Voici le résultat des différentes commandes. D'après ce que je comprends, j'ai un problème de configuration de mon imprimante?
calme@calme-550-192nf:~$ lsusb
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 0461:0010 Primax Electronics, Ltd HP PR1101U / Primax PMX-KPR1101U Keyboard
Bus 002 Device 002: ID 0bda:0153 Realtek Semiconductor Corp. 3-in-1 (SD/SDHC/SDXC) Card Reader
Bus 002 Device 004: ID 04a9:1827 Canon, Inc. TS3100 series
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 002: ID 0458:0036 KYE Systems Corp. (Mouse Systems) Pocket Mouse LE
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
calme@calme-550-192nf:~$ lpstat -p
printer Canon_TS3100_series_USB disabled since jeu. 16 oct. 2025 16:23:19 -
cause inconnue
calme@calme-550-192nf:~$ dmesg | grep -i usb
[ 0.398197] ACPI: USB4 _OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.398204] ACPI: USB4 _OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.418258] ACPI: bus type USB registered
[ 0.418258] usbcore: registered new interface driver usbfs
[ 0.418258] usbcore: registered new interface driver hub
[ 0.418258] usbcore: registered new device driver usb
[ 0.570256] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 1
[ 0.625420] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.14
[ 0.625431] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.625434] usb usb1: Product: OHCI PCI host controller
[ 0.625435] usb usb1: Manufacturer: Linux 6.14.0-33-generic ohci_hcd
[ 0.625437] usb usb1: SerialNumber: 0000:00:12.0
[ 0.625666] hub 1-0:1.0: USB hub found
[ 0.626308] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 2
[ 0.632115] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 0.632300] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[ 0.632304] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.632306] usb usb2: Product: EHCI Host Controller
[ 0.632308] usb usb2: Manufacturer: Linux 6.14.0-33-generic ehci_hcd
[ 0.632310] usb usb2: SerialNumber: 0000:00:12.2
[ 0.632570] hub 2-0:1.0: USB hub found
[ 0.682243] hub 1-0:1.0: USB hub found
[ 0.682572] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 3
[ 0.688556] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 0.688707] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[ 0.688711] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.688713] usb usb3: Product: EHCI Host Controller
[ 0.688716] usb usb3: Manufacturer: Linux 6.14.0-33-generic ehci_hcd
[ 0.688719] usb usb3: SerialNumber: 0000:00:13.2
[ 0.689106] hub 3-0:1.0: USB hub found
[ 0.689538] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 4
[ 0.745322] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.14
[ 0.745331] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.745333] usb usb4: Product: OHCI PCI host controller
[ 0.745335] usb usb4: Manufacturer: Linux 6.14.0-33-generic ohci_hcd
[ 0.745337] usb usb4: SerialNumber: 0000:00:13.0
[ 0.745614] hub 4-0:1.0: USB hub found
[ 0.746220] ohci-pci 0000:00:14.5: new USB bus registered, assigned bus number 5
[ 0.801336] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.14
[ 0.801345] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.801348] usb usb5: Product: OHCI PCI host controller
[ 0.801350] usb usb5: Manufacturer: Linux 6.14.0-33-generic ohci_hcd
[ 0.801352] usb usb5: SerialNumber: 0000:00:14.5
[ 0.801606] hub 5-0:1.0: USB hub found
[ 0.802259] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 6
[ 0.802817] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 7
[ 0.802822] xhci_hcd 0000:00:10.0: Host supports USB 3.0 SuperSpeed
[ 0.805910] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[ 0.805914] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.805916] usb usb6: Product: xHCI Host Controller
[ 0.805918] usb usb6: Manufacturer: Linux 6.14.0-33-generic xhci-hcd
[ 0.805920] usb usb6: SerialNumber: 0000:00:10.0
[ 0.806073] hub 6-0:1.0: USB hub found
[ 0.806324] usb usb7: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.806347] usb usb7: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[ 0.806350] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.806352] usb usb7: Product: xHCI Host Controller
[ 0.806353] usb usb7: Manufacturer: Linux 6.14.0-33-generic xhci-hcd
[ 0.806355] usb usb7: SerialNumber: 0000:00:10.0
[ 0.806453] hub 7-0:1.0: USB hub found
[ 0.806817] xhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 8
[ 0.807264] xhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 9
[ 0.807268] xhci_hcd 0000:00:10.1: Host supports USB 3.0 SuperSpeed
[ 0.810443] usb usb8: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[ 0.810446] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.810448] usb usb8: Product: xHCI Host Controller
[ 0.810449] usb usb8: Manufacturer: Linux 6.14.0-33-generic xhci-hcd
[ 0.810451] usb usb8: SerialNumber: 0000:00:10.1
[ 0.810571] hub 8-0:1.0: USB hub found
[ 0.810783] usb usb9: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.810807] usb usb9: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[ 0.810810] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.810811] usb usb9: Product: xHCI Host Controller
