Résolu le 10-03-26 probleme de permissions scanner
R_LEFEVRE
Message par R_LEFEVRE »
J'essaie de faire fonctionner un scanner HP Scanjet 5300C avec xsane.
Xsane me répond qu'aucun scanner n'est disponible. Après avoir fait un test j'ai ce retour:
"found possible USB scanner (vendor=0x03f0 [Hewlett Packard], product=0x0701 [Hewlett Packard ScanJet 5300C/5370C ]) at libusb:009:003"
Je comprends qu'il s'agit d'un problème de permissions, mais je ne sais pas comment m'en sortir.
Une idée ? Merci.
PC de 18 ans, CPU: Intel core 2 Duo E4500 2.2 GHz, carte graphique: AMD / ATI Radeon 550 2Go.
Re: probleme de permissions scanner
R_LEFEVRE
Merci pour ta réponse. Je n'ai jamais installé de scanner avec xsane...
Voici ce que donne
 sane-find-scanner
# sane-find-scanner will now attempt to detect your scanner. If the
  # result is different from what you expected, first make sure your
  # scanner is powered up and properly connected to your computer.
  # No SCSI scanners found. If you expected something different, make sure that
  # you have loaded a kernel SCSI driver for your SCSI adapter.
could not open USB device 0x1d6b/0x0002 at 002:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 008:001: Access denied (insufficient permissions)
could not open USB device 0x046d/0xc52b at 007:003: Access denied (insufficient permissions)
could not open USB device 0x0a12/0x0001 at 007:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 007:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 006:001: Access denied (insufficient permissions)
could not open USB device 0x05e3/0x0610 at 009:004: Access denied (insufficient permissions)
could not open USB device 0x2109/0x3431 at 009:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 009:001: Access denied (insufficient permissions)
could not open USB device 0x05e3/0x0617 at 010:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0003 at 010:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 001:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 005:001: Access denied (insufficient permissions)
could not open USB device 0x1c4f/0x0063 at 004:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 004:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 003:001: Access denied (insufficient permissions)
  # Your USB scanner was (probably) detected. It may or may not be supported by
  # SANE. Try scanimage -L and read the backend's manpage.
  # Not checking for parallel port scanners.
  # Most Scanners connected to the parallel port or other proprietary ports
  # can't be detected by this program.
  # You may want to run this program as root to find all devices. Once you
  # found the scanner devices, be sure to adjust access permissions as
  # necessary.
La ligne:
montre que le système trouve mon scanner mais je suis incapable d'aller plus loin.
Merci encore et bonne soirée.
Modifié en dernier par alain le mar. 24 févr. 2026 22:13, modifié 1 fois.
Raison : mise en place des balises code
Mni37
Message par Mni37 »
Peut-être un problème de groupe.
Pour véfier si tu es dans le groupe scanner, dans un terminal tu tapes :
[jacques@jacques-SATELLITE-L750D:~$ groups
jacques adm disk cdrom sudo dip plugdev users lpadmin bluetooth scanner sambashare vboxusers docker libvirt kvm
Laptop TOSHIBA SATELLITE-L750D RAM 8GB Quad core AMD A6-3420M SSD 250Go systèmes, SSD 500 Go données, Kernel: 6.8, Mint 22.1, Xfce 4.18, Windows 10
Graphics Card-1: [AMD/ATI] BeaverCreek [Radeon HD 6520G] Card-2: [AMD/ATI] Seymour [Radeon HD 6400M/7400M Series] Audio : [AMD] FCH Azalia
Network: Card-1: Qualcomm Atheros AR8152 v2.0 Fast Ethernet Card-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter
Mni37
Message par Mni37 »
Suite de mon précédent message :
Comme on le voit dans la réponse, je suis dans le groupe scanner.
Si tu ne vois pas ton utilisateur alors il faut lui donner les droits d'accès, pour cela tout est là :
https://www.malekal.com/lister-groupes-linux/
Chumi
Message par Chumi »
Tu peux déjà vérifié que tu es dans le groupe scanner comme te le suggère Mini37.
Maintenant le cas de ton scanner est un peu problématique et tu vas devoir aussi modifier un fichier de configuration.
C'est la solution qui émerge de la discussion dont arghlub t'a fourni le lien.
