boot-repair-4ppa2081 [20251029_1550]
============================= Boot Repair Summary ==============================
Ceci modifiera le point de montage de sda1 afin d'en supprimer les espaces et les caractères spéciaux. Voulez-vous continuer ?
modprobe: FATAL: Module efivars not found in directory /lib/modules/6.8.0-86-generic
Recommended repair: ____________________________________________________________
The default repair of the Boot-Repair utility will reinstall the grub-efi-amd64-signed of
nvme0n1p2,
using the following options: nvme0n1p1/boot/efi
Additional repair will be performed: unhide-bootmenu-10s use-standard-efi-file restore-efi-backups
rm /boot/efi/efi/Boot/bootx64.efi
mv /boot/efi/efi/Boot/bkpbootx64.efi /boot/efi/efi/Boot/bootx64.efi
/dev/nvme0n1p2/boot/efi not empty
============ Reinstall the grub-efi-amd64-signed of /dev/nvme0n1p2 =============
grub-install --version
grub-install (GRUB) 2.12-1ubuntu7.3
modprobe efivars
efibootmgr -v (filtered) before grub install
BootCurrent: 0001
Timeout: 2 seconds
BootOrder: 0001,0005,0006,0007
Boot0001* Ubuntu HD(1,GPT,4ccd5298-86b7-4861-8505-c02eca1ceeb6,0x800,0x100000)/File(EFIubuntushimx64.efi)
Boot0003 Windows Boot Manager HD(1,GPT,5566094a-2639-47cc-ae78-d884f2b95132,0x800,0xfa000)/File(EFIMicrosoftBootbootmgfw.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000026000100000010000000040000007fff0400
Boot0005* Onboard NIC(IPV4) PciRoot(0x0)/Pci(0x1f,0x6)/MAC(3448ed11bea8,0)/IPv4(0.0.0.00.0.0.0,0,0)0000424f
Boot0006* Onboard NIC(IPV6) PciRoot(0x0)/Pci(0x1f,0x6)/MAC(3448ed11bea8,0)/IPv6([::]:<->[::]:,0,0)0000424f
Boot0007* UEFI: USB, Partition 1 PciRoot(0x0)/Pci(0x14,0x0)/USB(14,0)/HD(1,GPT,4a416460-0cb0-4d43-a369-68fd161c72ff,0x800,0x1ca3550)0000424f
uname -r
6.8.0-86-generic
grub-install --efi-directory=/boot/efi --target=x86_64-efi --uefi-secure-boot
Installing for x86_64-efi platform.
Installation finished. No error reported.
df /dev/nvme0n1p1
mv /boot/efi/EFI/Boot/bootx64.efi /boot/efi/EFI/Boot/bkpbootx64.efi
cp /boot/efi/efi/ubuntu/shimx64.efi /boot/efi/EFI/Boot/bootx64.efi
efibootmgr -v (filtered) after grub install
BootCurrent: 0001
Timeout: 2 seconds
Warning: NVram was not modified.
update-grub
Found linux image: /boot/vmlinuz-6.8.0-86-generic
Found initrd image: /boot/initrd.img-6.8.0-86-generic
Found linux image: /boot/vmlinuz-6.8.0-51-generic
Found initrd image: /boot/initrd.img-6.8.0-51-generic
Adding boot menu entry for UEFI Firmware Settings ...
Unhide GRUB boot menu in nvme0n1p2/boot/grub/grub.cfg
Le démarrage de l'ordinateur a été correctement réparé.
Vous pouvez maintenant redémarrer votre ordinateur.
N'oubliez pas de faire démarrer votre firmware UEFI sur l'entrée L'OS actuellement utilisé - Linux Mint 22.1 (fichier nvme0n1p1/efi/ubuntu/shimx64.efi) !
============================ Boot Info After Repair ============================
=> No boot loader is installed in the MBR of /dev/nvme0n1.
