micro freeze
patrick-81
micro freeze
Message par patrick-81 »
J'ai un souci apparut il y a quelques temps de micro freeze de l'affichage. Je ne sais pas à quoi ou qui l'attribuer (hardware ou software). Ces micro freeze sont devenues très handicapantes dans des jeux de dextérité.
Existe-t-il un outil de diagnostic pour savoir quel est l'élément de mon système qui peut en être responsable ?
inxi -F
System:
  Host: orion Kernel: 6.8.0-90-generic arch: x86_64 bits: 64
  Desktop: Cinnamon v: 6.0.4 Distro: Ubuntu Cinnamon 24.04.3 LTS (Noble
    Numbat)
Machine:
  Type: Desktop Mobo: ASRock model: B450M-HDV R4.0
    serial: <superuser required> UEFI-[Legacy]: American Megatrends v: P3.10
    date: 07/18/2019
CPU:
  Info: 8-core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP cache: L2: 4 MiB
  Speed (MHz): avg: 2326 min/max: 1550/3200 cores: 1: 2955 2: 2794 3: 1270
    4: 1443 5: 3200 6: 3707 7: 3707 8: 1494 9: 3109 10: 2595 11: 1270 12: 1270
    13: 3758 14: 1550 15: 1550 16: 1550
Graphics:
  Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] driver: nvidia
    v: 580.95.05
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
    loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa
    gpu: nvidia,nvidia-nvswitch resolution: 2560x1440~60Hz
  API: EGL v: 1.5 drivers: nouveau,nvidia,swrast
    platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
    renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
  API: Vulkan v: 1.3.275 drivers: N/A surfaces: xcb,xlib
Audio:
  Device-1: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
  Device-2: AMD Family 17h HD Audio driver: snd_hda_intel
  API: ALSA v: k6.8.0-90-generic status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active
Network:
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    driver: r8169
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: 70:85:c2:df:a9:45
  Device-2: Qualcomm Atheros AR9271 802.11n driver: ath9k_htc type: USB
  IF: wlxf4f26d1423d6 state: down mac: f4:f2:6d:14:23:d6
  IF-ID-1: br-09f6d6d6067e state: up speed: 10000 Mbps duplex: unknown
    mac: ea:7e:01:9a:f6:a7
  IF-ID-2: docker0 state: down mac: 0e:bd:65:d6:85:6e
  IF-ID-3: veth1734594 state: up speed: 10000 Mbps duplex: full
    mac: 9e:19:3f:90:06:6d
  IF-ID-4: veth55e4394 state: up speed: 10000 Mbps duplex: full
    mac: 3e:20:c3:00:ed:e2
Bluetooth:
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    type: USB
  Report: hciconfig ID: hci0 state: up address: 00:1B:F6:02:9A:90 bt-v: 4.0
Drives:
  Local Storage: total: 3.86 TiB used: 1.13 TiB (29.3%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO 1TB size: 931.51 GiB
  ID-2: /dev/sda vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB
  ID-3: /dev/sdb vendor: Maxtor model: Z1 SSD 240GB size: 223.57 GiB
  ID-4: /dev/sdc vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
Partition:
  ID-1: / size: 915.81 GiB used: 799.81 GiB (87.3%) fs: ext4
    dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: file size: 512 MiB used: 1024 KiB (0.2%) file: /swapfile
Sensors:
  System Temperatures: cpu: 52.5 C mobo: N/A gpu: nvidia temp: 50 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 53%
Info:
  Memory: total: 32 GiB available: 31.27 GiB used: 14.89 GiB (47.6%)
  Processes: 470 Uptime: 1h 1m Shell: Bash inxi: 3.3.34
grep flags /proc/cpuinfo
flags		: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb hw_pstate ssbd ibpb vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 clzero irperf xsaveerptr arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif overflow_recov succor smca sev sev_es ibpb_exit_to_user
PC custom|amd Ryzen 2700|32Gb|GeForce 3060 super , Cinnamon v: 6.0.4 Distro: Ubuntu Cinnamon 24.04.2 LTS (Noble Numbat)
Mobile 1|Dell Latitude 5440|Linux Mint 20
Mobile 2|Dell Latitude E6440|Linux Mint 20
tioker
Re: micro freeze
Message par tioker »
Déjà mets le code et son résultat entre deux balises <code>, ça sera plus lisible.
Ensuite j'ai un peu le même soucis que je suis comme le lait sur le feu. J'analyse mes erreurs avec la commande
journalctl --since=yesterday | grep "error"
et comme pour ma part je suspecte mon disque NVMe je mettais
journalctl --since=yesterday | grep "NVMe error"
Bien sûr tu peux mettre en mot clé date: today, yesterday ( mais pas tomorrow :lol: ).
Et t'as vu comme c'est plus beau avec les balises.
Dis nous.
patrick-81
Re: micro freeze
Voilà le résultat de journalctl --since=yesterday | grep "error". J'ai du mal à m'y retrouver.
janv. 05 17:55:28 orion systemd[1]: apport-autoreport.path - Process error reports when automatic reporting is enabled (file watch) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/apport/autoreport).
janv. 05 17:55:28 orion systemd[1]: apport-autoreport.timer - Process error reports when automatic reporting is enabled (timer based) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/apport/autoreport).
janv. 05 17:55:30 orion nvidia-ctk[1415]: time="2026-01-05T17:55:30+01:00" level=warning msg="Ignoring error in locating libnvidia-sandboxutils.so.1: pattern libnvidia-sandboxutils.so.1 not found\nlibnvidia-sandboxutils.so.1: not found"
janv. 05 17:55:31 orion (webui.sh)[2003]: openwebui.service: Failed to execute /home/pat/.local/bin/launch_open_webui.sh: Exec format error
janv. 05 17:55:31 orion containerd[2029]: time="2026-01-05T17:55:31.886333676+01:00" level=info msg="skip loading plugin" error="no scratch file generator: skip plugin" id=io.containerd.snapshotter.v1.blockfile type=io.containerd.snapshotter.v1
janv. 05 17:55:31 orion containerd[2029]: time="2026-01-05T17:55:31.886862218+01:00" level=info msg="skip loading plugin" error="path /var/lib/containerd/io.containerd.snapshotter.v1.btrfs (ext4) must be a btrfs filesystem to be used with the btrfs snapshotter: skip plugin" id=io.containerd.snapshotter.v1.btrfs type=io.containerd.snapshotter.v1
janv. 05 17:55:31 orion containerd[2029]: time="2026-01-05T17:55:31.888200237+01:00" level=info msg="skip loading plugin" error="devmapper not configured: skip plugin" id=io.containerd.snapshotter.v1.devmapper type=io.containerd.snapshotter.v1
janv. 05 17:55:31 orion containerd[2029]: time="2026-01-05T17:55:31.888890461+01:00" level=info msg="skip loading plugin" error="EROFS unsupported, please `modprobe erofs`: skip plugin" id=io.containerd.snapshotter.v1.erofs type=io.containerd.snapshotter.v1
janv. 05 17:55:31 orion containerd[2029]: time="2026-01-05T17:55:31.889398134+01:00" level=info msg="skip loading plugin" error="lstat /var/lib/containerd/io.containerd.snapshotter.v1.zfs: no such file or directory: skip plugin" id=io.containerd.snapshotter.v1.zfs type=io.containerd.snapshotter.v1
janv. 05 17:55:31 orion containerd[2029]: time="2026-01-05T17:55:31.894150576+01:00" level=info msg="skip loading plugin" error="failed to check mkfs.erofs availability: failed to run mkfs.erofs --help: exec: \"mkfs.erofs\": executable file not found in $PATH: skip plugin" id=io.containerd.differ.v1.erofs type=io.containerd.differ.v1
janv. 05 17:55:31 orion containerd[2029]: time="2026-01-05T17:55:31.896783183+01:00" level=info msg="skip loading plugin" error="skip plugin: tracing endpoint not configured" id=io.containerd.tracing.processor.v1.otlp type=io.containerd.tracing.processor.v1
janv. 05 17:55:31 orion containerd[2029]: time="2026-01-05T17:55:31.896822527+01:00" level=info msg="skip loading plugin" error="skip plugin: tracing endpoint not configured" id=io.containerd.internal.v1.tracing type=io.containerd.internal.v1
janv. 05 17:55:32 orion cups.cupsd[2009]: + perl -p -i -e s:^(\s*\#)?\s*User\s+\S+\s*$:User snap_daemon\n:; -e s:^(\s*\#)?\s*Group\s+.*$:Group snap_daemon:; -e s:^(\s*\#)?\s*SystemGroup\s+.*$:SystemGroup lpadmin root:; -e s:^(\s*\#)?\s*AccessLog\s+.*$:AccessLog /var/snap/cups/1134/var/log/access_log:; -e s:^(\s*\#)?\s*CacheDir\s+.*$:CacheDir /var/snap/cups/1134/var/cache:; -e s:^(\s*\#)?\s*DataDir\s+.*$:DataDir /snap/cups/1134/share/cups:; -e s:^(\s*\#)?\s*DocumentRoot\s+.*$:DocumentRoot /snap/cups/1134/share/cups/doc:; -e s:^(\s*\#)?\s*ErrorLog\s+.*$:ErrorLog /var/snap/cups/1134/var/log/error_log:; -e s:^(\s*\#)?\s*FontPath\s+.*$:\#FontPath (NOT SUPPORTED ANY MORE):; -e s:^(\s*\#)?\s*PageLog\s+.*$:PageLog /var/snap/cups/1134/var/log/page_log:; -e s:^(\s*\#)?\s*Printcap\s+.*$:Printcap /var/snap/cups/common/etc/printcap:; -e s:^(\s*\#)?\s*RequestRoot\s+.*$:RequestRoot /var/snap/cups/1134/var/spool:; -e s:^(\s*\#)?\s*ServerBin\s+.*$:ServerBin /snap/cups/1134/lib/cups:; -e s:^(\s*\#)?\s*ServerRoot\s+.*$:ServerRoot /var/snap/cups/common/etc/cups:; -e s:^(\s*\#)?\s*StateDir\s+.*$:StateDir /var/snap/cups/1134/var/run:; -e s:^(\s*\#)?\s*TempDir\s+.*$:TempDir /var/snap/cups/1134/var/spool/tmp:; /var/snap/cups/common/etc/cups/cups-files.conf
janv. 05 17:55:37 orion dockerd[2707]: time="2026-01-05T17:55:37.907855020+01:00" level=info msg="Deleting nftables IPv4 rules" error="exit status 1"
janv. 05 17:55:37 orion dockerd[2707]: time="2026-01-05T17:55:37.924767087+01:00" level=info msg="Deleting nftables IPv6 rules" error="exit status 1"
janv. 05 17:57:09 orion goa-daemon[4845]: /org/gnome/OnlineAccounts/Accounts/account_1670889457_0: Setting AttentionNeeded to TRUE because EnsureCredentials() failed with: Aucune donnée d’authentification trouvée dans le trousseau de clés (goa-error-quark, 4)
janv. 05 18:32:35 orion firefox_firefox.desktop[43864]: [43864, Main Thread] WARNING: Theme parsing error: gtk.css:1:21: Failed to import: Erreur lors de l’ouverture du fichier /home/pat/snap/firefox/7559/.config/gtk-3.0/colors.css : No such file or directory: 'glib warning', file /build/firefox/parts/firefox/build/toolkit/xre/nsSigHandlers.cpp:201
janv. 05 18:32:35 orion firefox[43864]: Theme parsing error: gtk.css:1:21: Failed to import: Erreur lors de l’ouverture du fichier /home/pat/snap/firefox/7559/.config/gtk-3.0/colors.css : No such file or directory
janv. 05 18:52:52 orion dbus-daemon[1349]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.95" (uid=1000 pid=4436 comm="/usr/bin/wireplumber" label="unconfined") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.4" (uid=0 pid=1347 comm="/usr/libexec/bluetooth/bluetoothd" label="unconfined")
janv. 05 18:52:52 orion kernel: traps: llama-box-rpc-s[3656] general protection fault ip:7a1d1416b3fc sp:7a1d14118130 error:0 in libc.so.6[7a1d1414e000+195000]
janv. 05 18:52:52 orion dbus-daemon[1349]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.95" (uid=1000 pid=4436 comm="/usr/bin/wireplumber" label="unconfined") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.4" (uid=0 pid=1347 comm="/usr/libexec/bluetooth/bluetoothd" label="unconfined")
janv. 05 18:52:52 orion dbus-daemon[1349]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.95" (uid=1000 pid=4436 comm="/usr/bin/wireplumber" label="unconfined") interface="(unset)" member="(unset)" error name="org.bluez.Profile1.Error.NotImplemented" requested_reply="0" destination=":1.4" (uid=0 pid=1347 comm="/usr/libexec/bluetooth/bluetoothd" label="unconfined")
janv. 05 18:52:54 orion dockerd[2707]: time="2026-01-05T18:52:54.186010990+01:00" level=warning msg="ShouldRestart failed, container will not be restarted" container=7b6bc3de3e9f313c1c99c07ceb61dc2fc097badee0e1908180e0973e7c010ccd daemonShuttingDown=true error="restart canceled" execDuration=57m15.541311468s exitStatus="{0 2026-01-05 17:52:54.134195912 +0000 UTC}" hasBeenManuallyStopped=false restartCount=0
janv. 05 18:52:58 orion dockerd[2707]: time="2026-01-05T18:52:58.307397297+01:00" level=warning msg="ShouldRestart failed, container will not be restarted" container=260c32a30c6f05d81954838f81c637895106cddd440ebdd4dfd823db84c8d0b9 daemonShuttingDown=true error="restart canceled" execDuration=57m19.659983325s exitStatus="{137 2026-01-05 17:52:58.271199811 +0000 UTC}" hasBeenManuallyStopped=false restartCount=0
janv. 05 18:53:02 orion dockerd[2707]: time="2026-01-05T18:53:02.142941740+01:00" level=warning msg="ShouldRestart failed, container will not be restarted" container=bf4df2d08ce49639f0093a6731b398212fcd24a9f0a7492ab32a315e8b6069ce daemonShuttingDown=true error="restart canceled" execDuration=57m23.500721878s exitStatus="{137 2026-01-05 17:53:02.089567115 +0000 UTC}" hasBeenManuallyStopped=false restartCount=0
janv. 05 18:53:02 orion dockerd[2707]: time="2026-01-05T18:53:02.342990477+01:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
janv. 05 18:53:45 orion systemd[1]: apport-autoreport.path - Process error reports when automatic reporting is enabled (file watch) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/apport/autoreport).
janv. 05 18:53:45 orion systemd[1]: apport-autoreport.timer - Process error reports when automatic reporting is enabled (timer based) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/apport/autoreport).
