Galère pour installer imprimante Canon
B@B
Message par B@B »
je galère pour utiliser ma canon i-sensys MF3010
J'ai téléchargé et installé le bon pilote depuis le site de Canon
J'ai suivi la méthode 1 de ce tuto (https://blog.liberetonordi.com/index.ph ... otes-Canon) mais quand je veux lancer une impression de test, j'ai un mesasage qui me dit que c'est fait... mais ma Canon n'imprime rien ;-(
Pourquoi ?
Kernel: 6.17.0-14-generic arch: x86_64 bits: 64
Desktop : Cinnamon v: 6.4.8
Distrib: Linux Mint 22.2 Zara
CPU : 6 × Intel® Core™ i5-9400F CPU @ 2.90GHz
RAM : 7,7 Go
CG : llvmpipe
Gigabyte Technology Co., Ltd.
SSD : KINGSTON SA400S37240G
B@B
Re: Galère pour installer imprimante Canon
Message par B@B »
Voici les infos qui je l'espere correspondent à vos attentes :
# Configuration file for the CUPS scheduler.  See "man cupsd.conf" for a
# complete description of this file.
# Log general information in error_log - change "warn" to "debug"
# for troubleshooting...
LogLevel warn
PageLogFormat
# Specifies the maximum size of the log files before they are rotated.  The value "0" disables log rotation.
MaxLogSize 0
# Default error policy for printers
ErrorPolicy retry-job
# Only listen for connections from the local machine.
Listen localhost:631
Listen /run/cups/cups.sock
# Show shared printers on the local network.
Browsing No
BrowseLocalProtocols dnssd
# Default authentication type, when authentication is required...
DefaultAuthType Basic
# Web interface setting...
WebInterface Yes
# Timeout after cupsd exits if idle (applied only if cupsd runs on-demand - with -l)
IdleExitTimeout 60
# Restrict access to the server...
<Location />
  Order allow,deny
</Location>
# Restrict access to the admin pages...
<Location /admin>
  AuthType Default
  Require user @SYSTEM
  Order allow,deny
</Location>
# Restrict access to configuration files...
<Location /admin/conf>
  AuthType Default
  Order allow,deny
</Location>
# Restrict access to log files...
<Location /admin/log>
  AuthType Default
  Order allow,deny
</Location>
# Set the default printer/job policies...
<Policy default>
  # Job/subscription privacy...
  JobPrivateAccess default
  JobPrivateValues default
  SubscriptionPrivateAccess default
  SubscriptionPrivateValues default
  # Job-related operations must be done by the owner or an administrator...
  <Limit Create-Job Print-Job Print-URI Validate-Job>
    Order deny,allow
  </Limit>
  <Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job Cancel-My-Jobs Close-Job CUPS-Move-Job>
    Require user @OWNER @SYSTEM
    Order deny,allow
  </Limit>
  <Limit CUPS-Get-Document>
    AuthType Default
    Order deny,allow
  </Limit>
  # All administration operations require an administrator to authenticate...
  <Limit CUPS-Add-Modify-Printer CUPS-Delete-Printer CUPS-Add-Modify-Class CUPS-Delete-Class CUPS-Set-Default CUPS-Get-Devices>
    AuthType Default
    Order deny,allow
  </Limit>
  # All printer operations require a printer operator to authenticate...
  <Limit Pause-Printer Resume-Printer Enable-Printer Disable-Printer Pause-Printer-After-Current-Job Hold-New-Jobs Release-Held-New-Jobs Deactivate-Printer Activate-Printer Restart-Printer Shutdown-Printer Startup-Printer Promote-Job Schedule-Job-After Cancel-Jobs CUPS-Accept-Jobs CUPS-Reject-Jobs>
    AuthType Default
    Order deny,allow
  </Limit>
  # Only the owner or an administrator can cancel or authenticate a job...
  <Limit Cancel-Job>
    Order deny,allow
  </Limit>
  <Limit CUPS-Authenticate-Job>
    AuthType Default
    Order deny,allow
  </Limit>
  <Limit All>
    Order deny,allow
  </Limit>
</Policy>
# Set the authenticated printer/job policies...
<Policy authenticated>
    AuthType Default
    Order deny,allow
  </Limit>
  <Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job Cancel-My-Jobs Close-Job CUPS-Move-Job CUPS-Get-Document>
    AuthType Default
    Order deny,allow
  </Limit>
  <Limit CUPS-Add-Modify-Printer CUPS-Delete-Printer CUPS-Add-Modify-Class CUPS-Delete-Class CUPS-Set-Default>
    AuthType Default
    Order deny,allow
  </Limit>
    AuthType Default
    Order deny,allow
  </Limit>
  <Limit Cancel-Job CUPS-Authenticate-Job>
    AuthType Default
    Order deny,allow
  </Limit>
  <Limit All>
    Order deny,allow
  </Limit>
</Policy>
# Set the kerberized printer/job policies...
<Policy kerberos>
    AuthType Negotiate
    Order deny,allow
  </Limit>
    AuthType Negotiate
    Order deny,allow
  </Limit>
    AuthType Default
    Order deny,allow
  </Limit>
    AuthType Default
    Order deny,allow
  </Limit>
    AuthType Negotiate
    Order deny,allow
  </Limit>
  <Limit All>
    Order deny,allow
  </Limit>
</Policy>
Modifié en dernier par alain le jeu. 2 oct. 2025 18:11, modifié 1 fois.
Raison : mise en place des balises code
RAM : 7,7 Go
CG : llvmpipe
