gimp 2.10 est sorti (en flatpak)
thierryR
Message par thierryR »
Bonjour. Gimp 2.10 est sorti.
https://www.gimp.org/downloads/
EDIT: J'ai bien rentré le flatpak mais ensuite ça coince....
sh org.gimp.GIMP.flatpakref
org.gimp.GIMP.flatpakref: 1: org.gimp.GIMP.flatpakref: [Flatpak: not found
Pourtant flatpak est bien installé.
sudo flatpak org.gimp.GIMP.flatpakref
[sudo] Mot de passe de thierry :
Usage:
  flatpak [OPTION...] COMMAND
Builtin Commands:
 Manage installed apps and runtimes
  install             Install an application or runtime
  update              Update an installed application or runtime
  uninstall           Uninstall an installed application or runtime
  list                List installed apps and/or runtimes
  info                Show info for installed app or runtime
  config              Configure flatpak
 Running applications
  run                 Run an application
  override            Override permissions for an application
  make-current        Specify default version to run
  enter               Enter the namespace of a running application
 Manage file access
  document-export     Grant an application access to a specific file
  document-unexport   Revoke access to a specific file
  document-info       Show information about a specific file
  document-list       List exported files
 Manage remote repositories
  remotes             List all configured remotes
  remote-add          Add a new remote repository (by URL)
  remote-modify       Modify properties of a configured remote
  remote-delete       Delete a configured remote
  remote-ls           List contents of a configured remote
 Build applications
  build-init          Initialize a directory for building
  build               Run a build command inside the build dir
  build-finish        Finish a build dir for export
  build-export        Export a build dir to a repository
  build-bundle        Create a bundle file from a build directory
  build-import-bundle Import a bundle file
  build-sign          Sign an application or runtime
  build-update-repo   Update the summary file in a repository
  build-commit-from   Create new commit based on existing ref
  repo                Print information about a repo
Help Options:
  -h, --help       Show help options
error: Unknown command 'org.gimp.GIMP.flatpakref'
ou encore:
sudo flatpak run org.gimp.GIMP.flatpakref
error: app/org.gimp.GIMP.flatpakref/x86_64/master not installed
Il doit y avoir un truc que je saisi mal.
Modifié en dernier par thierryR le mer. 9 mai 2018 09:06, modifié 1 fois.
Kernel: 4.13.0-37-generic x86_64 (64 bit) Desktop: KDE Plasma 5.8.9
Distro: Linux Mint 18.3 Sylvia
Graphics: Card: Intel Device 22b1
Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa) Resolution: 1600x900@60.01hz
GLX Renderer: Mesa DRI Intel HD Graphics 405 (Braswell) GLX Version: 3.0 Mesa 17.2.8
Audio: Card-1 Intel Device 2284 driver: snd_hda_intel Sound: ALSA v: k4.13.0-37-generic
Card-2 C-Media driver: USB Audio
Re: gimp 2.10 est sorti
:l ton titre,
oui gimp 2.10 est sortie, ca fait quelques temps que l'on en parle :mrgreen:
Merci de faire un effort ;)
victoria
Message par victoria »
Flatpak??
Ce n'est pas plutôt les Snap sous Ubuntu et mint qui est conseillé ??
Ou je me trompe??
Parce que Ubuntu 18.04 embarqué d'emblée les Snap.
Flatpak n'est pas un peu mis de côté ??
Personnellement je n'ai jamais accroché à ces paquets universels, ça va créer des problèmes encore ce bazar, trop windowsien ces projets...
Pour une fois c'est rare pour être souligné mais je conseillerai presque d'installer GIMP via le ppa "otto06217"
C'est GIMP 2.10 stable.
Et petite question juste comme ça pr curiosité, mais pourquoi vouloir à tout prix la version 2.10??
mézig
Message par mézig »
Je l'ai installé avec la ppa
Les snaps ne créent pas le bazar dans le système, c'est pour moi leur principale qualité, c'est d'ailleurs pour ça que ça a été fait ,c'est completement independant , chaque logiciel créer comme un petit système Linux
Les inconvénients : c’est plus long a démarrer et ça ne voit pas les dossiers fichiers en lien vers une autre partition
Quand on désinstalle un snap il ne reste plus aucune trace
Pour moi a utiliser uniquement quand on a pas d'autre choix
Modifié en dernier par mézig le mer. 9 mai 2018 01:35, modifié 3 fois.
lm22
Message par lm22 »
victoria a écrit :
Et petite question juste comme ça par curiosité, mais pourquoi vouloir à tout prix la version 2.10??
Pourquoi ? :
Nous en saurions + si l'auteur de ce post nous avait donné ce lien complémentaire ? :|
Ensuite, c'est chacun qui voit... ;)
Manjaro-20.0.3_64 | KDE plasma 6.3.5-1 | Noyau 6.12.34-2| pilotes nvidia 550.120-5
Montage perso PC-tour juin 2015 : Alim modulaire 750 W | Asus Tuf Gaming B650 Plus | AMD FX-8350 Black Edition - 4,0 GHz |Gforce RTX 3060 12 go GeForce GTX 750 Ti OC - 2 Go | RAM DDR5 5600MHz CL40 2 fois 16 Go DDR3 1866 Mhz 32Go - 4x8Go
2 SSD-850 pro -128 Go | 1 SSD 1 To 1 SSD - 1To |1 Disque externe usb 3.0 - 2To
Re: gimp 2.10 est sorti (en flatpak)
La commande préconisée sur le site officiel pour l'installation est :
flatpak install https://flathub.org/repo/appstream/org.gimp.GIMP.flatpakref
Sinon tu peux aussi l'installer via le gestionnaire de logiciels :
thierryR
Le newbie que je suis ne comprends pas tout. Quelles différences y a t-il entre flatbak et flathub ? Est ce que dorénavant Gimp sera-t-il toujours comme ça ? ( Ou le reverrons nous dans synaptic et intégré à nos systemes linux)
Lycaon
Message par Lycaon »
thierryR a écrit :( Ou le reverrons nous dans synaptic et intégré à nos systemes linux)
Je suis bien d'accord, il y a de quoi y perdre son latin ... Entre les meubles en kit (flatpacks) avec des moyeux plats (flathubs) dans des bacs à sable (sandboxes) et des snaps (craquements ou instantanés ?), on s'y y perd. Les dépôts des distributions sont-ils si ringards ? :shock:
victoria
Les dépôts ringards non.
Mais les flatpack, Snap et autre joyeusetés veulent rendre les logiciels compatibles avec toutes les distributions.
Un flatpack tu l'installe sur une debian, arch, fedora, gentoo qui sait.
Du coup les .deb, les .rpm deviendront à terme inutiles pour beaucoup de logiciels non vitaux pour le système.
Mais comme dit plus haut personnellement je n'accroche pas à ce principe, je préfère le bon vieux paquet .deb qui est conçu par et pour debian.
Ce n'est qu'un choix personnel.
Lycaon
Merci pour l'explication, Victoria :D . Pour ça il y avait déjà le téléchargement suivi de la compilation des sources, mais bon, c'est vrai que c'était un peu complexe pour la plupart des nouveaux. :ugeek:
