regis@rexrog:~$ sudo journalctl --since "2025-05-10 12:00:00" --until "2025-05-10 15:40:00" | egrep 'error|fail|warn'
mai 10 12:11:48 rexrog systemd[1]: Starting grub-initrd-fallback.service - GRUB failed boot detection...
mai 10 12:11:48 rexrog bluetoothd[1159]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
mai 10 12:11:49 rexrog systemd[1]: Finished grub-initrd-fallback.service - GRUB failed boot detection.
(g-io-error-quark, 0)
mai 10 12:11:50 rexrog NetworkManager[1295]: <info> [1746871910.4685] failed to open /run/network/ifstate
mai 10 12:11:50 rexrog wpa_supplicant[1296]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Interface.P2PDevice dbus_property=P2PDeviceConfig getter failed
mai 10 12:11:52 rexrog lightdm[1558]: X Error of failed request: BadValue (integer parameter out of range for operation)
mai 10 12:11:52 rexrog lightdm[1558]: Major opcode of failed request: 140 (RANDR)
mai 10 12:11:52 rexrog lightdm[1558]: Minor opcode of failed request: 35 (RRSetProviderOutputSource)
mai 10 12:11:52 rexrog lightdm[1558]: Value in failed request: 0x46
mai 10 12:11:52 rexrog lightdm[1558]: Serial number of failed request: 16
mai 10 12:11:55 rexrog wireplumber[1612]: <WpSiAudioAdapter:0x5e56c246fd80> failed to activate item: Object activation aborted: proxy destroyed
mai 10 12:12:05 rexrog wireplumber[1779]: <WpSiAudioAdapter:0x58bcacf25340> failed to activate item: Object activation aborted: proxy destroyed
mai 10 12:12:07 rexrog flatpak[2109]: libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
mai 10 12:12:08 rexrog kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
mai 10 12:12:12 rexrog flatpak[2925]: libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
mai 10 12:12:13 rexrog flatpak[3046]: libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
mai 10 12:45:21 rexrog kernel: wlp3s0 Scan_results error (-22)
mai 10 12:45:51 rexrog pdate-worker[3211]: libostree HTTP error from remote flathub for <https://dl.flathub.org/repo/config>: Timeout was reached
mai 10 13:04:19 rexrog dbus-daemon[1161]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.60" (uid=1000 pid=1779 comm="/usr/bin/wireplumber" label="unconfined") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.3" (uid=0 pid=1159 comm="/usr/libexec/bluetooth/bluetoothd" label="unconfined")
mai 10 13:04:19 rexrog dbus-daemon[1161]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.60" (uid=1000 pid=1779 comm="/usr/bin/wireplumber" label="unconfined") interface="(unset)" member="(unset)" error name="org.bluez.Profile1.Error.NotImplemented" requested_reply="0" destination=":1.3" (uid=0 pid=1159 comm="/usr/libexec/bluetooth/bluetoothd" label="unconfined")
mai 10 13:04:19 rexrog dbus-daemon[1161]: [system] Activation via systemd failed for unit 'dbus-org.bluez.service': Transaction for bluetooth.service/start is destructive (cryptsetup.target has 'stop' job queued, but 'start' is included in transaction).
mai 10 13:04:19 rexrog dbus-daemon[1161]: [system] Activation via systemd failed for unit 'dbus-org.bluez.service': Transaction for bluetooth.service/start is destructive (proc-sys-fs-binfmt_misc.automount has 'stop' job queued, but 'start' is included in transaction).
mai 10 13:04:19 rexrog dbus-daemon[1161]: [system] Activation via systemd failed for unit 'colord.service': Transaction for colord.service/start is destructive (umount.target has 'start' job queued, but 'stop' is included in transaction).
mai 10 13:04:24 rexrog dbus-daemon[1161]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Transaction for NetworkManager-dispatcher.service/start is destructive (systemd-tmpfiles-setup.service has 'stop' job queued, but 'start' is included in transaction).
mai 10 13:04:30 rexrog bluetoothd[1079]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
mai 10 13:04:31 rexrog systemd[1]: Starting grub-initrd-fallback.service - GRUB failed boot detection...
mai 10 13:04:32 rexrog systemd[1]: Finished grub-initrd-fallback.service - GRUB failed boot detection.
mai 10 13:04:34 rexrog NetworkManager[1183]: <info> [1746875074.6055] failed to open /run/network/ifstate
mai 10 13:04:37 rexrog lightdm[1497]: X Error of failed request: BadValue (integer parameter out of range for operation)
mai 10 13:04:37 rexrog lightdm[1497]: Major opcode of failed request: 140 (RANDR)
mai 10 13:04:37 rexrog lightdm[1497]: Minor opcode of failed request: 35 (RRSetProviderOutputSource)
mai 10 13:04:37 rexrog lightdm[1497]: Value in failed request: 0x46
mai 10 13:04:37 rexrog lightdm[1497]: Serial number of failed request: 16
mai 10 13:04:39 rexrog wireplumber[1531]: <WpSiAudioAdapter:0x5f92b74e1290> failed to activate item: Object activation aborted: proxy destroyed
mai 10 13:04:46 rexrog wireplumber[1681]: <WpSiAudioAdapter:0x5a0030d423b0> failed to activate item: Object activation aborted: proxy destroyed
mai 10 13:04:48 rexrog flatpak[1982]: libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
mai 10 13:04:54 rexrog flatpak[2698]: libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
mai 10 13:04:55 rexrog flatpak[2764]: libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
mai 10 13:48:53 rexrog kernel: warning: `Qt bearer threa' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
mai 10 13:50:29 rexrog dbus-daemon[1081]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.59" (uid=1000 pid=1681 comm="/usr/bin/wireplumber" label="unconfined") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.2" (uid=0 pid=1079 comm="/usr/libexec/bluetooth/bluetoothd" label="unconfined")
mai 10 13:50:29 rexrog dbus-daemon[1081]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.59" (uid=1000 pid=1681 comm="/usr/bin/wireplumber" label="unconfined") interface="(unset)" member="(unset)" error name="org.bluez.Profile1.Error.NotImplemented" requested_reply="0" destination=":1.2" (uid=0 pid=1079 comm="/usr/libexec/bluetooth/bluetoothd" label="unconfined")
mai 10 13:50:29 rexrog cinnamon-session-binary[1711]: GLib-CRITICAL: t+2659.11751s: g_variant_unref: assertion 'value != NULL' failed
mai 10 13:50:30 rexrog dbus-daemon[1081]: [system] Activation via systemd failed for unit 'dbus-org.bluez.service': Transaction for bluetooth.service/start is destructive (cryptsetup.target has 'stop' job queued, but 'start' is included in transaction).
mai 10 13:50:30 rexrog dbus-daemon[1081]: [system] Activation via systemd failed for unit 'dbus-org.bluez.service': Transaction for bluetooth.service/start is destructive (systemd-tmpfiles-setup-dev.service has 'stop' job queued, but 'start' is included in transaction).
mai 10 13:50:30 rexrog dbus-daemon[1081]: [system] Activation via systemd failed for unit 'colord.service': Transaction for colord.service/start is destructive (systemd-update-utmp.service has 'stop' job queued, but 'start' is included in transaction).
mai 10 13:50:30 rexrog fwupd[8751]: 11:50:30.757 FuPluginUpower failed to query lid state
mai 10 13:50:31 rexrog dbus-daemon[1081]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Transaction for NetworkManager-dispatcher.service/start is destructive (veritysetup.target has 'stop' job queued, but 'start' is included in transaction).
mai 10 13:50:31 rexrog dbus-daemon[1081]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Transaction for NetworkManager-dispatcher.service/start is destructive (reboot.target has 'start' job queued, but 'stop' is included in transaction).
mai 10 13:50:32 rexrog dbus-daemon[1081]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Transaction for NetworkManager-dispatcher.service/start is destructive (boot-efi.mount has 'stop' job queued, but 'start' is included in transaction).
mai 10 13:50:33 rexrog systemd[1]: Starting grub-initrd-fallback.service - GRUB failed boot detection...
mai 10 13:50:33 rexrog systemd[1]: Finished grub-initrd-fallback.service - GRUB failed boot detection.
