Voici le 1°:
Info
PID: 1725 (xapp-sn-watcher)
UID: 1002 (pauld)
GID: 1002 (pauld)
Signal: 11 (SEGV)
Timestamp: Thu 2025-10-16 17:05:50 CEST (1 day 18h ago)
Command Line: /usr/lib/x86_64-linux-gnu/xapps/xapp-sn-watcher
Executable: /usr/lib/x86_64-linux-gnu/xapps/xapp-sn-watcher
Control Group: /user.slice/user-1002.slice/session-c2.scope
Unit: session-c2.scope
Slice: user-1002.slice
Session: c2
Owner UID: 1002 (pauld)
Boot ID: be63547f02cb4b309f470ca4711a163b
Machine ID: debd0e2a0e0b45f9b479fb06dcb4339d
Hostname: paul-KPL-W0X
Storage: /var/lib/systemd/coredump/core.xapp-sn-watcher.1002.be63547f02cb4b309f470ca4711a163b.1725.1760627150000000.zst (present)
Size on Disk: 988.8K
Message: Process 1725 (xapp-sn-watcher) of user 1002 dumped core.
Module libgcc_s.so.1 from deb gcc-14-14.2.0-4ubuntu2~24.04.amd64
Module libstdc++.so.6 from deb gcc-14-14.2.0-4ubuntu2~24.04.amd64
Module libzstd.so.1 from deb libzstd-1.5.5+dfsg2-2build1.1.amd64
Module libsystemd.so.0 from deb systemd-255.4-1ubuntu8.11.amd64
Stack trace of thread 1725:
#0 0x00007ec810cba501 g_type_check_instance (libgobject-2.0.so.0 + 0x3d501)
#1 0x00007ec810cad86e g_signal_connect_data (libgobject-2.0.so.0 + 0x3086e)
#2 0x000060dfbef2135d n/a (xapp-sn-watcher + 0xf35d)
#3 0x00007ec810d9179b n/a (libgio-2.0.so.0 + 0xb179b)
#4 0x00007ec810d956f3 n/a (libgio-2.0.so.0 + 0xb56f3)
#5 0x00007ec810e00132 n/a (libgio-2.0.so.0 + 0x120132)
#6 0x00007ec810d9179b n/a (libgio-2.0.so.0 + 0xb179b)
#7 0x00007ec810d956f3 n/a (libgio-2.0.so.0 + 0xb56f3)
#8 0x00007ec810dff941 n/a (libgio-2.0.so.0 + 0x11f941)
#9 0x00007ec810dffac2 n/a (libgio-2.0.so.0 + 0x11fac2)
#10 0x00007ec810d9179b n/a (libgio-2.0.so.0 + 0xb179b)
#11 0x00007ec810d956f3 n/a (libgio-2.0.so.0 + 0xb56f3)
#12 0x00007ec810defde2 n/a (libgio-2.0.so.0 + 0x10fde2)
#13 0x00007ec810d9179b n/a (libgio-2.0.so.0 + 0xb179b)
#14 0x00007ec810d917d5 n/a (libgio-2.0.so.0 + 0xb17d5)
#15 0x00007ec810b9149e n/a (libglib-2.0.so.0 + 0x5d49e)
#16 0x00007ec810bf0737 n/a (libglib-2.0.so.0 + 0xbc737)
#17 0x00007ec810b90a63 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca63)
#18 0x00007ec810dc787d g_application_run (libgio-2.0.so.0 + 0xe787d)
#19 0x000060dfbef1bfd0 main (xapp-sn-watcher + 0x9fd0)
#20 0x00007ec80fe2a1ca __libc_start_call_main (libc.so.6 + 0x2a1ca)
#21 0x00007ec80fe2a28b __libc_start_main_impl (libc.so.6 + 0x2a28b)
#22 0x000060dfbef1c0c5 _start (xapp-sn-watcher + 0xa0c5)
Stack trace of thread 1745:
#0 0x00007ec80ff1b4fd __GI___poll (libc.so.6 + 0x11b4fd)
#1 0x00007ec810bf068e n/a (libglib-2.0.so.0 + 0xbc68e)
#2 0x00007ec810b90a63 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca63)
#3 0x00007ec810b90ab9 n/a (libglib-2.0.so.0 + 0x5cab9)
#4 0x00007ec810bbfd92 n/a (libglib-2.0.so.0 + 0x8bd92)
#5 0x00007ec80fe9caa4 start_thread (libc.so.6 + 0x9caa4)
#6 0x00007ec80ff29c6c __clone3 (libc.so.6 + 0x129c6c)
Stack trace of thread 1744:
#0 0x00007ec80ff2728d syscall (libc.so.6 + 0x12728d)
#1 0x00007ec810bea4ad g_cond_wait (libglib-2.0.so.0 + 0xb64ad)
#2 0x00007ec810b5b53b n/a (libglib-2.0.so.0 + 0x2753b)
#3 0x00007ec810bc0b73 n/a (libglib-2.0.so.0 + 0x8cb73)
Stack trace of thread 1746:
#2 0x00007ec810b91f87 g_main_loop_run (libglib-2.0.so.0 + 0x5df87)
#3 0x00007ec810dfa542 n/a (libgio-2.0.so.0 + 0x11a542)
Stack trace of thread 1747:
#3 0x00007ec80ea5a595 n/a (libdconfsettings.so + 0x7595)
ELF object binary architecture: AMD x86-64
GDB Log
warning: could not find '.gnu_debugaltlink' file for /usr/lib/x86_64-linux-gnu/xapps/xapp-sn-watcher
warning: Can't open file /SYSV00000000 (deleted) during file-backed mapping note processing
