counter strike go ne se lance pas
Dr-Weedm@n
Message par Dr-Weedm@n »
Bonjour ,
comme l'explique le titre CS Go ne lance pas , quand je clic sur jouer la petite fenêtre "préparation au lancement..." s'ouvre et se ferme puis plus rien. J'ai donc lancé steam dans un terminal puis lancer CS Go et voilà ce que cela me donne :
SDL video target is 'x11'
SDL failed to create GL compatibility profile (whichProfile=0!
This system supports the OpenGL extension GL_EXT_framebuffer_object.
This system supports the OpenGL extension GL_EXT_framebuffer_blit.
This system supports the OpenGL extension GL_EXT_framebuffer_multisample.
This system DOES NOT support the OpenGL extension GL_APPLE_fence.
This system supports the OpenGL extension GL_NV_fence.
This system supports the OpenGL extension GL_ARB_sync.
This system supports the OpenGL extension GL_EXT_draw_buffers2.
This system supports the OpenGL extension GL_EXT_bindable_uniform.
This system DOES NOT support the OpenGL extension GL_APPLE_flush_buffer_range.
This system supports the OpenGL extension GL_ARB_map_buffer_range.
This system supports the OpenGL extension GL_ARB_vertex_buffer_object.
This system supports the OpenGL extension GL_ARB_occlusion_query.
This system DOES NOT support the OpenGL extension GL_APPLE_texture_range.
This system DOES NOT support the OpenGL extension GL_APPLE_client_storage.
This system DOES NOT support the OpenGL extension GL_ARB_uniform_buffer.
This system supports the OpenGL extension GL_ARB_vertex_array_bgra.
This system supports the OpenGL extension GL_EXT_vertex_array_bgra.
This system supports the OpenGL extension GL_ARB_framebuffer_object.
This system DOES NOT support the OpenGL extension GL_GREMEDY_string_marker.
This system supports the OpenGL extension GL_ARB_debug_output.
This system supports the OpenGL extension GL_EXT_direct_state_access.
This system supports the OpenGL extension GL_NV_bindless_texture.
This system DOES NOT support the OpenGL extension GL_AMD_pinned_memory.
This system supports the OpenGL extension GL_EXT_framebuffer_multisample_blit_scaled.
This system supports the OpenGL extension GL_EXT_texture_sRGB_decode.
This system supports the OpenGL extension GL_NVX_gpu_memory_info.
This system DOES NOT support the OpenGL extension GL_ATI_meminfo.
This system supports the OpenGL extension GL_EXT_texture_compression_s3tc.
This system supports the OpenGL extension GL_EXT_texture_compression_dxt1.
This system DOES NOT support the OpenGL extension GL_ANGLE_texture_compression_dxt3.
This system DOES NOT support the OpenGL extension GL_ANGLE_texture_compression_dxt5.
This system supports the OpenGL extension GL_ARB_buffer_storage.
This system supports the OpenGL extension GLX_EXT_swap_control_tear.
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/engine_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/engine_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/filesystem_stdio_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/filesystem_stdio_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/inputsystem_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/inputsystem_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/vphysics_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/vphysics_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/materialsystem_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/materialsystem_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/datacache_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/datacache_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/studiorender_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/studiorender_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/soundemittersystem_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/soundemittersystem_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/vscript_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/vscript_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/vguimatsurface_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/vguimatsurface_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/vgui2_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/vgui2_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/scaleformui_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/scaleformui_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/shaderapidx9_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/shaderapidx9_client.so: wrong ELF class: ELFCLASS32
 failed to dlopen /home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/localize_client.so error=/home/dr-weedmn/.steam/steamapps/common/Counter-Strike Global Offensive/bin/localize_client.so: wrong ELF class: ELFCLASS32
Using breakpad minidump system 730/13549.365
J'utilise le pilote Nvidia 361.42 et précise que j'ai déjà vérifié l'intégrité des fichier puis que le reste de mes jeux fonctionnent parfaitement (Counter strike source,team fortress 2, day of defeat , half life 2 deathmatch et portal)
Il semblerait que se soit un problème de librairie mais je ne vois pas comment le résoudre. :(
Si quelqu'un peut m'aider merci d'avance :mrgreen:
-Linux Mint 19.1 Cinnamon
-noyau linux 4.15.0-50-generic
-cinnamon 4.0.10
-laptop acer Chromebook cp5-471
-processeur Intel© Celeron© CPU 3855U @ 1.60GHz × 2
-ram 4go
-CG : Intel Corporation HD Graphics 510
Re: counter strike go ne se lance pas
beaucoup de problèmes chez certains avec ce jeu. mais il fonctionne pourquoi oui ? pourquoi non ?
Dr-Weedm@n
C'est pas vraiment le genre de réponse que j'attendais sur un forum dédié à linux...Le but étant que les plus ou moins érudits partagent leur expériences et pas un "des fois ça marche des fois ça marche pas" (un bon com de joueur cs go ça lol )
steam ouvert sur console et le rapport étant collé ,merci à ceux ou celles qui me donneront ne serait ce qu'une piste... merci
-cinnamon 4.0.10
-ram 4go
Tu as posés la même question le sur le forum ubu et personne n'a vraiment su te répondre.
as tu essayer csgo_linux64
car cs go est la version 32-bit
Modifié en dernier par mpat le lun. 3 oct. 2016 19:06, modifié 1 fois.
J'ai pas les jeux berk lol
mais ce que j'en vois , c'est que tu aurais installer la version 32bit de cs alors que ton système est en 64 ;)
Dr-Weedm@n
Et donc ??? tu es admin ?? tu es concerné par ma requête ??
rien ne lie les deux sites à part toi et je vois pas pourquoi je n'aurais pas plus ou moins de réponse ici...donc si ton but est de faire des coms qui ne servent à rien ou pour faire rager les gens laisse tomber...
pour ceux qui veulent voir les antécédents c'est ici :
https://forum.ubuntu-fr.org/viewtopic.php?id=1990917
-cinnamon 4.0.10
-ram 4go
Dr-Weedm@n
tyrry a écrit :J'ai pas les jeux berk lol
Quand on ne sait pas de quoi on parle......si t'as rien à dire c'est pareil....donc ....je reste poli..............
je n'ai rien choisi , c'est steam qui choisi...sérieux c'est quoi ce forum???
-cinnamon 4.0.10
-ram 4go
Dr-Weedm@n a écrit : Quand on ne sait pas de quoi on parle......si t'as rien à dire c'est pareil....donc ....je reste poli..............
Désolé , il m'avais semblé lire de ta pars , que tu cherchais toute pistes ,......... Ne t'étonne pas de ne pas avoir d'aide avec de tels propos ;)
Dr-Weedm@n
et toi avec cela ....tu t'attends à quoi???
si le sujet ne te concerne pas ou si tu sais pas de quoi tu parles ....bah laisse tomber tes réponses qui ne servent à rien...
pu....vivement qu'un admin passe par là....
-cinnamon 4.0.10
-ram 4go
T'emballe pas Dr-Weedm@n, respire un chouia, ta reaction ne va pas avec, ni ton avatar, ni avec ton pseudo ;)
Stp, reste zen, si les réponses ne te conviennent pas, ignore les, c'est juste un jeu ;)
Merci :!:
