fec04000-70f5fed00000 rw-p 00000000 00:00 0
70f5fed00000-70f5fed04000 ---p 00000000 00:00 0
70f5fed04000-70f5fee00000 rw-p 00000000 00:00 0
70f5fee00000-70f5fee04000 ---p 00000000 00:00 0
70f5fee04000-70f5fef00000 rw-p 00000000 00:00 0
70f5fef00000-70f5fef04000 ---p 00000000 00:00 0
70f5fef04000-70f5ff000000 rw-p 00000000 00:00 0
70f5ff000000-70f5ff004000 ---p 00000000 00:00 0
70f5ff004000-70f5ff100000 rw-p 00000000 00:00 0
70f5ff100000-70f5ff104000 ---p 00000000 00:00 0
70f5ff104000-70f5ff200000 rw-p 00000000 00:00 0
70f5ff200000-70f5ff204000 ---p 00000000 00:00 0
70f5ff204000-70f5ff300000 rw-p 00000000 00:00 0
70f5ff300000-70f5ff304000 ---p 00000000 00:00 0
70f5ff304000-70f5ff400000 rw-p 00000000 00:00 0
70f5ff4c0000-70f5ff540000 rw-s 10a4d2000 00:0f 2083 anon_inode:i915.gem
70f5ff540000-70f5ff5c0000 rw-s 105bb2000 00:0f 2083 anon_inode:i915.gem
70f5ff5c0000-70f5ff600000 rw-s 10ab72000 00:0f 2083 anon_inode:i915.gem
70f5ff600000-70f5ff800000 rw-s 1021fb000 00:0f 2083 anon_inode:i915.gem
70f5ff800000-70f5ff8de000 r--p 00000000 fc:00 10879069 /opt/olvid/lib/runtime/lib/sqlcipher-jdbc.so
70f5ff8de000-70f5ffc35000 r-xp 000de000 fc:00 10879069 /opt/olvid/lib/runtime/lib/sqlcipher-jdbc.so
70f5ffc35000-70f5ffd26000 r--p 00435000 fc:00 10879069 /opt/olvid/lib/runtime/lib/sqlcipher-jdbc.so
70f5ffd26000-70f5ffd27000 ---p 00526000 fc:00 10879069 /opt/olvid/lib/runtime/lib/sqlcipher-jdbc.so
70f5ffd27000-70f5ffd7e000 r--p 00526000 fc:00 10879069 /opt/olvid/lib/runtime/lib/sqlcipher-jdbc.so
70f5ffd7e000-70f5ffd8e000 rw-p 0057d000 fc:00 10879069 /opt/olvid/lib/runtime/lib/sqlcipher-jdbc.so
70f5ffd8e000-70f5ffd91000 rw-p 00000000 00:00 0
70f5ffd95000-70f5ffd97000 r--p 00000000 fc:00 5932040 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.4
70f5ffd97000-70f5ffd99000 r-xp 00002000 fc:00 5932040 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.4
70f5ffd99000-70f5ffda7000 r--p 00004000 fc:00 5932040 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.4
70f5ffda7000-70f5ffda8000 r--p 00011000 fc:00 5932040 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.4
70f5ffda8000-70f5ffda9000 rw-p 00012000 fc:00 5932040 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.4
70f5ffda9000-70f5ffdae000 r--p 00000000 fc:00 5900098 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.26.0
70f5ffdae000-70f5ffdc4000 r-xp 00005000 fc:00 5900098 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.26.0
70f5ffdc4000-70f5ffdd0000 r--p 0001b000 fc:00 5900098 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.26.0
70f5ffdd0000-70f5ffdd3000 r--p 00026000 fc:00 5900098 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.26.0
70f5ffdd3000-70f5ffdd4000 rw-p 00029000 fc:00 5900098 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.26.0
70f5ffdd4000-70f5ffdd7000 r--p 00000000 fc:00 5933460 /usr/lib/x86_64-linux-gnu/libproxy/libpxbackend-1.0.so
70f5ffdd7000-70f5ffddd000 r-xp 00003000 fc:00 5933460 /usr/lib/x86_64-linux-gnu/libproxy/libpxbackend-1.0.so
70f5ffddd000-70f5ffde0000 r--p 00009000 fc:00 5933460 /usr/lib/x86_64-linux-gnu/libproxy/libpxbackend-1.0.so
70f5ffde0000-70f5ffde1000 r--p 0000c000 fc:00 5933460 /usr/lib/x86_64-linux-gnu/libproxy/libpxbackend-1.0.so
70f5ffde1000-70f5ffde2000 rw-p 0000d000 fc:00 5933460 /usr/lib/x86_64-linux-gnu/libproxy/libpxbackend-1.0.so
70f5ffde2000-70f5ffde3000 r--p 00000000 fc:00 5932037 /usr/lib/x86_64-linux-gnu/libproxy.so.0.5.4
70f5ffde3000-70f5ffde4000 r-xp 00001000 fc:00 5932037 /usr/lib/x86_64-linux-gnu/libproxy.so.0.5.4
70f5ffde4000-70f5ffde5000 r--p 00002000 fc:00 5932037 /usr/lib/x86_64-linux-gnu/libproxy.so.0.5.4
70f5ffde5000-70f5ffde6000 r--p 00002000 fc:00 5932037 /usr/lib/x86_64-linux-gnu/libproxy.so.0.5.4
70f5ffde6000-70f5ffde7000 rw-p 00003000 fc:00 5932037 /usr/lib/x86_64-linux-gnu/libproxy.so.0.5.4
70f5ffdfa000-70f5ffdfc000 r--p 00000000 fc:00 6029807 /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so
70f5ffdfc000-70f5ffdfd000 r-xp 00002000 fc:00 6029807 /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so
70f5ffdfd000-70f5ffdfe000 r--p 00003000 fc:00 6029807 /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so
70f5ffdfe000-70f5ffdff000 r--p 00003000 fc:00 6029807 /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so
70f5ffdff000-70f5ffe00000 rw-p 00004000 fc:00 6029807 /usr/lib/x86_64-linux-gnu/gio/modules/libgiolibproxy.so
70f5ffe00000-70f5ffe04000 ---p 00000000 00:00 0
70f5ffe04000-70f5fff00000 rw-p 00000000 00:00 0
70f5fff00000-70f600000000 rw-s 00000000 00:01 28 /SYSV00000000 (deleted)
70f600000000-70f6002cd000 rw-p 00000000 00:00 0
70f6002cd000-70f6002ce000 rw-p 00000000 00:00 0
70f6002ce000-70f60030a000 rw-p 00000000 00:00 0
70f60030a000-70f600334000 rw-p 00000000 00:00 0
70f600334000-70f600336000 rw-p 00000000 00:00 0
70f600336000-70f600340000 rw-p 00000000 00:00 0
70f600340000-70f600341000 rw-p 00000000 00:00 0
70f600341000-70f60034a000 rw-p 00000000 00:00 0
70f60034a000-70f60034c000 rw-p 00000000 00:00 0
70f60034c000-70f6003c1000 rw-p 00000000 00:00 0
70f6003c1000-70f6003c3000 rw-p 00000000 00:00 0
70f6003c3000-70f600478000 rw-p 00000000 00:00 0
70f600478000-70f600479000 rw-p 00000000 00:00 0
70f600479000-70f60048e000 rw-p 00000000 00:00 0
70f60048e000-70f60048f000 rw-p 00000000 00:00 0
70f60048f000-70f60049e000 rw-p 00000000 00:00 0
70f60049e000-70f6004a0000 rw-p 00000000 00:00 0
70f6004a0000-70f6004e7000 rw-p 00000000 00:00 0
70f6004e7000-70f6004e9000 rw-p 00000000 00:00 0
70f6004e9000-70f6004ea000 rw-p 00000000 00:00 0
70f6004ea000-70f6004eb000 rw-p 00000000 00:00 0
70f6004eb000-70f60058b000 rw-p 00000000 00:00 0
70f60058b000-70f60058d000 rw-p 00000000 00:00 0
70f60058d000-70f6008ed000 rw-p 00000000 00:00 0
70f6008ed000-70f600a1f000 rw-p 00000000 00:00 0
70f600a1f000-70f600a20000 rw-p 00000000 00:00 0
70f600a20000-70f600a21000 rw-p 00000000 00:00 0
70f600a21000-70f600a22000 rw-p 00000000 00:00 0
70f600a22000-70f600a23000 rw-p 00000000 00:00 0
70f600a23000-70f600a25000 rw-p 00000000 00:00 0
70f600a25000-70f600aef000 rw-p 00000000 00:00 0
70f600aef000-70f604000000 ---p 00000000 00:00 0
70f604000000-70f6053f1000 rw-p 00000000 00:00 0
70f6053f1000-70f608000000 ---p 00000000 00:00 0
70f608000000-70f608075000 rw-p 00000000 00:00 0
70f608075000-70f60c000000 ---p 00000000 00:00 0
70f60c000000-70f60d2a7000 rw-p 00000000 00:00 0
70f60d2a7000-70f610000000 ---p 00000000 00:00 0
70f610000000-70f6100a1000 rw-p 00000000 00:00 0
70f6100a1000-70f614000000 ---p 00000000 00:00 0
70f614000000-70f614086000 rw-p 00000000 00:00 0
70f614086000-70f618000000 ---p 00000000 00:00 0
70f618000000-70f618021000 rw-p 00000000 00:00 0
70f618021000-70f61c000000 ---p 00000000 00:00 0
70f61c000000-70f61c021000 rw-p 00000000 00:00 0
70f61c021000-70f620000000 ---p 00000000 00:00 0
70f620000000-70f620021000 rw-p 00000000 00:00 0
70f620021000-70f624000000 ---p 00000000 00:00 0
70f624000000-70f624021000 rw-p 00000000 00:00 0
70f624021000-70f628000000 ---p 00000000 00:00 0
70f628000000-70f629819000 rw-p 00000000 00:00 0
70f629819000-70f62c000000 ---p 00000000 00:00 0
70f62c000000-70f62c021000 rw-p 00000000 00:00 0
70f62c021000-70f630000000 ---p 00000000 00:00 0
70f630000000-70f630021000 rw-p 00000000 00:00 0
70f630021000-70f634000000 ---p 00000000 00:00 0
70f634000000-70f634021000 rw-p 00000000 00:00 0
70f634021000-70f638000000 ---p 00000000 00:00 0
70f638000000-70f638021000 rw-p 00000000 00:00 0
70f638021000-70f63c000000 ---p 00000000 00:00 0
70f63c000000-70f63c021000 rw-p 00000000 00:00 0
70f63c021000-70f640000000 ---p 00000000 00:00 0
70f640000000-70f640021000 rw-p 00000000 00:00 0
70f640021000-70f644000000 ---p 00000000 00:00 0
70f644000000-70f644002000 r--p 00000000 fc:00 6029805 /usr/lib/x86_64-linux-gnu/gio/modules/libgiognomeproxy.so
70f644002000-70f644004000 r-xp 00002000 fc:00 6029805 /usr/lib/x86_64-linux-gnu/gio/modules/libgiognomeproxy.so
70f644004000-70f644005000 r--p 00004000 fc:00 6029805 /usr/lib/x86_64-linux-gnu/gio/modules/libgiognomeproxy.so
70f644005000-70f644006000 r--p 00004000 fc:00 6029805 /usr/lib/x86_64-linux-gnu/gio/modules/libgiognomeproxy.so
70f644006000-70f644007000 rw-p 00005000 fc:00 6029805 /usr/lib/x86_64-linux-gnu/gio/modules/libgiognomeproxy.so
70f644017000-70f644027000 rw-s 1026fe000 00:0f 2083 anon_inode:i915.gem
70f644027000-70f64402f000 rw-s 00000000 fc:00 13631647 /home/moi/.local/share/olvid/engine_db.sqlite-shm
70f64402f000-70f64404f000 rw-s 10511e000 00:0f 2083 anon_inode:i915.gem
70f64404f000-70f64405f000 rw-s 1023fb000 00:0f 2083 anon_inode:i915.gem
70f64405f000-70f64406f000 rw-s 101fcb000 00:0f 2083 anon_inode:i915.gem
70f64406f000-70f644075000 r--p 00000000 fc:00 7215830 /usr/share/locale-langpack/fr/LC_MESSAGES/gdk-pixbuf.mo
70f644075000-70f64407d000 rw-s 00000000 fc:00 13631641 /home/moi/.local/share/olvid/olvid_desktop_app.sqlite-shm
70f64407d000-70f64409b000 r--p 00000000 00:25 131 /tmp/+JXF13317418721836115350.tmp (deleted)
70f64409b000-70f6440ff000 r--p 00000000 00:25 130 /tmp/+JXF1074252508913747378.tmp (deleted)
70f6440ff000-70f644162000 r--p 00000000 00:25 129 /tmp/+JXF8265850273700777826.tmp (deleted)
70f644162000-70f6441ae000 r--p 00000000 00:25 128 /tmp/+JXF3260227770571476674.tmp (deleted)
70f6441ae000-70f6441b2000 r-xp 00000000 fc:00 13631638 /home/moi/.openjfx/cache/21+31/amd64/libjavafx_font_pango.so
70f6441b2000-70f6441b3000 r--p 00003000 fc:00 13631638 /home/moi/.openjfx/cache/21+31/amd64/libjavafx_font_pango.so
70f6441b3000-70f6441b4000 rw-p 00004000 fc:00 13631638 /home/moi/.openjfx/cache/21+31/amd64/libjavafx_font_pango.so
70f6441b4000-70f6441ff000 r--p 00000000 00:25 127 /tmp/+JXF9317400330282991162.tmp (deleted)
70f6441ff000-70f644200000 ---p 00000000 00:00 0
70f644200000-70f644300000 rw-p 00000000 00:00 0
70f644300000-70f644304000 ---p 00000000 00:00 0
70f644304000-70f644400000 rw-p 00000000 00:00 0
70f644400000-70f644404000 ---p 00000000 00:00 0
70f644404000-70f644500000 rw-p 00000000 00:00 0
70f644500000-70f644504000 ---p 00000000 00:00 0
70f644504000-70f644600000 rw-p 00000000 00:00 0
70f644600000-70f644604000 ---p 00000000 00:00 0
70f644604000-70f644700000 rw-p 00000000 00:00 0
70f644700000-70f644704000 ---p 00000000 00:00 0
70f644704000-70f644800000 rw-p 00000000 00:00 0
70f644800000-70f644a2f000 r-xp 00000000 fc:00 10879097 /opt/olvid/lib/runtime/lib/libfontmanager.so
70f644a2f000-70f644a30000 ---p 0022f000 fc:00 10879097 /opt/olvid/lib/runtime/lib/libfontmanager.so
70f644a30000-70f644a32000 r--p 0022f000 fc:00 10879097 /opt/olvid/lib/runtime/lib/libfontmanager.so
70f644a32000-70f644a33000 rw-p 00231000 fc:00 10879097 /opt/olvid/lib/runtime/lib/libfontmanager.so
70f644a33000-70f644a34000 rw-p 00000000 00:00 0
70f644a34000-70f644a42000 r--s 00000000 fc:00 19670066 /var/cache/fontconfig/a4e60e8d1e10d2fdff3fe3037a1845fb-le64.cache-9
70f644a42000-70f644aa0000 r--s 00000000 fc:00 19670065 /var/cache/fontconfig/2300eef321c393bfd76478a5c0e95b23-le64.cache-9
70f644aa0000-70f644b15000 r--s 00000000 fc:00 19664319 /var/cache/fontconfig/0bd3dc0958fa2205aaaa8ebb13e2872b-le64.cache-9
70f644b15000-70f644b22000 r--s 00000000 fc:00 19664984 /var/cache/fontconfig/d589a48862398ed80a3d6066f4f56f4c-le64.cache-9
70f644b22000-70f644b26000 ---p 00000000 00:00 0
70f644b26000-70f644c22000 rw-p 00000000 00:00 0
70f644c22000-70f644c91000 r-xp 00000000 fc:00 10879078 /opt/olvid/lib/runtime/lib/libawt_xawt.so
70f644c91000-70f644c92000 ---p 0006f000 fc:00 10879078 /opt/olvid/lib/runtime/lib/libawt_xawt.so
70f644c92000-70f644c97000 r--p 0006f000 fc:00 10879078 /opt/olvid/lib/runtime/lib/libawt_xawt.so
70f644c97000-70f644c99000 rw-p 00074000 fc:00 10879078 /opt/olvid/lib/runtime/lib/libawt_xawt.so
70f644c99000-70f644c9b000 rw-p 00000000 00:00 0
70f644c9b000-70f644d48000 r-xp 00000000 fc:00 10879065 /opt/olvid/lib/runtime/lib/libawt.so
70f644d48000-70f644d49000 r--p 000ac000 fc:00 10879065 /opt/olvid/lib/runtime/lib/libawt.so
70f644d49000-70f644d54000 rw-p 000ad000 fc:00 10879065 /opt/olvid/lib/runtime/lib/libawt.so
70f644d54000-70f644d79000 rw-p 00000000 00:00 0
70f644d79000-70f644db9000 rw-s 101b1b000 00:0f 2083 anon_inode:i915.gem
70f645b02000-70f645dbb000 rw-p 00000000 00:00 0
70f645dbb000-70f645dbc000 ---p 00000000 00:00 0
70f645dbc000-70f6465bc000 rw-p 00000000 00:00 0
70f6465bc000-70f6465bd000 ---p 00000000 00:00 0
70f6465bd000-70f646dbd000 rw-p 00000000 00:00 0
70f646dbd000-70f646efe000 rw-s 00000000 fc:00 13500506 /home/moi/.cache/mesa_shader_cache_db/index
70f646efe000-70f646eff000 ---p 00000000 00:00 0
70f646eff000-70f6476ff000 rw-p 00000000 00:00 0
70f6476ff000-70f647703000 ---p 00000000 00:00 0
70f647703000-70f6477ff000 rw-p 00000000 00:00 0
70f6477ff000-70f647800000 ---p 00000000 00:00 0
70f647800000-70f648000000 rw-p 00000000 00:00 0
70f648000000-70f648021000 rw-p 00000000 00:00 0
70f648021000-70f64c000000 ---p 00000000 00:00 0
70f64c001000-70f64c011000 r--s 00000000 fc:00 19670055 /var/cache/fontconfig/6cc790b63b123a6a96ee260fcdad32a9-le64.cache-9
70f64c011000-70f64c022000 r--s 00000000 fc:00 19670054 /var/cache/fontconfig/9b89f8e3dae116d678bbf48e5f21f69b-le64.cache-9
70f64c022000-70f64c02d000 r--s 00000000 fc:00 19670053 /var/cache/fontconfig/d0972c3d32f097851eb916381fc38920-le64.cache-9
70f64c02d000-70f64c07c000 r--p 00000000 fc:00 6031761 /usr/share/glib-2.0/schemas/gschemas.compiled (deleted)
70f64c07c000-70f64c080000 ---p 00000000 00:00 0
70f64c080000-70f64c17c000 rw-p 00000000 00:00 0
70f64c17c000-70f64c1a2000 r--p 00000000 fc:00 7215768 /usr/share/locale-langpack/fr/LC_MESSAGES/glib20.mo
70f64c1a2000-70f64c1a3000 ---p 00000000 00:00 0
70f64c1a3000-70f64c9a3000 rw-p 00000000 00:00 0
70f64c9a3000-70f64c9b5000 r--p 00000000 fc:00 5933345 /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so
70f64c9b5000-70f64c9d1000 r-xp 00012000 fc:00 5933345 /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so
70f64c9d1000-70f64c9dd000 r--p 0002e000 fc:00 5933345 /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so
70f64c9dd000-70f64c9e3000 r--p 00039000 fc:00 5933345 /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so
70f64c9e3000-70f64c9e4000 rw-p 0003f000 fc:00 5933345 /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so
70f64c9e4000-70f64c9ee000 r--p 00000000 fc:00 6029809 /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
70f64c9ee000-70f64ca0c000 r-xp 0000a000 fc:00 6029809 /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
70f64ca0c000-70f64ca15000 r--p 00028000 fc:00 6029809 /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
70f64ca15000-70f64ca17000 r--p 00030000 fc:00 6029809 /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
70f64ca17000-70f64ca18000 rw-p 00032000 fc:00 6029809 /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
70f64ca18000-70f64ca1c000 r--p 00000000 fc:00 5932526 /usr/lib/x86_64-linux-gnu/libxkbfile.so.1.0.2
70f64ca1c000-70f64ca37000 r-xp 00004000 fc:00 5932526 /usr/lib/x86_64-linux-gnu/libxkbfile.so.1.0.2
70f64ca37000-70f64ca3d000 r--p 0001f000 fc:00 5932526 /usr/lib/x86_64-linux-gnu/libxkbfile.so.1.0.2
70f64ca3d000-70f64ca3e000 r--p 00025000 fc:00 5932526 /usr/lib/x86_64-linux-gnu/libxkbfile.so.1.0.2
70f64ca3e000-70f64ca3f000 rw-p 00026000 fc:00 5932526 /usr/lib/x86_64-linux-gnu/libxkbfile.so.1.0.2
70f64ca3f000-70f64ca45000 r--p 00000000 fc:00 5932530 /usr/lib/x86_64-linux-gnu/libxklavier.so.16.4.0
70f64ca45000-70f64ca52000 r-xp 00006000 fc:00 5932530 /usr/lib/x86_64-linux-gnu/libxklavier.so.16.4.0
70f64ca52000-70f64ca59000 r--p 00013000 fc:00 5932530 /usr/lib/x86_64-linux-gnu/libxklavier.so.16.4.0
70f64ca59000-70f64ca5a000 r--p 00019000 fc:00 5932530 /usr/lib/x86_64-linux-gnu/libxklavier.so.16.4.0
70f64ca5a000-70f64ca5b000 rw-p 0001a000 fc:00 5932530 /usr/lib/x86_64-linux-gnu/libxklavier.so.16.4.0
70f64ca5b000-70f64ca63000 r--p 00000000 fc:00 5931422 /usr/lib/x86_64-linux-gnu/libgnomekbdui.so.8.0.0
70f64ca63000-70f64ca6e000 r-xp 00008000 fc:00 5931422 /usr/lib/x86_64-linux-gnu/libgnomekbdui.so.8.0.0
70f64ca6e000-70f64ca72000 r--p 00013000 fc:00 5931422 /usr/lib/x86_64-linux-gnu/libgnomekbdui.so.8.0.0
70f64ca72000-70f64ca73000 r--p 00017000 fc:00 5931422 /usr/lib/x86_64-linux-gnu/libgnomekbdui.so.8.0.0
70f64ca73000-70f64ca74000 rw-p 00018000 fc:00 5931422 /usr/lib/x86_64-linux-gnu/libgnomekbdui.so.8.0.0
70f64ca74000-70f64ca86000 r--p 00000000 fc:00 5932471 /usr/lib/x86_64-linux-gnu/libxapp.so.2.8.8
70f64ca86000-70f64caa7000 r-xp 00012000 fc:00 5932471 /usr/lib/x86_64-linux-gnu/libxapp.so.2.8.8
70f64caa7000-70f64cab5000 r--p 00033000 fc:00 5932471 /usr/lib/x86_64-linux-gnu/libxapp.so.2.8.8
70f64cab5000-70f64cab8000 r--p 00041000 fc:00 5932471 /usr/lib/x86_64-linux-gnu/libxapp.so.2.8.8
70f64cab8000-70f64cab9000 rw-p 00044000 fc:00 5932471 /usr/lib/x86_64-linux-gnu/libxapp.so.2.8.8
70f64cabb000-70f64cacc000 r--s 00000000 fc:00 19670040 /var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-le64.cache-9
70f64cacc000-70f64cb03000 r--p 00000000 fc:00 7215884 /usr/share/locale-langpack/fr/LC_MESSAGES/gtk30-properties.mo
70f64cb03000-70f64cb1f000 r--p 00000000 fc:00 7215885 /usr/share/locale-langpack/fr/LC_MESSAGES/gtk30.mo
70f64cb1f000-70f64cb5f000 r-xp 00000000 fc:00 13631630 /home/moi/.openjfx/cache/21+31/amd64/libglassgtk3.so
70f64cb5f000-70f64cb60000 ---p 00040000 fc:00 13631630 /home/moi/.openjfx/cache/21+31/amd64/libglassgtk3.so
70f64cb60000-70f64cb62000 r--p 00040000 fc:00 13631630 /home/moi/.openjfx/cache/21+31/amd64/libglassgtk3.so
70f64cb62000-70f64cb64000 rw-p 00042000 fc:00 13631630 /home/moi/.openjfx/cache/21+31/amd64/libglassgtk3.so
70f64cb64000-70f64cb68000 r--p 00000000 fc:00 5903796 /usr/lib/x86_64-linux-gnu/libgpg-error.so.0.34.0
70f64cb68000-70f64cb7e000 r-xp 00004000 fc:00 5903796 /usr/lib/x86_64-linux-gnu/libgpg-error.so.0.34.0
70f64cb7e000-70f64cb87000 r--p 0001a000 fc:00 5903796 /usr/lib/x86_64-linux-gnu/libgpg-error.so.0.34.0
70f64cb87000-70f64cb88000 r--p 00023000 fc:00 5903796 /usr/lib/x86_64-linux-gnu/libgpg-error.so.0.34.0
70f64cb88000-70f64cb89000 rw-p 00024000 fc:00 5903796 /usr/lib/x86_64-linux-gnu/libgpg-error.so.0.34.0
70f64cb89000-70f64cb98000 r--p 00000000 fc:00 5931366 /usr/lib/x86_64-linux-gnu/libgcrypt.so.20.4.3
70f64cb98000-70f64cc8c000 r-xp 0000f000 fc:00 5931366 /usr/lib/x86_64-linux-gnu/libgcrypt.so.20.4.3
70f64cc8c000-70f64ccc7000 r--p 00103000 fc:00 5931366 /usr/lib/x86_64-linux-gnu/libgcrypt.so.20.4.3
70f64ccc7000-70f64cccc000 r--p 0013e000 fc:00 5931366 /usr/lib/x86_64-linux-gnu/libgcrypt.so.20.4.3
70f64cccc000-70f64ccd0000 rw-p 00143000 fc:00 5931366 /usr/lib/x86_64-linux-gnu/libgcrypt.so.20.4.3
70f64ccd0000-70f64ccd1000 rw-p 00000000 00:00 0
70f64ccd1000-70f64cce7000 r--p 00000000 fc:00 5910741 /usr/lib/x86_64-linux-gnu/libsystemd.so.0.38.0
70f64cce7000-70f64cd76000 r-xp 00016000 fc:00 5910741 /usr/lib/x86_64-linux-gnu/libsystemd.so.0.38.0
70f64cd76000-70f64cda4000 r--p 000a5000 fc:00 5910741 /usr/lib/x86_64-linux-gnu/libsystemd.so.0.38.0
70f64cda4000-70f64cdaf000 r--p 000d2000 fc:00 5910741 /usr/lib/x86_64-linux-gnu/libsystemd.so.0.38.0
70f64cdaf000-70f64cdb0000 rw-p 000dd000 fc:00 5910741 /usr/lib/x86_64-linux-gnu/libsystemd.so.0.38.0
70f64cdb0000-70f64cdb1000 rw-p 00000000 00:00 0
70f64cdb1000-70f64cdbd000 r--p 00000000 fc:00 5931108 /usr/lib/x86_64-linux-gnu/libdbus-1.so.3.32.4
70f64cdbd000-70f64cded000 r-xp 0000c000 fc:00 5931108 /usr/lib/x86_64-linux-gnu/libdbus-1.so.3.32.4
70f64cded000-70f64cdfe000 r--p 0003c000 fc:00 5931108 /usr/lib/x86_64-linux-gnu/libdbus-1.so.3.32.4
70f64cdfe000-70f64cdff000 r--p 0004c000 fc:00 5931108 /usr/lib/x86_64-linux-gnu/libdbus-1.so.3.32.4
70f64cdff000-70f64ce00000 rw-p 0004d000 fc:00 5931108 /usr/lib/x86_64-linux-gnu/libdbus-1.so.3.32.4
70f64ce00000-70f64ce83000 r--p 00000000 fc:00 5904425 /usr/lib/x86_64-linux-gnu/libgtk-3.so.0.2409.32
70f64ce83000-70f64d231000 r-xp 00083000 fc:00 5904425 /usr/lib/x86_64-linux-gnu/libgtk-3.so.0.2409.32
70f64d231000-70f64d5b6000 r--p 00431000 fc:00 5904425 /usr/lib/x86_64-linux-gnu/libgtk-3.so.0.2409.32
70f64d5b6000-70f64d5c6000 r--p 007b5000 fc:00 5904425 /usr/lib/x86_64-linux-gnu/libgtk-3.so.0.2409.32
70f64d5c6000-70f64d5c8000 rw-p 007c5000 fc:00 5904425 /usr/lib/x86_64-linux-gnu/libgtk-3.so.0.2409.32
70f64d5c8000-70f64d5cd000 rw-p 00000000 00:00 0
70f64d5ce000-70f64d5d3000 r-xp 00000000 fc:00 13631634 /home/moi/.openjfx/cache/21+31/amd64/libjavafx_font_freetype.so
70f64d5d3000-70f64d5d4000 r--p 00004000 fc:00 13631634 /home/moi/.openjfx/cache/21+31/amd64/libjavafx_font_freetype.so
70f64d5d4000-70f64d5d5000 rw-p 00005000 fc:00 13631634 /home/moi/.openjfx/cache/21+31/amd64/libjavafx_font_freetype.so
70f64d5d5000-70f64d5dc000 r--p 00000000 fc:00 13504306 /home/moi/.config/dconf/user (deleted)
70f64d5dc000-70f64d5df000 r--p 00000000 fc:00 5931723 /usr/lib/x86_64-linux-gnu/liblz4.so.1.9.4
70f64d5df000-70f64d5fa000 r-xp 00003000 fc:00 5931723 /usr/lib/x86_64-linux-gnu/liblz4.so.1.9.4
70f64d5fa000-70f64d5fc000 r--p 0001e000 fc:00 5931723 /usr/lib/x86_64-linux-gnu/liblz4.so.1.9.4
70f64d5fc000-70f64d5fd000 r--p 00020000 fc:00 5931723 /usr/lib/x86_64-linux-gnu/liblz4.so.1.9.4
70f64d5fd000-70f64d5fe000 rw-p 00021000 fc:00 5931723 /usr/lib/x86_64-linux-gnu/liblz4.so.1.9.4
70f64d5fe000-70f64d5ff000 ---p 00000000 00:00 0
70f64d5ff000-70f64ddff000 rw-p 00000000 00:00 0
70f64ddff000-70f64de00000 ---p 00000000 00:00 0
70f64de00000-70f64e600000 rw-p 00000000 00:00 0
70f64e600000-70f64e601000 r--p 00000000 fc:00 5931592 /usr/lib/x86_64-linux-gnu/libicudata.so.74.2
70f64e601000-70f64e602000 r-xp 00001000 fc:00 5931592 /usr/lib/x86_64-linux-gnu/libicudata.so.74.2
70f64e602000-70f65035e000 r--p 00002000 fc:00 5931592 /usr/lib/x86_64-linux-gnu/libicudata.so.74.2
70f65035e000-70f65035f000 r--p 01d5d000 fc:00 5931592 /usr/lib/x86_64-linux-gnu/libicudata.so.74.2
70f65035f000-70f650360000 rw-p 01d5e000 fc:00 5931592 /usr/lib/x86_64-linux-gnu/libicudata.so.74.2
70f650361000-70f650365000 r--p 00000000 fc:00 6029804 /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
70f650365000-70f65036c000 r-xp 00004000 fc:00 6029804 /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
70f65036c000-70f65036e000 r--p 0000b000 fc:00 6029804 /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
70f65036e000-70f65036f000 r--p 0000d000 fc:00 6029804 /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
70f65036f000-70f650370000 rw-p 0000e000 fc:00 6029804 /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
70f650370000-70f650373000 r--p 00000000 fc:00 5903790 /usr/lib/x86_64-linux-gnu/libcap.so.2.66
70f650373000-70f650379000 r-xp 00003000 fc:00 5903790 /usr/lib/x86_64-linux-gnu/libcap.so.2.66
70f650379000-70f65037b000 r--p 00009000 fc:00 5903790 /usr/lib/x86_64-linux-gnu/libcap.so.2.66
70f65037b000-70f65037c000 r--p 0000b000 fc:00 5903790 /usr/lib/x86_64-linux-gnu/libcap.so.2.66
70f65037c000-70f65037d000 rw-p 0000c000 fc:00 5903790 /usr/lib/x86_64-linux-gnu/libcap.so.2.66
70f65037d000-70f650381000 r--p 00000000 fc:00 5931656 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.2.2
70f650381000-70f6503ce000 r-xp 00004000 fc:00 5931656 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.2.2
70f6503ce000-70f6503fe000 r--p 00051000 fc:00 5931656 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.2.2
70f6503fe000-70f6503ff000 r--p 00081000 fc:00 5931656 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.2.2
70f6503ff000-70f650400000 rw-p 00082000 fc:00 5931656 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.2.2
70f650400000-70f657946000 r-xp 00000000 fc:00 5899526 /usr/lib/x86_64-linux-gnu/libLLVM.so.19.1
70f657946000-70f657eb0000 r--p 07545000 fc:00 5899526 /usr/lib/x86_64-linux-gnu/libLLVM.so.19.1
70f657eb0000-70f657ef8000 rw-p 07aaf000 fc:00 5899526 /usr/lib/x86_64-linux-gnu/libLLVM.so.19.1
70f657ef8000-70f657f97000 rw-p 00000000 00:00 0
70f657f9b000-70f657f9d000 r--p 00000000 fc:00 5930682 /usr/lib/x86_64-linux-gnu/libXtst.so.6.1.0
70f657f9d000-70f657fa0000 r-xp 00002000 fc:00 5930682 /usr/lib/x86_64-linux-gnu/libXtst.so.6.1.0
70f657fa0000-70f657fa1000 r--p 00005000 fc:00 5930682 /usr/lib/x86_64-linux-gnu/libXtst.so.6.1.0
70f657fa1000-70f657fa2000 r--p 00005000 fc:00 5930682 /usr/lib/x86_64-linux-gnu/libXtst.so.6.1.0
70f657fa2000-70f657fa3000 rw-p 00006000 fc:00 5930682 /usr/lib/x86_64-linux-gnu/libXtst.so.6.1.0
70f657fa3000-70f657fa4000 r--p 00000000 fc:00 5930962 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.1.0
70f657fa4000-70f657fa5000 r-xp 00001000 fc:00 5930962 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.1.0
70f657fa5000-70f657fc4000 r--p 00002000 fc:00 5930962 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.1.0
70f657fc4000-70f657fc5000 r--p 00021000 fc:00 5930962 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.1.0
70f657fc5000-70f657fc6000 rw-p 00022000 fc:00 5930962 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.1.0
70f657fc6000-70f657fd6000 r--p 00000000 fc:00 5930878 /usr/lib/x86_64-linux-gnu/libatspi.so.0.0.1
70f657fd6000-70f657fef000 r-xp 00010000 fc:00 5930878 /usr/lib/x86_64-linux-gnu/libatspi.so.0.0.1
70f657fef000-70f657ffc000 r--p 00029000 fc:00 5930878 /usr/lib/x86_64-linux-gnu/libatspi.so.0.0.1
