En cours Le wifi ne fonctionne pas (carte broadcom bcm43142)
iceNslice
Message par iceNslice »
Je suis novice complet sur Linux, j'ai installé Mint 22.3 cinammon sur deux ordinateur :
- mon poste de travail principal (depuis lequel je fais ce post)
- un viel asus R301LJ-FN105T
Sur ce 2e, le wifi ne fonctionne pas (n'existe pas) :(
System:  Kernel: 7.0.0-14-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
  Desktop: Cinnamon v: 6.6.7 Distro: Linux Mint 22.3 Zena
    base: Ubuntu 24.04 noble
Machine:
  Type: Laptop System: ASUSTeK product: X302LJ v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: X302LJ v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: X302LJ.204 date: 08/24/2015
Battery:
  ID-1: BAT0 charge: 19.4 Wh (95.1%) condition: 20.4/38.0 Wh (53.7%)
    volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery status: charging
CPU:
  Info: dual core model: Intel Core i3-4005U bits: 64 type: MT MCP
    arch: Haswell rev: 1 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
  Speed (MHz): avg: 798 min/max: 800/1600 cores: 1: 798 2: 798 3: 798 4: 798
    bogomips: 13567
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: ASUSTeK driver: i915
    v: kernel arch: Gen-7.5 bus-ID: 00:02.0
  Device-2: NVIDIA GK208BM [GeForce 920M] vendor: ASUSTeK driver: nouveau
    v: kernel arch: Kepler bus-ID: 04:00.0 temp: 37.0 C
  Device-3: Chicony USB2.0 VGA UVC WebCam driver: uvcvideo type: USB
    bus-ID: 1-5:2
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
    loaded: modesetting unloaded: fbdev,vesa dri: crocus gpu: i915
    resolution: 1366x768~60Hz
  API: EGL v: 1.5 drivers: crocus,nouveau,swrast platforms:
    active: gbm,x11,surfaceless,device inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa
    v: 25.2.8-0ubuntu0.24.04.1 glx-v: 1.4 direct-render: yes renderer: Mesa
    Intel HD Graphics 4400 (HSW GT2)
  API: Vulkan v: 1.3.275 drivers: N/A surfaces: xcb,xlib devices: 3
Audio:
  Device-1: Intel Haswell-ULT HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0
  Device-2: Intel 8 Series HD Audio vendor: ASUSTeK 8 driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0
  Device-3: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel
    bus-ID: 04:00.1
  API: ALSA v: k7.0.0-14-generic status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active
Network:
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel port: e000
    bus-ID: 02:00.0
  IF: enp2s0 state: down mac: <filter>
  Device-2: Broadcom BCM43142 802.11b/g/n vendor: Lite-On driver: N/A
    bus-ID: 03:00.0
  IF-ID-1: enx025f37643034 state: unknown speed: -1 duplex: unknown
    mac: <filter>
Bluetooth:
  Device-1: Samsung Galaxy series misc. (tethering mode) driver: rndis_host
    v: kernel type: USB bus-ID: 1-3:6
  Device-2: Lite-On Broadcom BCM43142A0 Bluetooth Device driver: btusb
    v: 0.8 type: USB bus-ID: 1-6:3
  Report: ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0 lmp-v: 6
Drives:
  Local Storage: total: 894.25 GiB used: 14.93 GiB (1.7%)
  ID-1: /dev/sda vendor: Kingston model: SA400S37960G size: 894.25 GiB
Partition:
  ID-1: / size: 878.62 GiB used: 14.93 GiB (1.7%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 511 MiB used: 6.2 MiB (1.2%) fs: vfat dev: /dev/sda1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
  System Temperatures: cpu: 39.0 C pch: 37.0 C mobo: N/A gpu: nouveau
    temp: 38.0 C
  Fan Speeds (rpm): N/A
Info:
  Memory: total: 12 GiB available: 11.58 GiB used: 1.72 GiB (14.8%)
  Processes: 223 Uptime: 6m Init: systemd target: graphical (5)
  Packages: 1968 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Le pilote open source broadcom-sta-bkms (v6.30.223.270-23ubuntu1-1) est en théorie installé mais n'a pas l'air d'être reconnu par la carte
J'ai pour l'instant essayé :
- changer de noyaux plusieurs fois
- désactiver "secure boot"
- télécharger le pilote propriétaire via le site : https://doc.ubuntu-fr.org/wifi_broadcom_bcm43xx > mint me dit que le pilote est déjà installé quand je re-télécharge mais rien n’apparaît dans le gestionnaire de pilotes
Pour l'instant l'ordinateur fonctionne avec un modem usb mais ce n'est pas idéal..
Merci d'avance pour votre temps ^^
IceNslice
Linux Mint 22.3 Cinnamon
Lepoune
Re: Le wifi ne fonctionne pas (carte broadcom bcm43142)
Message par Lepoune »
Les Spécialistes auront besoin du retour de ton
rfkill list
EDIT : en attendant les Pros, y a t'il du wifi si tu lances une session Live USB ?
EDIT 2 : n'y a t'il pas une touche ou combinaison de touches (Fn+F?) pour activer/désactiver le wifi ?
