Linux Mint Xfce version 22.
Le Greffon Météo ne marche pas
Merci d'avance pour vos réponses.
Bonsoir,alain a écrit : lun. 19 mai 2025 19:53 Bonjour Zipty
As tu essayé la solution proposée par notre exellent Alv37? : Mise à jour xfce4-weather-plugin
Je viens de le tester chez moi sur LM21.3 et LM22.1 ça fonctionne nickel.Zipty a écrit : lun. 19 mai 2025 20:08 Oui, j'avais vu ce lien, j'ai testé, mais hélas cela n'a rien donnée![]()
alain@alain-desktop:~/xfce4-weather-plugin-0.11.3$ ./configure --prefix=/usr
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a race-free mkdir -p... /usr/bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether UID '1000' is supported by ustar format... yes
checking whether GID '1000' is supported by ustar format... yes
checking how to create a ustar tar archive... gnutar
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether make supports nested variables... (cached) yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether the compiler supports GNU C... yes
checking whether gcc accepts -g... yes
checking for gcc option to enable C11 features... none needed
checking whether gcc understands -c and -o together... yes
checking whether make supports the include directive... yes (GNU style)
checking dependency style of gcc... gcc3
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking for a sed that does not truncate output... /usr/bin/sed
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for fgrep... /usr/bin/grep -F
checking how to print strings... printf
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for file... file
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /usr/bin/dd
checking how to truncate binary pipes... /usr/bin/dd bs=4096 count=1
checking for mt... mt
checking if mt is a manifest tool... no
checking for stdio.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for strings.h... yes
checking for sys/stat.h... yes
checking for sys/types.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for math.h... yes
checking for stdarg.h... yes
checking for stddef.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for sys/stat.h... (cached) yes
checking for time.h... yes
checking for cos in -lm... yes
checking whether NLS is requested... yes
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking for ld used by gcc... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking for shared library run path origin... done
checking how to run the C preprocessor... gcc -E
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for gtk+-3.0 >= 3.22.0... 3.24.41
checking GTK_CFLAGS... -I/usr/include/gtk-3.0 -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/harfbuzz -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/fribidi -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/webp -I/usr/include/gio-unix-2.0 -I/usr/include/atk-1.0 -I/usr/include/at-spi2-atk/2.0 -I/usr/include/at-spi-2.0 -I/usr/include/dbus-1.0 -I/usr/lib/x86_64-linux-gnu/dbus-1.0/include -pthread
checking GTK_LIBS... -lgtk-3 -lgdk-3 -lz -lpangocairo-1.0 -lpango-1.0 -lharfbuzz -latk-1.0 -lcairo-gobject -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lgobject-2.0 -lglib-2.0
checking for pkg-config... (cached) /usr/bin/pkg-config
checking for gthread-2.0 >= 2.64.0... 2.80.0
checking GTHREAD_CFLAGS... -pthread -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include
checking GTHREAD_LIBS... -lgthread-2.0 -pthread -lglib-2.0
checking for glib-2.0 >= 2.64.0... 2.80.0
checking GLIB_CFLAGS... -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include
checking GLIB_LIBS... -lglib-2.0
configure: setting GLIB_VERSION_MAX_ALLOWED and GLIB_VERSION_MIN_REQUIRED according to 2.64.0
checking for libxfce4util-1.0 >= 4.12.0... 4.18.1
checking LIBXFCE4UTIL_CFLAGS... -I/usr/include/xfce4 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include
checking LIBXFCE4UTIL_LIBS... -lxfce4util -lglib-2.0
checking for libxfce4ui-2 >= 4.12.0... 4.18.4
checking LIBXFCE4UI_CFLAGS... -I/usr/include/xfce4/libxfce4ui-2 -I/usr/include/gtk-3.0 -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/harfbuzz -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/fribidi -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/webp -I/usr/include/gio-unix-2.0 -I/usr/include/atk-1.0 -I/usr/include/at-spi2-atk/2.0 -I/usr/include/at-spi-2.0 -I/usr/include/dbus-1.0 -I/usr/lib/x86_64-linux-gnu/dbus-1.0/include -pthread -I/usr/include/xfce4
checking LIBXFCE4UI_LIBS... -lxfce4ui-2 -lgtk-3 -lgdk-3 -lz -lpangocairo-1.0 -lpango-1.0 -lharfbuzz -latk-1.0 -lcairo-gobject -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lgobject-2.0 -lxfce4util -lglib-2.0
checking for libxfce4panel-2.0 >= 4.14.0... 4.18.4
checking LIBXFCE4PANEL_CFLAGS... -I/usr/include/xfce4/libxfce4panel-2.0 -I/usr/include/gtk-3.0 -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/harfbuzz -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/fribidi -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/webp -I/usr/include/gio-unix-2.0 -I/usr/include/atk-1.0 -I/usr/include/at-spi2-atk/2.0 -I/usr/include/at-spi-2.0 -I/usr/include/dbus-1.0 -I/usr/lib/x86_64-linux-gnu/dbus-1.0/include -pthread -I/usr/include/xfce4
checking LIBXFCE4PANEL_LIBS... -lxfce4panel-2.0 -lgtk-3 -lgdk-3 -lz -lpangocairo-1.0 -lpango-1.0 -lharfbuzz -latk-1.0 -lcairo-gobject -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lgobject-2.0 -Wl,--export-dynamic -lgmodule-2.0 -pthread -lglib-2.0 -lxfce4util -lglib-2.0
checking for libxfconf-0 >= 4.12.0... 4.18.1
checking XFCONF_CFLAGS... -I/usr/include/xfce4/xfconf-0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -pthread -I/usr/include/libmount -I/usr/include/blkid
checking XFCONF_LIBS... -lxfconf-0 -lgio-2.0 -lgobject-2.0 -lglib-2.0
checking for libxml-2.0 >= 2.4.0... 2.9.14
checking LIBXML_CFLAGS... -I/usr/include/libxml2
checking LIBXML_LIBS... -lxml2
checking for libsoup-2.4 >= 2.42.0... 2.74.3
checking SOUP_CFLAGS... -I/usr/include/libsoup-2.4 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -pthread -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/libxml2
checking SOUP_LIBS... -lsoup-2.4 -Wl,--export-dynamic -lgmodule-2.0 -pthread -lglib-2.0 -lgio-2.0 -lgobject-2.0 -lglib-2.0
checking for json-c >= 0.13.1... 0.17
checking JSON_CFLAGS... -I/usr/include/json-c
checking JSON_LIBS... -ljson-c
checking for optional package upower-glib >= 0.9.0... not found
checking whether to build with debugging support... minimum
checking if gcc supports -Wall... yes
checking if gcc supports -Wextra... yes
checking if gcc supports -Wno-missing-field-initializers... yes
checking if gcc supports -Wno-unused-parameter... yes
checking if gcc supports -Wmissing-declarations... yes
checking if gcc supports -Wmissing-noreturn... yes
checking if gcc supports -Wpointer-arith... yes
checking if gcc supports -Wcast-align... yes
checking if gcc supports -Wformat... yes
checking if gcc supports -Wformat-security... yes
checking if gcc supports -Wformat-y2k... yes
checking if gcc supports -Winit-self... yes
checking if gcc supports -Wmissing-include-dirs... yes
checking if gcc supports -Wundef... yes
checking if gcc supports -Wredundant-decls... yes
checking if gcc supports -Wshadow... yes
checking if gcc supports -Wnested-externs... yes
checking if gcc supports -Wold-style-definition... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating panel-plugin/Makefile
config.status: creating po/Makefile.in
config.status: creating icons/Makefile
config.status: creating icons/liquid/Makefile
config.status: creating icons/liquid/22/Makefile
config.status: creating icons/liquid/48/Makefile
config.status: creating icons/liquid/128/Makefile
config.status: creating icons/liquid-dark/Makefile
config.status: creating icons/liquid-dark/22/Makefile
config.status: creating icons/liquid-dark/48/Makefile
config.status: creating icons/liquid-dark/128/Makefile
config.status: creating icons/simplistic/Makefile
config.status: creating icons/simplistic/22/Makefile
config.status: creating icons/simplistic/48/Makefile
config.status: creating icons/simplistic/128/Makefile
config.status: creating icons/16x16/Makefile
config.status: creating icons/32x32/Makefile
config.status: creating icons/48x48/Makefile
config.status: creating icons/128x128/Makefile
config.status: creating icons/scalable/Makefile
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing po-directories commands
config.status: creating po/POTFILES
Build Configuration:
* Debug Support: minimum
alain@alain-desktop:~/xfce4-weather-plugin-0.11.3$ Code : Tout sélectionner
alain@alain-desktop:~/xfce4-weather-plugin-0.11.3$ make
make all-recursive
make[1] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3 »
Making all in panel-plugin
make[2] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/panel-plugin »
make all-am
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/panel-plugin »
CC libweather_la-weather.lo
CC libweather_la-weather-config.lo
weather-config.c: In function 'button_icons_dir_clicked':
weather-config.c:961:5: warning: 'xfce_spawn_command_line_on_screen' is deprecated: Use xfce_spawn_command_line() instead [-Wdeprecated-declarations]
961 | xfce_spawn_command_line_on_screen(gdk_screen_get_default(),
In file included from /usr/include/xfce4/libxfce4ui-2/libxfce4ui/libxfce4ui.h:31,
from weather-config.c:24:
/usr/include/xfce4/libxfce4ui-2/libxfce4ui/xfce-spawn.h:64:10: note: declared here
64 | gboolean xfce_spawn_command_line_on_screen (GdkScreen *screen,
CC libweather_la-weather-data.lo
CC libweather_la-weather-debug.lo
CC libweather_la-weather-icon.lo
CC libweather_la-weather-parsers.lo
CC libweather_la-weather-scrollbox.lo
CC libweather_la-weather-search.lo
weather-search.c: In function 'create_search_dialog':
weather-search.c:208:9: warning: 'xfce_titled_dialog_new_with_buttons' is deprecated: Use xfce_titled_dialog_new_with_mixed_buttons() instead [-Wdeprecated-declarations]
208 | xfce_titled_dialog_new_with_buttons(_("Search location"),
In file included from /usr/include/xfce4/libxfce4ui-2/libxfce4ui/libxfce4ui.h:35,
from weather-search.c:25:
/usr/include/xfce4/libxfce4ui-2/libxfce4ui/xfce-titled-dialog.h:71:23: note: declared here
71 | GtkWidget *xfce_titled_dialog_new_with_buttons (const gchar *title,
CC libweather_la-weather-summary.lo
CC libweather_la-weather-translate.lo
CCLD libweather.la
GEN weather.desktop
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/panel-plugin »
make[2] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/panel-plugin »
Making all in po
make[2] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/po »
make[2]: Rien à faire pour « all ».
make[2] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/po »
Making all in icons
make[2] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons »
Making all in liquid
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid »
Making all in 22
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid/22 »
make[4]: Rien à faire pour « all ».
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid/22 »
Making all in 48
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid/48 »
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid/48 »
Making all in 128
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid/128 »
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid/128 »
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid »
make[4]: Rien à faire pour « all-am ».
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid »
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid »
Making all in liquid-dark
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark »
Making all in 22
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark/22 »
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark/22 »
Making all in 48
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark/48 »
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark/48 »
Making all in 128
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark/128 »
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark/128 »
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark »
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark »
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark »
Making all in simplistic
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic »
Making all in 22
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic/22 »
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic/22 »
Making all in 48
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic/48 »
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic/48 »
Making all in 128
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic/128 »
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic/128 »
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic »
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic »
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic »
Making all in 16x16
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/16x16 »
make[3]: Rien à faire pour « all ».
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/16x16 »
Making all in 32x32
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/32x32 »
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/32x32 »
Making all in 48x48
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/48x48 »
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/48x48 »
Making all in 128x128
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/128x128 »
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/128x128 »
Making all in scalable
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/scalable »
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/scalable »
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons »
make[3]: Rien à faire pour « all-am ».
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons »
make[2] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons »
make[2] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3 »
make[2] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3 »
make[1] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3 »Code : Tout sélectionner
alain@alain-desktop:~/xfce4-weather-plugin-0.11.3$ sudo make install
[sudo] Mot de passe de alain :
Making install in panel-plugin
make[1] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/panel-plugin »
make install-am
make[3]: Rien à faire pour « install-exec-am ».
/usr/bin/mkdir -p '/usr/share/xfce4/panel/plugins'
/usr/bin/install -c -m 644 weather.desktop '/usr/share/xfce4/panel/plugins'
/usr/bin/mkdir -p '/usr/lib/xfce4/panel/plugins'
/bin/bash ../libtool --mode=install /usr/bin/install -c libweather.la '/usr/lib/xfce4/panel/plugins'
libtool: install: /usr/bin/install -c .libs/libweather.so /usr/lib/xfce4/panel/plugins/libweather.so
libtool: install: /usr/bin/install -c .libs/libweather.lai /usr/lib/xfce4/panel/plugins/libweather.la
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin:/sbin" ldconfig -n /usr/lib/xfce4/panel/plugins
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the '-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the 'LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the 'LD_RUN_PATH' environment variable
during linking
- use the '-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to '/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
make[1] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/panel-plugin »
Making install in po
make[1] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/po »
installing ar.gmo as /usr/share/locale/ar/LC_MESSAGES/xfce4-weather-plugin.mo
installing ast.gmo as /usr/share/locale/ast/LC_MESSAGES/xfce4-weather-plugin.mo
installing be.gmo as /usr/share/locale/be/LC_MESSAGES/xfce4-weather-plugin.mo
installing bg.gmo as /usr/share/locale/bg/LC_MESSAGES/xfce4-weather-plugin.mo
installing ca.gmo as /usr/share/locale/ca/LC_MESSAGES/xfce4-weather-plugin.mo
installing cs.gmo as /usr/share/locale/cs/LC_MESSAGES/xfce4-weather-plugin.mo
installing da.gmo as /usr/share/locale/da/LC_MESSAGES/xfce4-weather-plugin.mo
installing de.gmo as /usr/share/locale/de/LC_MESSAGES/xfce4-weather-plugin.mo
installing el.gmo as /usr/share/locale/el/LC_MESSAGES/xfce4-weather-plugin.mo
installing en_AU.gmo as /usr/share/locale/en_AU/LC_MESSAGES/xfce4-weather-plugin.mo
installing en_GB.gmo as /usr/share/locale/en_GB/LC_MESSAGES/xfce4-weather-plugin.mo
installing es.gmo as /usr/share/locale/es/LC_MESSAGES/xfce4-weather-plugin.mo
installing et.gmo as /usr/share/locale/et/LC_MESSAGES/xfce4-weather-plugin.mo
installing eu.gmo as /usr/share/locale/eu/LC_MESSAGES/xfce4-weather-plugin.mo
installing fi.gmo as /usr/share/locale/fi/LC_MESSAGES/xfce4-weather-plugin.mo
installing fr.gmo as /usr/share/locale/fr/LC_MESSAGES/xfce4-weather-plugin.mo
installing gl.gmo as /usr/share/locale/gl/LC_MESSAGES/xfce4-weather-plugin.mo
installing he.gmo as /usr/share/locale/he/LC_MESSAGES/xfce4-weather-plugin.mo
installing hr.gmo as /usr/share/locale/hr/LC_MESSAGES/xfce4-weather-plugin.mo
installing hu.gmo as /usr/share/locale/hu/LC_MESSAGES/xfce4-weather-plugin.mo
installing hye.gmo as /usr/share/locale/hye/LC_MESSAGES/xfce4-weather-plugin.mo
installing id.gmo as /usr/share/locale/id/LC_MESSAGES/xfce4-weather-plugin.mo
installing is.gmo as /usr/share/locale/is/LC_MESSAGES/xfce4-weather-plugin.mo
installing it.gmo as /usr/share/locale/it/LC_MESSAGES/xfce4-weather-plugin.mo
installing ja.gmo as /usr/share/locale/ja/LC_MESSAGES/xfce4-weather-plugin.mo
installing ko.gmo as /usr/share/locale/ko/LC_MESSAGES/xfce4-weather-plugin.mo
installing lt.gmo as /usr/share/locale/lt/LC_MESSAGES/xfce4-weather-plugin.mo
installing lv.gmo as /usr/share/locale/lv/LC_MESSAGES/xfce4-weather-plugin.mo
installing ms.gmo as /usr/share/locale/ms/LC_MESSAGES/xfce4-weather-plugin.mo
installing nb.gmo as /usr/share/locale/nb/LC_MESSAGES/xfce4-weather-plugin.mo
installing nl.gmo as /usr/share/locale/nl/LC_MESSAGES/xfce4-weather-plugin.mo
installing nn.gmo as /usr/share/locale/nn/LC_MESSAGES/xfce4-weather-plugin.mo
installing oc.gmo as /usr/share/locale/oc/LC_MESSAGES/xfce4-weather-plugin.mo
installing pa.gmo as /usr/share/locale/pa/LC_MESSAGES/xfce4-weather-plugin.mo
installing pl.gmo as /usr/share/locale/pl/LC_MESSAGES/xfce4-weather-plugin.mo
installing pt_BR.gmo as /usr/share/locale/pt_BR/LC_MESSAGES/xfce4-weather-plugin.mo
installing pt.gmo as /usr/share/locale/pt/LC_MESSAGES/xfce4-weather-plugin.mo
installing ru.gmo as /usr/share/locale/ru/LC_MESSAGES/xfce4-weather-plugin.mo
installing sk.gmo as /usr/share/locale/sk/LC_MESSAGES/xfce4-weather-plugin.mo
installing sl.gmo as /usr/share/locale/sl/LC_MESSAGES/xfce4-weather-plugin.mo
installing sq.gmo as /usr/share/locale/sq/LC_MESSAGES/xfce4-weather-plugin.mo
installing sr.gmo as /usr/share/locale/sr/LC_MESSAGES/xfce4-weather-plugin.mo
installing sv.gmo as /usr/share/locale/sv/LC_MESSAGES/xfce4-weather-plugin.mo
installing te.gmo as /usr/share/locale/te/LC_MESSAGES/xfce4-weather-plugin.mo
installing th.gmo as /usr/share/locale/th/LC_MESSAGES/xfce4-weather-plugin.mo
installing tr.gmo as /usr/share/locale/tr/LC_MESSAGES/xfce4-weather-plugin.mo
installing ug.gmo as /usr/share/locale/ug/LC_MESSAGES/xfce4-weather-plugin.mo
installing uk.gmo as /usr/share/locale/uk/LC_MESSAGES/xfce4-weather-plugin.mo
installing ur_PK.gmo as /usr/share/locale/ur_PK/LC_MESSAGES/xfce4-weather-plugin.mo
installing ur.gmo as /usr/share/locale/ur/LC_MESSAGES/xfce4-weather-plugin.mo
installing zh_CN.gmo as /usr/share/locale/zh_CN/LC_MESSAGES/xfce4-weather-plugin.mo
installing zh_TW.gmo as /usr/share/locale/zh_TW/LC_MESSAGES/xfce4-weather-plugin.mo
if test "xfce4-weather-plugin" = "gettext-tools"; then \
/usr/bin/mkdir -p /usr/share/gettext/po; \
for file in Makefile.in.in remove-potcdate.sin quot.sed boldquot.sed en@quot.header en@boldquot.header insert-header.sin Rules-quot Makevars.template; do \
/usr/bin/install -c -m 644 ./$file \
/usr/share/gettext/po/$file; \
done; \
for file in Makevars; do \
rm -f /usr/share/gettext/po/$file; \
done; \
else \
fi
make[1] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/po »
Making install in icons
make[1] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons »
Making install in liquid
make[2] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid »
Making install in 22
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid/22 »
make[4]: Rien à faire pour « install-exec-am ».
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid/22'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png lightcloud.png lightcloud-night.png lightrain.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rainthunder.png sleet.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png snow.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/liquid/22'
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid/22 »
Making install in 48
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid/48 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid/48'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png lightcloud.png lightcloud-night.png lightrain.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rainthunder.png sleet.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png snow.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/liquid/48'
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid/48 »
Making install in 128
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid/128 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid/128'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png lightcloud.png lightcloud-night.png lightrain.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rainthunder.png sleet.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png snow.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/liquid/128'
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid/128 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid'
/usr/bin/install -c -m 644 theme.info '/usr/share/xfce4/weather/icons/liquid'
make[2] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid »
Making install in liquid-dark
make[2] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark »
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark/22 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid-dark/22'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png lightcloud.png lightcloud-night.png lightrain.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rainthunder.png sleet.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png snow.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/liquid-dark/22'
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark/22 »
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark/48 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid-dark/48'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png lightcloud.png lightcloud-night.png lightrain.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rainthunder.png sleet.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png snow.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/liquid-dark/48'
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark/48 »
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark/128 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid-dark/128'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png lightcloud.png lightcloud-night.png lightrain.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rainthunder.png sleet.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png snow.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/liquid-dark/128'
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark/128 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid-dark'
/usr/bin/install -c -m 644 theme.info '/usr/share/xfce4/weather/icons/liquid-dark'
make[2] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/liquid-dark »
Making install in simplistic
make[2] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic »
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic/22 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/simplistic/22'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png fog-night.png lightcloud.png lightcloud-night.png lightrain.png lightrain-night.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthunder-night.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rain-night.png rainthunder.png rainthunder-night.png sleet.png sleet-night.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png sleetthunder-night.png snow.png snow-night.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png snowthunder-night.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/simplistic/22'
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic/22 »
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic/48 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/simplistic/48'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png fog-night.png lightcloud.png lightcloud-night.png lightrain.png lightrain-night.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthunder-night.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rain-night.png rainthunder.png rainthunder-night.png sleet.png sleet-night.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png sleetthunder-night.png snow.png snow-night.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png snowthunder-night.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/simplistic/48'
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic/48 »
make[3] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic/128 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/simplistic/128'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png fog-night.png lightcloud.png lightcloud-night.png lightrain.png lightrain-night.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthunder-night.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rain-night.png rainthunder.png rainthunder-night.png sleet.png sleet-night.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png sleetthunder-night.png snow.png snow-night.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png snowthunder-night.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/simplistic/128'
make[3] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic/128 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/simplistic'
/usr/bin/install -c -m 644 theme.info '/usr/share/xfce4/weather/icons/simplistic'
make[2] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/simplistic »
Making install in 16x16
make[2] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/16x16 »
/usr/bin/mkdir -p '/usr/share/icons/hicolor/16x16/apps'
/usr/bin/install -c -m 644 org.xfce.panel.weather.png '/usr/share/icons/hicolor/16x16/apps'
make[2] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/16x16 »
Making install in 32x32
make[2] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/32x32 »
/usr/bin/mkdir -p '/usr/share/icons/hicolor/32x32/apps'
/usr/bin/install -c -m 644 org.xfce.panel.weather.png '/usr/share/icons/hicolor/32x32/apps'
make[2] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/32x32 »
Making install in 48x48
make[2] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/48x48 »
/usr/bin/mkdir -p '/usr/share/icons/hicolor/48x48/apps'
/usr/bin/install -c -m 644 org.xfce.panel.weather.png '/usr/share/icons/hicolor/48x48/apps'
make[2] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/48x48 »
Making install in 128x128
make[2] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/128x128 »
/usr/bin/mkdir -p '/usr/share/icons/hicolor/128x128/apps'
/usr/bin/install -c -m 644 org.xfce.panel.weather.png '/usr/share/icons/hicolor/128x128/apps'
make[2] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/128x128 »
Making install in scalable
make[2] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/scalable »
/usr/bin/mkdir -p '/usr/share/icons/hicolor/scalable/apps'
/usr/bin/install -c -m 644 org.xfce.panel.weather.svg '/usr/share/icons/hicolor/scalable/apps'
make[2] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons/scalable »
make install-data-hook
make[4] : on entre dans le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons »
Updating Gtk icon cache.
gtk-update-icon-cache: Cache file created successfully.
make[4] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons »
make[1] : on quitte le répertoire « /home/alain/xfce4-weather-plugin-0.11.3/icons »
make[2]: Rien à faire pour « install-exec-am ».
make[2]: Rien à faire pour « install-data-am ».
ludovic@ludovic-HP-Laptop-17-cn2xxx:~/Téléchargements/xfce4-weather-plugin-0.11.
checking for gtk+-3.0 >= 3.22.0... not found
*** The required package gtk+-3.0 was not found on your system.
*** Please install gtk+-3.0 (atleast version 3.22.0) or adjust
*** the PKG_CONFIG_PATH environment variable if you
*** installed the package in a nonstandard prefix so that
*** pkg-config is able to find it.Code : Tout sélectionner
3$ make
make: *** Pas de cible spécifiée et aucun makefile n'a été trouvé. Arrêt.
