Résolu le 14-01-22 Sortie son OK mais micro non
DavidB
Message par DavidB »
Grand grand débutant sur Linux, je viens d'installer Mint sur un Lapttop Lenovo. Tout fonctionne à merveille sauf le micro intégré. Gooel Meet me dit qu'il est coupé dans les paramètres systèmes. Débutant, enseignant, je n'y connais absolument rien... :)
Voici INXI :
System:
  Host: david-Lenovo Kernel: 5.4.0-94-generic x86_64 bits: 64
  Desktop: Cinnamon 5.2.7 Distro: Linux Mint 20.3 Una
Machine:
  Type: Laptop System: LENOVO product: 80XH v: Lenovo ideapad 320-15ISK
  serial: <superuser/root required>
  Mobo: LENOVO model: LNVNB161216 v: NO DPK
  serial: <superuser/root required> UEFI: LENOVO v: 4WCN47WW
  date: 06/30/2020
Battery:
  ID-1: BAT0 charge: 20.4 Wh condition: 20.4/30.0 Wh (68%)
CPU:
  Topology: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP
  L2 cache: 3072 KiB
  Speed: 529 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 500 2: 500
  3: 500 4: 500
Graphics:
  Device-1: Intel HD Graphics 520 driver: i915 v: kernel
  Display: x11 server: X.Org 1.20.13 driver: modesetting
  unloaded: fbdev,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.0.3
Audio:
  Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
  Sound Server: ALSA v: k5.4.0-94-generic
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  driver: r8169
  IF: enp1s0 state: down mac: 8c:16:45:05:17:1e
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  driver: ath10k_pci
  IF: wlp2s0 state: up mac: 98:22:ef:d6:b9:45
  Device-3: Qualcomm Atheros type: USB driver: btusb
Drives:
  Local Storage: total: 931.51 GiB used: 10.00 GiB (1.1%)
  ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-24Z10T0
Partition:
  ID-1: / size: 37.42 GiB used: 9.97 GiB (26.7%) fs: ext4 dev: /dev/sda5
Sensors:
  System Temperatures: cpu: 24.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 227 Uptime: 3m Memory: 3.63 GiB used: 1.28 GiB (35.3%)
  Shell: bash inxi: 3.0.38
Avec AlsaMixer je vois que le MIC est indiqué comme fermé :
Merci pour votre aide
Cordialement
Modifié en dernier par thyam le jeu. 13 janv. 2022 10:07, modifié 1 fois.
Raison : mis en balises code
Pc : Lenovo ideapad 320-15ISK | Cinnamon 5.2.7 Distro: Linux Mint 20.3 Una | Desk | Kernel | CPU:
L2 cache: 3072 KiB
Speed: 600 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 600 2: 600
3: 600 4: 600 | Ram | Cg
Re: Sortie son OK mais micro non
'Jour,
2 p'tits trucs :
1) le retour du terminal se place entre balises code, le bouton [ </> ], je l'ai fait pour toi ce coup-ci, penses y la prochaine fois ;)
2) pourrais-tu faire une signature technique, c'est plus facile pour les aidants ;)
regarde la => signature
DavidB
Merci pour vos réponses et votre soutien (la signature est faite :))
[sudo] Mot de passe de david :
[    0.109217] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.259270] platform MSFT0101:00: failed to claim resource 1: [mem 0xfed40000-0xfed40fff]
[    0.259285] acpi MSFT0101:00: platform device creation failed: -16
[    1.289456] [drm] Finished loading DMC firmware i915/skl_dmc_ver1_27.bin (v1.27)
[   13.930239] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
[   20.218369] ath10k_pci 0000:02:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 42e41877
L2 cache: 3072 KiB
DavidB
Hop :
L2 cache: 3072 KiB
Cool la signature ;)
DavidB
Voilà le max.
L2 cache: 3072 KiB
Marabout
Message par Marabout »
Hello,
1 - Dans les centre de contrôle/sons, vérifier/tester 'Entrée";
2 - Eventuellement, tester avec Gnome-sound-recorder.
Dual-boot : Mint 20.3 Mate 1.26.0 Kernel 5.4.0-94 + Win10 - Intel Core I5-9400F - Radeon Rx460 - 8GB ram
DavidB
J'ai testé avec Audacity et d'autres softs d'enregistrement mais rien... Le micro n'est pas coupé via Fn.
As tu une autre piste ?
L2 cache: 3072 KiB
DavidB
Bon, j'ai installé Pavu
Maintenant le mic fonctionne avec Audacity mais tjrs pas sous Chrome quelque soit le site (Meet, OnLine record...).
L2 cache: 3072 KiB
DavidB
Merci !
Ça fonctionne.
mais pourquoi décocher cette case c'est pourtant les éléments par défauts non ?
L2 cache: 3072 KiB