=> No known boot loader is installed in the MBR of /dev/sda.
nvme0n1p1: _____________________________________________________________________
File system: vfat
Boot sector type: FAT32
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files: /efi/BOOT/bkpbootx64.efi /efi/BOOT/bootx64.efi
/efi/BOOT/fbx64.efi /efi/BOOT/grubx64.efi
/efi/BOOT/mmx64.efi /efi/ubuntu/grubx64.efi
/efi/ubuntu/mmx64.efi /efi/ubuntu/shimx64.efi
/efi/ubuntu/grub.cfg
nvme0n1p2: _____________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Linux Mint 22.1
Boot files: /boot/grub/grub.cfg /etc/fstab /etc/default/grub
File system: vfat
Operating System:
Boot files: /boot/grub/grub.cfg /syslinux.cfg
/efi/boot/bootia32.efi /efi/boot/bootx64.efi
/efi/boot/grubx64.efi
================================ 1 OS detected =================================
OS#1 (linux): L'OS actuellement utilisé - Linux Mint 22.1 on nvme0n1p2
================================ Host/Hardware =================================
CPU architecture: 64-bit
Video: WhiskeyLake-U GT2 [UHD Graphics 620] from Intel Corporation
BOOT_IMAGE of the installed session in use:
/boot/vmlinuz-6.8.0-86-generic root=UUID=780b10ed-abcc-4643-93c1-9f45d0a82d84 ro recovery nomodeset dis_ucode_ldr
df -Th / : /dev/nvme0n1p2 ext4 234G 13G 209G 6% /
===================================== UEFI =====================================
BIOS/UEFI firmware: 1.6.5(1.6) from Dell Inc.
The firmware is EFI-compatible, and is set in EFI-mode for this installed-session.
SecureBoot enabled according to mokutil - Veuillez indiquer ce message à boot.repair@gmail.com.
BootCurrent: 0001
Timeout: 2 seconds
Boot0001* Ubuntu HD(1,GPT,4ccd5298-86b7-4861-8505-c02eca1ceeb6,0x800,0x100000)/File(\EFI\ubuntu\shimx64.efi)
Boot0003 Windows Boot Manager HD(1,GPT,5566094a-2639-47cc-ae78-d884f2b95132,0x800,0xfa000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000026000100000010000000040000007fff0400
sda1/boot/bootia32.efi (same md5 as Microsoft/Boot/bootmgfw.efi)
sda1/boot/bootx64.efi (same md5 as Microsoft/Boot/bootmgfw.efi)
sda1/boot/grubx64.efi (same md5 as Microsoft/Boot/bootmgfw.efi)
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
nvme0n1 : is-GPT, no-BIOSboot, has---ESP, not-usb, not-mmc, has-os, no-wind, 2048 sectors * 512 bytes
sda : is-GPT, no-BIOSboot, has-noESP, liveusb, not-mmc, no-os, no-wind, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
nvme0n1p2 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, grubenv-ok, update-grub, end-after-100GB
nvme0n1p1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
sda1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
Partitions info (2/3): _________________________________________________________
nvme0n1p2 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, ext4
nvme0n1p1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, vfat
sda1 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, vfat
Partitions info (3/3): _________________________________________________________
nvme0n1p2 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, nvme0n1
nvme0n1p1 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, nvme0n1
sda1 : not--sepboot, no-kernel, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda
fdisk -l (filtered): ___________________________________________________________
Disk nvme0n1: 238.47 GiB, 256060514304 bytes, 500118192 sectors
Disk identifier: 9FB45FBA-D76E-4678-9496-1D5F91F4D6E5
Start End Sectors Size Type
nvme0n1p1 2048 1050623 1048576 512M EFI System
nvme0n1p2 1050624 500117503 499066880 238G Linux filesystem
Disk sda: 14.32 GiB, 15376000000 bytes, 30031250 sectors
Disk identifier: 442269DC-82FD-45A0-8F17-36967BB50532