[ 0.810813] usb usb9: Manufacturer: Linux 6.14.0-33-generic xhci-hcd
[ 0.810814] usb usb9: SerialNumber: 0000:00:10.1
[ 0.810914] hub 9-0:1.0: USB hub found
[ 0.867548] usb 2-3: new high-speed USB device number 2 using ehci-pci
[ 1.034623] usb 2-3: New USB device found, idVendor=0bda, idProduct=0153, bcdDevice=57.13
[ 1.034641] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.034644] usb 2-3: Product: USB2.0-CRW
[ 1.034648] usb 2-3: Manufacturer: Generic
[ 1.034650] usb 2-3: SerialNumber: 20120926571200000
[ 1.051600] usb 8-2: new low-speed USB device number 2 using xhci_hcd
[ 1.056599] usbcore: registered new interface driver usb-storage
[ 1.059319] usbcore: registered new interface driver uas
[ 1.061234] ums-realtek 2-3:1.0: USB Mass Storage device detected
[ 1.064710] scsi host0: usb-storage 2-3:1.0
[ 1.064998] usbcore: registered new interface driver ums-realtek
[ 1.220704] usb 8-2: New USB device found, idVendor=0458, idProduct=0036, bcdDevice= 1.10
[ 1.220719] usb 8-2: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 1.220729] usb 8-2: Product: NetScroll + Mini Traveler
[ 1.220732] usb 8-2: Manufacturer: Genius
[ 1.329025] usb 1-5: new low-speed USB device number 2 using ohci-pci
[ 1.493740] usb 1-5: New USB device found, idVendor=0461, idProduct=0010, bcdDevice= 1.04
[ 1.493751] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.493755] usb 1-5: Product: USB Keyboard
[ 1.493758] usb 1-5: Manufacturer: NOVATEK
[ 1.509330] usbcore: registered new interface driver usbhid
[ 1.509340] usbhid: USB HID core driver
[ 1.514334] input: Genius NetScroll + Mini Traveler as /devices/pci0000:00/0000:00:10.1/usb8/8-2/8-2:1.0/0003:0458:0036.0001/input/input3
[ 1.514696] hid-generic 0003:0458:0036.0001: input,hidraw0: USB HID v1.10 Mouse [Genius NetScroll + Mini Traveler] on usb-0000:00:10.1-2/input0
[ 1.515087] input: NOVATEK USB Keyboard as /devices/pci0000:00/0000:00:12.0/usb1/1-5/1-5:1.0/0003:0461:0010.0002/input/input4
[ 1.566243] hid-generic 0003:0461:0010.0002: input,hidraw1: USB HID v1.10 Keyboard [NOVATEK USB Keyboard] on usb-0000:00:12.0-5/input0
[ 1.566513] input: NOVATEK USB Keyboard System Control as /devices/pci0000:00/0000:00:12.0/usb1/1-5/1-5:1.1/0003:0461:0010.0003/input/input5
[ 1.617297] input: NOVATEK USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:12.0/usb1/1-5/1-5:1.1/0003:0461:0010.0003/input/input6
[ 1.617587] hid-generic 0003:0461:0010.0003: input,hidraw2: USB HID v1.10 Device [NOVATEK USB Keyboard] on usb-0000:00:12.0-5/input1
[ 520.235569] usb 2-1: new high-speed USB device number 4 using ehci-pci
[ 520.363120] usb 2-1: New USB device found, idVendor=04a9, idProduct=1827, bcdDevice= 1.03
[ 520.363138] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 520.363144] usb 2-1: Product: TS3100 series
[ 520.363149] usb 2-1: Manufacturer: Canon
[ 520.363153] usb 2-1: SerialNumber: 30FB33
[ 520.580868] usblp 2-1:1.1: usblp0: USB Bidirectional printer dev 4 if 1 alt 0 proto 2 vid 0x04A9 pid 0x1827
[ 520.580952] usbcore: registered new interface driver usblp
[ 520.853780] usblp0: removed
calme@calme-550-192nf:~$ journalctl -xe
oct. 16 16:35:54 calme-550-192nf dbus-daemon[703]: [system] Activating service name='org.opensuse.CupsPkHelper.Mechanism' requested by ':1.165' (uid=1000 pid=7634 comm="/usr/bin/python3 /usr/share/system-config-printer/" label="unconfine>
oct. 16 16:35:54 calme-550-192nf dbus-daemon[703]: [system] Successfully activated service 'org.opensuse.CupsPkHelper.Mechanism'
oct. 16 16:35:54 calme-550-192nf org.fedoraproject.Config.Printing[7634]: /usr/share/system-config-printer/scp-dbus-service.py:602: DeprecationWarning: Gdk.threads_enter is deprecated
oct. 16 16:35:54 calme-550-192nf org.fedoraproject.Config.Printing[7634]: Gdk.threads_enter ()
oct. 16 16:36:20 calme-550-192nf sudo[7782]: calme : PWD=/home/calme ; USER=root ; COMMAND=/usr/bin/mint-refresh-cache
oct. 16 16:36:20 calme-550-192nf sudo[7782]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
oct. 16 16:36:23 calme-550-192nf sudo[7782]: pam_unix(sudo:session): session closed for user root
oct. 16 16:36:43 calme-550-192nf dbus-daemon[703]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.170' (uid=1000 pid=8309 comm="/usr/bin/python3 /u>
oct. 16 16:36:43 calme-550-192nf systemd[1]: Starting systemd-hostnamed.service - Hostname Service...
░░ Subject: L'unité (unit) systemd-hostnamed.service a commencé à démarrer
░░ Defined-By: systemd
░░ Support: http://www.ubuntu.com/support
░░ L'unité (unit) systemd-hostnamed.service a commencé à démarrer.
oct. 16 16:36:43 calme-550-192nf dbus-daemon[703]: [system] Successfully activated service 'org.freedesktop.hostname1'
oct. 16 16:36:43 calme-550-192nf systemd[1]: Started systemd-hostnamed.service - Hostname Service.
░░ Subject: L'unité (unit) systemd-hostnamed.service a terminé son démarrage
░░ L'unité (unit) systemd-hostnamed.service a terminé son démarrage, avec le résultat done.
oct. 16 16:37:13 calme-550-192nf systemd[1]: systemd-hostnamed.service: Deactivated successfully.
░░ Subject: Unit succeeded
░░ The unit systemd-hostnamed.service has successfully entered the 'dead' state.
lines 2372-2398/2398 (END)