[sudo] Mot de passe de ludovic :
make: *** Aucune règle pour fabriquer la cible « install ». Arrêt.
3$ ^C
3$
ludovic@ludovic-HP-Laptop-17-cn2xxx:~$ sudo apt install pkg-config libgtk-3-dev
pkg-config est déjà la version la plus récente (1.8.1-2build1).
Les paquets supplémentaires suivants seront installés :
bzip2-doc gir1.2-freedesktop-dev gir1.2-glib-2.0-dev icu-devtools
libatk-bridge2.0-dev libatk1.0-dev libatspi2.0-dev libblkid-dev
libbrotli-dev libbz2-dev libcairo2-dev libdatrie-dev libdbus-1-dev
libdeflate-dev libegl-dev libegl1-mesa-dev libepoxy-dev libexpat1-dev
libffi-dev libfontconfig-dev libfreetype-dev libfribidi-dev
libgdk-pixbuf-2.0-dev libgirepository-2.0-0 libgl-dev libgles-dev libgles1
libglib2.0-dev libglib2.0-dev-bin libglvnd-core-dev libglvnd-dev libglx-dev
libgraphite2-dev libharfbuzz-cairo0 libharfbuzz-dev libice-dev libicu-dev
libjbig-dev libjpeg-dev libjpeg-turbo8-dev libjpeg8-dev liblerc-dev
liblzma-dev libmount-dev libopengl-dev libpango1.0-dev libpcre2-dev
libpcre2-posix3 libpixman-1-dev libpng-dev libpng-tools
libpthread-stubs0-dev libselinux1-dev libsepol-dev libsharpyuv-dev libsm-dev
libthai-dev libtiff-dev libtiffxx6 libwayland-bin libwayland-dev libwebp-dev
libwebpdecoder3 libx11-dev libxau-dev libxcb-render0-dev libxcb-shm0-dev
libxcb1-dev libxcomposite-dev libxcursor-dev libxdamage-dev libxdmcp-dev
libxext-dev libxfixes-dev libxft-dev libxi-dev libxinerama-dev
libxkbcommon-dev libxrandr-dev libxrender-dev libxtst-dev libzstd-dev
pango1.0-tools uuid-dev wayland-protocols x11proto-dev xorg-sgml-doctools
xtrans-dev zlib1g-dev
Paquets suggérés :
libcairo2-doc libdatrie-doc freetype2-doc libglib2.0-doc libgraphite2-utils
libgtk-3-doc libice-doc icu-doc liblzma-doc libpango1.0-doc libsm-doc
libthai-doc libwayland-doc libx11-doc libxcb-doc libxext-doc graphicsmagick
Les NOUVEAUX paquets suivants seront installés :
libgraphite2-dev libgtk-3-dev libharfbuzz-cairo0 libharfbuzz-dev libice-dev
libicu-dev libjbig-dev libjpeg-dev libjpeg-turbo8-dev libjpeg8-dev
liblerc-dev liblzma-dev libmount-dev libopengl-dev libpango1.0-dev
libpcre2-dev libpcre2-posix3 libpixman-1-dev libpng-dev libpng-tools
0 mis à jour, 90 nouvellement installés, 0 à enlever et 4 non mis à jour.
Il est nécessaire de prendre 26,6 Mo dans les archives.
Après cette opération, 133 Mo d'espace disque supplémentaires seront utilisés.
Souhaitez-vous continuer ? [O/n] O
Réception de :1 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 bzip2-doc all 1.0.8-5.1build0.1 [499 kB]
Réception de :2 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 gir1.2-glib-2.0-dev amd64 2.80.0-6ubuntu3.2 [848 kB]
Réception de :3 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 gir1.2-freedesktop-dev amd64 1.80.1-1 [28,8 kB]
Réception de :4 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 icu-devtools amd64 74.2-1ubuntu3.1 [212 kB]
Réception de :5 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libffi-dev amd64 3.4.6-1build1 [62,8 kB]
Réception de :6 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libglib2.0-dev-bin amd64 2.80.0-6ubuntu3.2 [138 kB]
Réception de :7 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 uuid-dev amd64 2.39.3-9ubuntu6.2 [33,5 kB]
Réception de :8 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libblkid-dev amd64 2.39.3-9ubuntu6.2 [204 kB]
Réception de :9 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libsepol-dev amd64 3.5-2build1 [384 kB]
Réception de :10 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libpcre2-posix3 amd64 10.42-4ubuntu2.1 [6 748 B]
Réception de :11 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libpcre2-dev amd64 10.42-4ubuntu2.1 [736 kB]
Réception de :12 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libselinux1-dev amd64 3.5-2ubuntu2.1 [164 kB]
Réception de :13 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libmount-dev amd64 2.39.3-9ubuntu6.2 [14,9 kB]
Réception de :14 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 zlib1g-dev amd64 1:1.3.dfsg-3.1ubuntu2.1 [894 kB]
Réception de :15 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libgirepository-2.0-0 amd64 2.80.0-6ubuntu3.2 [73,5 kB]
Réception de :16 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libglib2.0-dev amd64 2.80.0-6ubuntu3.2 [1 859 kB]
Réception de :17 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libatk1.0-dev amd64 2.52.0-1build1 [100 kB]
Réception de :18 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libdbus-1-dev amd64 1.14.10-4ubuntu4.1 [190 kB]
Réception de :19 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 xorg-sgml-doctools all 1:1.11-1.1 [10,9 kB]
Réception de :20 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 x11proto-dev all 2023.2-1 [602 kB]
Réception de :21 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxau-dev amd64 1:1.0.9-1build6 [9 570 B]
Réception de :22 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxdmcp-dev amd64 1:1.1.3-0ubuntu6 [26,5 kB]
Réception de :23 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 xtrans-dev all 1.4.0-1 [68,9 kB]
Réception de :24 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libpthread-stubs0-dev amd64 0.4-1build3 [4 746 B]
Réception de :25 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxcb1-dev amd64 1.15-1ubuntu2 [85,8 kB]
Réception de :26 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libx11-dev amd64 2:1.8.7-1build1 [732 kB]
Réception de :27 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxext-dev amd64 2:1.3.4-1build2 [83,5 kB]
Réception de :28 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxfixes-dev amd64 1:6.0.0-2build1 [12,1 kB]
Réception de :29 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxi-dev amd64 2:1.8.1-1build1 [194 kB]
Réception de :30 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxtst-dev amd64 2:1.2.3-1.1build1 [15,9 kB]
Réception de :31 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libatspi2.0-dev amd64 2.52.0-1build1 [76,2 kB]
Réception de :32 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libatk-bridge2.0-dev amd64 2.52.0-1build1 [4 284 B]
Réception de :33 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libbrotli-dev amd64 1.1.0-2build2 [353 kB]
Réception de :34 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libbz2-dev amd64 1.0.8-5.1build0.1 [33,6 kB]
Réception de :35 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libexpat1-dev amd64 2.6.1-2ubuntu0.3 [140 kB]
Réception de :36 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libpng-dev amd64 1.6.43-5build1 [264 kB]
Réception de :37 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libfreetype-dev amd64 2.13.2+dfsg-1build3 [575 kB]
Réception de :38 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libfontconfig-dev amd64 2.15.0-1.1ubuntu2 [161 kB]
Réception de :39 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libpixman-1-dev amd64 0.42.2-1build1 [296 kB]
Réception de :40 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libice-dev amd64 2:1.0.10-1build3 [51,0 kB]
Réception de :41 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libsm-dev amd64 2:1.2.3-1build3 [17,8 kB]
Réception de :42 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxcb-render0-dev amd64 1.15-1ubuntu2 [19,6 kB]
Réception de :43 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxcb-shm0-dev amd64 1.15-1ubuntu2 [8 246 B]
Réception de :44 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxrender-dev amd64 1:0.9.10-1.1build1 [26,3 kB]
Réception de :45 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libcairo2-dev amd64 1.18.0-3build1 [41,1 kB]
Réception de :46 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libdatrie-dev amd64 0.2.13-3build1 [19,4 kB]
Réception de :47 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libdeflate-dev amd64 1.19-1build1.1 [50,9 kB]
Réception de :48 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libglx-dev amd64 1.7.0-1build1 [14,2 kB]
Réception de :49 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libgl-dev amd64 1.7.0-1build1 [102 kB]
Réception de :50 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libegl-dev amd64 1.7.0-1build1 [18,2 kB]
Réception de :51 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libglvnd-core-dev amd64 1.7.0-1build1 [13,6 kB]
Réception de :52 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libgles1 amd64 1.7.0-1build1 [11,6 kB]
Réception de :53 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libgles-dev amd64 1.7.0-1build1 [50,5 kB]
Réception de :54 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libopengl-dev amd64 1.7.0-1build1 [3 454 B]
Réception de :55 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libglvnd-dev amd64 1.7.0-1build1 [3 198 B]
Réception de :56 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libegl1-mesa-dev amd64 24.2.8-1ubuntu1~24.04.1 [23,7 kB]
Réception de :57 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libepoxy-dev amd64 1.5.10-1build1 [132 kB]
Réception de :58 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libfribidi-dev amd64 1.0.13-3build1 [64,8 kB]
Réception de :59 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libjpeg-turbo8-dev amd64 2.1.5-2ubuntu2 [295 kB]
Réception de :60 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libjpeg8-dev amd64 8c-2ubuntu11 [1 484 B]
Réception de :61 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libjpeg-dev amd64 8c-2ubuntu11 [1 482 B]
Réception de :62 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libjbig-dev amd64 2.1-6.1ubuntu2 [27,9 kB]
Réception de :63 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 liblzma-dev amd64 5.6.1+really5.4.5-1ubuntu0.2 [176 kB]
Réception de :64 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libzstd-dev amd64 1.5.5+dfsg2-2build1.1 [364 kB]
Réception de :65 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libwebpdecoder3 amd64 1.3.2-0.4build3 [114 kB]
Réception de :66 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libsharpyuv-dev amd64 1.3.2-0.4build3 [16,0 kB]
Réception de :67 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libwebp-dev amd64 1.3.2-0.4build3 [367 kB]
Réception de :68 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libtiffxx6 amd64 4.5.1+git230720-4ubuntu2.2 [5 644 B]
Réception de :69 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 liblerc-dev amd64 4.0.0+ds-4ubuntu2 [182 kB]
Réception de :70 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libtiff-dev amd64 4.5.1+git230720-4ubuntu2.2 [338 kB]
Réception de :71 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libgdk-pixbuf-2.0-dev amd64 2.42.10+dfsg-3ubuntu3.1 [48,0 kB]
Réception de :72 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libgraphite2-dev amd64 1.3.14-2build1 [14,7 kB]
Réception de :73 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libharfbuzz-cairo0 amd64 8.3.0-2build2 [26,2 kB]
Réception de :74 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libicu-dev amd64 74.2-1ubuntu3.1 [11,9 MB]
Réception de :75 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libharfbuzz-dev amd64 8.3.0-2build2 [142 kB]
Réception de :76 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libthai-dev amd64 0.1.29-2build1 [26,6 kB]
Réception de :77 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxft-dev amd64 2.3.6-1build1 [64,3 kB]
Réception de :78 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 pango1.0-tools amd64 1.52.1+ds-1build1 [36,7 kB]
Réception de :79 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libpango1.0-dev amd64 1.52.1+ds-1build1 [147 kB]
Réception de :80 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libwayland-bin amd64 1.22.0-2.1build1 [20,6 kB]
Réception de :81 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libwayland-dev amd64 1.22.0-2.1build1 [71,3 kB]
Réception de :82 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxcomposite-dev amd64 1:0.4.5-1build3 [9 374 B]
Réception de :83 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxcursor-dev amd64 1:1.2.1-1build1 [31,8 kB]
Réception de :84 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxdamage-dev amd64 1:1.1.6-1build1 [5 270 B]
Réception de :85 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxinerama-dev amd64 2:1.1.4-3build1 [7 988 B]
Réception de :86 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxkbcommon-dev amd64 1.6.0-1build1 [56,3 kB]
Réception de :87 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libxrandr-dev amd64 2:1.5.2-2build1 [26,4 kB]
Réception de :88 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 wayland-protocols all 1.34-1 [85,2 kB]
Réception de :89 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libgtk-3-dev amd64 3.24.41-4ubuntu1.3 [1 096 kB]
Réception de :90 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libpng-tools amd64 1.6.43-5build1 [28,5 kB]
26,6 Mo réceptionnés en 5s (5 243 ko/s)
Extraction des modèles depuis les paquets : 100%
Sélection du paquet bzip2-doc précédemment désélectionné.
(Lecture de la base de données... 596947 fichiers et répertoires déjà installés.
Préparation du dépaquetage de .../00-bzip2-doc_1.0.8-5.1build0.1_all.deb ...
Dépaquetage de bzip2-doc (1.0.8-5.1build0.1) ...
Sélection du paquet gir1.2-glib-2.0-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../01-gir1.2-glib-2.0-dev_2.80.0-6ubuntu3.2_amd64
.deb ...
Dépaquetage de gir1.2-glib-2.0-dev:amd64 (2.80.0-6ubuntu3.2) ...
Sélection du paquet gir1.2-freedesktop-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../02-gir1.2-freedesktop-dev_1.80.1-1_amd64.deb .
Dépaquetage de gir1.2-freedesktop-dev:amd64 (1.80.1-1) ...
Sélection du paquet icu-devtools précédemment désélectionné.
Préparation du dépaquetage de .../03-icu-devtools_74.2-1ubuntu3.1_amd64.deb ...
Dépaquetage de icu-devtools (74.2-1ubuntu3.1) ...
Sélection du paquet libffi-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../04-libffi-dev_3.4.6-1build1_amd64.deb ...
Dépaquetage de libffi-dev:amd64 (3.4.6-1build1) ...
Sélection du paquet libglib2.0-dev-bin précédemment désélectionné.
Préparation du dépaquetage de .../05-libglib2.0-dev-bin_2.80.0-6ubuntu3.2_amd64.
deb ...
Dépaquetage de libglib2.0-dev-bin (2.80.0-6ubuntu3.2) ...
Sélection du paquet uuid-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../06-uuid-dev_2.39.3-9ubuntu6.2_amd64.deb ...
Dépaquetage de uuid-dev:amd64 (2.39.3-9ubuntu6.2) ...
Sélection du paquet libblkid-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../07-libblkid-dev_2.39.3-9ubuntu6.2_amd64.deb ..
Dépaquetage de libblkid-dev:amd64 (2.39.3-9ubuntu6.2) ...
Sélection du paquet libsepol-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../08-libsepol-dev_3.5-2build1_amd64.deb ...
Dépaquetage de libsepol-dev:amd64 (3.5-2build1) ...
Sélection du paquet libpcre2-posix3:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../09-libpcre2-posix3_10.42-4ubuntu2.1_amd64.deb
Dépaquetage de libpcre2-posix3:amd64 (10.42-4ubuntu2.1) ...
Sélection du paquet libpcre2-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../10-libpcre2-dev_10.42-4ubuntu2.1_amd64.deb ...
Dépaquetage de libpcre2-dev:amd64 (10.42-4ubuntu2.1) ...
Sélection du paquet libselinux1-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../11-libselinux1-dev_3.5-2ubuntu2.1_amd64.deb ..
Dépaquetage de libselinux1-dev:amd64 (3.5-2ubuntu2.1) ...
Sélection du paquet libmount-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../12-libmount-dev_2.39.3-9ubuntu6.2_amd64.deb ..
Dépaquetage de libmount-dev:amd64 (2.39.3-9ubuntu6.2) ...
Sélection du paquet zlib1g-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../13-zlib1g-dev_1%3a1.3.dfsg-3.1ubuntu2.1_amd64.
deb ...
Dépaquetage de zlib1g-dev:amd64 (1:1.3.dfsg-3.1ubuntu2.1) ...
Sélection du paquet libgirepository-2.0-0:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../14-libgirepository-2.0-0_2.80.0-6ubuntu3.2_amd
64.deb ...
Dépaquetage de libgirepository-2.0-0:amd64 (2.80.0-6ubuntu3.2) ...
Sélection du paquet libglib2.0-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../15-libglib2.0-dev_2.80.0-6ubuntu3.2_amd64.deb
Dépaquetage de libglib2.0-dev:amd64 (2.80.0-6ubuntu3.2) ...
Sélection du paquet libatk1.0-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../16-libatk1.0-dev_2.52.0-1build1_amd64.deb ...
Dépaquetage de libatk1.0-dev:amd64 (2.52.0-1build1) ...
Sélection du paquet libdbus-1-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../17-libdbus-1-dev_1.14.10-4ubuntu4.1_amd64.deb
Dépaquetage de libdbus-1-dev:amd64 (1.14.10-4ubuntu4.1) ...
Sélection du paquet xorg-sgml-doctools précédemment désélectionné.
Préparation du dépaquetage de .../18-xorg-sgml-doctools_1%3a1.11-1.1_all.deb ...
Dépaquetage de xorg-sgml-doctools (1:1.11-1.1) ...
Sélection du paquet x11proto-dev précédemment désélectionné.
Préparation du dépaquetage de .../19-x11proto-dev_2023.2-1_all.deb ...
Dépaquetage de x11proto-dev (2023.2-1) ...
Sélection du paquet libxau-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../20-libxau-dev_1%3a1.0.9-1build6_amd64.deb ...
Dépaquetage de libxau-dev:amd64 (1:1.0.9-1build6) ...
Sélection du paquet libxdmcp-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../21-libxdmcp-dev_1%3a1.1.3-0ubuntu6_amd64.deb .
Dépaquetage de libxdmcp-dev:amd64 (1:1.1.3-0ubuntu6) ...
Sélection du paquet xtrans-dev précédemment désélectionné.
Préparation du dépaquetage de .../22-xtrans-dev_1.4.0-1_all.deb ...
Dépaquetage de xtrans-dev (1.4.0-1) ...
Sélection du paquet libpthread-stubs0-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../23-libpthread-stubs0-dev_0.4-1build3_amd64.deb
Dépaquetage de libpthread-stubs0-dev:amd64 (0.4-1build3) ...
Sélection du paquet libxcb1-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../24-libxcb1-dev_1.15-1ubuntu2_amd64.deb ...
Dépaquetage de libxcb1-dev:amd64 (1.15-1ubuntu2) ...
Sélection du paquet libx11-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../25-libx11-dev_2%3a1.8.7-1build1_amd64.deb ...
Dépaquetage de libx11-dev:amd64 (2:1.8.7-1build1) ...
Sélection du paquet libxext-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../26-libxext-dev_2%3a1.3.4-1build2_amd64.deb ...
Dépaquetage de libxext-dev:amd64 (2:1.3.4-1build2) ...
Sélection du paquet libxfixes-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../27-libxfixes-dev_1%3a6.0.0-2build1_amd64.deb .
Dépaquetage de libxfixes-dev:amd64 (1:6.0.0-2build1) ...
Sélection du paquet libxi-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../28-libxi-dev_2%3a1.8.1-1build1_amd64.deb ...
Dépaquetage de libxi-dev:amd64 (2:1.8.1-1build1) ...
Sélection du paquet libxtst-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../29-libxtst-dev_2%3a1.2.3-1.1build1_amd64.deb .
Dépaquetage de libxtst-dev:amd64 (2:1.2.3-1.1build1) ...
Sélection du paquet libatspi2.0-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../30-libatspi2.0-dev_2.52.0-1build1_amd64.deb ..
Dépaquetage de libatspi2.0-dev:amd64 (2.52.0-1build1) ...
Sélection du paquet libatk-bridge2.0-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../31-libatk-bridge2.0-dev_2.52.0-1build1_amd64.d
eb ...
Dépaquetage de libatk-bridge2.0-dev:amd64 (2.52.0-1build1) ...
Sélection du paquet libbrotli-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../32-libbrotli-dev_1.1.0-2build2_amd64.deb ...
Dépaquetage de libbrotli-dev:amd64 (1.1.0-2build2) ...
Sélection du paquet libbz2-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../33-libbz2-dev_1.0.8-5.1build0.1_amd64.deb ...
Dépaquetage de libbz2-dev:amd64 (1.0.8-5.1build0.1) ...
Sélection du paquet libexpat1-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../34-libexpat1-dev_2.6.1-2ubuntu0.3_amd64.deb ..
Dépaquetage de libexpat1-dev:amd64 (2.6.1-2ubuntu0.3) ...
Sélection du paquet libpng-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../35-libpng-dev_1.6.43-5build1_amd64.deb ...
Dépaquetage de libpng-dev:amd64 (1.6.43-5build1) ...
Sélection du paquet libfreetype-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../36-libfreetype-dev_2.13.2+dfsg-1build3_amd64.d
eb ...
Dépaquetage de libfreetype-dev:amd64 (2.13.2+dfsg-1build3) ...
Sélection du paquet libfontconfig-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../37-libfontconfig-dev_2.15.0-1.1ubuntu2_amd64.d
eb ...
Dépaquetage de libfontconfig-dev:amd64 (2.15.0-1.1ubuntu2) ...
Sélection du paquet libpixman-1-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../38-libpixman-1-dev_0.42.2-1build1_amd64.deb ..
Dépaquetage de libpixman-1-dev:amd64 (0.42.2-1build1) ...
Sélection du paquet libice-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../39-libice-dev_2%3a1.0.10-1build3_amd64.deb ...
Dépaquetage de libice-dev:amd64 (2:1.0.10-1build3) ...
Sélection du paquet libsm-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../40-libsm-dev_2%3a1.2.3-1build3_amd64.deb ...
Dépaquetage de libsm-dev:amd64 (2:1.2.3-1build3) ...
Sélection du paquet libxcb-render0-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../41-libxcb-render0-dev_1.15-1ubuntu2_amd64.deb
Dépaquetage de libxcb-render0-dev:amd64 (1.15-1ubuntu2) ...
Sélection du paquet libxcb-shm0-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../42-libxcb-shm0-dev_1.15-1ubuntu2_amd64.deb ...
Dépaquetage de libxcb-shm0-dev:amd64 (1.15-1ubuntu2) ...
Sélection du paquet libxrender-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../43-libxrender-dev_1%3a0.9.10-1.1build1_amd64.d
eb ...
Dépaquetage de libxrender-dev:amd64 (1:0.9.10-1.1build1) ...
Sélection du paquet libcairo2-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../44-libcairo2-dev_1.18.0-3build1_amd64.deb ...
Dépaquetage de libcairo2-dev:amd64 (1.18.0-3build1) ...
Sélection du paquet libdatrie-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../45-libdatrie-dev_0.2.13-3build1_amd64.deb ...
Dépaquetage de libdatrie-dev:amd64 (0.2.13-3build1) ...
Sélection du paquet libdeflate-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../46-libdeflate-dev_1.19-1build1.1_amd64.deb ...
Dépaquetage de libdeflate-dev:amd64 (1.19-1build1.1) ...
Sélection du paquet libglx-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../47-libglx-dev_1.7.0-1build1_amd64.deb ...
Dépaquetage de libglx-dev:amd64 (1.7.0-1build1) ...
Sélection du paquet libgl-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../48-libgl-dev_1.7.0-1build1_amd64.deb ...
Dépaquetage de libgl-dev:amd64 (1.7.0-1build1) ...
Sélection du paquet libegl-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../49-libegl-dev_1.7.0-1build1_amd64.deb ...
Dépaquetage de libegl-dev:amd64 (1.7.0-1build1) ...
Sélection du paquet libglvnd-core-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../50-libglvnd-core-dev_1.7.0-1build1_amd64.deb .
Dépaquetage de libglvnd-core-dev:amd64 (1.7.0-1build1) ...
Sélection du paquet libgles1:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../51-libgles1_1.7.0-1build1_amd64.deb ...
Dépaquetage de libgles1:amd64 (1.7.0-1build1) ...
Sélection du paquet libgles-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../52-libgles-dev_1.7.0-1build1_amd64.deb ...
Dépaquetage de libgles-dev:amd64 (1.7.0-1build1) ...
Sélection du paquet libopengl-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../53-libopengl-dev_1.7.0-1build1_amd64.deb ...
Dépaquetage de libopengl-dev:amd64 (1.7.0-1build1) ...
Sélection du paquet libglvnd-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../54-libglvnd-dev_1.7.0-1build1_amd64.deb ...
Dépaquetage de libglvnd-dev:amd64 (1.7.0-1build1) ...
Sélection du paquet libegl1-mesa-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../55-libegl1-mesa-dev_24.2.8-1ubuntu1~24.04.1_am
d64.deb ...
Dépaquetage de libegl1-mesa-dev:amd64 (24.2.8-1ubuntu1~24.04.1) ...
Sélection du paquet libepoxy-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../56-libepoxy-dev_1.5.10-1build1_amd64.deb ...
Dépaquetage de libepoxy-dev:amd64 (1.5.10-1build1) ...
Sélection du paquet libfribidi-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../57-libfribidi-dev_1.0.13-3build1_amd64.deb ...
Dépaquetage de libfribidi-dev:amd64 (1.0.13-3build1) ...
Sélection du paquet libjpeg-turbo8-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../58-libjpeg-turbo8-dev_2.1.5-2ubuntu2_amd64.deb
Dépaquetage de libjpeg-turbo8-dev:amd64 (2.1.5-2ubuntu2) ...
Sélection du paquet libjpeg8-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../59-libjpeg8-dev_8c-2ubuntu11_amd64.deb ...
Dépaquetage de libjpeg8-dev:amd64 (8c-2ubuntu11) ...
Sélection du paquet libjpeg-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../60-libjpeg-dev_8c-2ubuntu11_amd64.deb ...
Dépaquetage de libjpeg-dev:amd64 (8c-2ubuntu11) ...
Sélection du paquet libjbig-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../61-libjbig-dev_2.1-6.1ubuntu2_amd64.deb ...
Dépaquetage de libjbig-dev:amd64 (2.1-6.1ubuntu2) ...
Sélection du paquet liblzma-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../62-liblzma-dev_5.6.1+really5.4.5-1ubuntu0.2_am
d64.deb ...
Dépaquetage de liblzma-dev:amd64 (5.6.1+really5.4.5-1ubuntu0.2) ...
Sélection du paquet libzstd-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../63-libzstd-dev_1.5.5+dfsg2-2build1.1_amd64.deb
Dépaquetage de libzstd-dev:amd64 (1.5.5+dfsg2-2build1.1) ...
Sélection du paquet libwebpdecoder3:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../64-libwebpdecoder3_1.3.2-0.4build3_amd64.deb .
Dépaquetage de libwebpdecoder3:amd64 (1.3.2-0.4build3) ...
Sélection du paquet libsharpyuv-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../65-libsharpyuv-dev_1.3.2-0.4build3_amd64.deb .
Dépaquetage de libsharpyuv-dev:amd64 (1.3.2-0.4build3) ...
Sélection du paquet libwebp-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../66-libwebp-dev_1.3.2-0.4build3_amd64.deb ...
Dépaquetage de libwebp-dev:amd64 (1.3.2-0.4build3) ...
Sélection du paquet libtiffxx6:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../67-libtiffxx6_4.5.1+git230720-4ubuntu2.2_amd64
.deb ...
Dépaquetage de libtiffxx6:amd64 (4.5.1+git230720-4ubuntu2.2) ...
Sélection du paquet liblerc-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../68-liblerc-dev_4.0.0+ds-4ubuntu2_amd64.deb ...
Dépaquetage de liblerc-dev:amd64 (4.0.0+ds-4ubuntu2) ...
Sélection du paquet libtiff-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../69-libtiff-dev_4.5.1+git230720-4ubuntu2.2_amd6
4.deb ...
Dépaquetage de libtiff-dev:amd64 (4.5.1+git230720-4ubuntu2.2) ...
Sélection du paquet libgdk-pixbuf-2.0-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../70-libgdk-pixbuf-2.0-dev_2.42.10+dfsg-3ubuntu3
.1_amd64.deb ...
Dépaquetage de libgdk-pixbuf-2.0-dev:amd64 (2.42.10+dfsg-3ubuntu3.1) ...
Sélection du paquet libgraphite2-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../71-libgraphite2-dev_1.3.14-2build1_amd64.deb .
Dépaquetage de libgraphite2-dev:amd64 (1.3.14-2build1) ...
Sélection du paquet libharfbuzz-cairo0:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../72-libharfbuzz-cairo0_8.3.0-2build2_amd64.deb
Dépaquetage de libharfbuzz-cairo0:amd64 (8.3.0-2build2) ...
Sélection du paquet libicu-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../73-libicu-dev_74.2-1ubuntu3.1_amd64.deb ...
Dépaquetage de libicu-dev:amd64 (74.2-1ubuntu3.1) ...
Sélection du paquet libharfbuzz-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../74-libharfbuzz-dev_8.3.0-2build2_amd64.deb ...
Dépaquetage de libharfbuzz-dev:amd64 (8.3.0-2build2) ...
Sélection du paquet libthai-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../75-libthai-dev_0.1.29-2build1_amd64.deb ...
Dépaquetage de libthai-dev:amd64 (0.1.29-2build1) ...
Sélection du paquet libxft-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../76-libxft-dev_2.3.6-1build1_amd64.deb ...
Dépaquetage de libxft-dev:amd64 (2.3.6-1build1) ...
Sélection du paquet pango1.0-tools précédemment désélectionné.
Préparation du dépaquetage de .../77-pango1.0-tools_1.52.1+ds-1build1_amd64.deb
Dépaquetage de pango1.0-tools (1.52.1+ds-1build1) ...
Sélection du paquet libpango1.0-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../78-libpango1.0-dev_1.52.1+ds-1build1_amd64.deb
Dépaquetage de libpango1.0-dev:amd64 (1.52.1+ds-1build1) ...
Sélection du paquet libwayland-bin précédemment désélectionné.
Préparation du dépaquetage de .../79-libwayland-bin_1.22.0-2.1build1_amd64.deb .
Dépaquetage de libwayland-bin (1.22.0-2.1build1) ...
Sélection du paquet libwayland-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../80-libwayland-dev_1.22.0-2.1build1_amd64.deb .
Dépaquetage de libwayland-dev:amd64 (1.22.0-2.1build1) ...
Sélection du paquet libxcomposite-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../81-libxcomposite-dev_1%3a0.4.5-1build3_amd64.d
eb ...
Dépaquetage de libxcomposite-dev:amd64 (1:0.4.5-1build3) ...
Sélection du paquet libxcursor-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../82-libxcursor-dev_1%3a1.2.1-1build1_amd64.deb
Dépaquetage de libxcursor-dev:amd64 (1:1.2.1-1build1) ...
Sélection du paquet libxdamage-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../83-libxdamage-dev_1%3a1.1.6-1build1_amd64.deb
Dépaquetage de libxdamage-dev:amd64 (1:1.1.6-1build1) ...
Sélection du paquet libxinerama-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../84-libxinerama-dev_2%3a1.1.4-3build1_amd64.deb
Dépaquetage de libxinerama-dev:amd64 (2:1.1.4-3build1) ...
Sélection du paquet libxkbcommon-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../85-libxkbcommon-dev_1.6.0-1build1_amd64.deb ..
Dépaquetage de libxkbcommon-dev:amd64 (1.6.0-1build1) ...
Sélection du paquet libxrandr-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../86-libxrandr-dev_2%3a1.5.2-2build1_amd64.deb .
Dépaquetage de libxrandr-dev:amd64 (2:1.5.2-2build1) ...
Sélection du paquet wayland-protocols précédemment désélectionné.
Préparation du dépaquetage de .../87-wayland-protocols_1.34-1_all.deb ...
Dépaquetage de wayland-protocols (1.34-1) ...
Sélection du paquet libgtk-3-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../88-libgtk-3-dev_3.24.41-4ubuntu1.3_amd64.deb .
Dépaquetage de libgtk-3-dev:amd64 (3.24.41-4ubuntu1.3) ...
Sélection du paquet libpng-tools précédemment désélectionné.
Préparation du dépaquetage de .../89-libpng-tools_1.6.43-5build1_amd64.deb ...
Dépaquetage de libpng-tools (1.6.43-5build1) ...
Paramétrage de libglib2.0-dev-bin (2.80.0-6ubuntu3.2) ...
Paramétrage de bzip2-doc (1.0.8-5.1build0.1) ...
Paramétrage de libjpeg-turbo8-dev:amd64 (2.1.5-2ubuntu2) ...
Paramétrage de libpixman-1-dev:amd64 (0.42.2-1build1) ...
Paramétrage de libzstd-dev:amd64 (1.5.5+dfsg2-2build1.1) ...
Paramétrage de libglvnd-core-dev:amd64 (1.7.0-1build1) ...
Paramétrage de libpng-tools (1.6.43-5build1) ...
Paramétrage de libgirepository-2.0-0:amd64 (2.80.0-6ubuntu3.2) ...
Paramétrage de libfribidi-dev:amd64 (1.0.13-3build1) ...
Paramétrage de libxkbcommon-dev:amd64 (1.6.0-1build1) ...
Paramétrage de pango1.0-tools (1.52.1+ds-1build1) ...
Paramétrage de libjbig-dev:amd64 (2.1-6.1ubuntu2) ...
Paramétrage de libwebpdecoder3:amd64 (1.3.2-0.4build3) ...
Paramétrage de libffi-dev:amd64 (3.4.6-1build1) ...
Paramétrage de libpthread-stubs0-dev:amd64 (0.4-1build3) ...
Paramétrage de xtrans-dev (1.4.0-1) ...
Paramétrage de libwayland-bin (1.22.0-2.1build1) ...
Paramétrage de libgraphite2-dev:amd64 (1.3.14-2build1) ...
Paramétrage de libexpat1-dev:amd64 (2.6.1-2ubuntu0.3) ...
Paramétrage de libharfbuzz-cairo0:amd64 (8.3.0-2build2) ...
Paramétrage de libdbus-1-dev:amd64 (1.14.10-4ubuntu4.1) ...
Paramétrage de uuid-dev:amd64 (2.39.3-9ubuntu6.2) ...
Paramétrage de libgles1:amd64 (1.7.0-1build1) ...
Paramétrage de icu-devtools (74.2-1ubuntu3.1) ...
Paramétrage de libsepol-dev:amd64 (3.5-2build1) ...
Paramétrage de liblerc-dev:amd64 (4.0.0+ds-4ubuntu2) ...
Paramétrage de liblzma-dev:amd64 (5.6.1+really5.4.5-1ubuntu0.2) ...
Paramétrage de zlib1g-dev:amd64 (1:1.3.dfsg-3.1ubuntu2.1) ...
Paramétrage de libpcre2-posix3:amd64 (10.42-4ubuntu2.1) ...
Paramétrage de wayland-protocols (1.34-1) ...
Paramétrage de libdatrie-dev:amd64 (0.2.13-3build1) ...
Paramétrage de gir1.2-glib-2.0-dev:amd64 (2.80.0-6ubuntu3.2) ...
Paramétrage de xorg-sgml-doctools (1:1.11-1.1) ...
Paramétrage de libopengl-dev:amd64 (1.7.0-1build1) ...
Paramétrage de libjpeg8-dev:amd64 (8c-2ubuntu11) ...
Paramétrage de libsharpyuv-dev:amd64 (1.3.2-0.4build3) ...
Paramétrage de libtiffxx6:amd64 (4.5.1+git230720-4ubuntu2.2) ...
Paramétrage de libdeflate-dev:amd64 (1.19-1build1.1) ...
Paramétrage de libicu-dev:amd64 (74.2-1ubuntu3.1) ...
Paramétrage de libbrotli-dev:amd64 (1.1.0-2build2) ...
Paramétrage de libbz2-dev:amd64 (1.0.8-5.1build0.1) ...
Paramétrage de libblkid-dev:amd64 (2.39.3-9ubuntu6.2) ...
Paramétrage de libpcre2-dev:amd64 (10.42-4ubuntu2.1) ...
