En faite depuis l'installation de Mint mon PC est assez long à démarré comparé à avant (même chose pour un redémarrage)
systemd-analyze
Startup finished in 10.467s (kernel) + 3min 3.177s (userspace) = 3min 13.645s
~ $ systemd-analyze blame
8.140s NetworkManager-wait-online.service
5.717s dev-sda1.device
4.719s ModemManager.service
4.010s fruhod.service
3.225s NetworkManager.service
2.713s accounts-daemon.service
2.408s qemu-kvm.service
2.315s thermald.service
2.219s ufw.service
1.738s polkitd.service
1.676s lvm2-monitor.service
1.617s gpu-manager.service
1.581s loadcpufreq.service
1.446s console-kit-log-system-start.service
1.422s systemd-logind.service
1.419s systemd-tmpfiles-setup-dev.service
1.365s systemd-user-sessions.service
1.262s keyboard-setup.service
1.136s rsyslog.service
1.103s systemd-modules-load.service
1.081s avahi-daemon.service
1.067s irqbalance.service
1.052s grub-common.serviceCode : Tout sélectionner
systemd-analyze critical-chain
The time after the unit is active or started is printed after the "@" character.
The time the unit takes to start is printed after the "+" character.
graphical.target @1min 49.656s
└─multi-user.target @1min 49.656s
└─fruhod.service @1min 45.636s +4.010s
└─network-online.target @1min 45.617s
└─NetworkManager-wait-online.service @1min 37.477s +8.140s
└─NetworkManager.service @1min 34.232s +3.225s
└─dbus.service @1min 33.028s
└─basic.target @1min 33.007s
└─sockets.target @1min 33.007s
└─acpid.socket @1min 33.007s
└─sysinit.target @1min 32.927s
└─systemd-update-utmp.service @10.184s +145ms
└─systemd-tmpfiles-setup.service @9.868s +304ms
└─local-fs.target @9.730s
└─run-user-1000-gvfs.mount @2min 26.300s
└─run-user-1000.mount @2min 21.046s
└─local-fs-pre.target @5.929s
└─systemd-remount-fs.service @5.821s +68ms
└─systemd-journald.socket @2.911s
└─-.slice @2.893sCode : Tout sélectionner
inxi -v 4
System: Host: user-PC Kernel: 4.4.0-21-generic x86_64 (64 bit gcc: 5.3.1)
Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.1)
Distro: Linux Mint 18.1 Serena
Machine: Mobo: ASUSTeK model: K42JY v: 1.0
Bios: American Megatrends v: 211 date: 01/06/2011
CPU: Dual core Intel Core i5 M 480 (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10639
clock speeds: max: 2667 MHz 1: 1199 MHz 2: 1733 MHz 3: 1999 MHz
4: 1333 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Seymour [Radeon HD 6400M/7400M Series]
bus-ID: 01:00.0
Display Server: X.Org 1.18.4 drivers: ati,radeon (unloaded: fbdev,vesa)
Resolution: 1366x768@60.00hz
GLX Renderer: Gallium 0.4 on AMD CAICOS (DRM 2.43.0, LLVM 3.8.0)
GLX Version: 3.0 Mesa 11.2.0 Direct Rendering: Yes
Network: Card-1: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express)
driver: ath9k bus-ID: 03:00.0
IF: wlp3s0 state: up mac: 48:5d:60:bc:87:3d
Card-2: JMicron JMC250 PCI Express Gigabit Ethernet Controller
driver: jme v: 1.0.8 ports: 7100 7000 bus-ID: 07:00.5
IF: enp7s0f5 state: down mac: bc:ae:c5:5b:44:8e
Drives: HDD Total Size: 500.1GB (16.3% used)
ID-1: /dev/sda model: ST9500325AS size: 500.1GB
Partition: ID-1: / size: 28G used: 5.8G (23%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 428G used: 70G (18%) fs: ext4 dev: /dev/sda2
ID-3: swap-1 size: 1.05GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Info: Processes: 212 Uptime: 2:12 Memory: 957.2/3807.1MB
Init: systemd runlevel: 5 Gcc sys: 5.4.0
Client: Shell (bash 4.3.461) inxi: 2.2.35
sudo apt-get update && sudo apt-get dist-upgrade
systemctl disable ...