mai 10 13:50:33 rexrog bluetoothd[1093]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
mai 10 13:50:35 rexrog NetworkManager[1222]: <info> [1746877835.0793] failed to open /run/network/ifstate
mai 10 13:50:37 rexrog lightdm[1445]: X Error of failed request: BadValue (integer parameter out of range for operation)
mai 10 13:50:37 rexrog lightdm[1445]: Major opcode of failed request: 140 (RANDR)
mai 10 13:50:37 rexrog lightdm[1445]: Minor opcode of failed request: 35 (RRSetProviderOutputSource)
mai 10 13:50:37 rexrog lightdm[1445]: Value in failed request: 0x46
mai 10 13:50:37 rexrog lightdm[1445]: Serial number of failed request: 16
mai 10 13:50:40 rexrog wireplumber[1499]: <WpSiAudioAdapter:0x654f49b88c20> failed to activate item: Object activation aborted: proxy destroyed
mai 10 13:50:46 rexrog wireplumber[1650]: <WpSiAudioAdapter:0x5e7b5a099ac0> failed to activate item: Object activation aborted: proxy destroyed
mai 10 13:50:48 rexrog flatpak[1966]: libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
mai 10 13:50:50 rexrog kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
mai 10 13:50:50 rexrog evolution-calen[2317]: e_source_unset_last_credentials_required_arguments: assertion 'E_IS_SOURCE (source)' failed
mai 10 13:50:53 rexrog flatpak[2811]: libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
mai 10 13:50:54 rexrog flatpak[2897]: libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
mai 10 13:51:03 rexrog wpa_supplicant[1223]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Interface.P2PDevice dbus_property=P2PDeviceConfig getter failed
mai 10 14:08:24 rexrog PackageKit[3343]: install-packages transaction /69_cdaabecc from uid 1000 finished with failed after 211213ms
mai 10 12:10:42 rexrog kernel: ACPI Error: Aborting method \_SB.PCI0.XHC.RHUB.HS15._PLD due to previous error (AE_AML_BUFFER_LIMIT) (20230628/psparse-529)
mai 10 12:10:42 rexrog kernel: pci 0000:00:1c.4: retraining failed
mai 10 12:10:45 rexrog kernel: asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -19
mai 10 12:10:45 rexrog kernel: asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -19
mai 10 12:10:45 rexrog kernel: asus_wmi: fan_curve_get_factory_default (0x00110032) failed: -19
mai 10 12:10:45 rexrog kernel: wl: module verification failed: signature and/or required key missing - tainting kernel
mai 10 12:10:45 rexrog kernel: spi-nor: probe of spi0.0 failed with error -22
mai 10 14:08:49 rexrog systemd[1]: Starting grub-initrd-fallback.service - GRUB failed boot detection...
mai 10 14:08:49 rexrog systemd[1]: Finished grub-initrd-fallback.service - GRUB failed boot detection.
mai 10 14:08:49 rexrog bluetoothd[1158]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
mai 10 14:08:50 rexrog NetworkManager[1294]: <info> [1746878930.8715] failed to open /run/network/ifstate
mai 10 14:08:53 rexrog lightdm[1595]: X Error of failed request: BadValue (integer parameter out of range for operation)
mai 10 14:08:53 rexrog lightdm[1595]: Major opcode of failed request: 140 (RANDR)
mai 10 14:08:53 rexrog lightdm[1595]: Minor opcode of failed request: 35 (RRSetProviderOutputSource)
mai 10 14:08:53 rexrog lightdm[1595]: Value in failed request: 0x46
mai 10 14:08:53 rexrog lightdm[1595]: Serial number of failed request: 16
mai 10 14:08:55 rexrog wireplumber[1628]: <WpSiAudioAdapter:0x58aba420b1d0> failed to activate item: Object activation aborted: proxy destroyed
mai 10 14:09:01 rexrog wireplumber[1766]: <WpSiAudioAdapter:0x63a83c3fe090> failed to activate item: Object activation aborted: proxy destroyed
mai 10 14:09:03 rexrog flatpak[2065]: libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
mai 10 14:09:04 rexrog kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
mai 10 14:09:08 rexrog flatpak[2972]: libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
mai 10 14:09:08 rexrog flatpak[3038]: libva error: /usr/lib/x86_64-linux-gnu/dri/intel-vaapi-driver/iHD_drv_video.so init failed
regis@rexrog:~$