sda1 2048 30031183 30029136 14.3G Microsoft basic data
parted -lm (filtered): _________________________________________________________
sda:15.4GB:scsi:512:512:gpt: USB SanDisk 3.2Gen1:;
1:1049kB:15.4GB:15.4GB:fat32:Main Data Partition:msftdata;
nvme0n1:256GB:nvme:512:512:gpt:KBG40ZNS256G NVMe KIOXIA 256GB:;
1:1049kB:538MB:537MB:fat32:EFI System Partition:boot, esp;
2:538MB:256GB:256GB:ext4::;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL
sda
└─sda1 vfat 6817-F7A8 4a416460-0cb0-4d43-a369-68fd161c72ff LINUX MINT Main Data Partition
nvme0n1
├─nvme0n1p1 vfat A5BC-4FA3 4ccd5298-86b7-4861-8505-c02eca1ceeb6 EFI System Partition
└─nvme0n1p2 ext4 780b10ed-abcc-4643-93c1-9f45d0a82d84 b767fb67-9efb-41e2-a0fc-229b9914f159
Mount points (filtered): _______________________________________________________
Avail Use% Mounted on
/dev/nvme0n1p2 208.6G 5% /
/dev/sda1 11.5G 19% /media/sposito/LINUX MINT
efivarfs 277.2K 27% /sys/firmware/efi/efivars
Mount options (filtered): ______________________________________________________
/dev/nvme0n1p2 ext4 rw,relatime,errors=remount-ro
/dev/sda1 vfat rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro
=================== nvme0n1p1/efi/ubuntu/grub.cfg (filtered) ===================
search.fs_uuid 780b10ed-abcc-4643-93c1-9f45d0a82d84 root
set prefix=($root)'/boot/grub'
configfile $prefix/grub.cfg
=================== nvme0n1p2/boot/grub/grub.cfg (filtered) ====================
Ubuntu 780b10ed-abcc-4643-93c1-9f45d0a82d84
UEFI Firmware Settings uefi-firmware
======================== nvme0n1p2/etc/fstab (filtered) ========================
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/nvme0n1p2 during installation
UUID=780b10ed-abcc-4643-93c1-9f45d0a82d84 / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/nvme0n1p1 during installation
UUID=A5BC-4FA3 /boot/efi vfat umask=0077 0 1
/swapfile none swap sw 0 0
==================== nvme0n1p2/etc/default/grub (filtered) =====================
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`( . /etc/os-release; echo ${NAME:-Ubuntu} ) 2>/dev/null || echo Ubuntu`
GRUB_CMDLINE_LINUX=""
GRUB_DISABLE_OS_PROBER=false
================= nvme0n1p2: Location of files loaded by Grub ==================
GiB - GB File Fragment(s)
15,880447388 = 17,051500544 boot/grub/grub.cfg 1
92,163387299 = 98,959683584 boot/vmlinuz 1
12,764484406 = 13,705760768 boot/vmlinuz-6.8.0-51-generic 2
92,163387299 = 98,959683584 boot/vmlinuz-6.8.0-86-generic 1
12,764484406 = 13,705760768 boot/vmlinuz.old 2
91,357307434 = 98,094161920 boot/initrd.img 2
91,419830322 = 98,161295360 boot/initrd.img-6.8.0-51-generic 2
91,357307434 = 98,094161920 boot/initrd.img-6.8.0-86-generic 2
91,419830322 = 98,161295360 boot/initrd.img.old 2
=================== nvme0n1p2: ls -l /etc/grub.d/ (filtered) ===================
-rwxr-xr-x 1 root root 18133 Apr 4 2024 10_linux
-rwxr-xr-x 1 root root 43202 Apr 4 2024 10_linux_zfs
-rwxr-xr-x 1 root root 14513 Apr 4 2024 20_linux_xen
-rwxr-xr-x 1 root root 786 Apr 4 2024 25_bli
-rwxr-xr-x 1 root root 13120 Apr 4 2024 30_os-prober
-rwxr-xr-x 1 root root 1174 Apr 4 2024 30_uefi-firmware
-rwxr-xr-x 1 root root 722 Dec 5 2024 35_fwupd
-rwxr-xr-x 1 root root 214 Apr 4 2024 40_custom
-rwxr-xr-x 1 root root 215 Apr 4 2024 41_custom
====================== sda1/boot/grub/grub.cfg (filtered) ======================
========================= sda1/syslinux.cfg (filtered) =========================
==================== sda1: Location of files loaded by Grub ====================
?? = ?? boot/grub/grub.cfg 1
================== sda1: Location of files loaded by Syslinux ==================
?? = ?? syslinux.cfg 1