warning: Can't open file /home/pauld/.config/dconf/user (deleted) during file-backed mapping note processing
warning: Can't open file /run/user/1002/dconf/user (deleted) during file-backed mapping note processing
[New LWP 1725]
[New LWP 1745]
[New LWP 1744]
[New LWP 1746]
[New LWP 1747]
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libxapp.so.1
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgio-2.0.so.0
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgobject-2.0.so.0
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libglib-2.0.so.0
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgdk-3.so.0
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgdk_pixbuf-2.0.so.0
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgnomekbdui.so.8
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgmodule-2.0.so.0
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libgnomekbd.so.8
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libbrotlidec.so.1
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libbrotlicommon.so.1
warning: could not find '.gnu_debugaltlink' file for /lib/x86_64-linux-gnu/libcap.so.2
warning: could not find '.gnu_debugaltlink' file for /usr/lib/x86_64-linux-gnu/gtk-3.0/modules/libxapp-gtk3-module.so
warning: could not find '.gnu_debugaltlink' file for /usr/lib/x86_64-linux-gnu/gio/modules/libgvfsdbus.so
warning: could not find '.gnu_debugaltlink' file for /usr/lib/x86_64-linux-gnu/gvfs/libgvfscommon.so
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/x86_64-linux-gnu/xapps/xapp-sn-watcher'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00007ec810cba501 in g_type_check_instance () from /lib/x86_64-linux-gnu/libgobject-2.0.so.0
[Current thread is 1 (Thread 0x7ec80eab3a80 (LWP 1725))]
GDB Backtrace
[New LWP 1725]
[New LWP 1745]
[New LWP 1744]
[New LWP 1746]
[New LWP 1747]
#1 0x00007ec810cad86e in g_signal_connect_data () from /lib/x86_64-linux-gnu/libgobject-2.0.so.0
#2 0x000060dfbef2135d in ?? ()
#3 0x00007ec810d9179b in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#4 0x00007ec810d956f3 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#5 0x00007ec810e00132 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#6 0x00007ec810d9179b in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#7 0x00007ec810d956f3 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#8 0x00007ec810dff941 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#9 0x00007ec810dffac2 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#10 0x00007ec810d9179b in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#11 0x00007ec810d956f3 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#12 0x00007ec810defde2 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#13 0x00007ec810d9179b in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#14 0x00007ec810d917d5 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#15 0x00007ec810b9149e in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#16 0x00007ec810bf0737 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#17 0x00007ec810b90a63 in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#18 0x00007ec810dc787d in g_application_run () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#19 0x000060dfbef1bfd0 in main ()
GDB Backtrace (all threads)
[New LWP 1725]
[New LWP 1745]
[New LWP 1744]
[New LWP 1746]
[New LWP 1747]
Thread 5 (Thread 0x7ec80affc6c0 (LWP 1747)):
#0 0x00007ec80ff1b4fd in __GI___poll (fds=0x7ec7f4000b90, nfds=1, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
sc_ret = -516
sc_cancel_oldtype = 0
sc_ret = <optimized out>
#1 0x00007ec810bf068e in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
No symbol table info available.
#2 0x00007ec810b90a63 in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007ec80ea5a595 in ?? () from /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
#4 0x00007ec810bbfd92 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#5 0x00007ec80fe9caa4 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:447
pd = <optimized out>
out = <optimized out>
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {139397643093696, -5947753137901738885, 139397643093696, -120, 17, 140720997937056, -5947753138014985093, -5947746421368363909}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
not_first_call = <optimized out>
#6 0x00007ec80ff29c6c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:78
No locals.
Thread 4 (Thread 0x7ec80b7fd6c0 (LWP 1746)):
#0 0x00007ec80ff1b4fd in __GI___poll (fds=0x7ec800000b90, nfds=2, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
sc_ret = -516
#2 0x00007ec810b91f87 in g_main_loop_run () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007ec810dfa542 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {139397651486400, -5947754237950237573, 139397651486400, -120, 11, 140720997938208, -5947754238063483781, -5947746421368363909}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
No locals.
Thread 3 (Thread 0x7ec80c7ff6c0 (LWP 1744)):
#0 syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
No locals.
#1 0x00007ec810bea4ad in g_cond_wait () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2 0x00007ec810b5b53b in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007ec810bc0b73 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {139397668271808, -5947747641954212741, 139397668271808, -120, 2, 140720997938064, -5947747642067458949, -5947746421368363909}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
No locals.
Thread 2 (Thread 0x7ec80bffe6c0 (LWP 1745)):
#0 0x00007ec80ff1b4fd in __GI___poll (fds=0x60dfc117c4e0, nfds=1, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
sc_ret = -516
#3 0x00007ec810b90ab9 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {139397659879104, -5947755337998736261, 139397659879104, -120, 2, 140720997937856, -5947755338111982469, -5947746421368363909}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
No locals.
Thread 1 (Thread 0x7ec80eab3a80 (LWP 1725)):
Info
PID: 8401 (xapp-sn-watcher)
UID: 1002 (pauld)
GID: 1002 (pauld)
Signal: 11 (SEGV)
Timestamp: Thu 2025-10-16 17:06:21 CEST (1 day 18h ago)
Session: c2
Storage: /var/lib/systemd/coredump/core.xapp-sn-watcher.1002.be63547f02cb4b309f470ca4711a163b.8401.1760627181000000.zst (present)
Size on Disk: 962.6K
Message: Process 8401 (xapp-sn-watcher) of user 1002 dumped core.
Stack trace of thread 8401:
#0 0x00007c9e4ed53501 g_type_check_instance (libgobject-2.0.so.0 + 0x3d501)
#1 0x00007c9e4ed4686e g_signal_connect_data (libgobject-2.0.so.0 + 0x3086e)
#2 0x000062a476198442 n/a (xapp-sn-watcher + 0xf442)
#3 0x00007c9e4ee2a79b n/a (libgio-2.0.so.0 + 0xb179b)
#4 0x00007c9e4ee2e6f3 n/a (libgio-2.0.so.0 + 0xb56f3)
#5 0x00007c9e4ee99132 n/a (libgio-2.0.so.0 + 0x120132)
#6 0x00007c9e4ee2a79b n/a (libgio-2.0.so.0 + 0xb179b)
#7 0x00007c9e4ee2e6f3 n/a (libgio-2.0.so.0 + 0xb56f3)
#8 0x00007c9e4ee98941 n/a (libgio-2.0.so.0 + 0x11f941)
#9 0x00007c9e4ee98ac2 n/a (libgio-2.0.so.0 + 0x11fac2)
#10 0x00007c9e4ee2a79b n/a (libgio-2.0.so.0 + 0xb179b)
#11 0x00007c9e4ee2e6f3 n/a (libgio-2.0.so.0 + 0xb56f3)
#12 0x00007c9e4ee88de2 n/a (libgio-2.0.so.0 + 0x10fde2)
#13 0x00007c9e4ee2a79b n/a (libgio-2.0.so.0 + 0xb179b)
#14 0x00007c9e4ee2a7d5 n/a (libgio-2.0.so.0 + 0xb17d5)
#15 0x00007c9e4ec2a49e n/a (libglib-2.0.so.0 + 0x5d49e)
#16 0x00007c9e4ec89737 n/a (libglib-2.0.so.0 + 0xbc737)
#17 0x00007c9e4ec29a63 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca63)
#18 0x00007c9e4ee6087d g_application_run (libgio-2.0.so.0 + 0xe787d)
#19 0x000062a476192fd0 main (xapp-sn-watcher + 0x9fd0)
#20 0x00007c9e4de2a1ca __libc_start_call_main (libc.so.6 + 0x2a1ca)
#21 0x00007c9e4de2a28b __libc_start_main_impl (libc.so.6 + 0x2a28b)
#22 0x000062a4761930c5 _start (xapp-sn-watcher + 0xa0c5)
Stack trace of thread 8404:
#0 0x00007c9e4df2728d syscall (libc.so.6 + 0x12728d)
#1 0x00007c9e4ec834ad g_cond_wait (libglib-2.0.so.0 + 0xb64ad)
#2 0x00007c9e4ebf453b n/a (libglib-2.0.so.0 + 0x2753b)
#3 0x00007c9e4ec59b73 n/a (libglib-2.0.so.0 + 0x8cb73)
#4 0x00007c9e4ec58d92 n/a (libglib-2.0.so.0 + 0x8bd92)
#5 0x00007c9e4de9caa4 start_thread (libc.so.6 + 0x9caa4)
#6 0x00007c9e4df29c6c __clone3 (libc.so.6 + 0x129c6c)
Stack trace of thread 8408:
#0 0x00007c9e4df1b4fd __GI___poll (libc.so.6 + 0x11b4fd)
#1 0x00007c9e4ec8968e n/a (libglib-2.0.so.0 + 0xbc68e)
#2 0x00007c9e4ec29a63 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca63)
#3 0x00007c9e4cb67595 n/a (libdconfsettings.so + 0x7595)
Stack trace of thread 8405:
#3 0x00007c9e4ec29ab9 n/a (libglib-2.0.so.0 + 0x5cab9)
Stack trace of thread 8406:
#2 0x00007c9e4ec2af87 g_main_loop_run (libglib-2.0.so.0 + 0x5df87)
#3 0x00007c9e4ee93542 n/a (libgio-2.0.so.0 + 0x11a542)
Stack trace of thread 8454:
#1 0x00007c9e4ec83da0 g_cond_wait_until (libglib-2.0.so.0 + 0xb6da0)
#2 0x00007c9e4ebf4503 n/a (libglib-2.0.so.0 + 0x27503)
#3 0x00007c9e4ec5e58a n/a (libglib-2.0.so.0 + 0x9158a)
GDB Log
[New LWP 8401]
[New LWP 8404]
[New LWP 8408]
[New LWP 8405]
[New LWP 8406]
[New LWP 8454]
#0 0x00007c9e4ed53501 in g_type_check_instance () from /lib/x86_64-linux-gnu/libgobject-2.0.so.0
[Current thread is 1 (Thread 0x7c9e4cb71a80 (LWP 8401))]
GDB Backtrace
[New LWP 8401]
[New LWP 8404]
[New LWP 8408]
[New LWP 8405]
[New LWP 8406]
[New LWP 8454]
#1 0x00007c9e4ed4686e in g_signal_connect_data () from /lib/x86_64-linux-gnu/libgobject-2.0.so.0
#2 0x000062a476198442 in ?? ()
#3 0x00007c9e4ee2a79b in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#4 0x00007c9e4ee2e6f3 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#5 0x00007c9e4ee99132 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#6 0x00007c9e4ee2a79b in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#7 0x00007c9e4ee2e6f3 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#8 0x00007c9e4ee98941 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#9 0x00007c9e4ee98ac2 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#10 0x00007c9e4ee2a79b in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#11 0x00007c9e4ee2e6f3 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#12 