Digikam ne se lance pas
jouly
Message par jouly »
J'ai linuxmint-17.2-xfce-64bit
J'ai installé digikam sur mon pc. Le problème c'est qu'il se plante au lancement au bout d'une dizaine de seconde.
Je vous livre le journal de débogage que j'ai obtenu, Je vois bien des erreurs dans les 20 dernières lignes mais je ne sais pas les interprété
Merci de votre aide
echo run | gdb digikam
GNU gdb (Ubuntu 7.7.1-0ubuntu5~14.04.2) 7.7.1
Copyright (C) 2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from digikam...(no debugging symbols found)...done.
(gdb) Starting program: /usr/bin/digikam
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fffd574d700 (LWP 2534)]
digikam(2528)/kdeui (KIconLoader): Error: standard icon theme "oxygen" not found!
[New Thread 0x7fffce796700 (LWP 2535)]
[New Thread 0x7fffcdf95700 (LWP 2536)]
Object::connect: No such signal org::freedesktop::UPower::DeviceAdded(QDBusObjectPath)
Object::connect: No such signal org::freedesktop::UPower::DeviceRemoved(QDBusObjectPath)
[New Thread 0x7fffcd794700 (LWP 2537)]
QSqlDatabasePrivate::removeDatabase: connection 'ConnectionTest' is still in use, all queries will cease to work.
[Thread 0x7fffcd794700 (LWP 2537) exited]
[New Thread 0x7fffcd794700 (LWP 2538)]
digikam(2528): No ksycoca4 database available!
digikam(2528)/kdecore (trader) KServiceTypeTrader::defaultOffers: KServiceTypeTrader: serviceType  "QImageIOPlugins"  not found
digikam(2528) KXMLGUIClient::setXMLFile: cannot find .rc file "khtml.rc" for component "khtml"
[New Thread 0x7fffba5da700 (LWP 2539)]
[Thread 0x7fffba5da700 (LWP 2539) exited]
[New Thread 0x7fffba5da700 (LWP 2540)]
[New Thread 0x7fffb4b21700 (LWP 2541)]
[Thread 0x7fffba5da700 (LWP 2540) exited]
[Thread 0x7fffb4b21700 (LWP 2541) exited]
digikam(2528) KPixmapSequence::Private::loadSequence: Invalid pixmap specified.
digikam(2528)/kdecore (K*TimeZone*): KSystemTimeZones: ktimezoned initialize() D-Bus call failed:  "The name org.kde.kded was not provided by any .service files"
digikam(2528)/kdecore (K*TimeZone*): No time zone information obtained from ktimezoned
[New Thread 0x7fffb4b21700 (LWP 2542)]
digikam(2528) KXMLGUIClient::loadStandardsXmlFile: ui/ui_standards.rc not found in ("/home/jean-louis/.kde/share/config/", "/etc/kde4/", "/usr/share/kde4/config/")
QFSFileEngine::open: No file name specified
!!!!!!! ERROR !!!!!!! - KHTML default stylesheet version mismatch. Aborting. Check your installation. File used was: /home/jean-louis. Expected STYLE_VERSION 1
Program received signal SIGABRT, Aborted.
0x00007ffff1018c37 in __GI_raise (sig=sig@entry=6)
    at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
56	../nptl/sysdeps/unix/sysv/linux/raise.c: Aucun fichier ou dossier de ce type.
(gdb) quit
A debugging session is active.
	Inferior 1 [process 2528] will be killed.
---Type <return> to continue, or q <return> to quit---Quit anyway? (y or n) [ans
produit: HP Pavilion g7 Notebook PC (D2G02EA#ABF), fabriquant: Hewlett-Packard, 64 bits
Desktop: Xfce 4.12.2 Distro: Linux Mint 17.2 Rafaela dual boot avec W7
noyau 3.16.0-38-generic x86_64 (64 bit)
processeur AMD A4-4300M APU with Radeon(tm) HD Graphics 2500 mhz
mémoire vive 8go et de stockage 750GB
carte graphique AMD A4-4300M APU with Radeon(tm) HD Graphics
Re: Digikam ne se lance pas
bonjour
j'ai mis les balises"code" pour éviter la longueur du post ;)
mylapk
Message par mylapk »
Est-ce que tu l'as installé à partir des dépôts?
Si c'était moi à qui ça arrivait, je désinstallerait ( par synaptic suppression complète ) ou par le terminal digikam et son fichier de configuration et je réinstallerait. Il se peut qu'il se soit mal installé.
jouly
Message par jouly »
Je l'ai installé par l’intermédiaire de mintInstall 7.6.2. et je l'ai fait 2 fois (installation, désinstallation puis de nouveau 1 instal)
mylapk
Quand tu dis Mintinstall, ce n'est pas par les dépôts Synaptic, n'est-ce pas?
jouly
Message par jouly »
Je viens justement à l'instant de désinstaller et réinstaller par synapic justement et toujours pareil
mylapk
Il faut pas seulement désinstaller, il faut purger le fichier de configuration qui reste là et digikam s'en sert quand tu réinstalles. Alors tu traînes l'erreur avec toi.
Par le terminal
rm --purge digikam ( j'espère ne pas me tromper :oops: , sinon corrigez-moi tout de suite :P )
pour éliminer le fichier de configuration.
Ou bien tu vérifies dans tes fichiers cachés de ton /home et tu supprimes le /.digikam avant de réinstaller. ;)
jouly
Message par jouly »
Je vais essayer d'etre clair mais je m'y perds un peu.
Petit rappel mon environnement de bureau est en xfce4-panel 4.12.0, cela a peut etre son importance car digikam est plutot kde, me semble t'il ?
j'ai supprimé manuellement le fichier de config qui est "/home/jean-louis/.kde/share/config/digikamrc"
la commande "rm --purge digikam" ne fopnctionne pas chez moi
je n'ai pas de répertoire ".digikam" dans mon home mais un ".kde/share/config/" dans mon home ou il y a le fichier de configuration de digikam.
Donc apres la désinstallation, la suppression du fichier de config et réinstallation, digikam me demande des option de configuration puis se plante de nouveau 10 secondes apres.
jouly
Message par jouly »
En fouillant sur un autre forum j'ai lancer la cde : sudo apt install kdelibs-bin kdelibs5-data kdelibs5-plugins
maintenant digikam se lance mais je n'arrive pas à avoir l’arborescence de mes dossiers. l'option dans outils maintenance est bien activée pour reconstruire les vignettes.
de plus le lancement de digikam en mode "terminal" me laisse apparaître pas mal d'erreur.
Salut ;)
jouly a écrit :Petit rappel mon environnement de bureau est en xfce4-panel 4.12.0
Oui, c'est aussi pour ça que l'on bassine les gens avec les signatures, ce n'est pas pour le fun ;)
Perte de temps, message pour un autre environnement, ...
Voili, voilou :D