70f657ffc000-70f657fff000 r--p 00036000 fc:00 5930878 /usr/lib/x86_64-linux-gnu/libatspi.so.0.0.1
70f657fff000-70f658000000 rw-p 00039000 fc:00 5930878 /usr/lib/x86_64-linux-gnu/libatspi.so.0.0.1
70f658000000-70f65929e000 rw-p 00000000 00:00 0
70f65929e000-70f65c000000 ---p 00000000 00:00 0
70f65c000000-70f65c006000 r--s 00000000 fc:00 19670060 /var/cache/fontconfig/3047814df9a2f067bd2d96a2b9c36e5a-le64.cache-9
70f65c006000-70f65c007000 r--p 00000000 fc:00 5931511 /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0.8000.0
70f65c007000-70f65c008000 r-xp 00001000 fc:00 5931511 /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0.8000.0
70f65c008000-70f65c009000 r--p 00002000 fc:00 5931511 /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0.8000.0
70f65c009000-70f65c00a000 r--p 00002000 fc:00 5931511 /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0.8000.0
70f65c00a000-70f65c00b000 rw-p 00003000 fc:00 5931511 /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0.8000.0
70f65c00b000-70f65c00c000 r--p 00000000 fc:00 5930964 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.1.0
70f65c00c000-70f65c014000 r-xp 00001000 fc:00 5930964 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.1.0
70f65c014000-70f65c017000 r--p 00009000 fc:00 5930964 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.1.0
70f65c017000-70f65c018000 r--p 0000b000 fc:00 5930964 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.1.0
70f65c018000-70f65c019000 rw-p 0000c000 fc:00 5930964 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.1.0
70f65c019000-70f65c01b000 r--p 00000000 fc:00 5930977 /usr/lib/x86_64-linux-gnu/libbz2.so.1.0.4
70f65c01b000-70f65c029000 r-xp 00002000 fc:00 5930977 /usr/lib/x86_64-linux-gnu/libbz2.so.1.0.4
70f65c029000-70f65c02b000 r--p 00010000 fc:00 5930977 /usr/lib/x86_64-linux-gnu/libbz2.so.1.0.4
70f65c02b000-70f65c02c000 r--p 00011000 fc:00 5930977 /usr/lib/x86_64-linux-gnu/libbz2.so.1.0.4
70f65c02c000-70f65c02d000 rw-p 00012000 fc:00 5930977 /usr/lib/x86_64-linux-gnu/libbz2.so.1.0.4
70f65c02d000-70f65c02f000 r--p 00000000 fc:00 5931102 /usr/lib/x86_64-linux-gnu/libdatrie.so.1.4.0
70f65c02f000-70f65c033000 r-xp 00002000 fc:00 5931102 /usr/lib/x86_64-linux-gnu/libdatrie.so.1.4.0
70f65c033000-70f65c034000 r--p 00006000 fc:00 5931102 /usr/lib/x86_64-linux-gnu/libdatrie.so.1.4.0
70f65c034000-70f65c035000 r--p 00006000 fc:00 5931102 /usr/lib/x86_64-linux-gnu/libdatrie.so.1.4.0
70f65c035000-70f65c036000 rw-p 00007000 fc:00 5931102 /usr/lib/x86_64-linux-gnu/libdatrie.so.1.4.0
70f65c036000-70f65c040000 r--p 00000000 fc:00 5931991 /usr/lib/x86_64-linux-gnu/libpixman-1.so.0.42.2
70f65c040000-70f65c0cd000 r-xp 0000a000 fc:00 5931991 /usr/lib/x86_64-linux-gnu/libpixman-1.so.0.42.2
70f65c0cd000-70f65c0dc000 r--p 00097000 fc:00 5931991 /usr/lib/x86_64-linux-gnu/libpixman-1.so.0.42.2
70f65c0dc000-70f65c0e4000 r--p 000a5000 fc:00 5931991 /usr/lib/x86_64-linux-gnu/libpixman-1.so.0.42.2
70f65c0e4000-70f65c0e5000 rw-p 000ad000 fc:00 5931991 /usr/lib/x86_64-linux-gnu/libpixman-1.so.0.42.2
70f65c0e5000-70f65c0ea000 r--p 00000000 fc:00 5932495 /usr/lib/x86_64-linux-gnu/libxcb-render.so.0.0.0
70f65c0ea000-70f65c0ef000 r-xp 00005000 fc:00 5932495 /usr/lib/x86_64-linux-gnu/libxcb-render.so.0.0.0
70f65c0ef000-70f65c0f2000 r--p 0000a000 fc:00 5932495 /usr/lib/x86_64-linux-gnu/libxcb-render.so.0.0.0
70f65c0f2000-70f65c0f3000 r--p 0000c000 fc:00 5932495 /usr/lib/x86_64-linux-gnu/libxcb-render.so.0.0.0
70f65c0f3000-70f65c0f4000 rw-p 0000d000 fc:00 5932495 /usr/lib/x86_64-linux-gnu/libxcb-render.so.0.0.0
70f65c0f4000-70f65c0f6000 r--p 00000000 fc:00 5930676 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
70f65c0f6000-70f65c0fd000 r-xp 00002000 fc:00 5930676 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
70f65c0fd000-70f65c0fe000 r--p 00009000 fc:00 5930676 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
70f65c0fe000-70f65c0ff000 r--p 00009000 fc:00 5930676 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
70f65c0ff000-70f65c100000 rw-p 0000a000 fc:00 5930676 /usr/lib/x86_64-linux-gnu/libXrender.so.1.3.0
70f65c100000-70f65c105000 r--p 00000000 fc:00 5932010 /usr/lib/x86_64-linux-gnu/libpng16.so.16.43.0
70f65c105000-70f65c12d000 r-xp 00005000 fc:00 5932010 /usr/lib/x86_64-linux-gnu/libpng16.so.16.43.0
70f65c12d000-70f65c136000 r--p 0002d000 fc:00 5932010 /usr/lib/x86_64-linux-gnu/libpng16.so.16.43.0
70f65c136000-70f65c137000 r--p 00035000 fc:00 5932010 /usr/lib/x86_64-linux-gnu/libpng16.so.16.43.0
70f65c137000-70f65c138000 rw-p 00036000 fc:00 5932010 /usr/lib/x86_64-linux-gnu/libpng16.so.16.43.0
70f65c138000-70f65c13b000 r--p 00000000 fc:00 5931453 /usr/lib/x86_64-linux-gnu/libgraphite2.so.3.2.1
70f65c13b000-70f65c158000 r-xp 00003000 fc:00 5931453 /usr/lib/x86_64-linux-gnu/libgraphite2.so.3.2.1
70f65c158000-70f65c15b000 r--p 00020000 fc:00 5931453 /usr/lib/x86_64-linux-gnu/libgraphite2.so.3.2.1
70f65c15b000-70f65c15d000 r--p 00022000 fc:00 5931453 /usr/lib/x86_64-linux-gnu/libgraphite2.so.3.2.1
70f65c15d000-70f65c15e000 rw-p 00024000 fc:00 5931453 /usr/lib/x86_64-linux-gnu/libgraphite2.so.3.2.1
70f65c15e000-70f65c16b000 r--p 00000000 fc:00 5931325 /usr/lib/x86_64-linux-gnu/libfreetype.so.6.20.1
70f65c16b000-70f65c1fc000 r-xp 0000d000 fc:00 5931325 /usr/lib/x86_64-linux-gnu/libfreetype.so.6.20.1
70f65c1fc000-70f65c222000 r--p 0009e000 fc:00 5931325 /usr/lib/x86_64-linux-gnu/libfreetype.so.6.20.1
70f65c222000-70f65c229000 r--p 000c4000 fc:00 5931325 /usr/lib/x86_64-linux-gnu/libfreetype.so.6.20.1
70f65c229000-70f65c22a000 rw-p 000cb000 fc:00 5931325 /usr/lib/x86_64-linux-gnu/libfreetype.so.6.20.1
70f65c22a000-70f65c22c000 r--p 00000000 fc:00 5932270 /usr/lib/x86_64-linux-gnu/libthai.so.0.3.1
70f65c22c000-70f65c230000 r-xp 00002000 fc:00 5932270 /usr/lib/x86_64-linux-gnu/libthai.so.0.3.1
70f65c230000-70f65c233000 r--p 00006000 fc:00 5932270 /usr/lib/x86_64-linux-gnu/libthai.so.0.3.1
70f65c233000-70f65c234000 r--p 00008000 fc:00 5932270 /usr/lib/x86_64-linux-gnu/libthai.so.0.3.1
70f65c234000-70f65c235000 rw-p 00009000 fc:00 5932270 /usr/lib/x86_64-linux-gnu/libthai.so.0.3.1
70f65c235000-70f65c237000 r--p 00000000 fc:00 5930674 /usr/lib/x86_64-linux-gnu/libXrandr.so.2.2.0
70f65c237000-70f65c23e000 r-xp 00002000 fc:00 5930674 /usr/lib/x86_64-linux-gnu/libXrandr.so.2.2.0
70f65c23e000-70f65c240000 r--p 00009000 fc:00 5930674 /usr/lib/x86_64-linux-gnu/libXrandr.so.2.2.0
70f65c240000-70f65c241000 r--p 0000a000 fc:00 5930674 /usr/lib/x86_64-linux-gnu/libXrandr.so.2.2.0
70f65c241000-70f65c242000 rw-p 0000b000 fc:00 5930674 /usr/lib/x86_64-linux-gnu/libXrandr.so.2.2.0
70f65c242000-70f65c247000 r--p 00000000 fc:00 5932524 /usr/lib/x86_64-linux-gnu/libxkbcommon.so.0.0.0
70f65c247000-70f65c267000 r-xp 00005000 fc:00 5932524 /usr/lib/x86_64-linux-gnu/libxkbcommon.so.0.0.0
70f65c267000-70f65c288000 r--p 00025000 fc:00 5932524 /usr/lib/x86_64-linux-gnu/libxkbcommon.so.0.0.0
70f65c288000-70f65c28a000 r--p 00045000 fc:00 5932524 /usr/lib/x86_64-linux-gnu/libxkbcommon.so.0.0.0
70f65c28a000-70f65c28b000 rw-p 00047000 fc:00 5932524 /usr/lib/x86_64-linux-gnu/libxkbcommon.so.0.0.0
70f65c28b000-70f65c2eb000 r--p 00000000 fc:00 5931220 /usr/lib/x86_64-linux-gnu/libepoxy.so.0.0.0
70f65c2eb000-70f65c351000 r-xp 00060000 fc:00 5931220 /usr/lib/x86_64-linux-gnu/libepoxy.so.0.0.0
70f65c351000-70f65c39f000 r--p 000c6000 fc:00 5931220 /usr/lib/x86_64-linux-gnu/libepoxy.so.0.0.0
70f65c39f000-70f65c3a7000 r--p 00113000 fc:00 5931220 /usr/lib/x86_64-linux-gnu/libepoxy.so.0.0.0
70f65c3a7000-70f65c3ae000 rw-p 0011b000 fc:00 5931220 /usr/lib/x86_64-linux-gnu/libepoxy.so.0.0.0
70f65c3ae000-70f65c3c2000 r--p 00000000 fc:00 5930993 /usr/lib/x86_64-linux-gnu/libcairo.so.2.11800.0
70f65c3c2000-70f65c4b3000 r-xp 00014000 fc:00 5930993 /usr/lib/x86_64-linux-gnu/libcairo.so.2.11800.0
70f65c4b3000-70f65c4eb000 r--p 00105000 fc:00 5930993 /usr/lib/x86_64-linux-gnu/libcairo.so.2.11800.0
70f65c4eb000-70f65c4ef000 r--p 0013d000 fc:00 5930993 /usr/lib/x86_64-linux-gnu/libcairo.so.2.11800.0
70f65c4ef000-70f65c4f1000 rw-p 00141000 fc:00 5930993 /usr/lib/x86_64-linux-gnu/libcairo.so.2.11800.0
70f65c4f1000-70f65c4f2000 rw-p 00000000 00:00 0
70f65c4f2000-70f65c4fd000 r--p 00000000 fc:00 5931548 /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0.60830.0
70f65c4fd000-70f65c5cb000 r-xp 0000b000 fc:00 5931548 /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0.60830.0
70f65c5cb000-70f65c5fd000 r--p 000d9000 fc:00 5931548 /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0.60830.0
70f65c5fd000-70f65c5fe000 r--p 0010b000 fc:00 5931548 /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0.60830.0
70f65c5fe000-70f65c5ff000 rw-p 0010c000 fc:00 5931548 /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0.60830.0
70f65c5ff000-70f65c600000 ---p 00000000 00:00 0
70f65c600000-70f65ce00000 rw-p 00000000 00:00 0
70f65ce00000-70f65d000000 rw-s 10183b000 00:0f 2083 anon_inode:i915.gem
70f65d000000-70f65d068000 r--p 00000000 fc:00 5931602 /usr/lib/x86_64-linux-gnu/libicuuc.so.74.2
70f65d068000-70f65d16d000 r-xp 00068000 fc:00 5931602 /usr/lib/x86_64-linux-gnu/libicuuc.so.74.2
70f65d16d000-70f65d1f7000 r--p 0016d000 fc:00 5931602 /usr/lib/x86_64-linux-gnu/libicuuc.so.74.2
70f65d1f7000-70f65d20a000 r--p 001f7000 fc:00 5931602 /usr/lib/x86_64-linux-gnu/libicuuc.so.74.2
70f65d20a000-70f65d20b000 rw-p 0020a000 fc:00 5931602 /usr/lib/x86_64-linux-gnu/libicuuc.so.74.2
70f65d20b000-70f65d20d000 rw-p 00000000 00:00 0
70f65d20f000-70f65d210000 r--p 00000000 fc:00 5930664 /usr/lib/x86_64-linux-gnu/libXinerama.so.1.0.0
70f65d210000-70f65d211000 r-xp 00001000 fc:00 5930664 /usr/lib/x86_64-linux-gnu/libXinerama.so.1.0.0
70f65d211000-70f65d212000 r--p 00002000 fc:00 5930664 /usr/lib/x86_64-linux-gnu/libXinerama.so.1.0.0
70f65d212000-70f65d213000 r--p 00002000 fc:00 5930664 /usr/lib/x86_64-linux-gnu/libXinerama.so.1.0.0
70f65d213000-70f65d214000 rw-p 00003000 fc:00 5930664 /usr/lib/x86_64-linux-gnu/libXinerama.so.1.0.0
70f65d214000-70f65d216000 r--p 00000000 fc:00 5930648 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
70f65d216000-70f65d21c000 r-xp 00002000 fc:00 5930648 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
70f65d21c000-70f65d21e000 r--p 00008000 fc:00 5930648 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
70f65d21e000-70f65d21f000 r--p 00009000 fc:00 5930648 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
70f65d21f000-70f65d220000 rw-p 0000a000 fc:00 5930648 /usr/lib/x86_64-linux-gnu/libXcursor.so.1.0.2
70f65d220000-70f65d22c000 r--p 00000000 fc:00 5930868 /usr/lib/x86_64-linux-gnu/libatk-bridge-2.0.so.0.0.0
70f65d22c000-70f65d246000 r-xp 0000c000 fc:00 5930868 /usr/lib/x86_64-linux-gnu/libatk-bridge-2.0.so.0.0.0
70f65d246000-70f65d259000 r--p 00026000 fc:00 5930868 /usr/lib/x86_64-linux-gnu/libatk-bridge-2.0.so.0.0.0
70f65d259000-70f65d25a000 r--p 00039000 fc:00 5930868 /usr/lib/x86_64-linux-gnu/libatk-bridge-2.0.so.0.0.0
70f65d25a000-70f65d25c000 rw-p 0003a000 fc:00 5930868 /usr/lib/x86_64-linux-gnu/libatk-bridge-2.0.so.0.0.0
70f65d25c000-70f65d267000 r--p 00000000 fc:00 5930866 /usr/lib/x86_64-linux-gnu/libatk-1.0.so.0.25209.1
70f65d267000-70f65d277000 r-xp 0000b000 fc:00 5930866 /usr/lib/x86_64-linux-gnu/libatk-1.0.so.0.25209.1
70f65d277000-70f65d282000 r--p 0001b000 fc:00 5930866 /usr/lib/x86_64-linux-gnu/libatk-1.0.so.0.25209.1
70f65d282000-70f65d285000 r--p 00026000 fc:00 5930866 /usr/lib/x86_64-linux-gnu/libatk-1.0.so.0.25209.1
70f65d285000-70f65d286000 rw-p 00029000 fc:00 5930866 /usr/lib/x86_64-linux-gnu/libatk-1.0.so.0.25209.1
70f65d286000-70f65d28e000 r--p 00000000 fc:00 5931380 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.4200.10
70f65d28e000-70f65d2a9000 r-xp 00008000 fc:00 5931380 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.4200.10
70f65d2a9000-70f65d2b2000 r--p 00023000 fc:00 5931380 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.4200.10
70f65d2b2000-70f65d2b3000 r--p 0002c000 fc:00 5931380 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.4200.10
70f65d2b3000-70f65d2b4000 rw-p 0002d000 fc:00 5931380 /usr/lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0.4200.10
70f65d2b4000-70f65d2bc000 r--p 00000000 fc:00 5931306 /usr/lib/x86_64-linux-gnu/libfontconfig.so.1.12.1
70f65d2bc000-70f65d2eb000 r-xp 00008000 fc:00 5931306 /usr/lib/x86_64-linux-gnu/libfontconfig.so.1.12.1
70f65d2eb000-70f65d302000 r--p 00037000 fc:00 5931306 /usr/lib/x86_64-linux-gnu/libfontconfig.so.1.12.1