0x00007c9e4ee88de2 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#13 0x00007c9e4ee2a79b in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#14 0x00007c9e4ee2a7d5 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#15 0x00007c9e4ec2a49e in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#16 0x00007c9e4ec89737 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#17 0x00007c9e4ec29a63 in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#18 0x00007c9e4ee6087d in g_application_run () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
#19 0x000062a476192fd0 in main ()
[New LWP 8401]
[New LWP 8404]
[New LWP 8408]
[New LWP 8405]
[New LWP 8406]
[New LWP 8454]
Thread 6 (Thread 0x7c9e43fff6c0 (LWP 8454)):
No locals.
#1 0x00007c9e4ec83da0 in g_cond_wait_until () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2 0x00007c9e4ebf4503 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007c9e4ec5e58a in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#4 0x00007c9e4ec58d92 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#5 0x00007c9e4de9caa4 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:447
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {137019187525312, 6265177080349784232, 137019187525312, -120, 0, 137019298670720, 6265177080303646888, 6265207953472682152}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
#6 0x00007c9e4df29c6c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:78
No locals.
Thread 5 (Thread 0x7c9e499fd6c0 (LWP 8406)):
#0 0x00007c9e4df1b4fd in __GI___poll (fds=0x7c9e34000b90, nfds=2, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
sc_ret = -516
#1 0x00007c9e4ec8968e in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2 0x00007c9e4ec2af87 in g_main_loop_run () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007c9e4ee93542 in ?? () from /lib/x86_64-linux-gnu/libgio-2.0.so.0
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {137019281888960, 6265199346533988520, 137019281888960, -120, 11, 140733911536832, 6265199346487851176, 6265207953472682152}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
No locals.
Thread 4 (Thread 0x7c9e4a1fe6c0 (LWP 8405)):
#0 0x00007c9e4df1b4fd in __GI___poll (fds=0x62a49dbed4e0, nfds=1, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
sc_ret = -516
#2 0x00007c9e4ec29a63 in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007c9e4ec29ab9 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {137019290281664, 6265196047462234280, 137019290281664, -120, 2, 140733911536480, 6265196047416096936, 6265207953472682152}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
No locals.
Thread 3 (Thread 0x7c9e491fc6c0 (LWP 8408)):
#0 0x00007c9e4df1b4fd in __GI___poll (fds=0x7c9e38000b90, nfds=1, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
sc_ret = -516
#3 0x00007c9e4cb67595 in ?? () from /usr/lib/x86_64-linux-gnu/gio/modules/libdconfsettings.so
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {137019273496256, 6265198247559231656, 137019273496256, -120, 17, 140733911535680, 6265198247513094312, 6265207953472682152}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
No locals.
Thread 2 (Thread 0x7c9e4a9ff6c0 (LWP 8404)):
No locals.
#1 0x00007c9e4ec834ad in g_cond_wait () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2 0x00007c9e4ebf453b in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007c9e4ec59b73 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {137019298674368, 6265197146436991144, 137019298674368, -120, 2, 140733911536688, 6265197146390853800, 6265207953472682152}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
No locals.
Thread 1 (Thread 0x7c9e4cb71a80 (LWP 8401)):
