impossible de monter mon DD externe
malmsteen
Message par malmsteen »
salut a tous
en voulant monter mon disque dur externe j ai eu ce message
Impossible d'accéder à « Seagate Expansion Drive »
Error mounting /dev/sdb1 at /media/johnny/Seagate Expansion Drive: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sdb1" "/media/johnny/Seagate Expansion Drive"' exited with non-zero exit status 13: $MFTMirr does not match $MFT (record 0).
Failed to mount '/dev/sdb1': Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a
SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows
then reboot into Windows twice. The usage of the /f parameter is very
important! If the device is a SoftRAID/FakeRAID then first activate
it and mount a different device under the /dev/mapper/ directory, (e.g.
/dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation
for more details.
voila info que j ai
K93SM:~$ uname -a
Linux johnny-K93SM 3.13.0-116-generic #163-Ubuntu SMP Fri Mar 31 14:13:22 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
K93SM:~$ lsusb
Bus 002 Device 003: ID 0bc2:231b Seagate RSS LLC
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 003: ID 058f:a016 Alcor Micro Corp.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
merci pour votre aide
HP Pavilion dv6700 Notebook PC
OS: Ubuntu 14.04 trusty Kernel: i686 Linux 3.19.0-56-generic
DE: Gnome 3.9.90 WM: GNOME Shell
CPU: Intel Core2 Duo CPU T8100 @ 2.101GHz
GPU: GeForce 8400M GS
RAM: 3028MB
Re: impossible de monter mon DD externe
Salut ;)
Ton souci ne vient pas spécialement de gnome, de plus ta question concerne ubuntu, donc je déplace dans "Autres distributions" ;)
Tu devrais modifier légèrement ton titre pour spécifier que c'est pour ubuntu.
malmsteen
désolé zebulon
RAM: 3028MB