Paramétrage de libselinux1-dev:amd64 (3.5-2ubuntu2.1) ...
Paramétrage de libpng-dev:amd64 (1.6.43-5build1) ...
Paramétrage de libjpeg-dev:amd64 (8c-2ubuntu11) ...
Paramétrage de libwayland-dev:amd64 (1.22.0-2.1build1) ...
Paramétrage de libfreetype-dev:amd64 (2.13.2+dfsg-1build3) ...
Paramétrage de libwebp-dev:amd64 (1.3.2-0.4build3) ...
Paramétrage de libtiff-dev:amd64 (4.5.1+git230720-4ubuntu2.2) ...
Paramétrage de gir1.2-freedesktop-dev:amd64 (1.80.1-1) ...
Paramétrage de libthai-dev:amd64 (0.1.29-2build1) ...
Paramétrage de libmount-dev:amd64 (2.39.3-9ubuntu6.2) ...
Paramétrage de libfontconfig-dev:amd64 (2.15.0-1.1ubuntu2) ...
Paramétrage de libglib2.0-dev:amd64 (2.80.0-6ubuntu3.2) ...
Traitement des actions différées (« triggers ») pour libc-bin (2.39-0ubuntu8.4)
Traitement des actions différées (« triggers ») pour man-db (2.12.0-4build2) ...
Traitement des actions différées (« triggers ») pour libglib2.0-0t64:amd64 (2.80
.0-6ubuntu3.2) ...
Traitement des actions différées (« triggers ») pour libglib2.0-0t64:i386 (2.80.
0-6ubuntu3.2) ...
Traitement des actions différées (« triggers ») pour sgml-base (1.31) ...
Traitement des actions différées (« triggers ») pour install-info (7.1-3build2)
Paramétrage de libatk1.0-dev:amd64 (2.52.0-1build1) ...
Paramétrage de x11proto-dev (2023.2-1) ...
Paramétrage de libgdk-pixbuf-2.0-dev:amd64 (2.42.10+dfsg-3ubuntu3.1) ...
Paramétrage de libharfbuzz-dev:amd64 (8.3.0-2build2) ...
Paramétrage de libxau-dev:amd64 (1:1.0.9-1build6) ...
Paramétrage de libice-dev:amd64 (2:1.0.10-1build3) ...
Paramétrage de libsm-dev:amd64 (2:1.2.3-1build3) ...
Paramétrage de libxdmcp-dev:amd64 (1:1.1.3-0ubuntu6) ...
Paramétrage de libxcb1-dev:amd64 (1.15-1ubuntu2) ...
Paramétrage de libx11-dev:amd64 (2:1.8.7-1build1) ...
Paramétrage de libxfixes-dev:amd64 (1:6.0.0-2build1) ...
Paramétrage de libxcb-shm0-dev:amd64 (1.15-1ubuntu2) ...
Paramétrage de libxcb-render0-dev:amd64 (1.15-1ubuntu2) ...
Paramétrage de libxext-dev:amd64 (2:1.3.4-1build2) ...
Paramétrage de libglx-dev:amd64 (1.7.0-1build1) ...
Paramétrage de libxi-dev:amd64 (2:1.8.1-1build1) ...
Paramétrage de libxrender-dev:amd64 (1:0.9.10-1.1build1) ...
Paramétrage de libgl-dev:amd64 (1.7.0-1build1) ...
Paramétrage de libxft-dev:amd64 (2.3.6-1build1) ...
Paramétrage de libxtst-dev:amd64 (2:1.2.3-1.1build1) ...
Paramétrage de libxdamage-dev:amd64 (1:1.1.6-1build1) ...
Paramétrage de libatspi2.0-dev:amd64 (2.52.0-1build1) ...
Paramétrage de libegl-dev:amd64 (1.7.0-1build1) ...
Paramétrage de libxcomposite-dev:amd64 (1:0.4.5-1build3) ...
Paramétrage de libxcursor-dev:amd64 (1:1.2.1-1build1) ...
Paramétrage de libepoxy-dev:amd64 (1.5.10-1build1) ...
Paramétrage de libatk-bridge2.0-dev:amd64 (2.52.0-1build1) ...
Paramétrage de libxrandr-dev:amd64 (2:1.5.2-2build1) ...
Paramétrage de libxinerama-dev:amd64 (2:1.1.4-3build1) ...
Paramétrage de libcairo2-dev:amd64 (1.18.0-3build1) ...
Paramétrage de libgles-dev:amd64 (1.7.0-1build1) ...
Paramétrage de libglvnd-dev:amd64 (1.7.0-1build1) ...
Paramétrage de libpango1.0-dev:amd64 (1.52.1+ds-1build1) ...
Paramétrage de libegl1-mesa-dev:amd64 (24.2.8-1ubuntu1~24.04.1) ...
Paramétrage de libgtk-3-dev:amd64 (3.24.41-4ubuntu1.3) ...
ludovic@ludovic-HP-Laptop-17-cn2xxx:~$ sudo apt install libxfce4util-dev libxfce4ui-2-dev libxfce4panel-2.0-dev libxml2-dev libsoup2.4-dev libjson-c-dev
gir1.2-libxfce4panel-2.0 gir1.2-libxfce4ui-2.0 gir1.2-libxfce4util-1.0
libpsl-dev libsqlite3-dev libxfconf-0-dev
Paquets suggérés :
libsoup2.4-doc sqlite3-doc devhelp
libjson-c-dev libpsl-dev libsoup2.4-dev libsqlite3-dev libxfce4panel-2.0-dev
libxfce4ui-2-dev libxfce4util-dev libxfconf-0-dev libxml2-dev
0 mis à jour, 12 nouvellement installés, 0 à enlever et 4 non mis à jour.
Il est nécessaire de prendre 2 163 ko dans les archives.
Après cette opération, 11,3 Mo d'espace disque supplémentaires seront utilisés.
Réception de :1 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/universe amd64 gir1.2-libxfce4util-1.0 amd64 4.18.1-2build3 [5 190 B]
Réception de :2 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/universe amd64 gir1.2-libxfce4panel-2.0 amd64 4.18.4-1ubuntu0.1 [7 738 B]
Réception de :3 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/universe amd64 gir1.2-libxfce4ui-2.0 amd64 4.18.4-1build4 [6 878 B]
Réception de :4 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libpsl-dev amd64 0.21.2-1.1build1 [76,4 kB]
Réception de :5 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libsqlite3-dev amd64 3.45.1-1ubuntu2.1 [912 kB]
Réception de :6 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libxml2-dev amd64 2.9.14+dfsg-1.3ubuntu3.3 [780 kB]
Réception de :7 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/main amd64 libsoup2.4-dev amd64 2.74.3-6ubuntu1.4 [155 kB]
Réception de :8 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/universe amd64 libxfce4util-dev amd64 4.18.1-2build3 [43,4 kB]
Réception de :9 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble-updates/universe amd64 libxfce4panel-2.0-dev amd64 4.18.4-1ubuntu0.1 [51,6 kB]
Réception de :10 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/universe amd64 libxfconf-0-dev amd64 4.18.1-1build3 [32,6 kB]
Réception de :11 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/universe amd64 libxfce4ui-2-dev amd64 4.18.4-1build4 [28,4 kB]
Réception de :12 http://ftp.hosteurope.de/mirror/archive.ubuntu.com noble/main amd64 libjson-c-dev amd64 0.17-1build1 [63,6 kB]
2 163 ko réceptionnés en 2s (956 ko/s)
Sélection du paquet gir1.2-libxfce4util-1.0:amd64 précédemment désélectionné.
(Lecture de la base de données... 600403 fichiers et répertoires déjà installés.
Préparation du dépaquetage de .../00-gir1.2-libxfce4util-1.0_4.18.1-2build3_amd6
4.deb ...
Dépaquetage de gir1.2-libxfce4util-1.0:amd64 (4.18.1-2build3) ...
Sélection du paquet gir1.2-libxfce4panel-2.0 précédemment désélectionné.
Préparation du dépaquetage de .../01-gir1.2-libxfce4panel-2.0_4.18.4-1ubuntu0.1_
amd64.deb ...
Dépaquetage de gir1.2-libxfce4panel-2.0 (4.18.4-1ubuntu0.1) ...
Sélection du paquet gir1.2-libxfce4ui-2.0:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../02-gir1.2-libxfce4ui-2.0_4.18.4-1build4_amd64.
deb ...
Dépaquetage de gir1.2-libxfce4ui-2.0:amd64 (4.18.4-1build4) ...
Sélection du paquet libpsl-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../03-libpsl-dev_0.21.2-1.1build1_amd64.deb ...
Dépaquetage de libpsl-dev:amd64 (0.21.2-1.1build1) ...
Sélection du paquet libsqlite3-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../04-libsqlite3-dev_3.45.1-1ubuntu2.1_amd64.deb
Dépaquetage de libsqlite3-dev:amd64 (3.45.1-1ubuntu2.1) ...
Sélection du paquet libxml2-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../05-libxml2-dev_2.9.14+dfsg-1.3ubuntu3.3_amd64.
deb ...
Dépaquetage de libxml2-dev:amd64 (2.9.14+dfsg-1.3ubuntu3.3) ...
Sélection du paquet libsoup2.4-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../06-libsoup2.4-dev_2.74.3-6ubuntu1.4_amd64.deb
Dépaquetage de libsoup2.4-dev:amd64 (2.74.3-6ubuntu1.4) ...
Sélection du paquet libxfce4util-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../07-libxfce4util-dev_4.18.1-2build3_amd64.deb .
Dépaquetage de libxfce4util-dev:amd64 (4.18.1-2build3) ...
Sélection du paquet libxfce4panel-2.0-dev précédemment désélectionné.
Préparation du dépaquetage de .../08-libxfce4panel-2.0-dev_4.18.4-1ubuntu0.1_amd
64.deb ...
Dépaquetage de libxfce4panel-2.0-dev (4.18.4-1ubuntu0.1) ...
Sélection du paquet libxfconf-0-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../09-libxfconf-0-dev_4.18.1-1build3_amd64.deb ..
Dépaquetage de libxfconf-0-dev:amd64 (4.18.1-1build3) ...
Sélection du paquet libxfce4ui-2-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../10-libxfce4ui-2-dev_4.18.4-1build4_amd64.deb .
Dépaquetage de libxfce4ui-2-dev:amd64 (4.18.4-1build4) ...
Sélection du paquet libjson-c-dev:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../11-libjson-c-dev_0.17-1build1_amd64.deb ...
Dépaquetage de libjson-c-dev:amd64 (0.17-1build1) ...
Paramétrage de libjson-c-dev:amd64 (0.17-1build1) ...
Paramétrage de libpsl-dev:amd64 (0.21.2-1.1build1) ...
Paramétrage de libxml2-dev:amd64 (2.9.14+dfsg-1.3ubuntu3.3) ...
Paramétrage de libsqlite3-dev:amd64 (3.45.1-1ubuntu2.1) ...
Paramétrage de libxfconf-0-dev:amd64 (4.18.1-1build3) ...
Paramétrage de gir1.2-libxfce4util-1.0:amd64 (4.18.1-2build3) ...
Paramétrage de gir1.2-libxfce4ui-2.0:amd64 (4.18.4-1build4) ...
Paramétrage de libxfce4util-dev:amd64 (4.18.1-2build3) ...
Paramétrage de libsoup2.4-dev:amd64 (2.74.3-6ubuntu1.4) ...
Paramétrage de gir1.2-libxfce4panel-2.0 (4.18.4-1ubuntu0.1) ...
Paramétrage de libxfce4ui-2-dev:amd64 (4.18.4-1build4) ...
Paramétrage de libxfce4panel-2.0-dev (4.18.4-1ubuntu0.1) ...
ludovic@ludovic-HP-Laptop-17-cn2xxx:~$ sudo apt remove xfce4-weather-plugin
Les paquets suivants seront ENLEVÉS :
0 mis à jour, 0 nouvellement installés, 1 à enlever et 4 non mis à jour.
Après cette opération, 5 043 ko d'espace disque seront libérés.
(Lecture de la base de données... 600782 fichiers et répertoires déjà installés.
Suppression de xfce4-weather-plugin:amd64 (0.11.2-1build2) ...
Traitement des actions différées (« triggers ») pour hicolor-icon-theme (0.17-2)
3$ ./configure --prefix=/usr
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a race-free mkdir -p... /usr/bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether UID '1000' is supported by ustar format... yes
checking whether GID '1000' is supported by ustar format... yes
checking how to create a ustar tar archive... gnutar
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether make supports nested variables... (cached) yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether the compiler supports GNU C... yes
checking whether gcc accepts -g... yes
checking for gcc option to enable C11 features... none needed
checking whether gcc understands -c and -o together... yes
checking whether make supports the include directive... yes (GNU style)
checking dependency style of gcc... gcc3
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking for a sed that does not truncate output... /usr/bin/sed
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for fgrep... /usr/bin/grep -F
checking how to print strings... printf
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for file... file
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /usr/bin/dd
checking how to truncate binary pipes... /usr/bin/dd bs=4096 count=1
checking for mt... mt
checking if mt is a manifest tool... no
checking for stdio.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for strings.h... yes
checking for sys/stat.h... yes
checking for sys/types.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for math.h... yes
checking for stdarg.h... yes
checking for stddef.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for sys/stat.h... (cached) yes
checking for time.h... yes
checking for cos in -lm... yes
checking whether NLS is requested... yes
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking for ld used by gcc... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking for shared library run path origin... done
checking how to run the C preprocessor... gcc -E
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for gtk+-3.0 >= 3.22.0... 3.24.41
checking GTK_CFLAGS... -I/usr/include/gtk-3.0 -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/harfbuzz -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/fribidi -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/webp -I/usr/include/gio-unix-2.0 -I/usr/include/atk-1.0 -I/usr/include/at-spi2-atk/2.0 -I/usr/include/at-spi-2.0 -I/usr/include/dbus-1.0 -I/usr/lib/x86_64-linux-gnu/dbus-1.0/include -pthread
checking GTK_LIBS... -lgtk-3 -lgdk-3 -lz -lpangocairo-1.0 -lpango-1.0 -lharfbuzz -latk-1.0 -lcairo-gobject -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lgobject-2.0 -lglib-2.0
checking for pkg-config... (cached) /usr/bin/pkg-config
checking for gthread-2.0 >= 2.64.0... 2.80.0
checking GTHREAD_CFLAGS... -pthread -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include
checking GTHREAD_LIBS... -lgthread-2.0 -pthread -lglib-2.0
checking for glib-2.0 >= 2.64.0... 2.80.0
checking GLIB_CFLAGS... -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include
checking GLIB_LIBS... -lglib-2.0
configure: setting GLIB_VERSION_MAX_ALLOWED and GLIB_VERSION_MIN_REQUIRED according to 2.64.0
checking for libxfce4util-1.0 >= 4.12.0... 4.18.1
checking LIBXFCE4UTIL_CFLAGS... -I/usr/include/xfce4 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include
checking LIBXFCE4UTIL_LIBS... -lxfce4util -lglib-2.0
checking for libxfce4ui-2 >= 4.12.0... 4.18.4
checking LIBXFCE4UI_CFLAGS... -I/usr/include/xfce4/libxfce4ui-2 -I/usr/include/gtk-3.0 -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/harfbuzz -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/fribidi -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/webp -I/usr/include/gio-unix-2.0 -I/usr/include/atk-1.0 -I/usr/include/at-spi2-atk/2.0 -I/usr/include/at-spi-2.0 -I/usr/include/dbus-1.0 -I/usr/lib/x86_64-linux-gnu/dbus-1.0/include -pthread -I/usr/include/xfce4
checking LIBXFCE4UI_LIBS... -lxfce4ui-2 -lgtk-3 -lgdk-3 -lz -lpangocairo-1.0 -lpango-1.0 -lharfbuzz -latk-1.0 -lcairo-gobject -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lgobject-2.0 -lxfce4util -lglib-2.0
checking for libxfce4panel-2.0 >= 4.14.0... 4.18.4
checking LIBXFCE4PANEL_CFLAGS... -I/usr/include/xfce4/libxfce4panel-2.0 -I/usr/include/gtk-3.0 -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/harfbuzz -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/fribidi -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/x86_64-linux-gnu -I/usr/include/webp -I/usr/include/gio-unix-2.0 -I/usr/include/atk-1.0 -I/usr/include/at-spi2-atk/2.0 -I/usr/include/at-spi-2.0 -I/usr/include/dbus-1.0 -I/usr/lib/x86_64-linux-gnu/dbus-1.0/include -pthread -I/usr/include/xfce4
checking LIBXFCE4PANEL_LIBS... -lxfce4panel-2.0 -lgtk-3 -lgdk-3 -lz -lpangocairo-1.0 -lpango-1.0 -lharfbuzz -latk-1.0 -lcairo-gobject -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lgobject-2.0 -Wl,--export-dynamic -lgmodule-2.0 -pthread -lglib-2.0 -lxfce4util -lglib-2.0
checking for libxfconf-0 >= 4.12.0... 4.18.1
checking XFCONF_CFLAGS... -I/usr/include/xfce4/xfconf-0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -pthread -I/usr/include/libmount -I/usr/include/blkid
checking XFCONF_LIBS... -lxfconf-0 -lgio-2.0 -lgobject-2.0 -lglib-2.0
checking for libxml-2.0 >= 2.4.0... 2.9.14
checking LIBXML_CFLAGS... -I/usr/include/libxml2
checking LIBXML_LIBS... -lxml2
checking for libsoup-2.4 >= 2.42.0... 2.74.3
checking SOUP_CFLAGS... -I/usr/include/libsoup-2.4 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -pthread -I/usr/include/libmount -I/usr/include/blkid -I/usr/include/libxml2
checking SOUP_LIBS... -lsoup-2.4 -Wl,--export-dynamic -lgmodule-2.0 -pthread -lglib-2.0 -lgio-2.0 -lgobject-2.0 -lglib-2.0
checking for json-c >= 0.13.1... 0.17
checking JSON_CFLAGS... -I/usr/include/json-c
checking JSON_LIBS... -ljson-c
checking for optional package upower-glib >= 0.9.0... not found
checking whether to build with debugging support... minimum
checking if gcc supports -Wall... yes
checking if gcc supports -Wextra... yes
checking if gcc supports -Wno-missing-field-initializers... yes
checking if gcc supports -Wno-unused-parameter... yes
checking if gcc supports -Wmissing-declarations... yes
checking if gcc supports -Wmissing-noreturn... yes
checking if gcc supports -Wpointer-arith... yes
checking if gcc supports -Wcast-align... yes
checking if gcc supports -Wformat... yes
checking if gcc supports -Wformat-security... yes
checking if gcc supports -Wformat-y2k... yes
checking if gcc supports -Winit-self... yes
checking if gcc supports -Wmissing-include-dirs... yes
checking if gcc supports -Wundef... yes
checking if gcc supports -Wredundant-decls... yes
checking if gcc supports -Wshadow... yes
checking if gcc supports -Wnested-externs... yes
checking if gcc supports -Wold-style-definition... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating panel-plugin/Makefile
config.status: creating po/Makefile.in
config.status: creating icons/Makefile
config.status: creating icons/liquid/Makefile
config.status: creating icons/liquid/22/Makefile
config.status: creating icons/liquid/48/Makefile
config.status: creating icons/liquid/128/Makefile
config.status: creating icons/liquid-dark/Makefile
config.status: creating icons/liquid-dark/22/Makefile
config.status: creating icons/liquid-dark/48/Makefile
config.status: creating icons/liquid-dark/128/Makefile
config.status: creating icons/simplistic/Makefile
config.status: creating icons/simplistic/22/Makefile
config.status: creating icons/simplistic/48/Makefile
config.status: creating icons/simplistic/128/Makefile
config.status: creating icons/16x16/Makefile
config.status: creating icons/32x32/Makefile
config.status: creating icons/48x48/Makefile
config.status: creating icons/128x128/Makefile
config.status: creating icons/scalable/Makefile
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing po-directories commands
config.status: creating po/POTFILES
Build Configuration:
* Debug Support: minimum Code : Tout sélectionner
3$ make
make all-recursive
make[1] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3 »
Making all in panel-plugin
make[2] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/panel-plugin »
make all-am
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/panel-plugin »
CC libweather_la-weather.lo
CC libweather_la-weather-config.lo
weather-config.c: In function 'button_icons_dir_clicked':
weather-config.c:961:5: warning: 'xfce_spawn_command_line_on_screen' is deprecated: Use xfce_spawn_command_line() instead [-Wdeprecated-declarations]
961 | xfce_spawn_command_line_on_screen(gdk_screen_get_default(),
In file included from /usr/include/xfce4/libxfce4ui-2/libxfce4ui/libxfce4ui.h:31,
from weather-config.c:24:
/usr/include/xfce4/libxfce4ui-2/libxfce4ui/xfce-spawn.h:64:10: note: declared here
64 | gboolean xfce_spawn_command_line_on_screen (GdkScreen *screen,
CC libweather_la-weather-data.lo
CC libweather_la-weather-debug.lo
CC libweather_la-weather-icon.lo
CC libweather_la-weather-parsers.lo
CC libweather_la-weather-scrollbox.lo
CC libweather_la-weather-search.lo
weather-search.c: In function 'create_search_dialog':
weather-search.c:208:9: warning: 'xfce_titled_dialog_new_with_buttons' is deprecated: Use xfce_titled_dialog_new_with_mixed_buttons() instead [-Wdeprecated-declarations]
208 | xfce_titled_dialog_new_with_buttons(_("Search location"),
In file included from /usr/include/xfce4/libxfce4ui-2/libxfce4ui/libxfce4ui.h:35,
from weather-search.c:25:
/usr/include/xfce4/libxfce4ui-2/libxfce4ui/xfce-titled-dialog.h:71:23: note: declared here
71 | GtkWidget *xfce_titled_dialog_new_with_buttons (const gchar *title,
CC libweather_la-weather-summary.lo
CC libweather_la-weather-translate.lo
CCLD libweather.la
GEN weather.desktop
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/panel-plugin »
make[2] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/panel-plugin »
Making all in po
make[2] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/po »
make[2]: Rien à faire pour « all ».
make[2] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/po »
Making all in icons
make[2] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons »
Making all in liquid
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid »
Making all in 22
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid/22 »
make[4]: Rien à faire pour « all ».
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid/22 »
Making all in 48
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid/48 »
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid/48 »
Making all in 128
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid/128 »
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid/128 »
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid »
make[4]: Rien à faire pour « all-am ».
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid »
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid »
Making all in liquid-dark
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark »
Making all in 22
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark/22 »
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark/22 »
Making all in 48
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark/48 »
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark/48 »
Making all in 128
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark/128 »
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark/128 »
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark »
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark »
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark »
Making all in simplistic
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic »
Making all in 22
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic/22 »
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic/22 »
Making all in 48
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic/48 »
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic/48 »
Making all in 128
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic/128 »
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic/128 »
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic »
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic »
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic »
Making all in 16x16
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/16x16 »
make[3]: Rien à faire pour « all ».
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/16x16 »
Making all in 32x32
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/32x32 »
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/32x32 »
Making all in 48x48
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/48x48 »
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/48x48 »
Making all in 128x128
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/128x128 »
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/128x128 »
Making all in scalable
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/scalable »
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/scalable »
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons »
make[3]: Rien à faire pour « all-am ».
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons »
make[2] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons »
make[2] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3 »
make[2] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3 »
make[1] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3 »
ludovic@ludovic-HP-Laptop-17-cn2xxx:~/Téléchargements/xfce4-weather-plugin-0.11.
3$ Code : Tout sélectionner
sudo make install
[sudo] Mot de passe de ludovic :
Making install in panel-plugin
make[1] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/panel-plugin »
make install-am
make[3]: Rien à faire pour « install-exec-am ».