70f65d302000-70f65d304000 r--p 0004d000 fc:00 5931306 /usr/lib/x86_64-linux-gnu/libfontconfig.so.1.12.1
70f65d304000-70f65d305000 rw-p 0004f000 fc:00 5931306 /usr/lib/x86_64-linux-gnu/libfontconfig.so.1.12.1
70f65d305000-70f65d32f000 r--p 00000000 fc:00 5904423 /usr/lib/x86_64-linux-gnu/libgdk-3.so.0.2409.32
70f65d32f000-70f65d3b3000 r-xp 0002a000 fc:00 5904423 /usr/lib/x86_64-linux-gnu/libgdk-3.so.0.2409.32
70f65d3b3000-70f65d3f5000 r--p 000ae000 fc:00 5904423 /usr/lib/x86_64-linux-gnu/libgdk-3.so.0.2409.32
70f65d3f5000-70f65d3fe000 r--p 000ef000 fc:00 5904423 /usr/lib/x86_64-linux-gnu/libgdk-3.so.0.2409.32
70f65d3fe000-70f65d400000 rw-p 000f8000 fc:00 5904423 /usr/lib/x86_64-linux-gnu/libgdk-3.so.0.2409.32
70f65d400000-70f65d49d000 r--p 00000000 fc:00 5932238 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.33
70f65d49d000-70f65d5e5000 r-xp 0009d000 fc:00 5932238 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.33
70f65d5e5000-70f65d66c000 r--p 001e5000 fc:00 5932238 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.33
70f65d66c000-70f65d677000 r--p 0026b000 fc:00 5932238 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.33
70f65d677000-70f65d67a000 rw-p 00276000 fc:00 5932238 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.33
70f65d67a000-70f65d67e000 rw-p 00000000 00:00 0
70f65d680000-70f65d681000 r--p 00000000 fc:00 5930646 /usr/lib/x86_64-linux-gnu/libXcomposite.so.1.0.0
70f65d681000-70f65d682000 r-xp 00001000 fc:00 5930646 /usr/lib/x86_64-linux-gnu/libXcomposite.so.1.0.0
70f65d682000-70f65d683000 r--p 00002000 fc:00 5930646 /usr/lib/x86_64-linux-gnu/libXcomposite.so.1.0.0
70f65d683000-70f65d684000 r--p 00002000 fc:00 5930646 /usr/lib/x86_64-linux-gnu/libXcomposite.so.1.0.0
70f65d684000-70f65d685000 rw-p 00003000 fc:00 5930646 /usr/lib/x86_64-linux-gnu/libXcomposite.so.1.0.0
70f65d685000-70f65d687000 r--p 00000000 fc:00 5932430 /usr/lib/x86_64-linux-gnu/libwayland-cursor.so.0.22.0
70f65d687000-70f65d689000 r-xp 00002000 fc:00 5932430 /usr/lib/x86_64-linux-gnu/libwayland-cursor.so.0.22.0
70f65d689000-70f65d68a000 r--p 00004000 fc:00 5932430 /usr/lib/x86_64-linux-gnu/libwayland-cursor.so.0.22.0
70f65d68a000-70f65d68b000 r--p 00004000 fc:00 5932430 /usr/lib/x86_64-linux-gnu/libwayland-cursor.so.0.22.0
70f65d68b000-70f65d68f000 rw-p 00005000 fc:00 5932430 /usr/lib/x86_64-linux-gnu/libwayland-cursor.so.0.22.0
70f65d68f000-70f65d694000 r--p 00000000 fc:00 5932428 /usr/lib/x86_64-linux-gnu/libwayland-client.so.0.22.0
70f65d694000-70f65d69a000 r-xp 00005000 fc:00 5932428 /usr/lib/x86_64-linux-gnu/libwayland-client.so.0.22.0
70f65d69a000-70f65d69c000 r--p 0000b000 fc:00 5932428 /usr/lib/x86_64-linux-gnu/libwayland-client.so.0.22.0
70f65d69c000-70f65d69e000 r--p 0000d000 fc:00 5932428 /usr/lib/x86_64-linux-gnu/libwayland-client.so.0.22.0
70f65d69e000-70f65d69f000 rw-p 0000f000 fc:00 5932428 /usr/lib/x86_64-linux-gnu/libwayland-client.so.0.22.0
70f65d69f000-70f65d6bf000 rw-s 101afb000 00:0f 2083 anon_inode:i915.gem
70f65d6bf000-70f65d800000 rw-s 00000000 fc:00 13500506 /home/moi/.cache/mesa_shader_cache_db/index
70f65d800000-70f65d89c000 r--p 00000000 fc:00 5899528 /usr/lib/x86_64-linux-gnu/libgallium-24.2.8-1ubuntu1~24.04.1.so
70f65d89c000-70f65eec9000 r-xp 0009c000 fc:00 5899528 /usr/lib/x86_64-linux-gnu/libgallium-24.2.8-1ubuntu1~24.04.1.so
70f65eec9000-70f65fc4a000 r--p 016c9000 fc:00 5899528 /usr/lib/x86_64-linux-gnu/libgallium-24.2.8-1ubuntu1~24.04.1.so
70f65fc4a000-70f65fcfa000 r--p 0244a000 fc:00 5899528 /usr/lib/x86_64-linux-gnu/libgallium-24.2.8-1ubuntu1~24.04.1.so
70f65fcfa000-70f65fd13000 rw-p 024fa000 fc:00 5899528 /usr/lib/x86_64-linux-gnu/libgallium-24.2.8-1ubuntu1~24.04.1.so
70f65fd13000-70f65fed6000 rw-p 00000000 00:00 0
70f65fed6000-70f65fed9000 r--p 00000000 fc:00 5930662 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
70f65fed9000-70f65fee5000 r-xp 00003000 fc:00 5930662 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
70f65fee5000-70f65fee7000 r--p 0000f000 fc:00 5930662 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
70f65fee7000-70f65fee8000 r--p 00011000 fc:00 5930662 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
70f65fee8000-70f65fee9000 rw-p 00012000 fc:00 5930662 /usr/lib/x86_64-linux-gnu/libXi.so.6.1.0
70f65fee9000-70f65feed000 r--p 00000000 fc:00 5930989 /usr/lib/x86_64-linux-gnu/libcairo-gobject.so.2.11800.0
70f65feed000-70f65feef000 r-xp 00004000 fc:00 5930989 /usr/lib/x86_64-linux-gnu/libcairo-gobject.so.2.11800.0
70f65feef000-70f65fef2000 r--p 00006000 fc:00 5930989 /usr/lib/x86_64-linux-gnu/libcairo-gobject.so.2.11800.0
70f65fef2000-70f65fef4000 r--p 00008000 fc:00 5930989 /usr/lib/x86_64-linux-gnu/libcairo-gobject.so.2.11800.0
70f65fef4000-70f65fef5000 rw-p 0000a000 fc:00 5930989 /usr/lib/x86_64-linux-gnu/libcairo-gobject.so.2.11800.0
70f65fef5000-70f65ff15000 rw-s 101adb000 00:0f 2083 anon_inode:i915.gem
70f65ff18000-70f65ff1a000 r--p 00000000 fc:00 5931327 /usr/lib/x86_64-linux-gnu/libfribidi.so.0.4.0
70f65ff1a000-70f65ff1e000 r-xp 00002000 fc:00 5931327 /usr/lib/x86_64-linux-gnu/libfribidi.so.0.4.0
70f65ff1e000-70f65ff34000 r--p 00006000 fc:00 5931327 /usr/lib/x86_64-linux-gnu/libfribidi.so.0.4.0
70f65ff34000-70f65ff35000 r--p 0001c000 fc:00 5931327 /usr/lib/x86_64-linux-gnu/libfribidi.so.0.4.0
70f65ff35000-70f65ff36000 rw-p 0001d000 fc:00 5931327 /usr/lib/x86_64-linux-gnu/libfribidi.so.0.4.0
70f65ff36000-70f65ff3e000 r--p 00000000 fc:00 5931948 /usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0.5200.1
70f65ff3e000-70f65ff4b000 r-xp 00008000 fc:00 5931948 /usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0.5200.1
70f65ff4b000-70f65ff4f000 r--p 00015000 fc:00 5931948 /usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0.5200.1
70f65ff4f000-70f65ff50000 r--p 00019000 fc:00 5931948 /usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0.5200.1
70f65ff50000-70f65ff51000 rw-p 0001a000 fc:00 5931948 /usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0.5200.1
70f65ff51000-70f65ff64000 r--p 00000000 fc:00 5931944 /usr/lib/x86_64-linux-gnu/libpango-1.0.so.0.5200.1
70f65ff64000-70f65ff9d000 r-xp 00013000 fc:00 5931944 /usr/lib/x86_64-linux-gnu/libpango-1.0.so.0.5200.1
70f65ff9d000-70f65ffb7000 r--p 0004c000 fc:00 5931944 /usr/lib/x86_64-linux-gnu/libpango-1.0.so.0.5200.1
70f65ffb7000-70f65ffbb000 r--p 00065000 fc:00 5931944 /usr/lib/x86_64-linux-gnu/libpango-1.0.so.0.5200.1
70f65ffbb000-70f65ffbc000 rw-p 00069000 fc:00 5931944 /usr/lib/x86_64-linux-gnu/libpango-1.0.so.0.5200.1
70f65ffbc000-70f65ffc1000 r--p 00000000 fc:00 5931946 /usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so.0.5200.1
70f65ffc1000-70f65ffc9000 r-xp 00005000 fc:00 5931946 /usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so.0.5200.1
70f65ffc9000-70f65ffcb000 r--p 0000d000 fc:00 5931946 /usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so.0.5200.1
70f65ffcb000-70f65ffcc000 r--p 0000f000 fc:00 5931946 /usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so.0.5200.1
70f65ffcc000-70f65ffcd000 rw-p 00010000 fc:00 5931946 /usr/lib/x86_64-linux-gnu/libpangocairo-1.0.so.0.5200.1
70f65ffcd000-70f65ffd0000 r-xp 00000000 fc:00 13631631 /home/moi/.openjfx/cache/21+31/amd64/libjavafx_font.so
70f65ffd0000-70f65ffd1000 r--p 00002000 fc:00 13631631 /home/moi/.openjfx/cache/21+31/amd64/libjavafx_font.so
70f65ffd1000-70f65ffd2000 rw-p 00003000 fc:00 13631631 /home/moi/.openjfx/cache/21+31/amd64/libjavafx_font.so
70f65ffd2000-70f65ffd5000 r--p 00000000 fc:00 5931420 /usr/lib/x86_64-linux-gnu/libgnomekbd.so.8.0.0
70f65ffd5000-70f65ffd8000 r-xp 00003000 fc:00 5931420 /usr/lib/x86_64-linux-gnu/libgnomekbd.so.8.0.0
70f65ffd8000-70f65ffd9000 r--p 00006000 fc:00 5931420 /usr/lib/x86_64-linux-gnu/libgnomekbd.so.8.0.0
70f65ffd9000-70f65ffda000 r--p 00007000 fc:00 5931420 /usr/lib/x86_64-linux-gnu/libgnomekbd.so.8.0.0
70f65ffda000-70f65ffdb000 rw-p 00008000 fc:00 5931420 /usr/lib/x86_64-linux-gnu/libgnomekbd.so.8.0.0
70f65ffdb000-70f65ffdc000 r--p 00000000 fc:00 6029868 /usr/lib/x86_64-linux-gnu/gtk-3.0/modules/libxapp-gtk3-module.so
70f65ffdc000-70f65ffdd000 r-xp 00001000 fc:00 6029868 /usr/lib/x86_64-linux-gnu/gtk-3.0/modules/libxapp-gtk3-module.so
70f65ffdd000-70f65ffde000 r--p 00002000 fc:00 6029868 /usr/lib/x86_64-linux-gnu/gtk-3.0/modules/libxapp-gtk3-module.so
70f65ffde000-70f65ffdf000 r--p 00002000 fc:00 6029868 /usr/lib/x86_64-linux-gnu/gtk-3.0/modules/libxapp-gtk3-module.so
70f65ffdf000-70f65ffe0000 rw-p 00003000 fc:00 6029868 /usr/lib/x86_64-linux-gnu/gtk-3.0/modules/libxapp-gtk3-module.so
70f65ffe0000-70f660000000 rw-s 101abb000 00:0f 2083 anon_inode:i915.gem
70f660000000-70f660021000 rw-p 00000000 00:00 0
70f660021000-70f664000000 ---p 00000000 00:00 0
70f664000000-70f664021000 rw-p 00000000 00:00 0
70f664021000-70f668000000 ---p 00000000 00:00 0
70f668000000-70f668021000 rw-p 00000000 00:00 0
70f668021000-70f66c000000 ---p 00000000 00:00 0
70f66c000000-70f66c021000 rw-p 00000000 00:00 0
70f66c021000-70f670000000 ---p 00000000 00:00 0
70f670000000-70f6700e7000 rw-p 00000000 00:00 0
70f6700e7000-70f674000000 ---p 00000000 00:00 0
70f674000000-70f674021000 rw-p 00000000 00:00 0
70f674021000-70f678000000 ---p 00000000 00:00 0
70f678000000-70f678021000 rw-p 00000000 00:00 0
70f678021000-70f67c000000 ---p 00000000 00:00 0
70f67c000000-70f67c4d4000 rw-p 00000000 00:00 0
70f67c4d4000-70f680000000 ---p 00000000 00:00 0
70f680000000-70f680021000 rw-p 00000000 00:00 0
70f680021000-70f684000000 ---p 00000000 00:00 0
70f684000000-70f684021000 rw-p 00000000 00:00 0
70f684021000-70f688000000 ---p 00000000 00:00 0
70f688000000-70f688021000 rw-p 00000000 00:00 0
70f688021000-70f68c000000 ---p 00000000 00:00 0
70f68c000000-70f68c021000 rw-p 00000000 00:00 0
70f68c021000-70f690000000 ---p 00000000 00:00 0
70f690000000-70f69019b000 rw-p 00000000 00:00 0
70f69019b000-70f694000000 ---p 00000000 00:00 0
70f694000000-70f6942c5000 rw-p 00000000 00:00 0
70f6942c5000-70f698000000 ---p 00000000 00:00 0
70f698000000-70f698021000 rw-p 00000000 00:00 0
70f698021000-70f69c000000 ---p 00000000 00:00 0
70f69c000000-70f69c021000 rw-p 00000000 00:00 0
70f69c021000-70f6a0000000 ---p 00000000 00:00 0
70f6a0000000-70f6a25a6000 rw-p 00000000 00:00 0
70f6a25a6000-70f6a4000000 ---p 00000000 00:00 0
70f6a4000000-70f6a48d7000 rw-p 00000000 00:00 0
70f6a48d7000-70f6a8000000 ---p 00000000 00:00 0
70f6a8000000-70f6a8021000 rw-p 00000000 00:00 0
70f6a8021000-70f6ac000000 ---p 00000000 00:00 0
70f6ac000000-70f6ac021000 rw-p 00000000 00:00 0
70f6ac021000-70f6b0000000 ---p 00000000 00:00 0
70f6b0000000-70f6b0021000 rw-p 00000000 00:00 0
70f6b0021000-70f6b4000000 ---p 00000000 00:00 0
70f6b4000000-70f6b4021000 rw-p 00000000 00:00 0
70f6b4021000-70f6b8000000 ---p 00000000 00:00 0
70f6b8000000-70f6b81ab000 rw-p 00000000 00:00 0
70f6b81ab000-70f6bc000000 ---p 00000000 00:00 0
70f6bc000000-70f6bc021000 rw-p 00000000 00:00 0
70f6bc021000-70f6c0000000 ---p 00000000 00:00 0
70f6c0000000-70f6c04f0000 rw-p 00000000 00:00 0
70f6c04f0000-70f6c0530000 rw-p 00000000 00:00 0
70f6c0530000-70f6c0570000 rw-p 00000000 00:00 0
70f6c0570000-70f6c0670000 rw-p 00000000 00:00 0
70f6c0670000-70f6c06f0000 rw-p 00000000 00:00 0
70f6c06f0000-70f6c08f0000 rw-p 00000000 00:00 0
70f6c08f0000-70f6c09f0000 rw-p 00000000 00:00 0
70f6c09f0000-70f6c0af0000 rw-p 00000000 00:00 0
70f6c0af0000-70f6c0bf0000 rw-p 00000000 00:00 0
70f6c0bf0000-70f6c0cb0000 rw-p 00000000 00:00 0
70f6c0cb0000-70f6c0cf0000 rw-p 00000000 00:00 0
70f6c0cf0000-70f6c0ef0000 rw-p 00000000 00:00 0
70f6c0ef0000-70f6c12f0000 rw-p 00000000 00:00 0
70f6c12f0000-70f6c15b0000 rw-p 00000000 00:00 0
70f6c15b0000-70f6c16f0000 rw-p 00000000 00:00 0
70f6c16f0000-70f6c18f0000 rw-p 00000000 00:00 0
70f6c18f0000-70f6c19f0000 rw-p 00000000 00:00 0
70f6c19f0000-70f6c1ef0000 rw-p 00000000 00:00 0
70f6c1ef0000-70f6c1ff0000 rw-p 00000000 00:00 0
70f6c1ff0000-70f6c24f0000 rw-p 00000000 00:00 0
70f6c24f0000-70f6c25f0000 rw-p 00000000 00:00 0
70f6c25f0000-70f6c2770000 rw-p 00000000 00:00 0
70f6c2770000-70f6c27f0000 rw-p 00000000 00:00 0
70f6c27f0000-70f6c28f0000 rw-p 00000000 00:00 0
70f6c28f0000-70f6c2af0000 rw-p 00000000 00:00 0
70f6c2af0000-70f6c2cf0000 rw-p 00000000 00:00 0
70f6c2cf0000-70f6c2df0000 rw-p 00000000 00:00 0
70f6c2df0000-70f6c30f0000 rw-p 00000000 00:00 0
70f6c30f0000-70f6c31f0000 rw-p 00000000 00:00 0
70f6c31f0000-70f6c36e0000 rw-p 00000000 00:00 0
70f6c36e0000-70f6c37f0000 rw-p 00000000 00:00 0
70f6c37f0000-70f6c3cf0000 rw-p 00000000 00:00 0
70f6c3cf0000-70f6c3d20000 rw-p 00000000 00:00 0