janv. 05 18:53:46 orion nvidia-ctk[1412]: time="2026-01-05T18:53:46+01:00" level=warning msg="Ignoring error in locating libnvidia-sandboxutils.so.1: pattern libnvidia-sandboxutils.so.1 not found\nlibnvidia-sandboxutils.so.1: not found"
janv. 05 18:53:48 orion (webui.sh)[1929]: openwebui.service: Failed to execute /home/pat/.local/bin/launch_open_webui.sh: Exec format error
janv. 05 18:53:48 orion containerd[1960]: time="2026-01-05T18:53:48.504044918+01:00" level=info msg="skip loading plugin" error="no scratch file generator: skip plugin" id=io.containerd.snapshotter.v1.blockfile type=io.containerd.snapshotter.v1
janv. 05 18:53:48 orion containerd[1960]: time="2026-01-05T18:53:48.504422716+01:00" level=info msg="skip loading plugin" error="path /var/lib/containerd/io.containerd.snapshotter.v1.btrfs (ext4) must be a btrfs filesystem to be used with the btrfs snapshotter: skip plugin" id=io.containerd.snapshotter.v1.btrfs type=io.containerd.snapshotter.v1
janv. 05 18:53:48 orion containerd[1960]: time="2026-01-05T18:53:48.504479323+01:00" level=info msg="skip loading plugin" error="devmapper not configured: skip plugin" id=io.containerd.snapshotter.v1.devmapper type=io.containerd.snapshotter.v1
janv. 05 18:53:48 orion containerd[1960]: time="2026-01-05T18:53:48.505055864+01:00" level=info msg="skip loading plugin" error="EROFS unsupported, please `modprobe erofs`: skip plugin" id=io.containerd.snapshotter.v1.erofs type=io.containerd.snapshotter.v1
janv. 05 18:53:48 orion containerd[1960]: time="2026-01-05T18:53:48.506951158+01:00" level=info msg="skip loading plugin" error="lstat /var/lib/containerd/io.containerd.snapshotter.v1.zfs: no such file or directory: skip plugin" id=io.containerd.snapshotter.v1.zfs type=io.containerd.snapshotter.v1
janv. 05 18:53:48 orion containerd[1960]: time="2026-01-05T18:53:48.510597978+01:00" level=info msg="skip loading plugin" error="failed to check mkfs.erofs availability: failed to run mkfs.erofs --help: exec: \"mkfs.erofs\": executable file not found in $PATH: skip plugin" id=io.containerd.differ.v1.erofs type=io.containerd.differ.v1
janv. 05 18:53:48 orion containerd[1960]: time="2026-01-05T18:53:48.513649560+01:00" level=info msg="skip loading plugin" error="skip plugin: tracing endpoint not configured" id=io.containerd.tracing.processor.v1.otlp type=io.containerd.tracing.processor.v1
janv. 05 18:53:48 orion containerd[1960]: time="2026-01-05T18:53:48.513688814+01:00" level=info msg="skip loading plugin" error="skip plugin: tracing endpoint not configured" id=io.containerd.internal.v1.tracing type=io.containerd.internal.v1
janv. 05 18:53:49 orion cups.cupsd[1935]: + perl -p -i -e s:^(\s*\#)?\s*User\s+\S+\s*$:User snap_daemon\n:; -e s:^(\s*\#)?\s*Group\s+.*$:Group snap_daemon:; -e s:^(\s*\#)?\s*SystemGroup\s+.*$:SystemGroup lpadmin root:; -e s:^(\s*\#)?\s*AccessLog\s+.*$:AccessLog /var/snap/cups/1134/var/log/access_log:; -e s:^(\s*\#)?\s*CacheDir\s+.*$:CacheDir /var/snap/cups/1134/var/cache:; -e s:^(\s*\#)?\s*DataDir\s+.*$:DataDir /snap/cups/1134/share/cups:; -e s:^(\s*\#)?\s*DocumentRoot\s+.*$:DocumentRoot /snap/cups/1134/share/cups/doc:; -e s:^(\s*\#)?\s*ErrorLog\s+.*$:ErrorLog /var/snap/cups/1134/var/log/error_log:; -e s:^(\s*\#)?\s*FontPath\s+.*$:\#FontPath (NOT SUPPORTED ANY MORE):; -e s:^(\s*\#)?\s*PageLog\s+.*$:PageLog /var/snap/cups/1134/var/log/page_log:; -e s:^(\s*\#)?\s*Printcap\s+.*$:Printcap /var/snap/cups/common/etc/printcap:; -e s:^(\s*\#)?\s*RequestRoot\s+.*$:RequestRoot /var/snap/cups/1134/var/spool:; -e s:^(\s*\#)?\s*ServerBin\s+.*$:ServerBin /snap/cups/1134/lib/cups:; -e s:^(\s*\#)?\s*ServerRoot\s+.*$:ServerRoot /var/snap/cups/common/etc/cups:; -e s:^(\s*\#)?\s*StateDir\s+.*$:StateDir /var/snap/cups/1134/var/run:; -e s:^(\s*\#)?\s*TempDir\s+.*$:TempDir /var/snap/cups/1134/var/spool/tmp:; /var/snap/cups/common/etc/cups/cups-files.conf
janv. 05 18:53:54 orion dockerd[2598]: time="2026-01-05T18:53:54.575982562+01:00" level=info msg="Deleting nftables IPv4 rules" error="exit status 1"
janv. 05 18:53:54 orion dockerd[2598]: time="2026-01-05T18:53:54.599197360+01:00" level=info msg="Deleting nftables IPv6 rules" error="exit status 1"
janv. 05 18:54:02 orion goa-daemon[3806]: /org/gnome/OnlineAccounts/Accounts/account_1670889457_0: Setting AttentionNeeded to TRUE because EnsureCredentials() failed with: Aucune donnée d’authentification trouvée dans le trousseau de clés (goa-error-quark, 4)
janv. 05 23:14:38 orion dbus-daemon[1343]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.92" (uid=1000 pid=3356 comm="/usr/bin/wireplumber" label="unconfined") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.3" (uid=0 pid=1341 comm="/usr/libexec/bluetooth/bluetoothd" label="unconfined")
janv. 05 23:14:38 orion dbus-daemon[1343]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.92" (uid=1000 pid=3356 comm="/usr/bin/wireplumber" label="unconfined") interface="(unset)" member="(unset)" error name="org.bluez.Profile1.Error.NotImplemented" requested_reply="0" destination=":1.3" (uid=0 pid=1341 comm="/usr/libexec/bluetooth/bluetoothd" label="unconfined")
janv. 05 23:14:40 orion dockerd[2598]: time="2026-01-05T23:14:40.271605009+01:00" level=warning msg="ShouldRestart failed, container will not be restarted" container=7b6bc3de3e9f313c1c99c07ceb61dc2fc097badee0e1908180e0973e7c010ccd daemonShuttingDown=true error="restart canceled" execDuration=4h20m45.012489495s exitStatus="{0 2026-01-05 22:14:40.214492009 +0000 UTC}" hasBeenManuallyStopped=false restartCount=0
janv. 05 23:14:44 orion dockerd[2598]: time="2026-01-05T23:14:44.660141223+01:00" level=warning msg="ShouldRestart failed, container will not be restarted" container=260c32a30c6f05d81954838f81c637895106cddd440ebdd4dfd823db84c8d0b9 daemonShuttingDown=true error="restart canceled" execDuration=4h20m49.398301721s exitStatus="{137 2026-01-05 22:14:44.605688393 +0000 UTC}" hasBeenManuallyStopped=false restartCount=0
janv. 05 23:14:48 orion dockerd[2598]: time="2026-01-05T23:14:48.473092837+01:00" level=warning msg="ShouldRestart failed, container will not be restarted" container=bf4df2d08ce49639f0093a6731b398212fcd24a9f0a7492ab32a315e8b6069ce daemonShuttingDown=true error="restart canceled" execDuration=4h20m53.216690822s exitStatus="{137 2026-01-05 22:14:48.42119633 +0000 UTC}" hasBeenManuallyStopped=false restartCount=0
janv. 05 23:14:48 orion dockerd[2598]: time="2026-01-05T23:14:48.674420994+01:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
janv. 05 23:14:48 orion dockerd[2598]: time="2026-01-05T23:14:48.675605816+01:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
janv. 06 10:35:44 orion systemd[1]: apport-autoreport.path - Process error reports when automatic reporting is enabled (file watch) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/apport/autoreport).
janv. 06 10:35:44 orion systemd[1]: apport-autoreport.timer - Process error reports when automatic reporting is enabled (timer based) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/apport/autoreport).
janv. 06 10:35:46 orion nvidia-ctk[1671]: time="2026-01-06T10:35:46+01:00" level=warning msg="Ignoring error in locating libnvidia-sandboxutils.so.1: pattern libnvidia-sandboxutils.so.1 not found\nlibnvidia-sandboxutils.so.1: not found"
janv. 06 10:35:47 orion (webui.sh)[2066]: openwebui.service: Failed to execute /home/pat/.local/bin/launch_open_webui.sh: Exec format error
janv. 06 10:35:48 orion containerd[2092]: time="2026-01-06T10:35:48.006784464+01:00" level=info msg="skip loading plugin" error="no scratch file generator: skip plugin" id=io.containerd.snapshotter.v1.blockfile type=io.containerd.snapshotter.v1
janv. 06 10:35:48 orion containerd[2092]: time="2026-01-06T10:35:48.007651320+01:00" level=info msg="skip loading plugin" error="path /var/lib/containerd/io.containerd.snapshotter.v1.btrfs (ext4) must be a btrfs filesystem to be used with the btrfs snapshotter: skip plugin" id=io.containerd.snapshotter.v1.btrfs type=io.containerd.snapshotter.v1
janv. 06 10:35:48 orion containerd[2092]: time="2026-01-06T10:35:48.007701955+01:00" level=info msg="skip loading plugin" error="devmapper not configured: skip plugin" id=io.containerd.snapshotter.v1.devmapper type=io.containerd.snapshotter.v1
janv. 06 10:35:48 orion containerd[2092]: time="2026-01-06T10:35:48.008486536+01:00" level=info msg="skip loading plugin" error="EROFS unsupported, please `modprobe erofs`: skip plugin" id=io.containerd.snapshotter.v1.erofs type=io.containerd.snapshotter.v1
janv. 06 10:35:48 orion containerd[2092]: time="2026-01-06T10:35:48.009296945+01:00" level=info msg="skip loading plugin" error="lstat /var/lib/containerd/io.containerd.snapshotter.v1.zfs: no such file or directory: skip plugin" id=io.containerd.snapshotter.v1.zfs type=io.containerd.snapshotter.v1
janv. 06 10:35:48 orion containerd[2092]: time="2026-01-06T10:35:48.014607583+01:00" level=info msg="skip loading plugin" error="failed to check mkfs.erofs availability: failed to run mkfs.erofs --help: exec: \"mkfs.erofs\": executable file not found in $PATH: skip plugin" id=io.containerd.differ.v1.erofs type=io.containerd.differ.v1
janv. 06 10:35:48 orion containerd[2092]: time="2026-01-06T10:35:48.016893339+01:00" level=info msg="skip loading plugin" error="skip plugin: tracing endpoint not configured" id=io.containerd.tracing.processor.v1.otlp type=io.containerd.tracing.processor.v1
janv. 06 10:35:48 orion containerd[2092]: time="2026-01-06T10:35:48.016923285+01:00" level=info msg="skip loading plugin" error="skip plugin: tracing endpoint not configured" id=io.containerd.internal.v1.tracing type=io.containerd.internal.v1
janv. 06 10:35:48 orion cups.cupsd[2072]: + perl -p -i -e s:^(\s*\#)?\s*User\s+\S+\s*$:User snap_daemon\n:; -e s:^(\s*\#)?\s*Group\s+.*$:Group snap_daemon:; -e s:^(\s*\#)?\s*SystemGroup\s+.*$:SystemGroup lpadmin root:; -e s:^(\s*\#)?\s*AccessLog\s+.*$:AccessLog /var/snap/cups/1134/var/log/access_log:; -e s:^(\s*\#)?\s*CacheDir\s+.*$:CacheDir /var/snap/cups/1134/var/cache:; -e s:^(\s*\#)?\s*DataDir\s+.*$:DataDir /snap/cups/1134/share/cups:; -e s:^(\s*\#)?\s*DocumentRoot\s+.*$:DocumentRoot /snap/cups/1134/share/cups/doc:; -e s:^(\s*\#)?\s*ErrorLog\s+.*$:ErrorLog /var/snap/cups/1134/var/log/error_log:; -e s:^(\s*\#)?\s*FontPath\s+.*$:\#FontPath (NOT SUPPORTED ANY MORE):; -e s:^(\s*\#)?\s*PageLog\s+.*$:PageLog /var/snap/cups/1134/var/log/page_log:; -e s:^(\s*\#)?\s*Printcap\s+.*$:Printcap /var/snap/cups/common/etc/printcap:; -e s:^(\s*\#)?\s*RequestRoot\s+.*$:RequestRoot /var/snap/cups/1134/var/spool:; -e s:^(\s*\#)?\s*ServerBin\s+.*$:ServerBin /snap/cups/1134/lib/cups:; -e s:^(\s*\#)?\s*ServerRoot\s+.*$:ServerRoot /var/snap/cups/common/etc/cups:; -e s:^(\s*\#)?\s*StateDir\s+.*$:StateDir /var/snap/cups/1134/var/run:; -e s:^(\s*\#)?\s*TempDir\s+.*$:TempDir /var/snap/cups/1134/var/spool/tmp:; /var/snap/cups/common/etc/cups/cups-files.conf
janv. 06 10:35:53 orion dockerd[2737]: time="2026-01-06T10:35:53.971648115+01:00" level=info msg="Deleting nftables IPv4 rules" error="exit status 1"
janv. 06 10:35:53 orion dockerd[2737]: time="2026-01-06T10:35:53.992681543+01:00" level=info msg="Deleting nftables IPv6 rules" error="exit status 1"
janv. 06 10:36:01 orion goa-daemon[3956]: /org/gnome/OnlineAccounts/Accounts/account_1670889457_0: Setting AttentionNeeded to TRUE because EnsureCredentials() failed with: Aucune donnée d’authentification trouvée dans le trousseau de clés (goa-error-quark, 4)
janv. 06 11:46:25 orion dockerd[2737]: time="2026-01-06T11:46:25.488081524+01:00" level=error msg="Failed to get event" error="rpc error: code = Unavailable desc = error reading from server: EOF" module=libcontainerd namespace=moby
janv. 06 11:46:25 orion dockerd[2737]: time="2026-01-06T11:46:25.488134623+01:00" level=error msg="Failed to get event" error="rpc error: code = Unavailable desc = error reading from server: EOF" module=libcontainerd namespace=plugins.moby
janv. 06 11:46:25 orion containerd[87517]: time="2026-01-06T11:46:25.580706747+01:00" level=info msg="skip loading plugin" error="no scratch file generator: skip plugin" id=io.containerd.snapshotter.v1.blockfile type=io.containerd.snapshotter.v1
janv. 06 11:46:25 orion containerd[87517]: time="2026-01-06T11:46:25.581327029+01:00" level=info msg="skip loading plugin" error="path /var/lib/containerd/io.containerd.snapshotter.v1.btrfs (ext4) must be a btrfs filesystem to be used with the btrfs snapshotter: skip plugin" id=io.containerd.snapshotter.v1.btrfs type=io.containerd.snapshotter.v1
janv. 06 11:46:25 orion containerd[87517]: time="2026-01-06T11:46:25.581374628+01:00" level=info msg="skip loading plugin" error="devmapper not configured: skip plugin" id=io.containerd.snapshotter.v1.devmapper type=io.containerd.snapshotter.v1
janv. 06 11:46:25 orion containerd[87517]: time="2026-01-06T11:46:25.581614136+01:00" level=info msg="skip loading plugin" error="EROFS unsupported, please `modprobe erofs`: skip plugin" id=io.containerd.snapshotter.v1.erofs type=io.containerd.snapshotter.v1
janv. 06 11:46:25 orion containerd[87517]: time="2026-01-06T11:46:25.581948563+01:00" level=info msg="skip loading plugin" error="lstat /var/lib/containerd/io.containerd.snapshotter.v1.zfs: no such file or directory: skip plugin" id=io.containerd.snapshotter.v1.zfs type=io.containerd.snapshotter.v1
janv. 06 11:46:25 orion containerd[87517]: time="2026-01-06T11:46:25.582832719+01:00" level=info msg="skip loading plugin" error="failed to check mkfs.erofs availability: failed to run mkfs.erofs --help: exec: \"mkfs.erofs\": executable file not found in $PATH: skip plugin" id=io.containerd.differ.v1.erofs type=io.containerd.differ.v1
janv. 06 11:46:25 orion containerd[87517]: time="2026-01-06T11:46:25.595740346+01:00" level=info msg="skip loading plugin" error="skip plugin: tracing endpoint not configured" id=io.containerd.tracing.processor.v1.otlp type=io.containerd.tracing.processor.v1
janv. 06 11:46:25 orion containerd[87517]: time="2026-01-06T11:46:25.595767326+01:00" level=info msg="skip loading plugin" error="skip plugin: tracing endpoint not configured" id=io.containerd.internal.v1.tracing type=io.containerd.internal.v1
janv. 06 11:48:25 orion kernel: llama-box-rpc-s[6110]: segfault at 526068230 ip 0000775fd00643fc sp 00007ffc3fe9e870 error 4 in libc.so.6[775fd0047000+195000] likely on CPU 6 (core 6, socket 0)
janv. 06 11:48:25 orion dbus-daemon[1414]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.92" (uid=1000 pid=3504 comm="/usr/bin/wireplumber" label="unconfined") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.3" (uid=0 pid=1412 comm="/usr/libexec/bluetooth/bluetoothd" label="unconfined")
janv. 06 11:48:25 orion dbus-daemon[1414]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.92" (uid=1000 pid=3504 comm="/usr/bin/wireplumber" label="unconfined") interface="(unset)" member="(unset)" error name="org.bluez.Profile1.Error.NotImplemented" requested_reply="0" destination=":1.3" (uid=0 pid=1412 comm="/usr/libexec/bluetooth/bluetoothd" label="unconfined")
janv. 06 11:48:27 orion dockerd[2737]: time="2026-01-06T11:48:27.552464711+01:00" level=warning msg="ShouldRestart failed, container will not be restarted" container=7b6bc3de3e9f313c1c99c07ceb61dc2fc097badee0e1908180e0973e7c010ccd daemonShuttingDown=true error="restart canceled" execDuration=1h12m32.910876372s exitStatus="{0 2026-01-06 10:48:27.493458801 +0000 UTC}" hasBeenManuallyStopped=false restartCount=0
janv. 06 11:48:32 orion dockerd[2737]: time="2026-01-06T11:48:32.053287291+01:00" level=warning msg="ShouldRestart failed, container will not be restarted" container=260c32a30c6f05d81954838f81c637895106cddd440ebdd4dfd823db84c8d0b9 daemonShuttingDown=true error="restart canceled" execDuration=1h12m37.414435061s exitStatus="{137 2026-01-06 10:48:31.995064384 +0000 UTC}" hasBeenManuallyStopped=false restartCount=0
janv. 06 11:48:35 orion dockerd[2737]: time="2026-01-06T11:48:35.832465359+01:00" level=warning msg="ShouldRestart failed, container will not be restarted" container=bf4df2d08ce49639f0093a6731b398212fcd24a9f0a7492ab32a315e8b6069ce daemonShuttingDown=true error="restart canceled" execDuration=1h12m41.196446442s exitStatus="{137 2026-01-06 10:48:35.768685468 +0000 UTC}" hasBeenManuallyStopped=false restartCount=0
janv. 06 11:48:36 orion dockerd[2737]: time="2026-01-06T11:48:36.041766114+01:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
janv. 06 11:48:36 orion dockerd[2737]: time="2026-01-06T11:48:36.043311637+01:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
janv. 06 11:49:19 orion systemd[1]: apport-autoreport.path - Process error reports when automatic reporting is enabled (file watch) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/apport/autoreport).
janv. 06 11:49:19 orion systemd[1]: apport-autoreport.timer - Process error reports when automatic reporting is enabled (timer based) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/apport/autoreport).
