En cours Comment éteindre complétement mon ordi ?
calixtus06
Message par calixtus06 »
J'ai en ma possession un Asus T6570 avec une carte NVIDIA GT120M , LMDE (debian 12) et le pc ne s'éteint pas complétement . Il n'y a pas de message d'erreur , pas de curseur qui cliglote. Le noyau :
6.1.0-25-amd64 x86_64
lspci -vnn | grep -A 12 '\[030[02]\]' | grep -Ei "vga|3d|display|kernel"
02:00.0 VGA compatible controller [0300]: NVIDIA Corporation G96CM [GeForce GT 120M] [10de:0653] (rev a1) (prog-if 00 [VGA controller])
	Kernel driver in use: nouveau
	Kernel modules: nouveau
bash NVIDIA-Linux-x86_64-340.32.run
Verifying archive integrity... OK
Uncompressing NVIDIA Accelerated Graphics Driver for Linux-x86_64 340.32.................................................................................................................................................................................................................................
Welcome to the NVIDIA Software Installer for Unix/Linux
The file '/tmp/.X0-lock' exists and appears to contain the process ID '702' of
a runnning X server.
ERROR: You appear to be running an X server; please exit X before installing.
       For further details, please see the section INSTALLING THE NVIDIA DRIVER
       in the README available on the Linux driver download page at
       www.nvidia.com.
ERROR: Installation has failed.  Please see the file
       '/var/log/nvidia-installer.log' for details.  You may find suggestions
       on fixing installation problems in the README available on the Linux
       driver download page at www.nvidia.com.
root@JEANPAUL:/home/jeanpaul/Téléchargements#
Merci pour vos éclairages
Nico
Modifié en dernier par calixtus06 le jeu. 19 sept. 2024 10:44, modifié 1 fois.
ACER ASPIRE M3641,
KDE Plasma 5.6.5, Distro: Linux Mint 18 Sarah, Intel model: DG41CN, Quad core Intel Core2 Quad Q6600, speed/max: 1596/2394 MHz, NVIDIA G73 [GeForce 7600 GT],
Network Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
Drives: HDD Total Size: 160.0GB (34.1% used)
Memory: 3 go DDR2 Synchrone 667 MHz (1,5 ns)
Kernel: 4.4.0-21-generic x86_64 (64 bit),
Re: Comment éteindre complétement mon ordi ?
Tourne toi vers la commande shutdown.
Par exemple; si tu veux arrêter ton PC immédiatement :
sudo shutdown now
plus d'infos :
man shutdown
Tu peux évidemment en faire un script bash pour le lancer graphiquement à partir d'une icone
Armaggion
Message par Armaggion »
Bonjour calixtus06,
En plus du souci d'extinction, tu as présenté des éléments relatifs à une carte graphique. Si ce n'est pas une erreur et que tu voulais communiquer à ce sujet en plus du souci d'extinction de ton ordinateur, pourrais-tu ouvrir un sujet distinct ? Cette discussion là pourra se concentrer sur le premier problème. Ca évitera de tout mélanger ;)
Pc : Desktop | Linux Mint 22 Wilma | Cinnamon | 6.8.0-41-generic | Intel Core i5-6600K | 16GB | Intel HD Graphics 530 / i915 + NVIDIA GA104 [GeForce RTX 3070] / 550.107.02
Faudrait une copie des lignes où il bloque... Peut être des ressources non démontées...
calixtus06
Bonjour à vous , j'ai présenté les infos sur la carte graphique car j'avais une autre distribution sur ce vieux pc et j'avais eu un soucis similaire. De mémoire ( vieille aussi) le problème venait du driver . Peut être qu'effectivement je m'emmêle les pinceaux. Je vous tiens au courant, l'ordi n'est pas chez moi.
ACER ASPIRE M3641,
calixtus06
En changeant le pilote de la carte graphique j'obtiens effectivement l'exctintion complète de l'ordi mais l'affichage est baveux et je n'ai plus le double écran ( utilisation d'un projecteur) . J'ai purgé nvdia :
apt purge ~nnvidia
et le pilote nouveau s'est remis. Par contre les commandes
shutdown -P
par exemple me laisse un écran presque éteint mais pas éteint complétement . Que faire ???
Peut être un problème de noyau trop récent pour cet ordi ??
ACER ASPIRE M3641,