70f6c3d20000-70f6c4000000 ---p 00000000 00:00 0
70f6c4000000-70f6c4021000 rw-p 00000000 00:00 0
70f6c4021000-70f6c8000000 ---p 00000000 00:00 0
70f6c8000000-70f6c8021000 rw-p 00000000 00:00 0
70f6c8021000-70f6cc000000 ---p 00000000 00:00 0
70f6cc000000-70f6cc021000 rw-p 00000000 00:00 0
70f6cc021000-70f6d0000000 ---p 00000000 00:00 0
70f6d0004000-70f6d0005000 r--p 00000000 fc:00 5930650 /usr/lib/x86_64-linux-gnu/libXdamage.so.1.1.0
70f6d0005000-70f6d0006000 r-xp 00001000 fc:00 5930650 /usr/lib/x86_64-linux-gnu/libXdamage.so.1.1.0
70f6d0006000-70f6d0007000 r--p 00002000 fc:00 5930650 /usr/lib/x86_64-linux-gnu/libXdamage.so.1.1.0
70f6d0007000-70f6d0008000 r--p 00002000 fc:00 5930650 /usr/lib/x86_64-linux-gnu/libXdamage.so.1.1.0
70f6d0008000-70f6d0009000 rw-p 00003000 fc:00 5930650 /usr/lib/x86_64-linux-gnu/libXdamage.so.1.1.0
70f6d0012000-70f6d0015000 rw-s 100722000 00:0f 2083 anon_inode:i915.gem
70f6d0025000-70f6d0035000 rw-s 1068c6000 00:0f 2083 anon_inode:i915.gem
70f6d0039000-70f6d0049000 rw-s 101fab000 00:0f 2083 anon_inode:i915.gem
70f6d0049000-70f6d0059000 rw-s 1002a1000 00:0f 2083 anon_inode:i915.gem
70f6d0059000-70f6d005e000 rw-s 10071d000 00:0f 2083 anon_inode:i915.gem
70f6d0062000-70f6d0072000 rw-s 103b8a000 00:0f 2083 anon_inode:i915.gem
70f6d0072000-70f6d0082000 rw-s 10240b000 00:0f 2083 anon_inode:i915.gem
70f6d0087000-70f6d0097000 rw-s 1066ae000 00:0f 2083 anon_inode:i915.gem
70f6d0097000-70f6d009a000 rw-s 105abf000 00:0f 2083 anon_inode:i915.gem
70f6d009c000-70f6d00ac000 rw-s 109822000 00:0f 2083 anon_inode:i915.gem
70f6d00b5000-70f6d00c5000 rw-s 1050ef000 00:0f 2083 anon_inode:i915.gem
70f6d00c5000-70f6d00c6000 rw-s 100cfa000 00:0f 2083 anon_inode:i915.gem
70f6d00c6000-70f6d00c7000 rw-s 1026ae000 00:0f 2083 anon_inode:i915.gem
70f6d00c7000-70f6d00c8000 rw-s 105025000 00:0f 2083 anon_inode:i915.gem
70f6d00c8000-70f6d00c9000 rw-s 108e27000 00:0f 2083 anon_inode:i915.gem
70f6d00c9000-70f6d00ca000 rw-s 103152000 00:0f 2083 anon_inode:i915.gem
70f6d00ca000-70f6d00cb000 rw-s 10667e000 00:0f 2083 anon_inode:i915.gem
70f6d00cb000-70f6d00cc000 rw-s 1015fa000 00:0f 2083 anon_inode:i915.gem
70f6d00cc000-70f6d00d1000 rw-s 108bfd000 00:0f 2083 anon_inode:i915.gem
70f6d00d1000-70f6d00d9000 rw-s 10619a000 00:0f 2083 anon_inode:i915.gem
70f6d00d9000-70f6d0119000 rw-s 100a68000 00:0f 2083 anon_inode:i915.gem
70f6d0119000-70f6d013e000 r--p 00000000 fc:00 7215941 /usr/share/locale-langpack/fr/LC_MESSAGES/libc.mo
70f6d013e000-70f6d0141000 r--p 00000000 fc:00 5904510 /usr/lib/x86_64-linux-gnu/liblzma.so.5.4.5
70f6d0141000-70f6d0163000 r-xp 00003000 fc:00 5904510 /usr/lib/x86_64-linux-gnu/liblzma.so.5.4.5
70f6d0163000-70f6d016e000 r--p 00025000 fc:00 5904510 /usr/lib/x86_64-linux-gnu/liblzma.so.5.4.5
70f6d016e000-70f6d016f000 r--p 00030000 fc:00 5904510 /usr/lib/x86_64-linux-gnu/liblzma.so.5.4.5
70f6d016f000-70f6d0170000 rw-p 00031000 fc:00 5904510 /usr/lib/x86_64-linux-gnu/liblzma.so.5.4.5
70f6d0170000-70f6d017e000 r--p 00000000 fc:00 5932286 /usr/lib/x86_64-linux-gnu/libtinfo.so.6.4
70f6d017e000-70f6d0191000 r-xp 0000e000 fc:00 5932286 /usr/lib/x86_64-linux-gnu/libtinfo.so.6.4
70f6d0191000-70f6d019f000 r--p 00021000 fc:00 5932286 /usr/lib/x86_64-linux-gnu/libtinfo.so.6.4
70f6d019f000-70f6d01a3000 r--p 0002e000 fc:00 5932286 /usr/lib/x86_64-linux-gnu/libtinfo.so.6.4
70f6d01a3000-70f6d01a4000 rw-p 00032000 fc:00 5932286 /usr/lib/x86_64-linux-gnu/libtinfo.so.6.4
70f6d01a4000-70f6d01a6000 r--p 00000000 fc:00 5931966 /usr/lib/x86_64-linux-gnu/libpciaccess.so.0.11.1
70f6d01a6000-70f6d01ab000 r-xp 00002000 fc:00 5931966 /usr/lib/x86_64-linux-gnu/libpciaccess.so.0.11.1
70f6d01ab000-70f6d01ad000 r--p 00007000 fc:00 5931966 /usr/lib/x86_64-linux-gnu/libpciaccess.so.0.11.1
70f6d01ad000-70f6d01ae000 r--p 00008000 fc:00 5931966 /usr/lib/x86_64-linux-gnu/libpciaccess.so.0.11.1
70f6d01ae000-70f6d01af000 rw-p 00009000 fc:00 5931966 /usr/lib/x86_64-linux-gnu/libpciaccess.so.0.11.1
70f6d01af000-70f6d01de000 r--p 00000000 fc:00 5903933 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.14 (deleted)
70f6d01de000-70f6d0344000 r-xp 0002f000 fc:00 5903933 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.14 (deleted)
70f6d0344000-70f6d0386000 r--p 00195000 fc:00 5903933 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.14 (deleted)
70f6d0386000-70f6d038f000 r--p 001d6000 fc:00 5903933 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.14 (deleted)
70f6d038f000-70f6d0390000 rw-p 001df000 fc:00 5903933 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.14 (deleted)
70f6d0390000-70f6d0391000 rw-p 00000000 00:00 0
70f6d0391000-70f6d0399000 r--p 00000000 fc:00 5931208 /usr/lib/x86_64-linux-gnu/libedit.so.2.0.72
70f6d0399000-70f6d03b8000 r-xp 00008000 fc:00 5931208 /usr/lib/x86_64-linux-gnu/libedit.so.2.0.72
70f6d03b8000-70f6d03c4000 r--p 00027000 fc:00 5931208 /usr/lib/x86_64-linux-gnu/libedit.so.2.0.72
70f6d03c4000-70f6d03c6000 r--p 00033000 fc:00 5931208 /usr/lib/x86_64-linux-gnu/libedit.so.2.0.72
70f6d03c6000-70f6d03c7000 rw-p 00035000 fc:00 5931208 /usr/lib/x86_64-linux-gnu/libedit.so.2.0.72
70f6d03c7000-70f6d03cb000 rw-p 00000000 00:00 0
70f6d03cb000-70f6d03cf000 r--p 00000000 fc:00 5931351 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
70f6d03cf000-70f6d03f3000 r-xp 00004000 fc:00 5931351 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
70f6d03f3000-70f6d03f7000 r--p 00028000 fc:00 5931351 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
70f6d03f7000-70f6d03f8000 r--p 0002b000 fc:00 5931351 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
70f6d03f8000-70f6d03f9000 rw-p 0002c000 fc:00 5931351 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
70f6d03f9000-70f6d03fc000 r--p 00000000 fc:00 5899515 /usr/lib/x86_64-linux-gnu/libdrm_intel.so.1.0.0
70f6d03fc000-70f6d0412000 r-xp 00003000 fc:00 5899515 /usr/lib/x86_64-linux-gnu/libdrm_intel.so.1.0.0
70f6d0412000-70f6d041b000 r--p 00019000 fc:00 5899515 /usr/lib/x86_64-linux-gnu/libdrm_intel.so.1.0.0
70f6d041b000-70f6d041c000 r--p 00021000 fc:00 5899515 /usr/lib/x86_64-linux-gnu/libdrm_intel.so.1.0.0
70f6d041c000-70f6d041d000 rw-p 00022000 fc:00 5899515 /usr/lib/x86_64-linux-gnu/libdrm_intel.so.1.0.0
70f6d041d000-70f6d0420000 r--p 00000000 fc:00 5899454 /usr/lib/x86_64-linux-gnu/libdrm_amdgpu.so.1.0.0
70f6d0420000-70f6d0426000 r-xp 00003000 fc:00 5899454 /usr/lib/x86_64-linux-gnu/libdrm_amdgpu.so.1.0.0
70f6d0426000-70f6d0428000 r--p 00009000 fc:00 5899454 /usr/lib/x86_64-linux-gnu/libdrm_amdgpu.so.1.0.0
70f6d0428000-70f6d0429000 r--p 0000a000 fc:00 5899454 /usr/lib/x86_64-linux-gnu/libdrm_amdgpu.so.1.0.0
70f6d0429000-70f6d042a000 rw-p 0000b000 fc:00 5899454 /usr/lib/x86_64-linux-gnu/libdrm_amdgpu.so.1.0.0
70f6d042a000-70f6d042d000 r--p 00000000 fc:00 5903671 /usr/lib/x86_64-linux-gnu/libelf-0.190.so
70f6d042d000-70f6d0443000 r-xp 00003000 fc:00 5903671 /usr/lib/x86_64-linux-gnu/libelf-0.190.so
70f6d0443000-70f6d0447000 r--p 00019000 fc:00 5903671 /usr/lib/x86_64-linux-gnu/libelf-0.190.so
70f6d0447000-70f6d0448000 r--p 0001c000 fc:00 5903671 /usr/lib/x86_64-linux-gnu/libelf-0.190.so
70f6d0448000-70f6d0449000 rw-p 0001d000 fc:00 5903671 /usr/lib/x86_64-linux-gnu/libelf-0.190.so
70f6d0449000-70f6d044b000 r--p 00000000 fc:00 5899524 /usr/lib/x86_64-linux-gnu/libdrm_radeon.so.1.0.1
70f6d044b000-70f6d0451000 r-xp 00002000 fc:00 5899524 /usr/lib/x86_64-linux-gnu/libdrm_radeon.so.1.0.1
70f6d0451000-70f6d0455000 r--p 00008000 fc:00 5899524 /usr/lib/x86_64-linux-gnu/libdrm_radeon.so.1.0.1
70f6d0455000-70f6d0456000 r--p 0000b000 fc:00 5899524 /usr/lib/x86_64-linux-gnu/libdrm_radeon.so.1.0.1
70f6d0456000-70f6d0457000 rw-p 0000c000 fc:00 5899524 /usr/lib/x86_64-linux-gnu/libdrm_radeon.so.1.0.1
70f6d0457000-70f6d0459000 r--p 00000000 fc:00 5932151 /usr/lib/x86_64-linux-gnu/libsensors.so.5.0.0
70f6d0459000-70f6d0460000 r-xp 00002000 fc:00 5932151 /usr/lib/x86_64-linux-gnu/libsensors.so.5.0.0
70f6d0460000-70f6d0464000 r--p 00009000 fc:00 5932151 /usr/lib/x86_64-linux-gnu/libsensors.so.5.0.0
70f6d0464000-70f6d0465000 r--p 0000d000 fc:00 5932151 /usr/lib/x86_64-linux-gnu/libsensors.so.5.0.0
70f6d0465000-70f6d0466000 rw-p 0000e000 fc:00 5932151 /usr/lib/x86_64-linux-gnu/libsensors.so.5.0.0
70f6d0466000-70f6d046a000 r--p 00000000 fc:00 5932570 /usr/lib/x86_64-linux-gnu/libzstd.so.1.5.5
70f6d046a000-70f6d0511000 r-xp 00004000 fc:00 5932570 /usr/lib/x86_64-linux-gnu/libzstd.so.1.5.5
70f6d0511000-70f6d051e000 r--p 000ab000 fc:00 5932570 /usr/lib/x86_64-linux-gnu/libzstd.so.1.5.5
70f6d051e000-70f6d051f000 r--p 000b7000 fc:00 5932570 /usr/lib/x86_64-linux-gnu/libzstd.so.1.5.5
70f6d051f000-70f6d0520000 rw-p 000b8000 fc:00 5932570 /usr/lib/x86_64-linux-gnu/libzstd.so.1.5.5
70f6d0520000-70f6d0523000 r--p 00000000 fc:00 5932507 /usr/lib/x86_64-linux-gnu/libxcb-xfixes.so.0.0.0
70f6d0523000-70f6d0526000 r-xp 00003000 fc:00 5932507 /usr/lib/x86_64-linux-gnu/libxcb-xfixes.so.0.0.0
70f6d0526000-70f6d0528000 r--p 00006000 fc:00 5932507 /usr/lib/x86_64-linux-gnu/libxcb-xfixes.so.0.0.0
70f6d0528000-70f6d0529000 r--p 00007000 fc:00 5932507 /usr/lib/x86_64-linux-gnu/libxcb-xfixes.so.0.0.0
70f6d0529000-70f6d052a000 rw-p 00008000 fc:00 5932507 /usr/lib/x86_64-linux-gnu/libxcb-xfixes.so.0.0.0
70f6d052a000-70f6d052d000 r--p 00000000 fc:00 5932503 /usr/lib/x86_64-linux-gnu/libxcb-sync.so.1.0.0
70f6d052d000-70f6d0530000 r-xp 00003000 fc:00 5932503 /usr/lib/x86_64-linux-gnu/libxcb-sync.so.1.0.0
70f6d0530000-70f6d0531000 r--p 00006000 fc:00 5932503 /usr/lib/x86_64-linux-gnu/libxcb-sync.so.1.0.0
70f6d0531000-70f6d0532000 r--p 00007000 fc:00 5932503 /usr/lib/x86_64-linux-gnu/libxcb-sync.so.1.0.0
70f6d0532000-70f6d0533000 rw-p 00008000 fc:00 5932503 /usr/lib/x86_64-linux-gnu/libxcb-sync.so.1.0.0
70f6d0533000-70f6d0534000 r--p 00000000 fc:00 5932489 /usr/lib/x86_64-linux-gnu/libxcb-present.so.0.0.0
70f6d0534000-70f6d0535000 r-xp 00001000 fc:00 5932489 /usr/lib/x86_64-linux-gnu/libxcb-present.so.0.0.0
70f6d0535000-70f6d0536000 r--p 00002000 fc:00 5932489 /usr/lib/x86_64-linux-gnu/libxcb-present.so.0.0.0
70f6d0536000-70f6d0537000 r--p 00002000 fc:00 5932489 /usr/lib/x86_64-linux-gnu/libxcb-present.so.0.0.0
70f6d0537000-70f6d0538000 rw-p 00003000 fc:00 5932489 /usr/lib/x86_64-linux-gnu/libxcb-present.so.0.0.0
70f6d0538000-70f6d053a000 r--p 00000000 fc:00 5932479 /usr/lib/x86_64-linux-gnu/libxcb-dri3.so.0.1.0
70f6d053a000-70f6d053c000 r-xp 00002000 fc:00 5932479 /usr/lib/x86_64-linux-gnu/libxcb-dri3.so.0.1.0
70f6d053c000-70f6d053d000 r--p 00004000 fc:00 5932479 /usr/lib/x86_64-linux-gnu/libxcb-dri3.so.0.1.0
70f6d053d000-70f6d053e000 r--p 00004000 fc:00 5932479 /usr/lib/x86_64-linux-gnu/libxcb-dri3.so.0.1.0
70f6d053e000-70f6d053f000 rw-p 00005000 fc:00 5932479 /usr/lib/x86_64-linux-gnu/libxcb-dri3.so.0.1.0
70f6d053f000-70f6d0546000 r--p 00000000 fc:00 5932491 /usr/lib/x86_64-linux-gnu/libxcb-randr.so.0.1.0
70f6d0546000-70f6d054b000 r-xp 00007000 fc:00 5932491 /usr/lib/x86_64-linux-gnu/libxcb-randr.so.0.1.0
70f6d054b000-70f6d054e000 r--p 0000c000 fc:00 5932491 /usr/lib/x86_64-linux-gnu/libxcb-randr.so.0.1.0
70f6d054e000-70f6d054f000 r--p 0000f000 fc:00 5932491 /usr/lib/x86_64-linux-gnu/libxcb-randr.so.0.1.0
70f6d054f000-70f6d0550000 rw-p 00010000 fc:00 5932491 /usr/lib/x86_64-linux-gnu/libxcb-randr.so.0.1.0
70f6d0550000-70f6d0551000 r--p 00000000 fc:00 5932544 /usr/lib/x86_64-linux-gnu/libxshmfence.so.1.0.0
70f6d0551000-70f6d0552000 r-xp 00001000 fc:00 5932544 /usr/lib/x86_64-linux-gnu/libxshmfence.so.1.0.0
70f6d0552000-70f6d0553000 r--p 00002000 fc:00 5932544 /usr/lib/x86_64-linux-gnu/libxshmfence.so.1.0.0
70f6d0553000-70f6d0554000 r--p 00002000 fc:00 5932544 /usr/lib/x86_64-linux-gnu/libxshmfence.so.1.0.0
70f6d0554000-70f6d0555000 rw-p 00003000 fc:00 5932544 /usr/lib/x86_64-linux-gnu/libxshmfence.so.1.0.0
70f6d0555000-70f6d0559000 r--p 00000000 fc:00 5898359 /usr/lib/x86_64-linux-gnu/libexpat.so.1.9.1
70f6d0559000-70f6d0576000 r-xp 00004000 fc:00 5898359 /usr/lib/x86_64-linux-gnu/libexpat.so.1.9.1
70f6d0576000-70f6d057e000 r--p 00021000 fc:00 5898359 /usr/lib/x86_64-linux-gnu/libexpat.so.1.9.1
70f6d057e000-70f6d0580000 r--p 00028000 fc:00 5898359 /usr/lib/x86_64-linux-gnu/libexpat.so.1.9.1
70f6d0580000-70f6d0581000 rw-p 0002a000 fc:00 5898359 /usr/lib/x86_64-linux-gnu/libexpat.so.1.9.1
70f6d0581000-70f6d0582000 r--p 00000000 fc:00 5932501 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
70f6d0582000-70f6d0583000 r-xp 00001000 fc:00 5932501 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
70f6d0583000-70f6d0584000 r--p 00002000 fc:00 5932501 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
70f6d0584000-70f6d0585000 r--p 00002000 fc:00 5932501 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
70f6d0585000-70f6d0586000 rw-p 00003000 fc:00 5932501 /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0.0.0
70f6d0586000-70f6d0588000 r--p 00000000 fc:00 5930656 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
70f6d0588000-70f6d058b000 r-xp 00002000 fc:00 5930656 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
70f6d058b000-70f6d058c000 r--p 00005000 fc:00 5930656 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
70f6d058c000-70f6d058d000 r--p 00005000 fc:00 5930656 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
70f6d058d000-70f6d058e000 rw-p 00006000 fc:00 5930656 /usr/lib/x86_64-linux-gnu/libXfixes.so.3.1.0
70f6d058e000-70f6d0590000 r--p 00000000 fc:00 5932477 /usr/lib/x86_64-linux-gnu/libxcb-dri2.so.0.0.0
70f6d0590000-70f6d0592000 r-xp 00002000 fc:00 5932477 /usr/lib/x86_64-linux-gnu/libxcb-dri2.so.0.0.0
70f6d0592000-70f6d0593000 r--p 00004000 fc:00 5932477 /usr/lib/x86_64-linux-gnu/libxcb-dri2.so.0.0.0
70f6d0593000-70f6d0594000 r--p 00004000 fc:00 5932477 /usr/lib/x86_64-linux-gnu/libxcb-dri2.so.0.0.0
70f6d0594000-70f6d0595000 rw-p 00005000 fc:00 5932477 /usr/lib/x86_64-linux-gnu/libxcb-dri2.so.0.0.0
70f6d0595000-70f6d05a0000 r--p 00000000 fc:00 5932481 /usr/lib/x86_64-linux-gnu/libxcb-glx.so.0.0.0
70f6d05a0000-70f6d05a9000 r-xp 0000b000 fc:00 5932481 /usr/lib/x86_64-linux-gnu/libxcb-glx.so.0.0.0
70f6d05a9000-70f6d05ae000 r--p 00014000 fc:00 5932481 /usr/lib/x86_64-linux-gnu/libxcb-glx.so.0.0.0
70f6d05ae000-70f6d05b0000 r--p 00019000 fc:00 5932481 /usr/lib/x86_64-linux-gnu/libxcb-glx.so.0.0.0
70f6d05b0000-70f6d05b1000 rw-p 0001b000 fc:00 5932481 /usr/lib/x86_64-linux-gnu/libxcb-glx.so.0.0.0
70f6d05b1000-70f6d05b6000 r--p 00000000 fc:00 5898491 /usr/lib/x86_64-linux-gnu/libdrm.so.2.4.0
70f6d05b6000-70f6d05c2000 r-xp 00005000 fc:00 5898491 /usr/lib/x86_64-linux-gnu/libdrm.so.2.4.0
70f6d05c2000-70f6d05c6000 r--p 00011000 fc:00 5898491 /usr/lib/x86_64-linux-gnu/libdrm.so.2.4.0
70f6d05c6000-70f6d05c7000 r--p 00014000 fc:00 5898491 /usr/lib/x86_64-linux-gnu/libdrm.so.2.4.0
70f6d05c7000-70f6d05c8000 rw-p 00015000 fc:00 5898491 /usr/lib/x86_64-linux-gnu/libdrm.so.2.4.0
70f6d05c8000-70f6d05d5000 r--p 00000000 fc:00 5907286 /usr/lib/x86_64-linux-gnu/libglapi.so.0.0.0
70f6d05d5000-70f6d05e3000 r-xp 0000d000 fc:00 5907286 /usr/lib/x86_64-linux-gnu/libglapi.so.0.0.0
70f6d05e3000-70f6d05f7000 r--p 0001b000 fc:00 5907286 /usr/lib/x86_64-linux-gnu/libglapi.so.0.0.0
70f6d05f7000-70f6d05fb000 r--p 0002f000 fc:00 5907286 /usr/lib/x86_64-linux-gnu/libglapi.so.0.0.0
70f6d05fb000-70f6d05fc000 rw-p 00033000 fc:00 5907286 /usr/lib/x86_64-linux-gnu/libglapi.so.0.0.0
70f6d05fc000-70f6d0615000 r--p 00000000 fc:00 5907281 /usr/lib/x86_64-linux-gnu/libGLX_mesa.so.0.0.0
70f6d0615000-70f6d0655000 r-xp 00019000 fc:00 5907281 /usr/lib/x86_64-linux-gnu/libGLX_mesa.so.0.0.0
70f6d0655000-70f6d0668000 r--p 00059000 fc:00 5907281 /usr/lib/x86_64-linux-gnu/libGLX_mesa.so.0.0.0
70f6d0668000-70f6d066b000 r--p 0006b000 fc:00 5907281 /usr/lib/x86_64-linux-gnu/libGLX_mesa.so.0.0.0
70f6d066b000-70f6d066c000 rw-p 0006e000 fc:00 5907281 /usr/lib/x86_64-linux-gnu/libGLX_mesa.so.0.0.0
70f6d066c000-70f6d066d000 rw-p 00000000 00:00 0
70f6d066d000-70f6d066f000 r--p 00000000 fc:00 5903798 /usr/lib/x86_64-linux-gnu/libmd.so.0.1.0
70f6d066f000-70f6d0678000 r-xp 00002000 fc:00 5903798 /usr/lib/x86_64-linux-gnu/libmd.so.0.1.0
70f6d0678000-70f6d067a000 r--p 0000b000 fc:00 5903798 /usr/lib/x86_64-linux-gnu/libmd.so.0.1.0
70f6d067a000-70f6d067b000 r--p 0000c000 fc:00 5903798 /usr/lib/x86_64-linux-gnu/libmd.so.0.1.0
70f6d067b000-70f6d067c000 rw-p 0000d000 fc:00 5903798 /usr/lib/x86_64-linux-gnu/libmd.so.0.1.0
70f6d067c000-70f6d0680000 r--p 00000000 fc:00 5898671 /usr/lib/x86_64-linux-gnu/libbsd.so.0.12.1
70f6d0680000-70f6d068c000 r-xp 00004000 fc:00 5898671 /usr/lib/x86_64-linux-gnu/libbsd.so.0.12.1
70f6d068c000-70f6d068f000 r--p 00010000 fc:00 5898671 /usr/lib/x86_64-linux-gnu/libbsd.so.0.12.1
70f6d068f000-70f6d0690000 r--p 00012000 fc:00 5898671 /usr/lib/x86_64-linux-gnu/libbsd.so.0.12.1
70f6d0690000-70f6d0691000 rw-p 00013000 fc:00 5898671 /usr/lib/x86_64-linux-gnu/libbsd.so.0.12.1
70f6d0691000-70f6d0692000 rw-p 00000000 00:00 0
70f6d0692000-70f6d0694000 r--p 00000000 fc:00 5930652 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
70f6d0694000-70f6d0696000 r-xp 00002000 fc:00 5930652 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
70f6d0696000-70f6d0698000 r--p 00004000 fc:00 5930652 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
70f6d0698000-70f6d0699000 r--p 00005000 fc:00 5930652 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
70f6d0699000-70f6d069a000 rw-p 00006000 fc:00 5930652 /usr/lib/x86_64-linux-gnu/libXdmcp.so.6.0.0
70f6d069a000-70f6d069d000 r--p 00000000 fc:00 5930567 /usr/lib/x86_64-linux-gnu/libGLX.so.0.0.0
70f6d069d000-70f6d06b8000 r-xp 00003000 fc:00 5930567 /usr/lib/x86_64-linux-gnu/libGLX.so.0.0.0
70f6d06b8000-70f6d06bb000 r--p 0001e000 fc:00 5930567 /usr/lib/x86_64-linux-gnu/libGLX.so.0.0.0
70f6d06bb000-70f6d06bc000 r--p 00020000 fc:00 5930567 /usr/lib/x86_64-linux-gnu/libGLX.so.0.0.0
70f6d06bc000-70f6d06bd000 rw-p 00021000 fc:00 5930567 /usr/lib/x86_64-linux-gnu/libGLX.so.0.0.0
70f6d06bd000-70f6d06cd000 rw-p 00000000 00:00 0
70f6d06cd000-70f6d070e000 r--p 00000000 fc:00 5930572 /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0.0.0
70f6d070e000-70f6d074d000 r-xp 00041000 fc:00 5930572 /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0.0.0
70f6d074d000-70f6d0760000 r--p 00080000 fc:00 5930572 /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0.0.0
70f6d0760000-70f6d077c000 r--p 00093000 fc:00 5930572 /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0.0.0
70f6d077c000-70f6d077d000 rw-p 000af000 fc:00 5930572 /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0.0.0
70f6d077d000-70f6d0785000 rw-p 00000000 00:00 0
70f6d0785000-70f6d0789000 r--p 00000000 fc:00 5930654 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
70f6d0789000-70f6d0794000 r-xp 00004000 fc:00 5930654 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
70f6d0794000-70f6d0797000 r--p 0000f000 fc:00 5930654 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
70f6d0797000-70f6d0798000 r--p 00011000 fc:00 5930654 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
70f6d0798000-70f6d0799000 rw-p 00012000 fc:00 5930654 /usr/lib/x86_64-linux-gnu/libXext.so.6.4.0
70f6d0799000-70f6d07a4000 r--p 00000000 fc:00 5932517 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
70f6d07a4000-70f6d07b7000 r-xp 0000b000 fc:00 5932517 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
70f6d07b7000-70f6d07c0000 r--p 0001e000 fc:00 5932517 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
70f6d07c0000-70f6d07c1000 r--p 00026000 fc:00 5932517 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
70f6d07c1000-70f6d07c2000 rw-p 00027000 fc:00 5932517 /usr/lib/x86_64-linux-gnu/libxcb.so.1.1.0
70f6d07c2000-70f6d0805000 r--p 00000000 fc:00 5930561 /usr/lib/x86_64-linux-gnu/libGL.so.1.7.0
70f6d0805000-70f6d0825000 r-xp 00043000 fc:00 5930561 /usr/lib/x86_64-linux-gnu/libGL.so.1.7.0
70f6d0825000-70f6d0839000 r--p 00063000 fc:00 5930561 /usr/lib/x86_64-linux-gnu/libGL.so.1.7.0
70f6d0839000-70f6d0847000 r--p 00077000 fc:00 5930561 /usr/lib/x86_64-linux-gnu/libGL.so.1.7.0
70f6d0847000-70f6d0848000 rw-p 00085000 fc:00 5930561 /usr/lib/x86_64-linux-gnu/libGL.so.1.7.0
70f6d0848000-70f6d0849000 rw-p 00000000 00:00 0
70f6d0849000-70f6d0862000 r--p 00000000 fc:00 5930637 /usr/lib/x86_64-linux-gnu/libX11.so.6.4.0
70f6d0862000-70f6d08f2000 r-xp 00019000 fc:00 5930637 /usr/lib/x86_64-linux-gnu/libX11.so.6.4.0
70f6d08f2000-70f6d0981000 r--p 000a9000 fc:00 5930637 /usr/lib/x86_64-linux-gnu/libX11.so.6.4.0
70f6d0981000-70f6d0982000 r--p 00138000 fc:00 5930637 /usr/lib/x86_64-linux-gnu/libX11.so.6.4.0
70f6d0982000-70f6d0986000 rw-p 00139000 fc:00 5930637 /usr/lib/x86_64-linux-gnu/libX11.so.6.4.0
70f6d0986000-70f6d0987000 rw-s 100344000 00:0f 2083 anon_inode:i915.gem
70f6d0987000-70f6d0988000 rw-s 1061a2000 00:0f 2083 anon_inode:i915.gem
70f6d0988000-70f6d0989000 rw-s 1026fb000 00:0f 2083 anon_inode:i915.gem
70f6d0989000-70f6d098a000 r--p 00000000 fc:00 5932432 /usr/lib/x86_64-linux-gnu/libwayland-egl.so.1.22.0
70f6d098a000-70f6d098b000 r-xp 00001000 fc:00 5932432 /usr/lib/x86_64-linux-gnu/libwayland-egl.so.1.22.0
70f6d098b000-70f6d098c000 r--p 00002000 fc:00 5932432 /usr/lib/x86_64-linux-gnu/libwayland-egl.so.1.22.0
70f6d098c000-70f6d098d000 r--p 00002000 fc:00 5932432 /usr/lib/x86_64-linux-gnu/libwayland-egl.so.1.22.0
70f6d098d000-70f6d098e000 rw-p 00003000 fc:00 5932432 /usr/lib/x86_64-linux-gnu/libwayland-egl.so.1.22.0
70f6d098e000-70f6d098f000 r-xp 00000000 fc:00 13631629 /home/moi/.openjfx/cache/21+31/amd64/libglass.so
70f6d098f000-70f6d0990000 ---p 00001000 fc:00 13631629 /home/moi/.openjfx/cache/21+31/amd64/libglass.so
70f6d0990000-70f6d0991000 r--p 00001000 fc:00 13631629 /home/moi/.openjfx/cache/21+31/amd64/libglass.so
70f6d0991000-70f6d0992000 rw-p 00002000 fc:00 13631629 /home/moi/.openjfx/cache/21+31/amd64/libglass.so
70f6d0992000-70f6d0999000 r--s 00000000 fc:00 5901694 /usr/lib/x86_64-linux-gnu/gconv/gconv-modules.cache
70f6d0a99000-70f6d0a9a000 ---p 00000000 00:00 0
70f6d0a9a000-70f6d0b9a000 rw-p 00000000 00:00 0
70f6d0b9a000-70f6d0b9b000 ---p 00000000 00:00 0
70f6d0b9b000-70f6d0c9b000 rw-p 00000000 00:00 0
70f6d0c9b000-70f6d0c9c000 ---p 00000000 00:00 0
70f6d0c9c000-70f6d0d9c000 rw-p 00000000 00:00 0
70f6d0d9c000-70f6d0d9d000 ---p 00000000 00:00 0
70f6d0d9d000-70f6d0e9d000 rw-p 00000000 00:00 0
70f6d0e9d000-70f6d0e9e000 ---p 00000000 00:00 0
70f6d0e9e000-70f6d0f9e000 rw-p 00000000 00:00 0
70f6d0f9e000-70f6d0fa2000 ---p 00000000 00:00 0
70f6d0fa2000-70f6d109e000 rw-p 00000000 00:00 0
70f6d109e000-70f6d10a2000 ---p 00000000 00:00 0
70f6d10a2000-70f6d119e000 rw-p 00000000 00:00 0
70f6d119e000-70f6d119f000 ---p 00000000 00:00 0
70f6d119f000-70f6d129f000 rw-p 00000000 00:00 0
70f6d129f000-70f6d12a0000 ---p 00000000 00:00 0
70f6d12a0000-70f6d13a0000 rw-p 00000000 00:00 0
70f6d13a0000-70f6d13a1000 ---p 00000000 00:00 0
70f6d13a1000-70f6d14a1000 rw-p 00000000 00:00 0
70f6d14a1000-70f6d14a2000 ---p 00000000 00:00 0
70f6d14a2000-70f6d15a2000 rw-p 00000000 00:00 0
70f6d15a2000-70f6d15a3000 ---p 00000000 00:00 0
70f6d15a3000-70f6d16a3000 rw-p 00000000 00:00 0
70f6d16a3000-70f6d16aa000 r--p 00000000 fc:00 5899669 /usr/lib/x86_64-linux-gnu/libblkid.so.1.1.0
70f6d16aa000-70f6d16ce000 r-xp 00007000 fc:00 5899669 /usr/lib/x86_64-linux-gnu/libblkid.so.1.1.0
70f6d16ce000-70f6d16d7000 r--p 0002b000 fc:00 5899669 /usr/lib/x86_64-linux-gnu/libblkid.so.1.1.0
70f6d16d7000-70f6d16dd000 r--p 00033000 fc:00 5899669 /usr/lib/x86_64-linux-gnu/libblkid.so.1.1.0
70f6d16dd000-70f6d16de000 rw-p 00039000 fc:00 5899669 /usr/lib/x86_64-linux-gnu/libblkid.so.1.1.0
70f6d16de000-70f6d16e0000 r--p 00000000 fc:00 5931258 /usr/lib/x86_64-linux-gnu/libffi.so.8.1.4
70f6d16e0000-70f6d16e7000 r-xp 00002000 fc:00 5931258 /usr/lib/x86_64-linux-gnu/libffi.so.8.1.4
70f6d16e7000-70f6d16e8000 r--p 00009000 fc:00 5931258 /usr/lib/x86_64-linux-gnu/libffi.so.8.1.4
70f6d16e8000-70f6d16e9000 r--p 0000a000 fc:00 5931258 /usr/lib/x86_64-linux-gnu/libffi.so.8.1.4
70f6d16e9000-70f6d16ea000 rw-p 0000b000 fc:00 5931258 /usr/lib/x86_64-linux-gnu/libffi.so.8.1.4
70f6d16ea000-70f6d16ec000 r--p 00000000 fc:00 5903801 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.11.2
70f6d16ec000-70f6d175a000 r-xp 00002000 fc:00 5903801 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.11.2
70f6d175a000-70f6d1782000 r--p 00070000 fc:00 5903801 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.11.2
70f6d1782000-70f6d1783000 r--p 00097000 fc:00 5903801 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.11.2
70f6d1783000-70f6d1784000 rw-p 00098000 fc:00 5903801 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.11.2
70f6d1784000-70f6d1793000 r--p 00000000 fc:00 5931430 /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8000.0
70f6d1793000-70f6d17ca000 r-xp 0000f000 fc:00 5931430 /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8000.0
70f6d17ca000-70f6d17e3000 r--p 00046000 fc:00 5931430 /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8000.0
70f6d17e3000-70f6d17e6000 r--p 0005e000 fc:00 5931430 /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8000.0
70f6d17e6000-70f6d17e7000 rw-p 00061000 fc:00 5931430 /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0.8000.0
70f6d17e7000-70f6d1805000 r--p 00000000 fc:00 5931406 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8000.0
70f6d1805000-70f6d18a5000 r-xp 0001e000 fc:00 5931406 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8000.0
70f6d18a5000-70f6d192d000 r--p 000be000 fc:00 5931406 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8000.0
70f6d192d000-70f6d192e000 r--p 00146000 fc:00 5931406 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8000.0
70f6d192e000-70f6d192f000 rw-p 00147000 fc:00 5931406 /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.8000.0
70f6d192f000-70f6d1930000 rw-p 00000000 00:00 0
70f6d1930000-70f6d1969000 r--p 00000000 fc:00 5931398 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.8000.0
70f6d1969000-70f6d1a80000 r-xp 00039000 fc:00 5931398 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.8000.0
70f6d1a80000-70f6d1af5000 r--p 00150000 fc:00 5931398 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.8000.0
70f6d1af5000-70f6d1afd000 r--p 001c4000 fc:00 5931398 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.8000.0
70f6d1afd000-70f6d1afe000 rw-p 001cc000 fc:00 5931398 /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0.8000.0
70f6d1afe000-70f6d1b00000 rw-p 00000000 00:00 0
70f6d1b00000-70f6d1b04000 ---p 00000000 00:00 0
70f6d1b04000-70f6d1c00000 rw-p 00000000 00:00 0
70f6d1c00000-70f6d1c04000 ---p 00000000 00:00 0
70f6d1c04000-70f6d1d00000 rw-p 00000000 00:00 0
70f6d1d00000-70f6d1d04000 ---p 00000000 00:00 0
70f6d1d04000-70f6d1e00000 rw-p 00000000 00:00 0
70f6d1e00000-70f6d1e04000 ---p 00000000 00:00 0
70f6d1e04000-70f6d1f00000 rw-p 00000000 00:00 0
70f6d1f00000-70f6d1f04000 ---p 00000000 00:00 0
70f6d1f04000-70f6d2000000 rw-p 00000000 00:00 0
70f6d2000000-70f6d4021000 rw-p 00000000 00:00 0
70f6d4021000-70f6d8000000 ---p 00000000 00:00 0
70f6d8000000-70f6d8021000 rw-p 00000000 00:00 0
70f6d8021000-70f6dc000000 ---p 00000000 00:00 0
70f6dc000000-70f6dc021000 rw-p 00000000 00:00 0
70f6dc021000-70f6e0004000 ---p 00000000 00:00 0
70f6e0004000-70f6e0100000 rw-p 00000000 00:00 0
70f6e0100000-70f6e0104000 ---p 00000000 00:00 0
70f6e0104000-70f6e0200000 rw-p 00000000 00:00 0
70f6e0200000-70f6e0204000 ---p 00000000 00:00 0
70f6e0204000-70f6e0300000 rw-p 00000000 00:00 0
70f6e0400000-70f6e0404000 ---p 00000000 00:00 0
70f6e0404000-70f6e0500000 rw-p 00000000 00:00 0
70f6e0500000-70f6e0504000 ---p 00000000 00:00 0
70f6e0504000-70f6e0600000 rw-p 00000000 00:00 0
70f6e0600000-70f6e0df2000 r--p 00000000 fc:00 5913581 /usr/lib/locale/locale-archive
70f6e0df2000-70f6e0df3000 r--s 00000000 fc:00 19670061 /var/cache/fontconfig/da43223dd54fb3bb4243ae19d4b583b2-le64.cache-9
70f6e0df3000-70f6e0df4000 r--s 00000000 fc:00 19663768 /var/cache/fontconfig/8a687c406b77f27d99abfeeba937fcce-le64.cache-9
70f6e0df4000-70f6e0df5000 r--p 00000000 fc:00 5930692 /usr/lib/x86_64-linux-gnu/libXxf86vm.so.1.0.0
70f6e0df5000-70f6e0df8000 r-xp 00001000 fc:00 5930692 /usr/lib/x86_64-linux-gnu/libXxf86vm.so.1.0.0
70f6e0df8000-70f6e0df9000 r--p 00004000 fc:00 5930692 /usr/lib/x86_64-linux-gnu/libXxf86vm.so.1.0.0
70f6e0df9000-70f6e0dfa000 r--p 00004000 fc:00 5930692 /usr/lib/x86_64-linux-gnu/libXxf86vm.so.1.0.0
70f6e0dfa000-70f6e0dfb000 rw-p 00005000 fc:00 5930692 /usr/lib/x86_64-linux-gnu/libXxf86vm.so.1.0.0
70f6e0dfb000-70f6e0e04000 r--p 00000000 fc:00 5903805 /usr/lib/x86_64-linux-gnu/libmount.so.1.1.0
70f6e0e04000-70f6e0e38000 r-xp 00009000 fc:00 5903805 /usr/lib/x86_64-linux-gnu/libmount.so.1.1.0
70f6e0e38000-70f6e0e45000 r--p 0003d000 fc:00 5903805 /usr/lib/x86_64-linux-gnu/libmount.so.1.1.0
70f6e0e45000-70f6e0e47000 r--p 00049000 fc:00 5903805 /usr/lib/x86_64-linux-gnu/libmount.so.1.1.0
70f6e0e47000-70f6e0e48000 rw-p 0004b000 fc:00 5903805 /usr/lib/x86_64-linux-gnu/libmount.so.1.1.0
70f6e0e48000-70f6e0e49000 ---p 00000000 00:00 0
70f6e0e49000-70f6e0f49000 rw-p 00000000 00:00 0
70f6e104a000-70f6e1126000 rw-p 00000000 00:00 0
70f6e1328000-70f6e1d32000 rw-p 00000000 00:00 0
70f6e1d32000-70f6e1d33000 ---p 00000000 00:00 0
70f6e1d33000-70f6e1e33000 rw-p 00000000 00:00 0
70f6e1f34000-70f6e1f35000 ---p 00000000 00:00 0
70f6e1f35000-70f6e2035000 rw-p 00000000 00:00 0
70f6e2035000-70f6e2235000 rw-p 00000000 00:00 0
70f6e2235000-70f6e2405000 ---p 00000000 00:00 0
70f6e2405000-70f6e240d000 rw-p 00000000 00:00 0
70f6e240d000-70f6e5d85000 ---p 00000000 00:00 0
70f6e5d85000-70f6e5ddd000 rw-p 00000000 00:00 0
70f6e5ddd000-70f6e5e17000 ---p 00000000 00:00 0
70f6e5e17000-70f6e5e18000 rw-p 00000000 00:00 0
70f6e5e18000-70f6e6547000 ---p 00000000 00:00 0
70f6e6547000-70f6e658a000 rw-p 00000000 00:00 0
70f6e658a000-70f6e65c4000 ---p 00000000 00:00 0
70f6e65c4000-70f6e65c5000 rw-p 00000000 00:00 0
70f6e65c5000-70f6e6cf4000 ---p 00000000 00:00 0
70f6e6cf4000-70f6e7600000 rw-p 00000000 00:00 0
70f6e7600000-70f6e8b40000 rwxp 00000000 00:00 0
70f6e8b40000-70f6eeb37000 ---p 00000000 00:00 0
70f6eeb37000-70f6eeda7000 rwxp 00000000 00:00 0
70f6eeda7000-70f6ef0c9000 ---p 00000000 00:00 0
70f6ef0c9000-70f6ef849000 rwxp 00000000 00:00 0
70f6ef849000-70f6f6600000 ---p 00000000 00:00 0
70f6f6600000-70f6f7f6b000 r--s 00000000 fc:00 10879057 /opt/olvid/lib/runtime/lib/modules
70f6f7f6b000-70f6f7f6c000 r--p 00000000 fc:00 5930641 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
70f6f7f6c000-70f6f7f6e000 r-xp 00001000 fc:00 5930641 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
70f6f7f6e000-70f6f7f6f000 r--p 00003000 fc:00 5930641 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
70f6f7f6f000-70f6f7f70000 r--p 00003000 fc:00 5930641 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
70f6f7f70000-70f6f7f71000 rw-p 00004000 fc:00 5930641 /usr/lib/x86_64-linux-gnu/libXau.so.6.0.0
70f6f7f71000-70f6f7f77000 r--p 00000000 fc:00 5903804 /usr/lib/x86_64-linux-gnu/libselinux.so.1
70f6f7f77000-70f6f7f94000 r-xp 00006000 fc:00 5903804 /usr/lib/x86_64-linux-gnu/libselinux.so.1
70f6f7f94000-70f6f7f9a000 r--p 00023000 fc:00 5903804 /usr/lib/x86_64-linux-gnu/libselinux.so.1
70f6f7f9a000-70f6f7f9b000 r--p 00029000 fc:00 5903804 /usr/lib/x86_64-linux-gnu/libselinux.so.1
70f6f7f9b000-70f6f7f9c000 rw-p 0002a000 fc:00 5903804 /usr/lib/x86_64-linux-gnu/libselinux.so.1
70f6f7f9c000-70f6f7f9e000 rw-p 00000000 00:00 0
70f6f7f9e000-70f6f7f9f000 r--p 00000000 fc:00 5930635 /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1.0.0
70f6f7f9f000-70f6f7fa0000 r-xp 00001000 fc:00 5930635 /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1.0.0
70f6f7fa0000-70f6f7fa1000 r--p 00002000 fc:00 5930635 /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1.0.0
70f6f7fa1000-70f6f7fa2000 r--p 00002000 fc:00 5930635 /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1.0.0
70f6f7fa2000-70f6f7fa3000 rw-p 00003000 fc:00 5930635 /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1.0.0
70f6f7fa3000-70f6f7faf000 r-xp 00000000 fc:00 13631625 /home/moi/.openjfx/cache/21+31/amd64/libprism_es2.so
70f6f7faf000-70f6f7fb0000 r--p 0000b000 fc:00 13631625 /home/moi/.openjfx/cache/21+31/amd64/libprism_es2.so
70f6f7fb0000-70f6f7fb1000 rw-p 0000c000 fc:00 13631625 /home/moi/.openjfx/cache/21+31/amd64/libprism_es2.so
70f6f7fb1000-70f6f7fbd000 r-xp 00000000 fc:00 10879076 /opt/olvid/lib/runtime/lib/libnet.so
70f6f7fbd000-70f6f7fbe000 r--p 0000b000 fc:00 10879076 /opt/olvid/lib/runtime/lib/libnet.so
70f6f7fbe000-70f6f7fbf000 rw-p 0000c000 fc:00 10879076 /opt/olvid/lib/runtime/lib/libnet.so
70f6f7fbf000-70f6f8a75000 rw-p 00000000 00:00 0
70f6f8a75000-70f6fc000000 ---p 00000000 00:00 0
70f6fc000000-70f6fc001000 r--s 00000000 fc:00 19670059 /var/cache/fontconfig/3f7329c5293ffd510edef78f73874cfd-le64.cache-9
70f6fc001000-70f6fc002000 r--s 00000000 fc:00 19663762 /var/cache/fontconfig/c277e94e32b20404286a1ddafa5a80f0-le64.cache-9
70f6fc002000-70f6fc003000 rw-s 00000000 00:01 25368 /memfd:xshmfence (deleted)
70f6fc003000-70f6fc007000 r-xp 00000000 fc:00 10879058 /opt/olvid/lib/runtime/lib/libmanagement.so
70f6fc007000-70f6fc008000 r--p 00003000 fc:00 10879058 /opt/olvid/lib/runtime/lib/libmanagement.so
70f6fc008000-70f6fc009000 rw-p 00004000 fc:00 10879058 /opt/olvid/lib/runtime/lib/libmanagement.so
70f6fc009000-70f6fc01d000 r-xp 00000000 fc:00 10879060 /opt/olvid/lib/runtime/lib/libnio.so
70f6fc01d000-70f6fc01e000 r--p 00013000 fc:00 10879060 /opt/olvid/lib/runtime/lib/libnio.so
70f6fc01e000-70f6fc01f000 rw-p 00014000 fc:00 10879060 /opt/olvid/lib/runtime/lib/libnio.so
70f6fc01f000-70f6fc026000 r-xp 00000000 fc:00 10879086 /opt/olvid/lib/runtime/lib/libzip.so
70f6fc026000-70f6fc027000 ---p 00007000 fc:00 10879086 /opt/olvid/lib/runtime/lib/libzip.so
70f6fc027000-70f6fc028000 r--p 00007000 fc:00 10879086 /opt/olvid/lib/runtime/lib/libzip.so
70f6fc028000-70f6fc029000 rw-p 00008000 fc:00 10879086 /opt/olvid/lib/runtime/lib/libzip.so
70f6fc029000-70f6fc139000 rw-p 00000000 00:00 0
70f6fc139000-70f6fc215000 ---p 00000000 00:00 0
70f6fc215000-70f6fc240000 rw-p 00000000 00:00 0
70f6fc240000-70f6fc300000 ---p 00000000 00:00 0
70f6fc300000-70f6fc304000 ---p 00000000 00:00 0
70f6fc304000-70f6fc400000 rw-p 00000000 00:00 0
70f6fc400000-70f6fd712000 r-xp 00000000 fc:00 10879092 /opt/olvid/lib/runtime/lib/server/libjvm.so
70f6fd712000-70f6fd713000 ---p 01312000 fc:00 10879092 /opt/olvid/lib/runtime/lib/server/libjvm.so
70f6fd713000-70f6fd7e0000 r--p 01312000 fc:00 10879092 /opt/olvid/lib/runtime/lib/server/libjvm.so
70f6fd7e0000-70f6fd80e000 rw-p 013df000 fc:00 10879092 /opt/olvid/lib/runtime/lib/server/libjvm.so
70f6fd80e000-70f6fd8f3000 rw-p 00000000 00:00 0
70f6fd8f3000-70f6fd913000 r-xp 00000000 fc:00 10879070 /opt/olvid/lib/runtime/lib/libjava.so
70f6fd913000-70f6fd914000 ---p 00020000 fc:00 10879070 /opt/olvid/lib/runtime/lib/libjava.so
70f6fd914000-70f6fd915000 r--p 00020000 fc:00 10879070 /opt/olvid/lib/runtime/lib/libjava.so
70f6fd915000-70f6fd916000 rw-p 00021000 fc:00 10879070 /opt/olvid/lib/runtime/lib/libjava.so
70f6fd916000-70f6fd917000 rw-p 00000000 00:00 0
70f6fd917000-70f6fd927000 r--p 00000000 fc:00 5901707 /usr/lib/x86_64-linux-gnu/libm.so.6
70f6fd927000-70f6fd9a6000 r-xp 00010000 fc:00 5901707 /usr/lib/x86_64-linux-gnu/libm.so.6
70f6fd9a6000-70f6fd9fe000 r--p 0008f000 fc:00 5901707 /usr/lib/x86_64-linux-gnu/libm.so.6
70f6fd9fe000-70f6fd9ff000 r--p 000e7000 fc:00 5901707 /usr/lib/x86_64-linux-gnu/libm.so.6
70f6fd9ff000-70f6fda00000 rw-p 000e8000 fc:00 5901707 /usr/lib/x86_64-linux-gnu/libm.so.6
70f6fda00000-70f6fda28000 r--p 00000000 fc:00 5901704 /usr/lib/x86_64-linux-gnu/libc.so.6
70f6fda28000-70f6fdbb0000 r-xp 00028000 fc:00 5901704 /usr/lib/x86_64-linux-gnu/libc.so.6
70f6fdbb0000-70f6fdbff000 r--p 001b0000 fc:00 5901704 /usr/lib/x86_64-linux-gnu/libc.so.6
70f6fdbff000-70f6fdc03000 r--p 001fe000 fc:00 5901704 /usr/lib/x86_64-linux-gnu/libc.so.6
70f6fdc03000-70f6fdc05000 rw-p 00202000 fc:00 5901704 /usr/lib/x86_64-linux-gnu/libc.so.6
70f6fdc05000-70f6fdc12000 rw-p 00000000 00:00 0
70f6fdc12000-70f6fdc13000 rw-s 100364000 00:0f 2083 anon_inode:i915.gem
70f6fdc13000-70f6fdc14000 r--s 00000000 00:3f 183 /run/user/1000/dconf/user (deleted)
70f6fdc14000-70f6fdc15000 r--p 00000000 fc:00 7215710 /usr/share/locale-langpack/fr/LC_MESSAGES/at-spi2-core.mo
70f6fdc15000-70f6fdc16000 rw-s 100348000 00:0f 2083 anon_inode:i915.gem
70f6fdc16000-70f6fdc1b000 rw-p 00000000 00:00 0
70f6fdc1b000-70f6fdc22000 ---p 00000000 00:00 0
70f6fdc22000-70f6fdc3d000 r-xp 00000000 fc:00 10879077 /opt/olvid/lib/runtime/lib/libjimage.so
70f6fdc3d000-70f6fdc3e000 ---p 0001b000 fc:00 10879077 /opt/olvid/lib/runtime/lib/libjimage.so
70f6fdc3e000-70f6fdc40000 r--p 0001b000 fc:00 10879077 /opt/olvid/lib/runtime/lib/libjimage.so
70f6fdc40000-70f6fdc41000 rw-p 0001d000 fc:00 10879077 /opt/olvid/lib/runtime/lib/libjimage.so
70f6fdc41000-70f6fdc42000 r--p 00000000 fc:00 5901718 /usr/lib/x86_64-linux-gnu/librt.so.1
70f6fdc42000-70f6fdc43000 r-xp 00001000 fc:00 5901718 /usr/lib/x86_64-linux-gnu/librt.so.1
70f6fdc43000-70f6fdc44000 r--p 00002000 fc:00 5901718 /usr/lib/x86_64-linux-gnu/librt.so.1
70f6fdc44000-70f6fdc45000 r--p 00002000 fc:00 5901718 /usr/lib/x86_64-linux-gnu/librt.so.1
70f6fdc45000-70f6fdc46000 rw-p 00003000 fc:00 5901718 /usr/lib/x86_64-linux-gnu/librt.so.1
70f6fdc46000-70f6fdc47000 r--p 00000000 fc:00 5901716 /usr/lib/x86_64-linux-gnu/libpthread.so.0
70f6fdc47000-70f6fdc48000 r-xp 00001000 fc:00 5901716 /usr/lib/x86_64-linux-gnu/libpthread.so.0
70f6fdc48000-70f6fdc49000 r--p 00002000 fc:00 5901716 /usr/lib/x86_64-linux-gnu/libpthread.so.0
70f6fdc49000-70f6fdc4a000 r--p 00002000 fc:00 5901716 /usr/lib/x86_64-linux-gnu/libpthread.so.0
70f6fdc4a000-70f6fdc4b000 rw-p 00003000 fc:00 5901716 /usr/lib/x86_64-linux-gnu/libpthread.so.0
70f6fdc4b000-70f6fdc4d000 r--p 00000000 fc:00 5932560 /usr/lib/x86_64-linux-gnu/libz.so.1.3
70f6fdc4d000-70f6fdc5f000 r-xp 00002000 fc:00 5932560 /usr/lib/x86_64-linux-gnu/libz.so.1.3
70f6fdc5f000-70f6fdc65000 r--p 00014000 fc:00 5932560 /usr/lib/x86_64-linux-gnu/libz.so.1.3
70f6fdc65000-70f6fdc66000 r--p 0001a000 fc:00 5932560 /usr/lib/x86_64-linux-gnu/libz.so.1.3
70f6fdc66000-70f6fdc67000 rw-p 0001b000 fc:00 5932560 /usr/lib/x86_64-linux-gnu/libz.so.1.3
70f6fdc67000-70f6fdc68000 rw-s 100347000 00:0f 2083 anon_inode:i915.gem
70f6fdc68000-70f6fdc69000 rw-s 100cfc000 00:0f 2083 anon_inode:i915.gem
70f6fdc69000-70f6fdc6b000 r--p 00000000 fc:00 5931414 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.8000.0
70f6fdc6b000-70f6fdc6d000 r-xp 00002000 fc:00 5931414 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.8000.0
70f6fdc6d000-70f6fdc6e000 r--p 00004000 fc:00 5931414 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.8000.0
70f6fdc6e000-70f6fdc6f000 r--p 00004000 fc:00 5931414 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.8000.0
70f6fdc6f000-70f6fdc70000 rw-p 00005000 fc:00 5931414 /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0.8000.0
70f6fdc70000-70f6fdc78000 rw-s 00000000 00:25 122 /tmp/hsperfdata_moi/2389 (deleted)
70f6fdc78000-70f6fdc79000 ---p 00000000 00:00 0
70f6fdc79000-70f6fdc7a000 r--p 00000000 00:00 0
70f6fdc7a000-70f6fdc7d000 rw-p 00000000 00:00 0
70f6fdc7d000-70f6fdc7e000 r--p 00000000 fc:00 5901706 /usr/lib/x86_64-linux-gnu/libdl.so.2
70f6fdc7e000-70f6fdc7f000 r-xp 00001000 fc:00 5901706 /usr/lib/x86_64-linux-gnu/libdl.so.2
70f6fdc7f000-70f6fdc80000 r--p 00002000 fc:00 5901706 /usr/lib/x86_64-linux-gnu/libdl.so.2
70f6fdc80000-70f6fdc81000 r--p 00002000 fc:00 5901706 /usr/lib/x86_64-linux-gnu/libdl.so.2
70f6fdc81000-70f6fdc82000 rw-p 00003000 fc:00 5901706 /usr/lib/x86_64-linux-gnu/libdl.so.2
70f6fdc82000-70f6fdc83000 rw-s 100cfb000 00:0f 2083 anon_inode:i915.gem
70f6fdc83000-70f6fdc84000 ---p 00000000 00:00 0
70f6fdc84000-70f6fdc92000 r-xp 00000000 fc:00 10879082 /opt/olvid/lib/runtime/lib/libjli.so
70f6fdc92000-70f6fdc93000 ---p 0000e000 fc:00 10879082 /opt/olvid/lib/runtime/lib/libjli.so
70f6fdc93000-70f6fdc94000 r--p 0000e000 fc:00 10879082 /opt/olvid/lib/runtime/lib/libjli.so
70f6fdc94000-70f6fdc95000 rw-p 0000f000 fc:00 10879082 /opt/olvid/lib/runtime/lib/libjli.so
70f6fdc95000-70f6fdc97000 rw-p 00000000 00:00 0
70f6fdc97000-70f6fdc98000 r--p 00000000 fc:00 5901701 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
70f6fdc98000-70f6fdcc3000 r-xp 00001000 fc:00 5901701 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
70f6fdcc3000-70f6fdccd000 r--p 0002c000 fc:00 5901701 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
70f6fdccd000-70f6fdccf000 r--p 00036000 fc:00 5901701 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
70f6fdccf000-70f6fdcd1000 rw-p 00038000 fc:00 5901701 /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
7fff3937b000-7fff3939c000 rw-p 00000000 00:00 0 [stack]
7fff393ac000-7fff393b0000 r--p 00000000 00:00 0 [vvar]
7fff393b0000-7fff393b2000 r-xp 00000000 00:00 0 [vdso]
ffffffffff600000-ffffffffff601000 --xp 00000000 00:00 0 [vsyscall]
Total number of mappings: 1459
VM Arguments:
jvm_args: -Djpackage.app-version=2.4.2 -Dolvid.sqlcipher=true -Dolvid.dev=false -Dolvid.packaged=true -Dolvid.multiuser=false -Dolvid.debug=false -Dolvid.version=2.4.2 -Djava.net.useSystemProxies=true -Djpackage.app-path=/opt/olvid/bin/olvid
java_command: io.olvid.windows.messenger.start_up.Launcher
java_class_path (initial): /opt/olvid/lib/app/obv_windows_client-2.4.2.jar:/opt/olvid/lib/app/angus-activation-2.0.1.jar:/opt/olvid/lib/app/annotations-24.0.1.jar:/opt/olvid/lib/app/autolink-0.11.0.jar:/opt/olvid/lib/app/base64-2.3.9.jar:/opt/olvid/lib/app/commonmark-0.23.0.jar:/opt/olvid/lib/app/commonmark-ext-gfm-strikethrough-0.23.0.jar:/opt/olvid/lib/app/commons-codec-1.15.jar:/opt/olvid/lib/app/core-3.0.0.jar:/opt/olvid/lib/app/engine.jar:/opt/olvid/lib/app/flowless-0.7.3.jar:/opt/olvid/lib/app/httpclient5-5.3.1.jar:/opt/olvid/lib/app/httpcore5-5.2.4.jar:/opt/olvid/lib/app/httpcore5-h2-5.2.4.jar:/opt/olvid/lib/app/istack-commons-runtime-4.1.2.jar:/opt/olvid/lib/app/jackson-annotations-2.15.2.jar:/opt/olvid/lib/app/jackson-core-2.15.2.jar:/opt/olvid/lib/app/jackson-databind-2.15.2.jar:/opt/olvid/lib/app/jakarta.activation-api-2.1.2.jar:/opt/olvid/lib/app/jakarta.xml.bind-api-4.0.0.jar:/opt/olvid/lib/app/javafx-base-21-linux.jar:/opt/olvid/lib/app/javafx-base-21.jar:/opt/olvid/lib/app/javafx-controls-21-linux.jar:/opt/olvid/lib/app/javafx-controls-21.jar:/opt/olvid/lib/app/javafx-fxml-21-linux.jar:/opt/olvid/lib/app/javafx-graphics-21-linux.jar:/opt/olvid/lib/app/javafx-graphics-21.jar:/opt/olvid/lib/app/javafx-media-21-linux.jar:/opt/olvid/lib/app/javafx-swing-21-linux.jar:/opt/olvid/lib/app/javase-3.0.0.jar:/opt/olvid/lib/app/jaxb-core-4.0.3.jar:/opt/olvid/lib/app/jaxb-runtime-4.0.3.jar:/opt/olvid/lib/app/jna-5.13.0.jar:/opt/olvid/lib/app/jna-platform-5.13.0.jar:/opt/olvid/lib/app/jose4j-0.9.6.jar:/opt/olvid/lib/app/json-20240303.jar:/opt/olvid/lib/app/jsoup-1.17.2.jar:/opt/olvid/lib/app/kotlin-stdlib-1.9.10.jar:/opt/olvid/lib/app/kotlin-stdlib-common-1.9.10.jar:/opt/olvid/lib/app/kotlin-stdlib-jdk7-1.9.10.jar:/opt/olvid/lib/app/kotlin-stdlib-jdk8-1.9.10.jar:/opt/olvid/lib/app/log4j-api-2.20.0.jar:/opt/olvid/lib/app/log4j-core-2.20.0.jar:/opt/olvid/lib/app/metadata-extractor-2.18.0.jar:/opt/olvid/lib/app/okhttp-4.12.0.jar:/opt/olvid/lib/app/okio-jvm-3.6.0.jar:/opt/olvid/lib/app/ormlite-core-6.1.jar:/opt/olvid/lib/app/ormlite-jdbc-6.1.jar:/opt/olvid/lib/app/qrgen-1.4.jar:/opt/olvid/lib/app/reactfx-2.0-M5.jar:/opt/olvid/lib/app/richtextfx-0.11.4.jar:/opt/olvid/lib/app/slf4j-api-2.0.16.jar:/opt/olvid/lib/app/slf4j-simple-2.0.16.jar:/opt/olvid/lib/app/sqlite-jdbc-3.42.0.1.jar:/opt/olvid/lib/app/txw2-4.0.3.jar:/opt/olvid/lib/app/undofx-2.1.1.jar:/opt/olvid/lib/app/wellbehavedfx-0.3.3.jar:/opt/olvid/lib/app/xmpcore-6.1.11.jar
Launcher Type: SUN_STANDARD
[Global flags]
intx CICompilerCount = 4 {product} {ergonomic}
uint ConcGCThreads = 3 {product} {ergonomic}
uint G1ConcRefinementThreads = 10 {product} {ergonomic}
size_t G1HeapRegionSize = 2097152 {product} {ergonomic}
uintx GCDrainStackTargetSize = 64 {product} {ergonomic}
size_t InitialHeapSize = 257949696 {product} {ergonomic}
size_t MarkStackSize = 4194304 {product} {ergonomic}
size_t MaxHeapSize = 4120903680 {product} {ergonomic}
size_t MaxNewSize = 2472542208 {product} {ergonomic}
size_t MinHeapDeltaBytes = 2097152 {product} {ergonomic}
size_t MinHeapSize = 8388608 {product} {ergonomic}
uintx NonNMethodCodeHeapSize = 5839372 {pd product} {ergonomic}
uintx NonProfiledCodeHeapSize = 122909434 {pd product} {ergonomic}
uintx ProfiledCodeHeapSize = 122909434 {pd product} {ergonomic}
uintx ReservedCodeCacheSize = 251658240 {pd product} {ergonomic}
bool SegmentedCodeCache = true {product} {ergonomic}
size_t SoftMaxHeapSize = 4120903680 {manageable} {ergonomic}
bool UseCompressedOops = true {product lp64_product} {ergonomic}
bool UseG1GC = true {product} {ergonomic}
Logging:
Log output configuration:
#0:
[error occurred during error reporting (printing log configuration), id 0xb, SIGSEGV (0xb) at pc=0x000070f6fcf5bede]
Environment Variables:
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
LD_LIBRARY_PATH=:/opt/olvid/lib/app
SHELL=/bin/bash
DISPLAY=:0
LANG=fr_FR.UTF-8
Active Locale:
LC_ALL=fr_FR.UTF-8
LC_COLLATE=fr_FR.UTF-8
LC_CTYPE=fr_FR.UTF-8
LC_MESSAGES=fr_FR.UTF-8
LC_MONETARY=fr_FR.UTF-8
LC_NUMERIC=fr_FR.UTF-8
LC_TIME=fr_FR.UTF-8
Signal Handlers:
SIGSEGV: crash_handler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO, unblocked
SIGBUS: crash_handler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO, unblocked
SIGFPE: crash_handler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO, unblocked
SIGPIPE: SIG_IGN, mask=00000000000010000000000000000000, flags=SA_RESTART, blocked
*** Handler was modified!
*** Expected: javaSignalHandler in libjvm.so, mask=11100100110111111111111111111110, flags=SA_RESTART|SA_SIGINFO
SIGXFSZ: javaSignalHandler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO, blocked
SIGILL: crash_handler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO, unblocked
SIGUSR2: SR_handler in libjvm.so, mask=00000000000000000000000000000000, flags=SA_RESTART|SA_SIGINFO, blocked
SIGHUP: UserHandler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO, blocked
SIGINT: UserHandler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO, blocked
SIGTERM: UserHandler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO, blocked
SIGQUIT: UserHandler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO, blocked
SIGTRAP: crash_handler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO, unblocked
Periodic native trim disabled
--------------- S Y S T E M ---------------
OS:
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=22.1
DISTRIB_CODENAME=xia
DISTRIB_DESCRIPTION="Linux Mint 22.1 Xia"
uname: Linux 6.8.0-58-generic #60-Ubuntu SMP PREEMPT_DYNAMIC Fri Mar 14 18:29:48 UTC 2025 x86_64
OS uptime: 1 days 18:13 hours
libc: glibc 2.39 NPTL 2.39
rlimit (soft/hard): STACK 8192k/infinity , CORE 0k/infinity , NPROC 62543/62543 , NOFILE 1048576/1048576 , AS infinity/infinity , CPU infinity/infinity , DATA infinity/infinity , FSIZE infinity/infinity , MEMLOCK 2011644k/2011644k
load average: 1,02 1,13 1,01
/proc/meminfo:
MemTotal: 16093168 kB
MemFree: 12132808 kB
MemAvailable: 14442464 kB
Buffers: 154232 kB
Cached: 2458856 kB
SwapCached: 142408 kB
Active: 423272 kB
Inactive: 2605116 kB
Active(anon): 171524 kB
Inactive(anon): 454116 kB
Active(file): 251748 kB
Inactive(file): 2151000 kB
Unevictable: 125328 kB
Mlocked: 220 kB
SwapTotal: 17825788 kB
SwapFree: 17502960 kB
Zswap: 0 kB
Zswapped: 0 kB
Dirty: 3172 kB
Writeback: 96 kB
AnonPages: 528632 kB
Mapped: 188132 kB
Shmem: 209796 kB
KReclaimable: 338820 kB
Slab: 563148 kB
SReclaimable: 338820 kB
SUnreclaim: 224328 kB
KernelStack: 8992 kB
PageTables: 10824 kB
SecPageTables: 0 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 25872372 kB
Committed_AS: 3201704 kB
VmallocTotal: 34359738367 kB
VmallocUsed: 47852 kB
VmallocChunk: 0 kB
Percpu: 13632 kB
HardwareCorrupted: 0 kB
AnonHugePages: 0 kB
ShmemHugePages: 159744 kB
ShmemPmdMapped: 0 kB
FileHugePages: 0 kB
FilePmdMapped: 0 kB
Unaccepted: 0 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 0 kB
DirectMap4k: 372992 kB
DirectMap2M: 10878976 kB
DirectMap1G: 5242880 kB
/sys/kernel/mm/transparent_hugepage/enabled: always [madvise] never
/sys/kernel/mm/transparent_hugepage/defrag (defrag/compaction efforts parameter): always defer defer+madvise [madvise] never
Process Memory:
Virtual Size: 12281648K (peak: 12325272K)
Resident Set Size: 463920K (peak: 512640K) (anon: 371292K, file: 92424K, shmem: 204K)
Swapped out: 86916K
[error occurred during error reporting (printing OS information), id 0xb, SIGSEGV (0xb) at pc=0x000070f6fdaa9098]
CPU: total 12 (initial active 12) (12 cores per cpu, 1 threads per core) family 6 model 186 stepping 3 microcode 0x4124, cx8, cmov, fxsr, mmx, 3dnowpref, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, lzcnt, tsc, tscinvbit, avx, avx2, aes, erms, clmul, bmi1, bmi2, adx, sha, fma, vzeroupper, clflush, clflushopt, clwb, serialize, rdtscp, rdpid, fsrm, f16c, pku, ospke, cet_ibt, cet_ss
CPU Model and flags from /proc/cpuinfo:
model name : 13th Gen Intel(R) Core(TM) i5-1335U
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves split_lock_detect user_shstk avx_vnni dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req hfi vnmi umip pku ospke waitpkg gfni vaes vpclmulqdq rdpid movdiri movdir64b fsrm md_clear serialize arch_lbr ibt flush_l1d arch_capabilities
Online cpus: 0-11
Offline cpus:
BIOS frequency limitation: <Not Available>
Frequency switch latency (ns): 0
Available cpu frequencies: <Not Available>
Current governor: powersave
Core performance/turbo boost: <Not Available>
Memory: 4k page, physical 16093168k(14432044k free), swap 17825788k(17503216k free)
Page Sizes: 4k
vm_info: OpenJDK 64-Bit Server VM (21.0.2+13-58) for linux-amd64 JRE (21.0.2+13-58), built on 2024-01-05T18:32:24Z by "mach5one" with gcc 11.2.0
END.Cordialement