janv. 06 11:49:20 orion nvidia-ctk[1397]: time="2026-01-06T11:49:20+01:00" level=warning msg="Ignoring error in locating libnvidia-sandboxutils.so.1: pattern libnvidia-sandboxutils.so.1 not found\nlibnvidia-sandboxutils.so.1: not found"
janv. 06 11:49:22 orion (webui.sh)[1904]: openwebui.service: Failed to execute /home/pat/.local/bin/launch_open_webui.sh: Exec format error
janv. 06 11:49:23 orion containerd[1939]: time="2026-01-06T11:49:23.071441803+01:00" level=info msg="skip loading plugin" error="no scratch file generator: skip plugin" id=io.containerd.snapshotter.v1.blockfile type=io.containerd.snapshotter.v1
janv. 06 11:49:23 orion containerd[1939]: time="2026-01-06T11:49:23.071866750+01:00" level=info msg="skip loading plugin" error="path /var/lib/containerd/io.containerd.snapshotter.v1.btrfs (ext4) must be a btrfs filesystem to be used with the btrfs snapshotter: skip plugin" id=io.containerd.snapshotter.v1.btrfs type=io.containerd.snapshotter.v1
janv. 06 11:49:23 orion containerd[1939]: time="2026-01-06T11:49:23.071907496+01:00" level=info msg="skip loading plugin" error="devmapper not configured: skip plugin" id=io.containerd.snapshotter.v1.devmapper type=io.containerd.snapshotter.v1
janv. 06 11:49:23 orion containerd[1939]: time="2026-01-06T11:49:23.072607880+01:00" level=info msg="skip loading plugin" error="EROFS unsupported, please `modprobe erofs`: skip plugin" id=io.containerd.snapshotter.v1.erofs type=io.containerd.snapshotter.v1
janv. 06 11:49:23 orion containerd[1939]: time="2026-01-06T11:49:23.073110793+01:00" level=info msg="skip loading plugin" error="lstat /var/lib/containerd/io.containerd.snapshotter.v1.zfs: no such file or directory: skip plugin" id=io.containerd.snapshotter.v1.zfs type=io.containerd.snapshotter.v1
janv. 06 11:49:23 orion containerd[1939]: time="2026-01-06T11:49:23.077847155+01:00" level=info msg="skip loading plugin" error="failed to check mkfs.erofs availability: failed to run mkfs.erofs --help: exec: \"mkfs.erofs\": executable file not found in $PATH: skip plugin" id=io.containerd.differ.v1.erofs type=io.containerd.differ.v1
janv. 06 11:49:23 orion containerd[1939]: time="2026-01-06T11:49:23.080300817+01:00" level=info msg="skip loading plugin" error="skip plugin: tracing endpoint not configured" id=io.containerd.tracing.processor.v1.otlp type=io.containerd.tracing.processor.v1
janv. 06 11:49:23 orion containerd[1939]: time="2026-01-06T11:49:23.080329371+01:00" level=info msg="skip loading plugin" error="skip plugin: tracing endpoint not configured" id=io.containerd.internal.v1.tracing type=io.containerd.internal.v1
janv. 06 11:49:23 orion cups.cupsd[1908]: + perl -p -i -e s:^(\s*\#)?\s*User\s+\S+\s*$:User snap_daemon\n:; -e s:^(\s*\#)?\s*Group\s+.*$:Group snap_daemon:; -e s:^(\s*\#)?\s*SystemGroup\s+.*$:SystemGroup lpadmin root:; -e s:^(\s*\#)?\s*AccessLog\s+.*$:AccessLog /var/snap/cups/1134/var/log/access_log:; -e s:^(\s*\#)?\s*CacheDir\s+.*$:CacheDir /var/snap/cups/1134/var/cache:; -e s:^(\s*\#)?\s*DataDir\s+.*$:DataDir /snap/cups/1134/share/cups:; -e s:^(\s*\#)?\s*DocumentRoot\s+.*$:DocumentRoot /snap/cups/1134/share/cups/doc:; -e s:^(\s*\#)?\s*ErrorLog\s+.*$:ErrorLog /var/snap/cups/1134/var/log/error_log:; -e s:^(\s*\#)?\s*FontPath\s+.*$:\#FontPath (NOT SUPPORTED ANY MORE):; -e s:^(\s*\#)?\s*PageLog\s+.*$:PageLog /var/snap/cups/1134/var/log/page_log:; -e s:^(\s*\#)?\s*Printcap\s+.*$:Printcap /var/snap/cups/common/etc/printcap:; -e s:^(\s*\#)?\s*RequestRoot\s+.*$:RequestRoot /var/snap/cups/1134/var/spool:; -e s:^(\s*\#)?\s*ServerBin\s+.*$:ServerBin /snap/cups/1134/lib/cups:; -e s:^(\s*\#)?\s*ServerRoot\s+.*$:ServerRoot /var/snap/cups/common/etc/cups:; -e s:^(\s*\#)?\s*StateDir\s+.*$:StateDir /var/snap/cups/1134/var/run:; -e s:^(\s*\#)?\s*TempDir\s+.*$:TempDir /var/snap/cups/1134/var/spool/tmp:; /var/snap/cups/common/etc/cups/cups-files.conf
janv. 06 11:49:28 orion dockerd[2585]: time="2026-01-06T11:49:28.974771669+01:00" level=info msg="Deleting nftables IPv4 rules" error="exit status 1"
janv. 06 11:49:28 orion dockerd[2585]: time="2026-01-06T11:49:28.992576350+01:00" level=info msg="Deleting nftables IPv6 rules" error="exit status 1"
janv. 06 11:49:35 orion goa-daemon[3740]: /org/gnome/OnlineAccounts/Accounts/account_1670889457_0: Setting AttentionNeeded to TRUE because EnsureCredentials() failed with: Aucune donnée d’authentification trouvée dans le trousseau de clés (goa-error-quark, 4)
pat@orion:~$
Delbadir
Re: micro freeze
Message par Delbadir »
Bonsoir Patrick,
EDIT : Je viens d'éditer mon message car je te proposais de tenter de passer sur X11 sauf qu'en relisant mieux ton inxi -F, je constate que tu es déjà sur X11 ...
Donc ça ne vient pas de ça
Laptop : Dell Latitude 5400 | Os LMDE7 Gigi | Desk Cinnamon 6.4.13 | Kernel 6.12.57 | Cpu Intel Core i5-8356U | Ram 16Go | Cg Intel UHD Graphics 620
Laptop : Lenovo LOQ 15ARP9 | Dual boot Os Linux Mint 22.3 Zena / Fedora Workstation 43 | Desk Cinnamon 6.6.4 | Kernel 6.14.0-37 | Cpu AMD Ryzen 7 7435HS | Ram 24Go | NVIDIA GeForce RTX 4060 Max-Q