/usr/bin/mkdir -p '/usr/share/xfce4/panel/plugins'
/usr/bin/install -c -m 644 weather.desktop '/usr/share/xfce4/panel/plugins'
/usr/bin/mkdir -p '/usr/lib/xfce4/panel/plugins'
/bin/bash ../libtool --mode=install /usr/bin/install -c libweather.la '/usr/lib/xfce4/panel/plugins'
libtool: install: /usr/bin/install -c .libs/libweather.so /usr/lib/xfce4/panel/plugins/libweather.so
libtool: install: /usr/bin/install -c .libs/libweather.lai /usr/lib/xfce4/panel/plugins/libweather.la
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin:/sbin" ldconfig -n /usr/lib/xfce4/panel/plugins
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the '-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the 'LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the 'LD_RUN_PATH' environment variable
during linking
- use the '-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to '/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
make[1] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/panel-plugin »
Making install in po
make[1] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/po »
installing ar.gmo as /usr/share/locale/ar/LC_MESSAGES/xfce4-weather-plugin.mo
installing ast.gmo as /usr/share/locale/ast/LC_MESSAGES/xfce4-weather-plugin.mo
installing be.gmo as /usr/share/locale/be/LC_MESSAGES/xfce4-weather-plugin.mo
installing bg.gmo as /usr/share/locale/bg/LC_MESSAGES/xfce4-weather-plugin.mo
installing ca.gmo as /usr/share/locale/ca/LC_MESSAGES/xfce4-weather-plugin.mo
installing cs.gmo as /usr/share/locale/cs/LC_MESSAGES/xfce4-weather-plugin.mo
installing da.gmo as /usr/share/locale/da/LC_MESSAGES/xfce4-weather-plugin.mo
installing de.gmo as /usr/share/locale/de/LC_MESSAGES/xfce4-weather-plugin.mo
installing el.gmo as /usr/share/locale/el/LC_MESSAGES/xfce4-weather-plugin.mo
installing en_AU.gmo as /usr/share/locale/en_AU/LC_MESSAGES/xfce4-weather-plugin.mo
installing en_GB.gmo as /usr/share/locale/en_GB/LC_MESSAGES/xfce4-weather-plugin.mo
installing es.gmo as /usr/share/locale/es/LC_MESSAGES/xfce4-weather-plugin.mo
installing et.gmo as /usr/share/locale/et/LC_MESSAGES/xfce4-weather-plugin.mo
installing eu.gmo as /usr/share/locale/eu/LC_MESSAGES/xfce4-weather-plugin.mo
installing fi.gmo as /usr/share/locale/fi/LC_MESSAGES/xfce4-weather-plugin.mo
installing fr.gmo as /usr/share/locale/fr/LC_MESSAGES/xfce4-weather-plugin.mo
installing gl.gmo as /usr/share/locale/gl/LC_MESSAGES/xfce4-weather-plugin.mo
installing he.gmo as /usr/share/locale/he/LC_MESSAGES/xfce4-weather-plugin.mo
installing hr.gmo as /usr/share/locale/hr/LC_MESSAGES/xfce4-weather-plugin.mo
installing hu.gmo as /usr/share/locale/hu/LC_MESSAGES/xfce4-weather-plugin.mo
installing hye.gmo as /usr/share/locale/hye/LC_MESSAGES/xfce4-weather-plugin.mo
installing id.gmo as /usr/share/locale/id/LC_MESSAGES/xfce4-weather-plugin.mo
installing is.gmo as /usr/share/locale/is/LC_MESSAGES/xfce4-weather-plugin.mo
installing it.gmo as /usr/share/locale/it/LC_MESSAGES/xfce4-weather-plugin.mo
installing ja.gmo as /usr/share/locale/ja/LC_MESSAGES/xfce4-weather-plugin.mo
installing ko.gmo as /usr/share/locale/ko/LC_MESSAGES/xfce4-weather-plugin.mo
installing lt.gmo as /usr/share/locale/lt/LC_MESSAGES/xfce4-weather-plugin.mo
installing lv.gmo as /usr/share/locale/lv/LC_MESSAGES/xfce4-weather-plugin.mo
installing ms.gmo as /usr/share/locale/ms/LC_MESSAGES/xfce4-weather-plugin.mo
installing nb.gmo as /usr/share/locale/nb/LC_MESSAGES/xfce4-weather-plugin.mo
installing nl.gmo as /usr/share/locale/nl/LC_MESSAGES/xfce4-weather-plugin.mo
installing nn.gmo as /usr/share/locale/nn/LC_MESSAGES/xfce4-weather-plugin.mo
installing oc.gmo as /usr/share/locale/oc/LC_MESSAGES/xfce4-weather-plugin.mo
installing pa.gmo as /usr/share/locale/pa/LC_MESSAGES/xfce4-weather-plugin.mo
installing pl.gmo as /usr/share/locale/pl/LC_MESSAGES/xfce4-weather-plugin.mo
installing pt_BR.gmo as /usr/share/locale/pt_BR/LC_MESSAGES/xfce4-weather-plugin.mo
installing pt.gmo as /usr/share/locale/pt/LC_MESSAGES/xfce4-weather-plugin.mo
installing ru.gmo as /usr/share/locale/ru/LC_MESSAGES/xfce4-weather-plugin.mo
installing sk.gmo as /usr/share/locale/sk/LC_MESSAGES/xfce4-weather-plugin.mo
installing sl.gmo as /usr/share/locale/sl/LC_MESSAGES/xfce4-weather-plugin.mo
installing sq.gmo as /usr/share/locale/sq/LC_MESSAGES/xfce4-weather-plugin.mo
installing sr.gmo as /usr/share/locale/sr/LC_MESSAGES/xfce4-weather-plugin.mo
installing sv.gmo as /usr/share/locale/sv/LC_MESSAGES/xfce4-weather-plugin.mo
installing te.gmo as /usr/share/locale/te/LC_MESSAGES/xfce4-weather-plugin.mo
installing th.gmo as /usr/share/locale/th/LC_MESSAGES/xfce4-weather-plugin.mo
installing tr.gmo as /usr/share/locale/tr/LC_MESSAGES/xfce4-weather-plugin.mo
installing ug.gmo as /usr/share/locale/ug/LC_MESSAGES/xfce4-weather-plugin.mo
installing uk.gmo as /usr/share/locale/uk/LC_MESSAGES/xfce4-weather-plugin.mo
installing ur_PK.gmo as /usr/share/locale/ur_PK/LC_MESSAGES/xfce4-weather-plugin.mo
installing ur.gmo as /usr/share/locale/ur/LC_MESSAGES/xfce4-weather-plugin.mo
installing zh_CN.gmo as /usr/share/locale/zh_CN/LC_MESSAGES/xfce4-weather-plugin.mo
installing zh_TW.gmo as /usr/share/locale/zh_TW/LC_MESSAGES/xfce4-weather-plugin.mo
if test "xfce4-weather-plugin" = "gettext-tools"; then \
/usr/bin/mkdir -p /usr/share/gettext/po; \
for file in Makefile.in.in remove-potcdate.sin quot.sed boldquot.sed en@quot.header en@boldquot.header insert-header.sin Rules-quot Makevars.template; do \
/usr/bin/install -c -m 644 ./$file \
/usr/share/gettext/po/$file; \
done; \
for file in Makevars; do \
rm -f /usr/share/gettext/po/$file; \
done; \
else \
fi
make[1] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/po »
Making install in icons
make[1] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons »
Making install in liquid
make[2] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid »
Making install in 22
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid/22 »
make[4]: Rien à faire pour « install-exec-am ».
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid/22'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png lightcloud.png lightcloud-night.png lightrain.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rainthunder.png sleet.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png snow.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/liquid/22'
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid/22 »
Making install in 48
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid/48 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid/48'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png lightcloud.png lightcloud-night.png lightrain.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rainthunder.png sleet.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png snow.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/liquid/48'
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid/48 »
Making install in 128
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid/128 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid/128'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png lightcloud.png lightcloud-night.png lightrain.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rainthunder.png sleet.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png snow.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/liquid/128'
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid/128 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid'
/usr/bin/install -c -m 644 theme.info '/usr/share/xfce4/weather/icons/liquid'
make[2] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid »
Making install in liquid-dark
make[2] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark »
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark/22 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid-dark/22'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png lightcloud.png lightcloud-night.png lightrain.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rainthunder.png sleet.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png snow.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/liquid-dark/22'
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark/22 »
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark/48 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid-dark/48'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png lightcloud.png lightcloud-night.png lightrain.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rainthunder.png sleet.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png snow.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/liquid-dark/48'
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark/48 »
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark/128 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid-dark/128'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png lightcloud.png lightcloud-night.png lightrain.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rainthunder.png sleet.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png snow.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/liquid-dark/128'
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark/128 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/liquid-dark'
/usr/bin/install -c -m 644 theme.info '/usr/share/xfce4/weather/icons/liquid-dark'
make[2] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/liquid-dark »
Making install in simplistic
make[2] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic »
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic/22 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/simplistic/22'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png fog-night.png lightcloud.png lightcloud-night.png lightrain.png lightrain-night.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthunder-night.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rain-night.png rainthunder.png rainthunder-night.png sleet.png sleet-night.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png sleetthunder-night.png snow.png snow-night.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png snowthunder-night.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/simplistic/22'
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic/22 »
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic/48 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/simplistic/48'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png fog-night.png lightcloud.png lightcloud-night.png lightrain.png lightrain-night.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthunder-night.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rain-night.png rainthunder.png rainthunder-night.png sleet.png sleet-night.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png sleetthunder-night.png snow.png snow-night.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png snowthunder-night.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/simplistic/48'
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic/48 »
make[3] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic/128 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/simplistic/128'
/usr/bin/install -c -m 644 nodata.png cloud.png fog.png fog-night.png lightcloud.png lightcloud-night.png lightrain.png lightrain-night.png lightrainsun.png lightrainsun-night.png lightrainthunder.png lightrainthunder-night.png lightrainthundersun.png lightrainthundersun-night.png partlycloud.png partlycloud-night.png rain.png rain-night.png rainthunder.png rainthunder-night.png sleet.png sleet-night.png sleetsun.png sleetsun-night.png sleetsunthunder.png sleetsunthunder-night.png sleetthunder.png sleetthunder-night.png snow.png snow-night.png snowsun.png snowsun-night.png snowsunthunder.png snowsunthunder-night.png snowthunder.png snowthunder-night.png sun.png sun-night.png '/usr/share/xfce4/weather/icons/simplistic/128'
make[3] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic/128 »
/usr/bin/mkdir -p '/usr/share/xfce4/weather/icons/simplistic'
/usr/bin/install -c -m 644 theme.info '/usr/share/xfce4/weather/icons/simplistic'
make[2] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/simplistic »
Making install in 16x16
make[2] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/16x16 »
/usr/bin/mkdir -p '/usr/share/icons/hicolor/16x16/apps'
/usr/bin/install -c -m 644 org.xfce.panel.weather.png '/usr/share/icons/hicolor/16x16/apps'
make[2] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/16x16 »
Making install in 32x32
make[2] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/32x32 »
/usr/bin/mkdir -p '/usr/share/icons/hicolor/32x32/apps'
/usr/bin/install -c -m 644 org.xfce.panel.weather.png '/usr/share/icons/hicolor/32x32/apps'
make[2] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/32x32 »
Making install in 48x48
make[2] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/48x48 »
/usr/bin/mkdir -p '/usr/share/icons/hicolor/48x48/apps'
/usr/bin/install -c -m 644 org.xfce.panel.weather.png '/usr/share/icons/hicolor/48x48/apps'
make[2] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/48x48 »
Making install in 128x128
make[2] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/128x128 »
/usr/bin/mkdir -p '/usr/share/icons/hicolor/128x128/apps'
/usr/bin/install -c -m 644 org.xfce.panel.weather.png '/usr/share/icons/hicolor/128x128/apps'
make[2] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/128x128 »
Making install in scalable
make[2] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/scalable »
/usr/bin/mkdir -p '/usr/share/icons/hicolor/scalable/apps'
/usr/bin/install -c -m 644 org.xfce.panel.weather.svg '/usr/share/icons/hicolor/scalable/apps'
make[2] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons/scalable »
make install-data-hook
make[4] : on entre dans le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons »
Updating Gtk icon cache.
gtk-update-icon-cache: Cache file created successfully.
make[4] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons »
make[1] : on quitte le répertoire « /home/ludovic/Téléchargements/xfce4-weather-plugin-0.11.3/icons »
make[2]: Rien à faire pour « install-exec-am ».
make[2]: Rien à faire pour « install-data-am ».
3$