La même solution se retrouve d'ailleurs ici : https://forums.linuxmint.com/viewtopic. ... 3#p1672583
Le fichier qu'il va falloir modifier est celui-ci : /etc/sane.d/avision.conf
Donne le retour de cette commande :
cat /etc/sane.d/avision.conf
TOUR 1 : LM 22.3 Zena | Cinnamon 6.6.7 | Kernel 7.0.0-28-generic | Intel Core i7-4770 | SSD : 500 Go + 2 HDDs : 2 x 2 To | Ram : 16 Go | Intel HD Graphics 4600
PORT 1 : ThinkPad X240 | LM 22.3 Zena | Cinnamon 6.6.7 | Kernel 7.0.0-28-generic | Intel Core I5-4300U | SSD : 128 Go | Ram : 8 Go | Intel HD Graphics 4400
TOUR 2 : HP 110-006ef | LM 22.3 Zena | Cinnamon 6.6.7 | Kernel 7.0.0-28-generic | Clé USB Wifi Chipset RTL8812BU | Intel Pentium G2030T | SSD : 240 Go | Ram : 6 Go | Intel HD Graphics 2500
PORT 2 : Dell E5400 | LM 22.3 Zena | Xfce 4.18.1 | Kernel 7.0.0-28-generic | Intel Core2 Duo T7250 | SSD : 120 Go | Ram : 3 Go | Intel GMA 4500MHD
R_LEFEVRE
Merci pour vos réponses.
Je pars quelques jours au soleil et reprendrai tout cela à mon retour.
Bien sincèrement, Robet
R_LEFEVRE
Et bien me voici de retour avec mon problème de scanner et xsane.
Voici le retour de la commande
# These are the possible options. Normally any scanner
# should work just fine without them - and they are only
# needed for test and debugging. So if you experience problems
# and you solve them with enabling options here, please notify
# the SANE/Avision maintainer: Mike Kelly <mike@piratehaven.org>
#option disable-gamma-table
#option disable-calibration
#option force-a4
#scsi AVISION
#scsi FCPA
#scsi MINOLTA
#scsi MITSBISH MCA-S600C
#scsi MITSBISH MCA-SS600
#scsi HP
#scsi hp
#scsi /dev/scanner
# usb libusb:002:003
# usb 0x03f0 0x0701
En fait, dans tout cela, ce que j'aimerais c'est comprendre. Merci.
Modifié en dernier par alain le lun. 9 mars 2026 23:13, modifié 1 fois.
pastille
Message par pastille »
Bonjour R_LEFEVRE
R_LEFEVRE a écrit : lun. 9 mars 2026 23:07… En fait, dans tout cela, ce que j'aimerais c'est comprendre. …
Voir le retour de la ligne de commande suivante :
man sane-avision
R_LEFEVRE a écrit : mar. 24 févr. 2026 20:38...
Voici ce que donne
sane-find-scanner
Comme on ne voit pas le prompt, on ne peut pas savoir avec quels privilèges la commande sane-find-scanner a été lancée,
mais vu les retours de la commande (could not open USB device…Access denied (insufficient permissions)), je pense qu'elle n'a pas été lancée avec les privilèges du compte root
Essaye comme ça :
sudo sane-find-scanner
Vu le contenu actuel de ton fichier /etc/sane.d/avision.conf et les solutions données dans les liens proposés dans ce fil de discussion,
tu peux dé-commenter les deux lignes suivantes :
et :
# usb 0x03f0 0x0701
Pour dé-commenter ces deux lignes,
lance la ligne de commandes suivante :
sudo sed -i 's/^#\(option disable-g\)/\1/;s/^# \(usb 0\)/\1/' /etc/sane.d/avision.conf
Dans ce type de fichier de configuration, toutes les lignes qui commencent par un caractère # sont considérées comme étant des commentaires.
Le contenu des lignes dont le premier caractère est un caractère # ne sera donc pas pris en compte par le programme qui utilisera ce fichier de configuration.
Pour dé-commenter une ligne, il faut dont supprimer le caractère # qui est au début de la ligne.
Cordialement.
Portable : Thinkpad T450 | i5-5300U | 16GB | HD Graphics 5500 | Debian 13.6 & Mint 22.3 | Xfce
R_LEFEVRE
Je fais bien partie du groupe scanner et voici le contenu du fichier /etc/sane.d/avision.conf, avec les deux lignes décommentées:
#option force-a4
#scsi AVISION
#scsi FCPA
#scsi MINOLTA
#scsi HP
#scsi hp
#scsi /dev/scanner
usb 0x03f0 0x0701
Sane ne me trouve toujours pas mon scanner...
Merci encore et bonne journée.
Robert
Modifié en dernier par alain le mar. 10 mars 2026 12:25, modifié 1 fois.
Raison : mise en place de la balise code
